Disable washer fluid light on an Audi B8
4lane
C?ID=8554
I have a B8 Allroad with a washer fluid warning light on. The sensor is good and I replaced it with no result, I jumped the wires in the connector with no result, in case the connector was faulty I cut the wires and tied them together with no result. It’s driving me mad and I’m not taking my dash apart to start digging into the control module for this stupid thing. Is there a vag com option to just disable this thing?
Mari
C?ID=150535
Would be helpful if you posted a full and unedited autoscan of the car...
  • Agree
NostraJackAss
OP your request is not acceptable nor a qualified repair!
It would not because did you know OP's request is illegal in CFR USC 49?
  • Disagree
NostraJackAss
OP
You could test wiring or overlay harness plus qualify the function with a decade box.
Delete of a safety device is not usually permissible in cluster or bcm either for a US region.
None of this is applicable to the OP's specific request.
First, he is an individual, not a manufacturer, distributor, dealer, or motor vehicle repair business, and:
the "make inoperative" provision does not prohibit consumers from modifying their own vehicles, even if such modifications adversely affect the compliance of the vehicle with the FMVSS.
Second, he is not considering making his wipers or washers inoperative, just the washer fluid level warning, which does not appear to be a requirement of
49 CFR § 571.104 - Standard No. 104.
NostraJackAss
Indeed but you skipped past this though, huh?
49 CFR § 571.101 - Standard No. 101; Controls and displays.
The OP request is to modify a safety device, we are not permitted to engage or aid in conspiring to do this are we?
Your link brings up an essentially empty page. If you're going to claim it's illegal, please provide a working link and quote the exact portion that you think is relevant.
NostraJackAss
It was working last night huh, but no problem?
Sorry about text size..... :(
Did you search the aforementioned CFR control device and telltale, this one again below?
See the gifs at bottom of page to correlate.
Is not a wiper washer considered a "control" and communication "telltale" based on regulation/chart or am I mistaken?
Relevant>>>
I see nothing in there that indicates a washer fluid level indicator is required.
NostraJackAss
The only thing that refers to the washers there is a CONTROL, not a tell-tale for the washer fluid level.
Again, the OP is not asking to make his washers non-functional.
NostraJackAss
Is not a "control device" with a "combination use" of telltale, not permitted to be disabled and tampering with illumination considered a violation of the regulation & why an MIL "control or telltale" device in combination are required to function as originally certified?
My point is, if the functions of such an MIL are considered linked in "combination" would not the OP's request be illegal and open the forum or anyone advising to aid and abet by conspiring a possible civil maybe criminal liability?
:rolleyes:
Stop grasping at straws. It's not a MIL. It's a low washer fluid warning. Washers are required. Low washer fluid indicators are not. You're done in this thread.
@4lane,
Based on the scan here you have a coding bit in address 17-Instrumets that includes Washer Fluid Warning active in our Long Coding Helper. I'd try turning that off to see if it helps.
4lane
C?ID=8554
@4lane,
yes, found the coding bit in 17-Instruments, but deactivating it didn’t do anything.
4lane
C?ID=8554
Today I went at this issue again because this giant dash warning is making me want to drive the car off a cliff. Disabling the washer warning did not work, likely because of a warning prompt.
I went under the wheel well to look at the wire again and pulled 6” of one wire. If I can’t disable this, I have to find where this wire goes from the top of the wheel well. I see one loom coming up from that area but it just goes direct to the positive terminal in the cowl. Does anyone know where I can find this wire accessible so I can tie them together?
NostraJackAss
First I have to capitulate in this thread because I was reading into the spirit of the regulation and got carried away.
I was wrong...Uwe is right, in regards to this.
My first intuition is to always do stuff fixed proper to best of ability.
My hope is that if we review WD and find wiring, we can still repair, however, the testing process by decade box. This will also net knowledge of a work around, see were I'm going?
OP post a scan please & so I can try to help you.
4lane
C?ID=8554
Thank you - here you go:
Sunday,01,November,2020,16:36:49:02305
VIN: WA1UFAFL0DA069272   License Plate:
Mileage: 106380km-66101mi   Repair Order:
Chassis Type: FL-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 44 46 47 52 53 56 5F 62
          6C 6D 72
VIN: WA1UFAFL0DA069272   Mileage: 106380km-66101miles
Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 F    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0008
   Revision: ECH09---
   Coding: 722A0013242600062000
   Shop #: WSC 54964 001 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115F 001009
   ROD: EV_ECM20TFS0118K5907115F.rod
   VCID: 3537DC2F05C1E6B3B15-8060
5646 - Leak in Air Intake System
          P2279 00 [237] - -
                    Mileage: 106241 km
                    Date: 2020.10.26
                    Time: 08:47:27
                    Engine speed: 799.00 /min
                    Normed load value: 15.7 %
                    Coolant temperature: 71 °C
                    Intake air temperature: 13 °C
                    Voltage terminal 30: 14.442 V
                    Median injection timing: 1.147 ms
                    Engine operating condition: Idling
                    A/C compressor: load current: act. value: 920.50 A
4106 - Bank 1; System too Rich at Idle
          P2188 00 [104] - -
                    Mileage: 105815 km
                    Date: 2020.10.19
                    Time: 09:00:53
                    Engine speed: 791.50 /min
                    Normed load value: 21.6 %
                    Coolant temperature: 87 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 14.559 V
                    Unlearning counter according OBD: 37
                    Median injection timing: 1.291 ms
   Part No SW: 8K1 927 158     HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   VCID: 74B1212B4E3BBFBB46B-8020
   Part No SW: 8K9 907 379 M    HW: 8K9 907 379 M
   Component: ESP8 quattro  H09 0100
   Coding: 0E1D18
   Shop #: WSC 06334 000 00000
   VCID: 4CC199CB76CB877BFEB-8018
   Part No SW: 8K0 907 064 FP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H10 0602
   Coding: 0D820000000000000000
   Shop #: WSC 06335 000 00000
   VCID: 035372F71B1588034F1-8056
   Serial number: 2312000100185014
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Revision: C1000000    Serial number: 01110520121266
   Coding: 6480208000
   VCID: 3333E2370B35F8839F1-8066
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
   Component: BCM1 1.0      H14 0103
   Revision: 08014001    Serial number: 00000030437701
   Coding: 26000091803CAFC00000480300003D0D0F1C4708A2090221000008000000030100000030000000
   Shop #: WSC 08185 444 103375
   VCID: 78A9151B52D3DBDB6A3-802C
   Component: WWS 110512  H07 0070
   Serial number: SWF12050115803
   Coding: 00FD11
   Serial number: 20271225
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000305120151
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R1NZ702
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 2908C126000000000001
   Part No SW: 8K0 959 655 M    HW: 8K0 959 655 M
   Component: AirbagVW-AU10 H46 0610
   Serial number: 003KEDA014G
   Coding: 303844354A32303030304A55304C384B3053
   Shop #: WSC 00040 002 1048576
   VCID: 47CBA6E76F2D6423D39-8012
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R1200008MMA
   Serial number: 6334MSME6E514072C
   Serial number: 6344MSME6F222D3BS
   Serial number: 6352QSME441653628
   Serial number: 6362QSME4F15014CK
   Serial number: 63732SME6D14325A0
   Serial number: 63832SME4C145162Z
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20120514001084
   Coding: 000017
   VCID: 4FFB8EC787DDBC639B9-801A
   Component: E221 - MFL  H03 0003
   Part No SW: 8K0 920 982 A    HW: 8K0 920 982 A
   Component: KOMBIINSTR.   H35 0540
   Revision: 00000000    Serial number: NTC23475D
   Coding: 8B2629020301D705020000
   VCID: 323DE733F42FF18B947-8066
   Part No SW: 8R0 907 468 C    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H10 0025
   Revision: 1Y030014    Serial number: 1441Y125030368
   Coding: 00C303FF00
   VCID: 3FDBBE07377D2CE36B9-806A
   Serial number: 8175957401
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000029145580
   Coding: 00581B00000000000000
   VCID: 3B23CA17236530C3471-806E
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000029908343
   Coding: 011C13205E00410001
   VCID: 4DC794CF8DD18E73E95-8018
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0020526803
   Coding: 100000000001
   Shop #: WSC 08185 444 122181
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3431E12B0EBBFFBB86B-8060
   Revision: 00002001    Serial number: 0176517259
   Coding: 0126023A20BA709580B0023200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000519778
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS150  H08 0043
   Subsystem 4 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J394 PS240  H08 0043
   Component: DSP Prem      H04 0030
   Revision: 00004001    Serial number: 94814003201301
   VCID: 2D07F44FED11AE73C95-8078
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000029772602
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000000048809
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3829D51B12D31BDBAA3-806C
   Part No SW: 4G0 035 080 G    HW: 4G0 035 080
   Revision: AB001007    Serial number: 158H10E7505942
   Coding: 020007010000000001
   Shop #: WSC 01238 002 1048576
   VCID: 221D1773A4CF610B647-8076
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 A
   Component: H-BNT-NA      H42 0901
   Revision: --------    Serial number: 096E 0C7510836
   Coding: 010200050006A1EF41028F4E00000403140000000000000000
   Component: NAR 2011  0505
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130EG0CS169387
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001153298
   Component: CD-Database  3371
   Part No SW: 8K0 959 795 D    HW: 8K0 959 795 D
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000030049731
   Coding: 010C13204000210001
   VCID: 43D3B2F75B9548030F1-8016
   Part No SW: 8T0 907 441 D    HW: 8T0 907 441 D
   Component: J772__Rearview      0140
   Revision: --H06---    Serial number: 525PA8-J229325
   Coding: 1000007
   VCID: 392FD01F255902D355D-806C
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H52 0330
   Revision: --------    Serial number: 8K9827851A
   VCID: 3C21C90B266B37FB4EB-8068
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H52 0330
   Serial number: 8K9827852A
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000030050712
End----(Elapsed Time: 02:02, VBatt start/end: 11.4V/11.4V. VIgn 11.4V)-----
NostraJackAss
Sub system redundancy check config started!
Vehicle Identification No.WA1UFAFL0DA069272
ModelAudi A4 Av. Allroad
quattro 2.0
A4AR
Date of production23.05.2012
Model year2013
Sales type8KH52A
Engine CodeCPMA
Transmission CodeNGR
Emission standard7GBEmission standard ULEV 2
Intermittent windshield wiper control/
light/rain sensor
8N6Windshield wiper intermittent control
with light/rain sensor
PART NUMBERDESCRIPTION
7M0 919 376 water level switch
OP.....
First are you sure the sensor is this part number you changed above and no FOD?
Can you please undo the changes in VCDS?
Can you scan blocks of BCM/Cluster to see if we can locate the washer tank values, Uwe please chime in if you have handy?
As can be seen, G33 is fed by J519 from T32b/ PIN 25 to T32b/ PIN 28 to loop the washer sensor at J519.
The feed tracks are shared for F34,G17,G32.......!
Isolate them and verify the display sees faults for each, further while seeing if feed voltage is at PIN 1 of G33 washer sensor and matches feed voltage at any of these respective shared tracks in WD under hood?
A quick test if voltage is not present at G33 would be to jump overlay to G33 from any above sensor that is functional since its a tree anyway and its only one wire back to J519 from G33.
This should be pretty simple to achieve, make sense now?
A quick test scrolling with a decade box in car at T32b PINS 28 and 25 starting at 100-1000 ohms bridged should net a result or J519 is kauput!
