- Feb 1, 2017
- 62
- 22
- Oulu, Finland
- C?ID=229426
Car: Skoda Octavia Mk2
MY: 2007
Engine Code: BKD
Hello!
The car's original engine ecu (03G 906 021 MC) has had to change the tuning to the ecu (03G 906 016 BA) by the time the original engine ecu is broken. The tuning ecu salesman had said the product had been in Seat and VW cars with the same engine code as the Octavia. Once the tuning ecu was installed in the Octavia, there had become fault lights and functionality problems. Symptoms include engine vibration & jerking during driving (1500-2000 rpm) and at higher revs, gear in neutral with uneven running. The original engine ecu did not have the above problems before disintegrating.
- Is the Engine ECU broken / incorrect?
- Is the tuning program broken?
1. Round
2. Round
Regards: V3lmu
MY: 2007
Engine Code: BKD
Hello!
1. Round
Thursday,17,September,2020,15:21:17:00464
Dealer/Shop Name: J.P - V3lmu
VIN: TMBKE61Z178023129 License Plate: SKODA OCTAVIA
Mileage: 393430km-244466mi Repair Order: 1. kierros
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 22 25 42 44 46 52 55 56 62 69 72
VIN: TMBKE61Z178023129 Mileage: 393430km-244466miles
69-Trailer -- Status: Not registered 0001
Address 01: Engine Labels: 03G-906-016-BKD.clb
Part No SW: 03G 906 016 BA HW: 028 101 184 7
Component: R4 2,0L EDC G000SG 7000
Revision: 12345678 Serial number: XXXXXXXXXXXXXX
Coding: 0000172
Shop #: WSC 01286 386 08256
VCID: 6393AF9B5755A5132F1-8036
19558 - Motor for Intake Manifold Flap (V157)
P3102 - 000 - No Signal
Torque: 92.0 Nm
Voltage: 12.08 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 354.0 Nm
17848 - EGR Valve (N18)
P1440 - 000 - Open Circuit
Torque: 92.0 Nm
Voltage: 12.08 V
Bin. Bits: 00101100
Mass Air / Rev.: 820.0 mg/str
Mass Air / Rev.: 0.0 mg/str
19557 - Motor for Intake Manifold Flap (V157)
P3101 - 000 - Open or Short to Ground
Torque: 92.0 Nm
Voltage: 12.08 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 354.0 Nm
18617 - Engine Coolant Temp Sensor on Radiator Outlet (G83)
P2185 - 000 - Signal too High - Intermittent
Torque: 22.0 Nm
Voltage: 12.24 V
Bin. Bits: 00101100
Temperature: 54.9°C
Temperature: 38.7°C
Readiness: 1 3 0 0 0
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0023170
Shop #: WSC 73430 790 00000
VCID: 72BDDADF98AF3C9B547-8026
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1Z0 907 044 J
Component: ClimatronicPQ35 084 0305
VCID: 3D2739E39171B3E3795-8068
01273 - Fresh Air Blower (V2)
010 - Open or Short to Plus
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 AE HW: 3C0 937 049 AE
Component: Bordnetz-SG H52 2002
Revision: 00H52000 Serial number: 00000004627357
Coding: 498A8F130004140000110D000000000000087F065C0000
VCID: 6C81C4A7BA8BEA6B9EB-8038
Subsystem 1 - Part No: 1Z1 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 181106 022 0601
Coding: 00055223
Shop #: WSC 73430
Subsystem 2 - Part No: 1K0 955 559 AE Labels: 1K0-955-559-AF.CLB
Component: RLS 151106 014 1201
Coding: 00471077
Shop #: WSC 73430
Part No SW: 1K0 909 605 AA HW: 1K0 909 605 AA
Component: Q2 AIRBAG VW8 027 0900
Revision: 11027000 Serial number: 003B5D10G56H
Coding: 0020786
VCID: 6B83C7BBBF85ED53971-803E
Subsystem 1 - Serial number: 6332MSME144438320
Subsystem 2 - Serial number: 6342MSME146874428
Subsystem 3 - Serial number: 6351HSME0B792928F
Subsystem 4 - Serial number: 6361HSME0B791E2FR
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 036 0070
Coding: 0000042
VCID: 74B1DCC7E2BB32AB46B-8020
00888 - Wiper Switch for Intermittent Operation (E22)
Part No SW: 1Z0 920 842 D HW: 1Z0 920 842 D
Component: KOMBIINSTRUMENT VD1 1612
Revision: V1612036 Serial number: SKZ7Z0F3950438
Coding: 0007101
Shop #: WSC 80093 222 69422
VCID: 382928F7BE5396CBAA3-806C
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H04 0020
Revision: H04 02 Serial number: 291106F2000466
Coding: FD3F034007002302
VCID: 2F3B13AB4B1D5173FB9-807A
Fault Status: 00110100
Reset counter: 208
Mileage: 390915 km
Time: 19:37:16
Mileage: 390639 km
Time: 00:11:53
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554 L
Component: Haldex 4Motion 0116
Coding: 0000001
VCID: 363526CFB44760BBB8F-8062
Component: IMMO VD1 1612
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0953
Coding: 0000246
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Address 44: Steering Assist Labels: 1Kx-909-144-G2V3.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
Shop #: WSC 02069 000 90108
VCID: 34311CC7A23B72AB86B-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0203
Revision: 00020000 Serial number: 00000000000000
Coding: 80801A085283007F3F02850500084F01807C00
VCID: 03538F1BB71505134F1-8056
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Component: Tuer-SG 005 0943
Coding: 0000246
VCID: 392F2DF385598FC355D-806C
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000008
Part No SW: 1Z0 035 161 C HW: 1Z0 035 161 C
Component: Radio FO3 019 0034
Revision: 00019000 Serial number: SKZ7Z3F0099618
Coding: 0000400
VCID: 2E050EAF4C17587BF0F-807A
Part No SW: 1K0 959 703 J HW: 1K0 959 703 J
Component: Tuer-SG 005 0907
Coding: 0000144
Shop #: WSC 73430 790 1012544
VCID: 372B2BCBB34D99B3A39-8062
Component: ConWysTrailer H07 0100
Revision: 3A001001 Serial number: 00000132425721
Coding: 0100000100000000
Shop #: WSC 00007 223 174336
VCID: 303910D75A234E8BE23-8064
Part No SW: 1K0 959 704 J HW: 1K0 959 704 J
Coding: 0000144
End----------(Elapsed Time: 01:23, VBatt start/end: 12.4V/12.5V)-----------
Thursday,17,September,2020,15:25:34:00464
Mileage: 393430km-244466mi Repair Order: 2. kierros
Coding: 0000172
Torque: 0.0 Nm
Voltage: 12.39 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 354.0 Nm
Torque: 0.0 Nm
Voltage: 12.39 V
Bin. Bits: 00101100
Mass Air / Rev.: 785.0 mg/str
Torque: 0.0 Nm
Voltage: 12.39 V
Bin. Bits: 00101100
Torque: 0.0 Nm
Torque: 354.0 Nm
Readiness: 0 0 1 1 1
Revision: 00H13001
Coding: 0023170
Coding: 00055223
Shop #: WSC 73430
Coding: 00471077
Shop #: WSC 73430
Coding: 0020786
Coding: 0000042
Coding: 0007101
Mileage: 393435 km
Time: 15:21:49
Coding: 0000001
Coding: 0000246
No Faults Found
Coding: 0000246
Coding: 0000008
Coding: 0000400
Coding: 0000144
Coding: 0000144
End----------(Elapsed Time: 01:29, VBatt start/end: 12.3V/12.3V)-----------
