ABS module wont accept coding after battery disconect
PJC
C?ID=273722
Hi vehicle is 2009 Golf original fault was a fried engine ECU , Replaced with a second hand unit with immobilizer deleted
this got me running but with imobilizer codes and lights flashing in DIM
Purchased a lock set ,clocks ,engine ECU and Central electronic module from a damaged vehicle
saved an autoscan before starting repairs ,swapped the items over and re scaned
coding wrong in address 09 copied original coding and re scanned . Found codes logged for address 03 coding lost
copied original coding but module will not accept
Coding rejected Error31: Request out of range
first scan
Sunday,13,September,2020,10:50:39:20877
VCDS Version: 20.4.2.0 (x64)
VIN: WVWZZZ1KZ9W499500   License Plate: C12MPX
Mileage: 174450km-108398mi   Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 03 08 09 15 16 17 19 25 2E 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ9W499500   Mileage: 174450km-108398miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 LA    HW: 03L 906 022 G
   Component: R4 2.0l TDI G000SG  9977
   Revision: 13H01---    Serial number:
   Coding: 0001072
   Shop #: WSC 28357 001 104857
   VCID: 6FEDA04F7ECC81FEFA-803A
001299 - Incorrect Immobilizer Key
               P0513 - 000 -
                    Mileage: 168820 km
                    Date: 2015.01.25
                    Time: 04:27:31
                    RPM: 943 /min
                    Voltage: 12.08 V
                    Absolute Pres.: 999.6 mbar
                    Absolute Pres.: 979.2 mbar
                    Temperature: 27.9°C
                    Temperature: 43.2°C
   Part No SW: 1K0 907 379 CD    HW: 1K0 907 379 AD
   Revision: 00H35001
   Coding: 163B400D092500FB680F02E5901C00823400
   Shop #: WSC 61962 001 1048576
   VCID: 76E3952BC196B03639-8022
02214 - Tire Pressure Warning
                    Reset counter: 180
                    Mileage: 173382 km
                    Date: 2015.02.04
                    Time: 04:53:52
                    Count: 32768
                    Count: 4608
                    Count: 397
                    Count: 50737
                    Count: 255
   Part No SW: 3C8 907 336     HW: 3C8 907 336
   Component: Climatic      120 0102
   Revision: 00004001
   Coding: 0000000000
   ASAM Dataset: EV_Climatic A01001
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6ADBB15B8D2E64D6AD-803E
          B10AB F0 [009] - Too Low
                    Reset counter: 132
                    Mileage: 173984 km
                    Date: 2020.09.13
                    Time: 15:03:21
   Part No SW: 1K0 937 086     HW: 1K0 937 086
   Component: BCM PQ35  M   020 0358
   Revision: 00020000
   Coding: 48180A3A9025F1C044080080140081E441510088536D8960648000000000
   VCID: 6DD1BA47B4C073EEC8-8038
   Component: Wischer 28100  21  0501
   Coding: 009795
   Component: RLS 121108 05  54  0402
   Coding: 0330AD
   Subsystem 4 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HO  H08 9001
                    Fault Status: 00101010
                    Reset counter: 171
                    Mileage: 168820 km
                    Date: 2015.01.25
                    Time: 04:26:15
                    Voltage: 12.45 V
                        Term 50 Off
                    Reset counter: 171
                    Mileage: 168820 km
                    Date: 2015.01.25
                    Time: 04:26:15
                    Voltage: 12.45 V
                        Term 50 Off
01495 - Bulb for High-Beams; Left (M30)
                    Reset counter: 171
                    Mileage: 168846 km
                    Date: 2015.01.25
                    Time: 06:14:43
                    Voltage: 13.75 V
                        Term 50 Off
                    Reset counter: 171
                    Mileage: 168846 km
                    Date: 2015.01.25
                    Time: 06:14:44
                    Voltage: 13.65 V
                        Term 50 Off
   Part No SW: 5K0 959 655     HW: 5K0 959 655
   Component: AirbagVW10    022 0507
   Serial number: 003C2D05BNG%
   Coding: 00003136
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01003
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 77FD982FCE9CC93E22-8022
   Component: S.Sens.Fahr.V  U01 ----
   Serial number: 7B744543ZZZZZZZZZZZZ
   Component: S.Sens.Beif.V  U01 ----
   Serial number: 29354543ZZZZZZZZZZZZ
   Serial number: 3434146BZZZZZZZZZZZZ
   Serial number: 38411449ZZZZZZZZZZZZ
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           055 0111
   Coding: 0000532
   VCID: 78FF9B130B82C6462B-802C
   Subsystem 1 - Part No: 3C8 959 537 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP   H4ÿ 0021
   Coding: 00000226
   Part No SW: 5K0 920 970 E    HW: 5K0 920 970 E
   Component: KOMBI         H21 0029
   Coding: 470B00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04020
   VCID: 306F63336B72DE06A3-8064
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533  Gateway   H07 0071
   Revision:   H07 01    Serial number: 241008F2000357
   Coding: E9807F06000212000003
   VCID: 377D582F461C093EE2-8062
   Component: IMMO          H21 0029
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03002
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [009] - -
                    Mileage: 168820 km
                    Date: 2020.09.03
                    Time: 04:27:29
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667307448
   VCID: 2643856B51B680B649-8072
   Part No SW: 1K0 959 701 AM    HW: 1K0 959 701 AM
   Component: Tuer-SG         008 2016
   Coding: 0000692
   VCID: 79F99E173088DF4E54-802C
   Part No: 1K0 909 144 C
   Component: EPS_ZFLS Kl. 70     2301
   Revision: 00H15000
   Shop #: WSC 01324 785 00200
   VCID: 2A5B715B85AEA4D66D-807E
   Part No SW: 1K0 959 702 AM    HW: 1K0 959 702 AM
   Coding: 0000692
   VCID: 7AFB811B358ED4565D-802E
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  012 0029
   Revision: 00000000    Serial number: VWZ1Z2H5846727
   Coding: 0100040004
   VCID: 65C1C2676C304BAE80-8030
   Part No SW: 1K0 959 703 AL    HW: 1K0 959 703 AL
   Component: Tuer-SG         007 2009
   Coding: 0000144
   Shop #: WSC 01357 011 1012552
   Part No SW: 1K0 959 704 AL    HW: 1K0 959 704 AL
   Coding: 0000144
   VCID: 7BF5841F3AB4ED5E46-802E
End-------------------------(Elapsed Time: 02:11)--------------------------
second scan
Sunday,13,September,2020,13:15:34:20877
VIN: WVWZZZ1KZ9W470407   License Plate: C12MPX
Mileage: 161020km-100053mi   Repair Order: V1
VIN: WVWZZZ1KZ9W470407   Mileage: 161020km-100053miles
   Coding: 0001072
   Shop #: WSC 00791 210 88275
005641 - Crash Shut-Down Activated
               P1609 - 000 -  - Intermittent
                    Mileage: 161029 km
                    Date: 2015.01.28
                    Time: 16:31:51
                    RPM: 943 /min
                    Temperature: 7.2°C
                    Voltage: 12.62 V
                    Bin. Bits: 00001111
                    Torque: 165.0 Nm
                    Torque: 0.0 Nm
001674 - ECM Power Relay Load Circuit
               P068A - 000 - Opens Too Early - Intermittent
                    Voltage: 0.00 V
                    Hex Value: 0xFF00
                    Bin. Bits: 00000000
                    Temperature: -90.0°C
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
                    Reset counter: 151
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:03:52
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 195
                    Count: 50176
                    Fault Status: 01100101
                    Reset counter: 151
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:03:52
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 279
                    Count: 50176
                    Reset counter: 151
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:03:52
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 270
                    Count: 50176
                    Reset counter: 151
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:03:52
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 291
                    Count: 50176
   Revision: 00004001
   Coding: 0000000000
   Revision: 00020000
   Coding: 48180A3A9825F1C044080080100081E441010088524D8960648000000000
   Shop #: WSC 00791 210 84995
   Coding: 009795
   Subsystem 2 - Part No: 1K8 951 171
   Subsystem 3 - Part No: 1K0 951 605 D
01800 - Light Switch (E1)
                    Fault Status: 01101000
                    Reset counter: 151
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:03:50
                    Voltage: 14.05 V
                        Term 50 Off
   Coding: 00003136
   Coding: 0000532
   Coding: 00000226
   Coding: 470B00
   Coding: 0000692
   Revision: 00H15000
                    Fault Status: 11100101
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:03:50
                    Battery Volts: 13.9 V
                        DU
                    Temperature: 23.0°C
                    Count: 3
                    Steering Angle: 0.00°
                    Count: 1
                        SteerAng n.Init
   Coding: 0000692
   Coding: 0100040004
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:03)--------------------------
Address 01: DTCs cleared
Address 09: DTCs cleared
Address 03: DTCs cleared
Address 09,1K0 937 086 ,recoded (Long Coding),from,48180A3A9825F1C044080080100081E441010088524D8960648000000000,to,48180A3A9025F1C044080080140081E441510088536D8960648000000000,(00791/210/84995),
Address 44,1K0 909 144 C,channel 9,adapted from,0,to,0,
Address 44: DTCs cleared
Address 03,1K0 907 379 CD,recoded (Long Coding),from,000000000000000000000000000000000000,to,163B400D092500FB680F02E5901C00823400,(61962/001/1048576),
Address 03,1K0 907 379 CD,channel 9,adapted from,0,to,0,
Address 03,1K0 907 379 CD,channel 10,adapted from,1,to,1,
Address 03,1K0 907 379 CD,channel 54,adapted from,0,to,0,
Address 03,1K0 907 379 CD,channel 55,adapted from,1,to,1,
third scan
Sunday,13,September,2020,15:47:52:20877
Mileage: 161020km-100053mi   Repair Order: V2
   Coding: 0001072
   Revision: 00H35001
                    Reset counter: 152
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:46:22
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 195
                    Count: 49664
                    Reset counter: 152
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:46:22
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 279
                    Count: 49664
                    Reset counter: 152
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:46:22
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 295
                    Count: 49664
                    Reset counter: 152
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:46:22
                    Count: 7
                    Count: 2
                    Count: 12800
                    Count: 270
                    Count: 49664
   Revision: 00004001
   Coding: 0000000000
   Revision: 00020000
   Coding: 009795
   Coding: 0330AD
   Coding: 00003136
   Coding: 0000532
   Coding: 00000226
   Coding: 470B00
   Coding: 0000692
   Revision: 00H15000
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 161029 km
                    Date: 2015.02.04
                    Time: 00:46:21
                    Battery Volts: 13.8 V
                        DU
                    Temperature: 32.0°C
                    Count: 2
                    Count: 1
                        SteerAng n.Init
   Coding: 0000692
   Coding: 0100040004
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:09)--------------------------
first post hope i posted right info
United States
You included everything. The only thing you needed to do was add the Code tags before and after each scan. I tweaked that for you.
MK60EC1 ABS coding contains digits of the VIN so 01, 17 and 25 need to have the same VIN. The VIN / [Advanced ID-1A] notes here should add clarity
... but I don't believe you are going to have success getting an Immo defeated ECM matched to the car so all of the diagnostic VINs match.
Edit, I missed the clocks. If you have a matched used cluster and ECM installed there is hope. Please post the Adv ID logs when you get time.
PJC
C?ID=273722
Hi so just for clarity Original Engine ECU (Fried unable to read) Vin no: WVWZZZ1KZ9W431413 This ECU replaced with immo defeat ECU with Vin no: WVWZZZ1KZ9W499500 this gave 001299 - Incorrect Immobilizer Key and flashing in dim
so ECU,s at address 01,09,17&25 were replaced Vin no: WVWZZZ1KZ9W470407. Address 09 was successfully coded leaving only address 03 having dtc's logged as reported unable to copy original coding. attached are requested notes
Friday,18,September,2020,19:24:44:20877
Workshop Code: 001 61962 104857
Mileage:    Repair Order:V4
                Address 01: Engine
Control Module Part Number: 03L 906 022 LA
  Component and/or Version: R4 2.0l TDI G000SG  9977
           Software Coding: 0001072
            Work Shop Code: WSC 00791
Advanced Identification
     Identification: BPG-810
     Revision: 13H01---
     Date: 21.11.08
     Test stand number: 1334
     Manufacturer number: 0761
Flash Status
     Programming Attempts: 1
     Successful Attempts: 1
     Programming Status: 00000000
     Required Conditions: 00000000
     Flash Tool Code: 15728640 002 42601
     Flash Date: 25.14.91
Software
Misc.
     Hardware number: 03L 906 022 G
     Lot Number: 78
     Type Lock:
Car Info
     Chassis Number: WVWZZZ1KZ9W470407
     Engine code: CBA
VCDS Info:
       Readiness: No script available
Control Module Part Number: 5K0 920 970 E
  Component and/or Version: KOMBI         H21 0029
           Software Coding: 470B00
            Work Shop Code: WSC 01357
Advanced Identification/FAZIT
     Identification: VDD-024
     Date: 07.12.08
     Manufacturer number: 1901
     Test stand number: 2636
Flash Status
     Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
     Flash Date: 00.00.00
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
Misc.
     Hardware number: 5K0 920 970 E
     Workshop System Name: J285
     End of Line Equipment Level: ------------------
     ASAM Dataset Revision: A04020
Car Info
VCDS Info:
       Labels: 5K0-920-xxx-17.clb-SRI1
  Component and/or Version: IMMO          H21 0029
           Software Coding:
            Work Shop Code:
     Date: 07.12.08
Flash Status
Software
     BAP: 01.04.01
     OSEK-OS: 03.14.00
Misc.
     Workshop System Name: J334
     ASAM Dataset Revision: A03002
Car Info
Immobilizer
     Transponder ID (Current val.): B7BAA74D
     Transponder ID 1: B7943136
     Transponder ID 2: B7BAA74D
VCDS Info:
       Labels: 5K0-920-xxx-25.clb
United States
Excellent. Thanks for the clarity and Adv ID logs!
Since 01, 17 and 25 all have the same VIN (wrong) we can fix this easily using your original scan/coding:
Original VIN and ABS coding:
VIN: WVWZZZ1KZ9W431413
Current config with donor VIN:
Inserting the new donor VIN bytes into the original ABS coding results in:
163B400D092900FA680F02E4902000823400
Consider that experimental but the last string should be accepted.
NostraJackAss
You could also program the correct VIN to immo defeat ECU & coding would be accepted too, no?
Since that cannot be done with VCDS, it is rather questionable whether the OP "could" do that or not. ;)
NostraJackAss
Well sure, however, is why I offer the data transfer services & so no need for immo defeat or an incorrect VIN display.
Did you know the OEM has the ability to do this too, unfortunately I get way too many inquiries where unscrupulous or just plain ignorant dealers, they write the wrong VIN to the vehicle for ever controller from used unit, then proceed at trying to sell every controller in the car as the ONLY solution new to the consumer & often totaling the car?
PJC
C?ID=273722
Advised coding accepted G201,G200 &G85 Adaptions carried out no codes logged Big thankyou to Dana
codes in address 09 are a bulb that went today :(
Sunday,20,September,2020,20:08:18:20877
Mileage: 162030km-100680mi   Repair Order: V3
VIN: WVWZZZ1KZ9W470407   Mileage: 162030km-100680miles
   Coding: 0001072
   Revision: 00H35001
   Coding: 163B400D092900FA680F02E4902000823400
   Revision: 00004001
   Coding: 0000000000
   Revision: 00020000
   Coding: 40180A3A9025F1C044080080140081E441510088536D8960648000000000
   Coding: 009795
   Coding: 0330AD
                    Fault Status: 01101010
                    Fault Frequency: 14
                    Reset counter: 172
                    Mileage: 161570 km
                    Date: 2015.02.10
                    Time: 15:04:29
                    Voltage: 13.80 V
                        Term 50 Off
                    Reset counter: 212
                    Mileage: 161570 km
                    Date: 2015.02.10
                    Time: 15:04:36
                    Voltage: 13.50 V
                        Term 50 Off
                    Fault Status: 01101100
                    Reset counter: 172
                    Mileage: 162037 km
                    Date: 2015.02.11
                    Time: 20:05:25
                    Voltage: 12.90 V
                        Term 50 Off
   Coding: 00003136
   Coding: 0000532
   Coding: 00000226
   Coding: 470B00
   Coding: 0000692
   Revision: 00H15000
            000 - - - MIL ON
                    Mileage: 162037 km
                    Date: 2015.02.11
                    Time: 20:04:29
                    Battery Volts: 13.6 V
                        DU
                    Temperature: 49.0°C
                    Count: 9
                    Steering Angle: 3.19°
                    Count: 1
                        SteerAng n.Init
   Coding: 0000692
   Coding: 0100040004
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:06)--------------------------
   Coding: 0001072
   Revision: 00H35001
   Revision: 00004001
   Coding: 0000000000
   Revision: 00020000
   Coding: 009795
   Coding: 0330AD
                    Fault Frequency: 15
                    Reset counter: 172
                    Mileage: 161570 km
                    Date: 2015.02.10
                    Time: 15:04:29
                    Voltage: 13.80 V
                        Term 50 Off
                    Reset counter: 212
                    Mileage: 161570 km
                    Date: 2015.02.10
                    Time: 15:04:36
                    Voltage: 13.50 V
                        Term 50 Off
                    Reset counter: 172
                    Mileage: 162037 km
                    Date: 2015.02.11
                    Time: 20:11:54
                    Voltage: 13.00 V
                        Term 50 Off
   Coding: 00003136
   Coding: 0000532
   Coding: 00000226
   Coding: 470B00
   Coding: 0000692
   Revision: 00H15000
   Coding: 0000692
   Coding: 0100040004
   Coding: 0000144
   Coding: 0000144
End-------------------------(Elapsed Time: 02:04)--------------------------
