Audi A4 B8 2010 Auto Start/Stop
matbcvo
Estonia
C?ID=396297
Hi, I need little help about making auto start/stop work like that way: SS off = light off, SS on = light on, and memory activated (when I turn that off, then it stays off) or by default disabled
I found that: https://forums.ross-tech.com/index.php?threads/17489/#post-155505
I think I had value 34, so I tried to set 130 (34+32+64) value, it still didn't work. Also tried 32, 64 and 96.
Thursday,17,September,2020,13:12:17:12697
VIN: WAUZZZ8K4AA158387   License Plate:
Chassis Type: 8K-AU48 (8T0)
Scan: 01 03 05 08 09 10 15 16 17 19 20 42 46 52 53 56 5F 62 72
VIN: WAUZZZ8K4AA158387   Mileage: 272700km-169447miles
Address 01: Engine (J623-CAHA)       Labels:. 03L-906-019-CAG.clb
   Part No SW: 03L 906 022 RM    HW: 03L 906 019 AL
   Component: R4 2.0l TDI   H23 9978
   Revision: 25H23---
   Coding: 12194012232603080000
   Shop #: WSC 40638 002 1048576
   ASAM Dataset: EV_ECM20TDI03L906022RM A02008
   ROD: EV_ECM20TDI03L906022NP.rod
   VCID: 015F837F118A13935DD-8054
   Part No SW: 8K0 907 379 BE    HW: 8K0 907 379 BE
   Component: ESP8 quattro  H04 0030
   Coding: 180D04
   Shop #: WSC 06325 000 00000
   VCID: 7DA7FF8F6DF27773395-8028
   Part No SW: 8K0 907 064 DP    HW: 8K0 907 064 DP
   Component: BCM2 1.1      H02 0328
   Coding: 032200
   VCID: 015F837F110A13935DD-8054
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0510000018282019
   Serial number: 0210000037673005
   Part No SW: 8T1 820 043 AH    HW: 8T1 820 043 AH
   Component: KLIMA 1 ZONE  H08 0171
   Revision: A1000000    Serial number: 01200320101385
   Coding: 34300000
   VCID: 77ABEDA74FCE5D23639-8022
   Component: BCM1 1.0      H29 0380
   Revision: 10029001    Serial number: 00000000628816
   Coding: 260810B10174A7211701000300001D0D0F9C064806000101000000
   VCID: 3C21328B3668BE7B4EB-8068
   Component: WWS 230310  H06 0070
   Serial number: SWF10030235646
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10839487
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001803100197
   Part No SW: 8K0 919 475 Q    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0070
   Revision: 11001001    Serial number: 51241008301067
   Coding: 100003
   Shop #: WSC 06325 123 12345
   VCID: 47CB5D677FAEEDA3D39-8012
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0DXEJ2
   Coding: 30343435363030303030554A304C384B3053
   VCID: 44D14A6B4E18C6BB36B-8010
   Serial number: 6334MSME51551A77E
   Serial number: 6344MSME5103152E5
   Serial number: 6352QSME58583924L
   Serial number: 6362QSME6D564906R
   Serial number: 63732SME6D581B38B
   Serial number: 63832SME6B580430.
Address 16: Steering wheel ()       Labels:. 8K0-953-568.clb
   Revision: --------    Serial number: 90304JCS0005E
   Coding: 000017
   VCID: 3D273F8F2D72B773795-8068
   Component: E221 - MFL  H02 0010
   Part No SW: 8K0 920 930 D    HW: 8K0 920 930 D
   Component: KOMBIINSTR.   H21 0255
   Revision: 00000000    Serial number: CIY731C5A
   Coding: 0F0D110003000008010001
   Shop #: WSC 49514 126 92542
   VCID: 2E0508C3F0145CEBF0F-807A
   Part No SW: 8T0 907 468 AJ    HW: 8T0 907 468 L
   Component: GW-BEM 5CAN-M H10 0121
   Revision: FB400042    Serial number: 4200F081028131
   Coding: 00CF07
   Shop #: WSC 00046 000 00000
   VCID: 094F9B5F293A5BD305D-805C
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650130731
   Component: J532_DCDCStab  H16 0038
   Serial number: 10085000531021200180
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 01018B646E6E645A5A253D3E
   VCID: 333319B71B3671039F1-8066
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000010375371
   Coding: 011C02204000410001
   VCID: 45D7576F45A2FFB3215-8010
   Revision: 00002001    Serial number: 0128131681
   Coding: 01000620203904400120023680000000
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000103267780
   VCID: 44D14A6B4E98C6BB36B-8010
   Revision: 00000003    Serial number: 10000000473315
   VCID: 34311AAB1E38763B86B-8060
   Part No SW: 4F0 035 053 K    HW: 4F0 035 053
   Component: Radio U Basic H45 0074
   Revision: AB001007    Serial number: 341CU0A7720648
   Coding: 010003020100000001
   VCID: 2517F7EFA5E21FB3015-8070
   Part No SW: 8T1 035 666 M    HW: 8T1 035 666 E
   Component: H-BN-EU       H47 0187
   Revision: --------    Serial number: 483CK0A7610111
   Coding: 010100010006A1ED05000F1E000000030001
   Subsystem 1 - Part No: 8R0 060 884 FC
   Component: EUR 2018  2601
   Component: DU7 High  H43 0306
   Serial number: 9356C-0A1227994
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000502095
   Component: CD-Database  1293
00658 - Control Head
                    Fault Status: 01101100
                    Reset counter: 222
                    Mileage: 272538 km
                    Date: 2020.09.15
                    Time: 22:56:42
                    Voltage: 12.60 V
                    Bin. Bits:      001
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000103257381
   Coding: 010C02204000210001
   VCID: 42DD4C73548CC88B047-8016
   Revision:             Serial number: 0000103256528
End----------(Elapsed Time: 01:20, VBatt start/end: 12.1V/12.1V)-----------
