MK5 ABS Code Needed (ESP FRONT MK60)
Miguelaustin
Del Valle, TX, USA
C?ID=392723
Tuesday,15,September,2020,13:29:07:54521
VIN: WVWFV71K57W120128   License Plate:
Mileage: 332320km-206494mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWFV71K57W120128   Mileage: 332320km-206494miles
02-Auto Trans -- Status: Sporadic communication error 1000
1C-Position Sensing -- Status: Malfunction 0010
   Part No SW: 1K0 907 115 H    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI     0040
   Revision: 5BH15---    Serial number: VWZ7Z0F8198779
   Coding: 0403010A1C070160
   Shop #: WSC 07811 444 85708
   VCID: 2B0300526F087FC3D71-807E
005425 - Camshaft Timing Adjustment
               P1531 - 004 - Open Circuit - MIL ON
                    Fault Status: 11100100
                    Mileage: 332323 km
                    Time: 06:44:25
                    RPM: 764 /min
                    Load: 17.6 %
                    Temperature: 87.0∞C
                    Temperature: 53.0∞C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.462 V
000320 - Oxygen (Lambda) Sensor B1 S2
               P0140 - 004 - No Activity
                    Mileage: 332323 km
                    Time: 07:03:38
                    RPM: 4727 /min
                    Load: 96.0 %
                    Speed: 90.0 km/h
                    Temperature: 87.0∞C
                    Temperature: 52.0∞C
                    Voltage: 13.335 V
004372 - Oxygen (Lambda) Sensor; B1 S2
               P1114 - 008 - Internal Resistance too High
                    Fault Status: 01101000
                    Mileage: 332323 km
                    Time: 07:03:38
                    RPM: 4727 /min
                    Load: 96.0 %
                    Speed: 90.0 km/h
                    Temperature: 87.0∞C
                    Temperature: 52.0∞C
                    Voltage: 13.335 V
Readiness: 0110 0101
   Part No SW: 02E 300 043 Q    HW: 02E 927 770 AE
   Component: GSG DSG         070 1311
   Revision: 04507000    Serial number: 00000610190541
   Shop #: WSC 01279 785 00200
   VCID: 221DED7618C2BE8B647-8076
   Revision: 00H11001
   Coding: 0006792
   Shop #: WSC 12345 790 00000
   VCID: 73B3D832F7B867035F1-8026
            003 - Mechanical Failure
   Part No: 1K0 820 047 GR
   Component: Climatic PQ35   120 0606
   VCID: 7AADF516D0D2164B1C7-802E
00229 - Refrigerant Pressure
   Part No SW: 3C0 937 049 Q    HW: 3C0 937 049 Q
   Component: Bordnetz-SG     H46 1501
   Revision: 00H46000    Serial number: 00000006313433
   Coding: 178D0F214004150000140000001400000028770B5C0000
   Shop #: WSC 05051 444 54445
   VCID: 372B2C22A340CB23A39-8062
   Component: Wischer 071106 020  0501
   Coding: 00038805
   Shop #: WSC 05051
10 Faults Found:
                    Fault Status: 01101100
                    Reset counter: 33
                    Mileage: 332325 km
                    Voltage: 11.95 V
                    Reset counter: 33
                    Mileage: 332325 km
                    Voltage: 11.95 V
                    Reset counter: 33
                    Mileage: 332325 km
                    Voltage: 11.95 V
00906 - Horn (H1)
                    Fault Status: 00101001
                    Reset counter: 60
                    Mileage: 332151 km
                    Voltage: 14.25 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 33
                    Mileage: 330866 km
                    Voltage: 13.60 V
                    Reset counter: 33
                    Mileage: 332325 km
                    Voltage: 11.95 V
                    Reset counter: 69
                    Mileage: 332151 km
                    Voltage: 12.40 V
                    Reset counter: 60
                    Mileage: 332151 km
                    Voltage: 12.35 V
02389 - Release Signal Transmission; Position P/N
                    Reset counter: 69
                    Mileage: 332151 km
                    Voltage: 12.65 V
01341 - Control Module in Instrument Panel On Comfort CAN (J285)
                    Reset counter: 60
                    Mileage: 332151 km
                    Voltage: 12.40 V
   Component: 5L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D07CZZ-
   Coding: 0013644
   Shop #: WSC 01269 785 00200
   VCID: 6C81C34EAA86B8FB9EB-8038
   Subsystem 1 - Part No: 1K0 959 339 G
   Component: BF-Gewichtsens. 007 0007
   Subsystem 2 - Serial number: 633  SME
   Subsystem 3 - Serial number: 634  SME
   Subsystem 4 - Serial number: 6352QSME176D4143G
   Subsystem 5 - Serial number: 6362QSME17531C71F
   Subsystem 6 - Serial number: 63727SME0B36046D3
   Subsystem 7 - Serial number: 63827SME0B36124C0
7 Faults Found:
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
            008 - Implausible Signal - MIL ON
01221 - Crash Sensor Side Airbag; Driver Side (G179)
            002 - Lower Limit Exceeded - Intermittent - MIL ON
02688 - Control Module for Seat Occupant Recognition (J706); Not Calibrated
            000 - - - MIL ON
            004 - No Signal/Communication - Intermittent - MIL ON
01312 - Powertrain Data Bus
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           636 0070
   Coding: 0012122
   VCID: 77ABEC22E3C00B23639-8022
   Part No SW: 1K6 920 973 A    HW: 1K6 920 973 A
   Revision: V0003000    Serial number: VWZ7Z0F8198779
   Coding: 0007207
   Shop #: WSC 01287 785 00200
   VCID: 313F123A4D241513EDD-8064
11 Faults Found:
                    Reset counter: 57
                    Mileage: 332149 km
                    Time: 00:02:56
                    Fault Frequency: 22
                    Reset counter: 59
                    Mileage: 330867 km
                    Time: 20:05:48
                    Reset counter: 60
                    Reset counter: 60
                    Mileage: 332151 km
                    Time: 00:14:33
                    Fault Frequency: 25
                    Reset counter: 60
                    Reset counter: 60
                    Reset counter: 60
                    Reset counter: 60
00771 - Fuel Level Sensor (G)
                    Fault Status: 00101010
                    Fault Frequency: 17
                    Reset counter: 35
                    Mileage: 330867 km
                    Time: 00:59:36
                    Reset counter: 60
                    Reset counter: 60
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 24070602000826
   Coding: 7F8F03400F000000
   VCID: 2F3B14425B1003E3FB9-807A
                    Fault Status: 00110100
                    Reset counter: 60
                    Mileage: 330867 km
                    Time: 00:57:36
                    Reset counter: 60
                    Mileage: 332151 km
                    Time: 00:10:45
                    Reset counter: 60
                    Mileage: 332151 km
                    Time: 00:12:25
01304 - Radio
                    Mileage: 331169 km
                    Time: 04:42:38
                    Reset counter: 59
                    Mileage: 330867 km
                    Time: 00:08:42
   Part No SW: 1K6 919 879     HW: 1K6 919 879
   Component: Kompass         001 0003
   Revision: 00001000    Serial number: 1225223T1MBE03
   VCID: 7DA7FE0AC1FC2173395-8028
                    Reset counter: 60
                    Mileage: 330867 km
                    Reset counter: 60
                    Mileage: 330867 km
                    Reset counter: 69
                    Mileage: 330867 km
                    Time: 00:07:26
                    Reset counter: 60
                    Mileage: 330867 km
                    Time: 00:07:39
                    Reset counter: 60
                    Mileage: 330867 km
                    Time: 00:00:02
   Component: IMMO            VDD 1610
01176 - Key
                    Mileage: 330876 km
                    Time: 15:36:29
   Part No SW: 1K0 959 701 AG    HW: 1K0 959 701 AG
   Component: Tuer-SG         008 2039
   Coding: 0000049
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.074 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 34311B2EB236203B86B-8060
                    Temperature: 42.0∞C
                    Voltage: 9.70 V
                    Voltage: 9.50 V
                    Mileage: 332140 km
                    Temperature: 19.0∞C
                    Voltage: 12.40 V
                    Voltage: 12.20 V
   Component:    KSG PQ35 RDK 052 0218
   Coding: 139006885103281B0904058FB0080A04889C00
   VCID: 04518BEEA21650BB76B-8050
                    Fault Frequency: 14
                    Reset counter: 59
                    Mileage: 330866 km
                    Time: 01:38:02
                    Fault Frequency: 16
                    Reset counter: 60
                    Mileage: 330867 km
                    Time: 00:00:03
00830 - Convertible Top Control Module (J256)
                    Reset counter: 53
00955 - Key 1
                    Fault Status: 00100101
                    Fault Frequency: 75
                    Reset counter: 35
                    Reset counter: 60
   Component: Tuer-SG         005 0967
   Coding: 0001076
   VCID: 392F2A1A9554DD5355D-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74B1DB2EF2B6603B46B-8020
   Part No SW: 1K0 035 180 H    HW: 1K0 035 180 H
   Component: Radio PM6       017 0023
   Revision: 00017000    Serial number: VWZ5Z7F2116965
   Coding: 0040401
   VCID: 2517F66A09EC49B3015-8070
00849 - S-contact at Ignition/Starter Switch (D)
                    Reset counter: 60
                    Mileage: 332151 km
                    Time: 00:14:33
00625 - Vehicle Speed Signal
                    Reset counter: 60
                    Mileage: 332151 km
                    Time: 00:14:33
                    Reset counter: 60
                    Mileage: 332151 km
                    Time: 00:14:33
                    Fault Frequency: 32
                    Reset counter: 71
                    Mileage: 330866 km
                    Time: 01:31:17
   Component:    RDK              0440
   Coding: 0100101
   Shop #: WSC 01387 785 00200
                    Fault Frequency: 17
                    Reset counter: 69
                    Mileage: 332318 km
                    Time: 04:49:30
End----(Elapsed Time: 01:14, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Miguelaustin
Del Valle, TX, USA
C?ID=392723
Some context would be nice
I just got this GTI from a friend but it has the abs light on and after the scan I get:
"Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Revision: 00H11001
Coding: 0006792
003 - Mechanical Failure"
he said, he switched it out before giving it to me. It obviously more issues but that is one major that I can think of.
