Hi, I have a question about the information shown in an initial gateway installation list. I have seen several time where the gateway installation list shows ok like in this example "01-Engine -- Status: OK 0000" but when a complete scan was run there was a code in the engine control "
1 Fault Found: 10434 - Catalyst System; Bank 1 P0420 00 [096] - Efficiency Below Threshold". Is this normal function? Should I not trust the info displayed in the gateway installation list?
One more thing, I have noticed sometimes if I choose "clear all codes via can" sometimes when the gateway is re scanned the engine control code has not cleared (red). I have to manually go into the control unit and clear it. Is this a known issue?
Thanks, Shep
Thanks, Shep
Tuesday,15,September,2020,13:25:47:57829
VCDS Version: 20.4.2.0 (x64) HEX-NET CB: 0.4513.4
VIN: WAUWFAFL0AA037039 License Plate:
Mileage: 148140km-92049mi Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
72
VIN: WAUWFAFL0AA037039 Mileage: 148140km-92049miles
Address 01: Engine (DL0MA-CAEB) Labels:| 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 AL HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H15 0001
Revision: E1H15---
Coding: 010C010A190F0160
Shop #: WSC 45083 000 1048576
VCID: F9BAB78D7838374ED4-80AC
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8K0 927 158 J HW: 0B6 927 156
Component: 0B6 20TFSIUSA H05 0008
Revision: --H05---
Coding: 001012
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_TCMAL651 A01006
ROD: EV_TCMAL651.rod
VCID: BD32639D2C90CB6EB8-80E8
Part No SW: 8K0 907 379 CA HW: 8K0 907 379 AN
Component: ESP8 quattro H04 0010
Coding: 150D18
VCID: FAB8A881753E3C56DD-80AE
Part No SW: 8K0 907 064 DG HW: 8K0 907 064 DG
Component: BCM2 1.1 H02 0321
Coding: 090200
VCID: F8BCB2894B322E46AB-80AC
Subsystem 1 - Part No SW: 8T0 959 754 A HW: 8T0 959 754 A
Component: FBSAUDIB8 IDG H37 0060
Serial number: 0509000036545009
Component: J764 ELV MLB H37 0042
Serial number: 0209000049930014
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AQ HW: 8T1 820 043 AQ
Component: KLIMA 3 ZONEN H08 0160
Revision: C1000000 Serial number: 01140720091304
Coding: 64102000
VCID: 804CDA6913E2668693-80D4
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H25 0380
Revision: 10025001 Serial number: 00000000425377
Coding: 26001091063CAF010000080300003D0D0F1C460800010161000000
VCID: BC346E993F8AC2668F-80E8
Component: WWS 110709 H06 0070
Serial number: SWF09070116041
Coding: 00FD11
Component: RLS H04 0003
Serial number: 10539258
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000407090576
Subsystem 4 - Part No SW: 8K0 907 410 B HW: 8K0 907 410 B
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 H HW: 8K0 919 475
Component: PARKHILFE 4K H06 0050
Revision: 11001001 Serial number: 39940919422424
Coding: 200103
Shop #: WSC 06342 000 00000
VCID: BE3064912996D076A1-80EA
Part No SW: 8K0 959 655 H HW: 8K0 959 655 H
Component: AirbagVW-AU10 H37 0520
Serial number: 003EGD027F4V
VCID: C2C81061556EB496C5-8096
Subsystem 1 - Part No SW: 8K0 959 339 B HW: 8K0 959 339 B
Component: BF-Gewichtss. H01 0030
Serial number: 5810000R0900003VQ1
Serial number: 6334MSME4976153EM
Serial number: 6344MSME49754531C
Serial number: 6352QSME77311A3AJ
Serial number: 6362QSME7134222ED
Serial number: 63732SME2B323914Y
Serial number: 63832SME4132193CZ
Component: Lenks.Modul H16 0014
Revision: -------- Serial number: 90304IGF000HW
Coding: 000017
VCID: BD32639D2490CB6EB8-80E8
Part No SW: 8K0 920 980 M HW: 8K0 920 980 M
Component: KOMBIINSTR. H19 0253
Revision: 00100000 Serial number: BXM52HY69
Coding: 8B1611000300D705020000
Part No SW: 8T0 907 468 T HW: 8T0 907 468 K
Component: GW-BEM 4CAN-M H09 0101
Revision: EB700052 Serial number: 5200E0963081EE
Coding: 00C303
VCID: D2E820218D0E241675-8086
Subsystem 1 - Part No SW: 8K0 915 181 E HW: 8K0 915 181 E
Component: J367-BDM H06 0160
Serial number: 19083142230609
Reset counter: 48
Mileage: 148145 km
Date: 2020.09.14
Time: 14:13:35
Bin. Bits: 10000
Voltage: 11.80 V
Count: 10
Part No SW: 8K0 959 793 H HW: 8K0 959 793 D
Component: TSG FA H11 0306
Revision: Serial number: 0000009074764
Coding: 011C03204000410001
VCID: C5C20B7D4C4083AEE0-8090
Reset counter: 44
Mileage: 147557 km
Date: 2020.09.02
Time: 19:33:09
Revision: 00002001 Serial number: 0119910611
Coding: 0126023A207A441400B0020000000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719
Component: GTO BF H06 0050
Serial number: 00000000000000151855
Subsystem 3 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J245 PS133 H06 0041
Subsystem 4 - Part No SW: 8K0 959 591 A HW: 8K0 959 591
Component: J394 PS228 H06 0041
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 114
Reset counter: 4
Mileage: 118348 km
Date: 2018.07.27
Time: 06:45:26
02616 - Fuel Tank Cap; Unlock
Fault Frequency: 133
Reset counter: 8
Mileage: 118348 km
Date: 2018.07.27
Time: 08:38:28
Part No SW: 8K0 959 792 H HW: 8K0 959 792 D
Component: TSG BF H11 0306
Revision: Serial number: 0000009071697
VCID: C4C41679477ABAA6F7-8090
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0090
Revision: 00000003 Serial number: 10000000278940
VCID: B42446B917DA0A2647-80E0
Part No: 8K5 907 357
Coding: 0000004
Shop #: WSC 06334 000 00000
VCID: F7BEB1B5862C213EA2-80A2
Part No SW: 4F0 035 082 A HW: 4F0 035 082
Component: Radio U SIRIU H45 0021
Revision: AB001007 Serial number: 335GY097521359
Coding: 020000020100000001
VCID: 9D72831D8450AB6E98-80C8
02983 - Connection between Impedance Converter 1 and Window Antenna
Fault Status: 01101011
Reset counter: 82
Mileage: 118345 km
Date: 2018.07.26
Time: 17:17:55
Voltage: 13.50 V
02788 - Internal Communications Error
Reset counter: 162
Mileage: 123994 km
Date: 2019.01.04
Time: 15:56:51
Bin. Bits: 00000001
Part No SW: 8T1 035 664 A HW: 8T1 035 664 A
Component: H-BN-NA H41 0042
Revision: -------- Serial number: 490H/097513892
Coding: 010200010006A1EF01000B0E000000030000
Shop #: WSC 26097 444 11939
VCID: B6207CB101A6183679-80E2
Subsystem 1 - Part No: 8R0 060 884 F
Component: NAR 2009/2010 5304
Subsystem 2 - Part No SW: 4F0 919 604 HW: 4F0 919 604
Component: DU7 High H43 0306
Serial number: 9356GU091034908
Subsystem 3 - Part No SW: 8T0 919 609 F HW: 8T0 919 609 F
Component: E0380 Bedient H08 0100
Serial number: 00000000323119
Subsystem 4 - Part No: 8R0 906 961 A
Component: CD-Database 1293
Part No SW: 8K0 959 795 C HW: 8K0 959 795 C
Component: TSG HL H10 0306
Revision: Serial number: 0000101500020
Coding: 010C03204000210001
VCID: C2C810615D6EB496C5-8096
Part No SW: 8T0 907 441 C HW: 4L0 907 441 B
Revision: --H03--- Serial number: 525PA8-J9690UI
Coding: 1000007
Shop #: WSC 06435 000 00000
VCID: B83C7289CBB2EE466B-80EC
Component: TSG HR H10 0306
Revision: Serial number: 0000101499997
Fault Status: 01101000
Fault Frequency: 14
Reset counter: 73
Mileage: 135084 km
Date: 2019.11.09
Time: 16:19:42
End----(Elapsed Time: 01:55, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
