I need some help....
pearing
C?ID=388355
I got my VCSD registered tonight-car forced my hand and is throwing check engine light and the coiled wire looking light which flashes. All of which seems bad from the initial search on the web. 2015 Golf tdi sportwagon. I ran a report; however, I am not a mechanic in the sense that I know how to read the codes and makes sense of it, This I need to learn-thus the request for help. I know this is kind of in the wrong spot but I wanted admin to know I finally registered, so I can verified and ask all my nubie questions in the forum proper...
This is the scan:
Wednesday,16,September,2020,18:38:50:18576
VIN: 3VWCA7AU0FM503177   License Plate: AGN2320
Mileage: 81645km-50731mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 2B 42 44 52 5F 75
VIN: 3VWCA7AU0FM503177   Mileage: 81645km-50731miles
Address 01: Engine (J623-CRUA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 997 022 N    HW: 04L 907 309
   Component: R4 2.0l TDI   H23 9459
   Revision: 85H23---
   Coding: 011D0012032410081000
   Shop #: WSC 02428 444 00000
   ASAM Dataset: EV_ECM20TDI01104L997022N 004002
   ROD: EV_ECM20TDI01104L997022N.rod
   VCID: 3B23304873E129D3471-806E
9 Faults Found:
17158 - Databus
4794 - Mass Air Flow Sensor (G70)
          P0101 00 [237] - Implausible Signal
                    Mileage: 81564 km
                    Date: 2020.08.17
                    Time: 17:37:04
                    Engine speed: 1172.00 /min
                    Vehicle speed: 54 km/h
                    Coolant temperature: 82 °C
                    Intake air temperature: 59 °C
                    Voltage terminal 30: 13.840 V
                    Mass airflow sensor 1 bank 1 airflow: raw value: 409.3 mg/stroke
                    Standardized airflow ratio: filtered: 1.1891
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.02 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.00 %
                    Charge air pressure specified value: 1097 hPa
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1088.2 hPa
                    Mean injection quantity: 0.00 mg/stroke
13865 - Coolant Pump for Intercooler
          P023A 00 [032] - Open Circuit
27016 - EGR System
          P0402 00 [232] - Excessive Flow
                    Mileage: 81530 km
                    Date: 2020.08.17
                    Time: 09:41:12
                    Engine speed: 1912.00 /min
                    Normed load value: 79.6 %
                    Vehicle speed: 67 km/h
                    Coolant temperature: 89 °C
                    Intake air temperature: 94 °C
                    Voltage terminal 30: 14.060 V
                    EGR travel diagnosis: strongly increased NOx emission: 70.4 kg/h
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.05 %
                    EGR travel diagnosis: marginally increased NOx emission: 71.5 kg/h
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 12.34 %
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 2.16 %
                    Pressure after throttle valve: calculated: -5.0 hPa
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.4937
22589 - Reductant Tank Temperature Sensor
          P205B 00 [096] - Implausible Signal
23010 - Exhaust Gas Recirculation System
          P240F 00 [237] - Response too Slow
                    Mileage: 81511 km
                    Date: 2020.08.15
                    Time: 13:59:22
                    Engine speed: 1805.50 /min
                    Normed load value: 39.2 %
                    Vehicle speed: 25 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 54 °C
                    Voltage terminal 30: 13.920 V
                    Air mass dynamic during negative increase: error criterion: 0.36 kg/h
                    Air mass dynamic during positive increase: error criterion: 4.73 kg/h
                    Air mass dynamic during negative increase: error threshold: 9.00 kg/h
                    Air mass dynamic during positive increase: error threshold: 4.00 kg/h
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 31.51 %
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 28.91 %
                    Throttl.valve adapt. 1 bank 1: posit feedback - Act.value: 0.07 %
25221 - EGR System
          P0402 00 [237] - Excessive Flow
                    Mileage: 81530 km
                    Date: 2020.08.17
                    Time: 09:41:14
                    Engine speed: 1806.50 /min
                    Normed load value: 72.9 %
                    Vehicle speed: 82 km/h
                    Coolant temperature: 66 °C
                    Intake air temperature: 88 °C
                    Voltage terminal 30: 13.980 V
                    EGR travel diagnosis: strongly increased NOx emission: 39.3 kg/h
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.01 %
                    EGR travel diagnosis: marginally increased NOx emission: 40.1 kg/h
                    Exhaust recirc.valve 2 bank 1: posit.feedback - Act.value: 14.05 %
                    Exh.recircul.valve 1 bank 1: pos.feedback - Act.value: 2.25 %
                    Pressure after throttle valve: calculated: -4.0 hPa
                    O2 sens. 1 bank 1 upstrm oxi cat: raw value: 1.5444
          U0428 00 [032] - -
21467 - Mass Airflow Sensor 1
          P00BC 00 [237] - Airflow too Low
                    Fault Frequency: 63
                    Mileage: 81539 km
                    Date: 2020.08.17
                    Time: 11:56:56
                    Engine speed: 1232.00 /min
                    Normed load value: 74.9 %
                    Vehicle speed: 69 km/h
                    Coolant temperature: 73 °C
                    Intake air temperature: 58 °C
                    Voltage terminal 30: 13.820 V
                    Mass airflow sensor 1 bank 1 airflow: raw value: 323.3 mg/stroke
                    Standardized airflow ratio: filtered: 1.5714
                    Exhaust recirc.valve 1 bank 1: posit.feedback - Act.value: 0.09 %
                    Charge air pressure specified value: 1131 hPa
                    Charge air cooler inlet: pressure sensor 1 bank 1: raw value: 1133.6 hPa
                    Mean injection quantity: 19.33 mg/stroke
Readiness: 1 5 0 0 0
   Part No SW: 0D9 300 041 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4512
   Revision: 05853104    Serial number: TFK01412162232
   Shop #: WSC 00066 790 00202
   ROD: EV_TCMDQ250021.rod
   VCID: 2313E828EB5171136F1-8076
          P1734 00 [002] - -
   Part No SW: 3Q0 907 379 P    HW: 3Q0 907 379 C
   Revision: 00000000    Serial number: 50115000000701
   Coding: 04FA6AA12420096F0078020781CA2520562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   VCID: 47CB5CB83F297D33D39-8012
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 18
                    Date: 2019.02.14
                    Time: 00:46:25
   Revision: 00021000    Serial number: 0356344029
   Coding: 030C0C
   VCID: 3A2D354C7CDB10DB5C7-806E
   Part No SW: 5GM 907 426     HW: 5GM 907 426
   Component: AC Manuell    H02 1001
   Revision: 00001K01
   Coding: 02020104200100000000000000000000
   VCID: 055796B045A5AF23615-8050
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-BV1.clb
   Part No SW: 5Q0 937 087 Q    HW: 5Q0 937 087 Q
   Revision: --------    Serial number: 86580601152647
   Coding: 000118424041804169E44000000403001800000000000000000000000000
   Shop #: WSC 00066 790 00195
   ROD: EV_BCMBOSCH_014.rod
   VCID: 49CF5A80293D8B43C5D-801C
   Component: WWS    140830  043 0581
   Serial number:         150220192620
          U1400 00 [008] - -
919560 - Light Switch
          B126A 29 [136] - Signal Implausible
                    Fault Frequency: 243
                    Reset counter: 162
                    Mileage: 67354 km
                    Date: 2019.12.16
                    Time: 09:45:36
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Fault Frequency: 110
                    Reset counter: 153
                    Mileage: 52674 km
                    Date: 2019.04.05
                    Time: 22:11:03
   Serial number: 003GCR014JJF
   Occupant Detection:
   Serial number: IBH0000J150002BVHJ0M
   Coding: 303138
   Subsystem 2 - Part No SW: -----------    HW: 480 001 312 14
   Serial number: 35700000000B966D321N
   Subsystem 3 - Part No SW: -----------    HW: 480 001 312 14
   Serial number: 3580000000011584221/
   Subsystem 4 - Part No SW: -----------    HW: 480 401 512 14
   Serial number: 3510002BB1811B96013V
   Subsystem 5 - Part No SW: -----------    HW: 480 401 811 14
   Serial number: 3520002AF188FC04938J
   Subsystem 6 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3550002B7188FBF3640I
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 612 14
   Serial number: 3560002B7188FBF3738R
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141222500673
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 04518BB44E9F962B76B-8050
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BA4121A2180CF0502086A001000000000000000
   VCID: 6597B630A5E54F23C15-8030
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 18011510000449
   Coding: 0901000800087300EF0000081C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00200
   ROD: EV_GatewConti_011.rod
   VCID: 71BFD260612D9383ADD-8024
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0101
   Serial number: 29150000187410055062
   Coding: 29FFFF
   Power Converter DC AC:
   Subsystem 3 - Part No SW: 5Q0 907 155 A    HW: 5Q0 907 155 A
   Component: WECHSELRICHTE  H53 0041
   Serial number: 0023708
   Revision: 00000000    Serial number: 15000012257005
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34311B745EBFE6AB86B-8060
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 24011506050AVQ
   Coding: 003013200000040000000000
   VCID: 3E25395C60F33CFB60F-806A
   Serial number: 00000000000000550876
   Coding: 011000
   Component: EPS_MQB_ZFLS  126 1061
   Coding: 0102
   VCID: 43D348A80B1151130F1-8016
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 240115060509SG
   VCID: 3D273E506DF527E3795-8068
   Serial number: 00000000000000516934
   Coding: 091000
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     014 0655
   Serial number: V7B00901151954
   Coding: 02730200FF00000021220001001800001F0100140100010002
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 6491AB34AEDF362BD6B-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS5013Q5
          B11CF 53 [009] - Deactivated
                    Reset counter: 82
                    Mileage: 80252 km
                    Date: 2020.07.31
                    Time: 09:26:24
                    Voltage terminal 30: 13.8 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
0023 - Tuner for Satellite Radio
          B11CF 96 [008] - Component internal failure
                    Reset counter: 144
                    Mileage: 81028 km
                    Date: 2020.08.09
                    Time: 08:59:11
                    Voltage terminal 30: 12.4 V
   Component: OCULowMQBUS   007 0564
   Coding: 02730202C2821A017F1E06000000
   Shop #: WSC 00066 790 00123
   ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:27, VBatt start/end: 12.3V/12.3V)-----------
Thanks!
Confirmed, Verified, and moving this to Car Repair Support for you.
You have MAF issues and EGR issues, possibly related. This car looks to have the Dieselgate "fix" software and it only has a tad over 50,000 miles on it. Thus I'm reasonably confident that VW will cover those kinds of problems under the extended Dieselgate warranty.
pearing
C?ID=388355
Thank you! The nearest dealer is a two hour drive-is it safe to drive that far? I am going to contact vw today but wondering about getting the car there...
iichel
Eindhoven, NB, NL
C?ID=284912
From the looks to it, your EGR valve is jammed open. More exhaust gas than intended is going through the EGR system. This in turn makes more air enter the inlet manifold so your engine is like "MAF is wrong" while it isn't. It's more air due to the EGR system 'leaking'.
I'm not sure about any procedures concerning warranties in the USA. Perhaps VW can authorise a local workshop do do the warranty repair.
Otherwise I guess the car is is limp mode and will only have a fraction of its power. Not very safe to drive.
pearing
C?ID=388355
Follow up: the dealer was able to clear the codes and the car was fine. They drove it (40 miles) and could not get it to through the codes again and it did regen. Is this a common thing with the tdi? how hard are the EGR valves to change (and why didn't the dealer want to?)
Cheers
