VW T5 CCS retrofit interior light BCM upgrade issue
amigokola
Poland
C?ID=281040
Hi to all retrofit Maniacs ;)
Lately I retrofitted CCS in VW T5. All was ok but interior lights didnt work.
I found out that I need to add to BCM extra feed which I did ( T73a/63 T73b/68 from SA9)
Now interior light is working properly but as soon as I turn on lights or reverse gear foult pops out..
Old BCM 7H0937086F
Any suggestions ?? Someone had this problem before ??
VIN: WV3ZZZ7JZBX012654   License Plate: SG 12345
Mileage: 301800km-187529mi   Repair Order: T5 BCM Upgrade
Chassis Type: 7J-VN75 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 56 69 0B
VIN: WV3ZZZ7JZBX012654   Mileage: 301800km-187529miles
Address 01: Engine (J623-CAAC)       Labels:. 03L-906-022-CAA.clb
   Part No SW: 03L 906 022 CH    HW: 03L 907 309 K
   Component: R4 2,0L EDC   H42 9970
   Revision: 26H42---    Serial number: 00000000000000
   Coding: 01194012233400080000
   Shop #: WSC 12345 123 34567
   ASAM Dataset: EV_ECM20TDI01103L906022CH 002013
   ROD: EV_ECM20TDI01103L906019AM_002.rod
   VCID: 6D92D365BC77E4EED9-8038
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 G    HW: 7E0 907 379 E
   Component: ESP MK25A XT  H43 0105
   Revision: 00H43001
   Coding: 408724AF89A5029724A891766B6210
   Shop #: WSC 35110 377 49152
   VCID: 36203C0981A16736E8-8062
   Part No SW: 7E5 907 047 AL    HW: 7E5 907 047 AL
   Component: Climatic-T5   H11 0203
   Revision: 00005001
   Coding: 0000000002
   Shop #: WSC 35110 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 79BAF735F83F484E45-802C
   Part No SW: 7H0 937 089 D    HW: 7H0 937 089
   Component: BCM T5GP Li4  H47 0230
   Revision: BS047001    Serial number: 0398 144110130
   Coding: A00012800E210000000008103C0B8C140080410F60040000300000000000
   Shop #: WSC 00999 123 04321
   VCID: 373E310D86AB9E3EF3-8062
03304 - Response Closing Status of Rear Right Door
                    Fault Status: 01101000
                    Reset counter: 92
                    Mileage: 301807 km
                    Date: 2015.02.08
                    Time: 15:16:23
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 92
                    Mileage: 301807 km
                    Date: 2015.02.08
                    Time: 15:19:01
   Component: VW10Airbag003 H06 0013
   Revision: --------    Serial number: 003HL004WWVB
   Coding: 000000000000000000000000000000003033
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 35223B0594A76C2EE1-8060
   Part No SW: 7E0 920 860 C    HW: 7E0 920 860 C
   Component: KOMBI         H04 0204
   Coding: 160A00
   VCID: 281CE271531501C66A-807C
   Part No SW: 6N0 909 901     HW: 7H0 937 089
   Component: GW-K-CAN TP20 0230
   Coding: 042200
   VCID: 70ACCA11A3450906F2-8024
   Component: IMMO          H04 0204
   VCID: 6A98D8798D99F3D6BC-803E
   Part No SW: 7E0 035 156 A    HW: 7E0 035 156 A
   Component: Radio         H30 0072
   Revision: R0000000    Serial number: VWZAZ1L0752496
   Coding: 0000020001
   Shop #: WSC 35110 377 08192
   VCID: 210AFF55382FF08E2D-8074
   Revision: 3A001001    Serial number: 00000144348400
   Coding: 410D000100000000
   VCID: 302C0A1163C54906B2-8064
iichel
Eindhoven, NB, NL
C?ID=284912
IIRC the reverse light needs to go via BCM as well. Just like i.e. low beam. You did a BCM low to BCM Max conversion, that is not a plug and play swap to a 089 BCM.
For that, an 087 BCM would have been better.
amigokola
Poland
C?ID=281040
Yes I know but there was no used 087 only 089 available.
Why it throws only M29 foult and no other bulbs ??
I sit on wiring diagrams for a while now but there are a lot of versions depending on year in T5...
For me it is unclear why after adding this two extra power feed cables BCM react on light switch like this ??
iichel
Eindhoven, NB, NL
C?ID=284912
Reverse light in 086:
Gearbox  ______ BCM
              Reverse light
Reverse light in 089 BCM:
Gearbox -------- BCM ------ Reverse light
With this high-level illustration, the difference between 086 and 089 BCM is hopefully clear.
Now you have an 089 BCM with 086 wiring. All works as per the 086 scheme, but the BCM is receiving only the input. It wants to output a signal to power the reverse light but finds nothing (like a blown light).
Hence the warning light. Same will probably happen with the license plate lights and low beams. At least, in principle. The low beams are a bit more complicated.
amigokola
Poland
C?ID=281040
Ok but why BCM throws only M29 foult and not reverse bulb and M30 from right side dipped beam ??
iichel
Eindhoven, NB, NL
C?ID=284912
Since your 089 BCM is probably still coded with the coding of your 086 BCM but is parameterized to work with the wiring as per the 089 diagram. So it's confused, to say the least.
amigokola
Poland
C?ID=281040
Ok. I'll try it tomorrow. Thx.
iichel
Eindhoven, NB, NL
C?ID=284912
Yes. My recommendation is to find yourself the wiring diagrams for the T5.2 or T6.
Find the wiring that you now have in basic equipment and look at the wiring in the basic equipment for 7L6 (start/stop). Wire your car as it were a car with start/stop for the low beam, fog light, DRL, reverse light and license plate lights.
Then we'll have a look at the coding.
Alternatively, find a 087 BCM and it will be plug and play.
