Q7 EGR code 4807 -
noomiij
HC48xxxx (2nd hand?)
Hi, I had problem with my climate control and on scan picked up this code for EGR. Otherwise it drives well. No warning lights or issues or symptoms. Does this code worry anyone? Can there be a remedy before it goes bad? Scan is uploaded. Thanks for input.
Saturday,05,September,2020,14:07:13:02168
VCDS Version: 20.4.2.0 (x64)
VIN:    License Plate:
Mileage: 105340km-65455mi   Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3D 42 46 47 4F 52 56 5F
          62 6C 6D 6F 72 76
VIN:    Mileage: 105340km-65455miles
3D-Special Function -- Status: OK 0000
6F-Centr. Conv. II -- Status: Malfunction 0010
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine (J623-CCMA)       Labels:. 059-907-401-V2.clb
   Part No SW: 4L1 910 401 L    HW: 4L0 907 401 D
   Component: 3.0TDI EDC17  H18 0007
   Revision: 54H18---    Serial number:
   Coding: 2A2A4012A52700030000
   Shop #: WSC 54730 001 1048576
   ASAM Dataset: EV_ECM30TDI0114L1910401L 001010
   ROD: EV_ECM30TDI0114L1910401L.rod
   VCID: 2C5CD44F47034FE69F-8078
4807 - EGR System
          P0401 00 [096] - Insufficient Flow
                    Mileage: 105328 km
                    Date: 2020.09.03
                    Time: 16:11:56
                    Engine speed: 777.00 /min
                    Normed load value: 30.2 %
                    Coolant temperature: 95 °C
                    Intake air temperature: 38 °C
                    Voltage terminal 30: 14.660 V
                    Mean injection quantity: 6.20 mg/stroke
                    Control Module temperature: 37.1 °C
                    EGR_governor_deviation: -94.4 mg/stroke
                    Inj Ctl q Curr: 6.20 mg/stroke
                    Mass_air_flow_sensor_drift: 1.7675
                    Air_Flow_Rate_from_Mass_Air_Flow_Sensor_kg_h: 41.3 kg/h
                    Actual charge pressure: 1015 hPa
4344 - Please Check Fault Codes in Control Module for HVAC (J301)
          U1025 00 [040] - -
                    Mileage: 104507 km
                    Date: 2020.08.13
                    Time: 18:32:25
                    Engine speed: 0.00 /min
                    Coolant temperature: 42 °C
                    Voltage terminal 30: 11.980 V
                    Unlearning counter according OBD: 36
                    Torque request: A/C compressor: 0.0 Nm
                    Status of compressor release-Bits 0-7: 00000001
                    Air C p Clnt: 65534 hPa
                    A/C compressor torque: 0.0 Nm
                    Engine status: COENG_READY
                    Outside air temperature: 27.0 °C
4339 - Please Check Fault Codes in Control Module for HVAC (J301)
          U1025 00 [040] - -
                    Mileage: 104507 km
                    Date: 2020.08.13
                    Time: 18:32:26
                    Voltage terminal 30: 11.960 V
                    Mean injection quantity: 0.00 mg/stroke
                    Exh.gas temp.sen 1: 45.0 °C
                    Control Module temperature: 40.0 °C
15668 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 11:59:39
                    Engine speed: 857.00 /min
                    Normed load value: 32.5 %
                    Vehicle speed: 4 km/h
                    Coolant temperature: 86 °C
                    Intake air temperature: 32 °C
                    Voltage terminal 30: 13.120 V
                    Limitation: accelerator pedal: 44.6 Nm
                    CAN status - engine control module-Bits 0-7: 00000000
                    Cruise Control System (CCS): status-Bits 0-7: 00101100
                    CAN status - transmission control module-Bits 0-7: 00000000
                    CAN status - brake control module 1-Bits 0-7: 00000000
                    CAN status - brake control module 2-Bits 0-7: 00000000
                    selected gear-Bits 0-7: 00000001
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 11:59:33
                    Coolant temperature: 87 °C
                    Voltage terminal 30: 12.120 V
                    CAN status - brake control module 1-Bits 0-7: 00001000
                    selected gear-Bits 0-7: 00000000
5619 - Engine Off Timer Performance
          P150A 00 [032] - -
                    Mileage: 104758 km
                    Engine speed: 549.00 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 89 °C
                    Intake air temperature: 22 °C
                    Voltage terminal 30: 13.360 V
                    Unlearning counter according OBD: 29
                    Shut-off timer: last engine shut-off time: 2 s
                    Shut-off timer: last ECM after-run time: 124 s
                    Time since ignition off: 2 s
                    Shut-off timer: instrum panel counter: open circuit in term 30-Bits 0-7: 00000000
                    Terminal 15 status-Bits 0-7: 00000001
   Part No SW: 0C8 927 750 T    HW: 0C8 927 750 T
   Component: AL1000 AISIN  001 1816
   Coding: 001178
   Shop #: WSC 25720 001 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031_001_AU56.rod
   VCID: 3D7AE90BAC79D66E38-8068
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 0103569
   Shop #: WSC 31414 790 00001
   VCID: 346CCC2F57331726C7-8060
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 F
   Component: FBSAUDIC6 ELV   H05 0130
   Revision: 00H05000    Serial number: 10603401755927
   Coding: 0000211
   VCID: 254A216BECE97EAE40-8070
   Subsystem 1 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0054
                    Reset counter: 13
                    Mileage: 104954 km
                    Date: 2020.08.20
                    Time: 11:55:38
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AE
   Component: KLIMA 4 ZONEN H13 0060
   Revision: 00---022    Serial number: 00000000252760
   Coding: 01009416
   VCID: 254A216B2CE97EAE40-8070
15 Faults Found:
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:00:06
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:00:06
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:00:06
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:00:06
                    Fault Status: 00101001
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:00:06
                    Temperature: 0.0°C
                    Temperature: 3.0°C
                    Temperature: -55.0°C
                    Absolute Pres.: 1.0 bar
                    Current: 0.000 A
                    Temperature: 3.0°C
00218 - Humidity Sensor (G355)
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:00:09
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:00:11
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:00:11
02874 - Control Module 2 for Central Convenience (J773)
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:00:11
                    Reset counter: 150
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:04:55
                    Voltage: 11.30 V
01853 - Heated Seat; Left Front (Z45)
                    Fault Status: 00101011
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:05:09
                    Temperature: 3.0°C
01855 - Temperature Sensor for Heated Seat; Left Front (G344)
                    Fault Status: 00101010
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:05:09
                    Temperature: 3.0°C
01854 - Heated Seat; Front Right (Z46)
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:09:29
                    Temperature: 4.0°C
01856 - Temperature Sensor for Heated Seat; Front Right (G345)
                    Reset counter: 11
                    Mileage: 121266 km
                    Date: 2010.04.16
                    Time: 00:09:29
                    Temperature: 4.0°C
                    Fault Frequency: 12
                    Reset counter: 230
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 12:01:24
                    Bin. Bits:    01111
   Part No SW: 4F0 910 279 AF    HW: 4F0 907 279
   Component: ILM Fahrer      H30 0390
   Coding: 0038121
   VCID: 6DDA194B749986EEC8-8038
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H12 0100
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 71 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D07J8B-
   Coding: 0014129
   VCID: 2E58DE47B91F3DF6B1-807A
   Subsystem 1 - Serial number: 6332QSME6901114EB
   Subsystem 2 - Serial number: 6342QSME647F2130E
   Subsystem 3 - Serial number: 6352QSME667F4E3C1
   Subsystem 4 - Serial number: 6362QSME6A7F3502Q
   Subsystem 5 - Serial number: 63734SME597F15224
   Subsystem 6 - Serial number: 63834SME227D4D369
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90026110040394
   Coding: 0102042
   VCID: 27562B6396E56CBE72-8072
   Component: E0221           H02 0100
Address 17: Instruments (J285)       Labels:. 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 983 T    HW: 4L0 920 983 T
   Component: KOMBIINSTR.   H10 0209
   Revision: 00000000    Serial number: FLN05NU1C
   Coding: 2F56640400012600010400
   VCID: 438E9FF3C29DA09E4E-8016
Address 18: Aux. Heat        Labels: 4L0-910-105.lbl
   Part No SW: 4L0 910 105     HW: 4L0 815 071 G
   Component: Heizgeraet      H09 0140
   Revision: 0000000C    Serial number: 00000009021078
   Coding: 0000001
   VCID: 60C4707FB34BDB8673-8034
   Part No SW: 4F0 907 468 P    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0047
   Revision: LB200032    Serial number: 3200L11104009F
   Coding: 00CB03
   VCID: 3C7CE40FBF63DF660F-8068
   Component: J367-BDM  H07 0125
   Serial number: 00000000002799370661
                    Reset counter: 14
                    Mileage: 104954 km
                    Date: 2020.08.20
                    Time: 11:55:39
                    Bin. Bits:    10000
                    Voltage: 12.30 V
                    Count: 12
                    Bin. Bits:    10010
                    Time: 25.40 s
                    Reset counter: 7
                    Mileage: 104959 km
                    Date: 2020.08.26
                    Time: 19:39:30
                    Bin. Bits:    10000
                    Voltage: 12.70 V
                    Count: 10
                    Bin. Bits:    10010
                    Reset counter: 11
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 11:55:29
                    Bin. Bits:    10000
                    Voltage: 12.00 V
                    Count: 12
                    Bin. Bits:    10011
                    Time: 25.40 s
                    Reset counter: 226
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 12:01:24
                    Bin. Bits:    10111
                    Voltage: 11.80 V
                    Count: 7
                    Text: FFF86C2C00827102
                    Raw, Index/Key Err.: 248 108 044
                    Raw, Form. N/A: 000 130 113
Address 34: Level Control        Labels: 4L0-910-553.lbl
   Part No SW: 4L0 910 553 J    HW: 4L0 907 553 E
   Component: LUFTFDR.-CDC    H04 7860
   Revision: --H04001    Serial number: 15.1528-0143.2
   Coding: 0015510
   VCID: 3162C53BA821220EAC-8064
01577 - Turn-Off due to Over-Temp
                    Fault Status: 00100001
                    Reset counter: 0
                    Mileage: 104536 km
                    Date: 2020.08.15
                    Time: 16:28:28
                    Error Code: 68
Address 3D: Special Function        Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440     HW: 8K0 907 440
   Component: STS             H04 0040
   Revision: S0H04000    Serial number: 00000000029344
   Coding: 01010101000000000000000202
   VCID: 6BDE17534A8D88DED6-803E
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0361
   Revision:             Serial number: 0004000199518
   Coding: 011F06205061440004
   VCID: 489488DFFBBB83C69B-801C
01705 - Selection Switch for Mirror-Adjust (E48)
                    Reset counter: 253
                    Mileage: 104507 km
                    Date: 2020.08.13
                    Time: 19:32:06
                    Reset counter: 14
                    Mileage: 104954 km
                    Date: 2020.08.20
                    Time: 11:55:38
                    Reset counter: 11
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 11:55:32
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01421435130000
   Coding: 3809531
   VCID: 356AF12B5C490E2EF0-8060
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
                    Reset counter: 13
                    Mileage: 104954 km
                    Date: 2020.08.20
                    Time: 11:55:38
                    Reset counter: 10
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 11:55:34
   Part No SW: 4L0 035 223 J    HW: 4L0 035 223 G
   Component: BOSE G3 Q7    H03 0160
   Revision: CH003000    Serial number: 00000000021675
   Coding: 030000
   Shop #: WSC 17427 000 1048576
   VCID: 29522D5B40F15ACE64-807C
                    Fault Status: 00111011
                    Reset counter: 7
                    Reset counter: 11
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 11:59:54
                    Bin. Bits: 00000100
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H14 0100
   Revision:             Serial number: 00000000203153
   Coding: 0011101
   VCID: 5EB84E87893FED7641-800A
                    Reset counter: 11
                    Mileage: 105152 km
                    Date: 2020.09.02
                    Time: 11:55:00
                    Voltage: 12.200 V
                    Temperature: 20.0°C
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0361
   Revision:             Serial number: 0004000190654
   VCID: 47968BE3F6A58CBE92-8012
                    Reset counter: 14
                    Mileage: 104956 km
                    Date: 2020.08.24
                    Time: 17:35:36
                    Reset counter: 11
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 11:55:33
   Part No SW: 4G0 035 053 D    HW: 4G0 035 053
   Component: Radio U Basic H52 0094
   Revision: AB001007    Serial number: 496A 0B7633652
   Coding: 010003010000000000
   VCID: 1F4633830EB5A47E0A-804A
   Part No SW: 4L0 035 666 F    HW: 4L0 035 666 A
   Component: H-BN-EU       H51 0174
   Revision: --------    Serial number: 473AT0B7540291
   Coding: 010101060004D3EF01000315EF6300030000
   VCID: 3064C03F632B2B06A3-8064
   Subsystem 1 - Part No: 8R0 060 884 N
   Component: EUR 2011  1205
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0098
   Serial number: 9466AO0B0300792
   Subsystem 3 - Part No SW: 4L0 910 609     HW: 4L0 919 611 B
   Component: E0380 Bedient  H05 0060
   Serial number: 00000001766250
   Subsystem 4 - Part No: 8R0 060 961 A
   Component: CD-Database  2712
                    Reset counter: 11
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 11:59:45
                    Bin. Bits: 00000000 00001010
                    Bin. Bits: 00000000 00000000
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0361
   Revision:             Serial number: 0004000192786
   Coding: 010E06204061230004
   VCID: 468886E7F1AF95B669-8012
   Revision: --H05---    Serial number: 525PA8-J0Z428Y
   Coding: 1021001
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Component: ValeoHeckdeckel H56 0500
   Revision: --H56001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6CDC144F4F838FE6DF-8038
   Subsystem 3 - Serial number: RD26.01.11--H56001001A0377ÿ
   Subsystem 4 - Serial number: 1A0377ÿ
   Part No SW: 4L0 910 290     HW: 4L0 907 290
   Component: ILM HINTEN 2    H07 0080
   Revision: AAH07080    Serial number: 111894390-----
   Coding: 0000001
   VCID: 65CA616BAC69BEAE80-8030
                    Reset counter: 11
                    Mileage: 105155 km
                    Date: 2020.09.02
                    Time: 11:55:29
   Component: TSG HR        H11 0361
   Revision:             Serial number: 0004000192753
   Part No SW: 4L0 910 283 C    HW: 4L0 919 283 C
   Component: Parkhilfe 8-Kan H03 0500
   Revision: 00H03000    Serial number: 37331101702251
   Coding: 0221066
   VCID: 2A50D25785F751D66D-807E
End-------------------------(Elapsed Time: 03:35)--------------------------
Since we have a scan and relevant fault codes, moving from General VW/Audi Repair to New User section.
