Gateway installation list shows ok but code stored in control unit
Shzeps
C?ID=11561
Hi, I have a question about the information shown in an initial gateway installation list. I have seen several time where the gateway installation list shows ok like in this example "01-Engine -- Status: OK 0000" but when a complete scan was run there was a code in the engine control "
1 Fault Found: 10434 - Catalyst System; Bank 1 P0420 00 [096] - Efficiency Below Threshold". Is this normal function? Should I not trust the info displayed in the gateway installation list?
One more thing, I have noticed sometimes if I choose "clear all codes via can" sometimes when the gateway is re scanned the engine control code has not cleared (red). I have to manually go into the control unit and clear it. Is this a known issue?
Thanks, Shep
Tuesday,15,September,2020,13:25:47:57829
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUWFAFL0AA037039   License Plate:
Mileage: 148140km-92049mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
          72
VIN: WAUWFAFL0AA037039   Mileage: 148140km-92049miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AL    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H15 0001
   Revision: E1H15---
   Coding: 010C010A190F0160
   Shop #: WSC 45083 000 1048576
   ASAM Dataset: EV_ECM20TFS0118K2907115AL 001001
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: F9BAB78D7838374ED4-80AC
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 J    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H05 0008
   Revision: --H05---
   Coding: 001012
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: BD32639D2C90CB6EB8-80E8
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 AN
   Component: ESP8 quattro  H04 0010
   Coding: 150D18
   VCID: FAB8A881753E3C56DD-80AE
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0321
   Coding: 090200
   VCID: F8BCB2894B322E46AB-80AC
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
   Serial number: 0509000036545009
   Serial number: 0209000049930014
   Component: KLIMA 3 ZONEN H08 0160
   Revision: C1000000    Serial number: 01140720091304
   Coding: 64102000
   VCID: 804CDA6913E2668693-80D4
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000425377
   Coding: 26001091063CAF010000080300003D0D0F1C460800010161000000
   VCID: BC346E993F8AC2668F-80E8
   Component: WWS 110709  H06 0070
   Serial number: SWF09070116041
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10539258
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000000407090576
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940919422424
   Coding: 200103
   Shop #: WSC 06342 000 00000
   VCID: BE3064912996D076A1-80EA
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EGD027F4V
   Coding: 303836354230303030304A55304C384B3053
   VCID: C2C81061556EB496C5-8096
   Subsystem 1 - Part No SW: 8K0 959 339 B    HW: 8K0 959 339 B
   Serial number: 5810000R0900003VQ1
   Serial number: 6334MSME4976153EM
   Serial number: 6344MSME49754531C
   Serial number: 6352QSME77311A3AJ
   Serial number: 6362QSME7134222ED
   Serial number: 63732SME2B323914Y
   Serial number: 63832SME4132193CZ
   Revision: --------    Serial number: 90304IGF000HW
   Coding: 000017
   VCID: BD32639D2490CB6EB8-80E8
   Part No SW: 8K0 920 980 M    HW: 8K0 920 980 M
   Component: KOMBIINSTR.   H19 0253
   Revision: 00100000    Serial number: BXM52HY69
   Coding: 8B1611000300D705020000
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0101
   Revision: EB700052    Serial number: 5200E0963081EE
   Coding: 00C303
   VCID: D2E820218D0E241675-8086
   Component: J367-BDM  H06 0160
   Serial number: 19083142230609
                    Reset counter: 48
                    Mileage: 148145 km
                    Date: 2020.09.14
                    Time: 14:13:35
                    Bin. Bits:    10000
                    Voltage: 11.80 V
                    Count: 10
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009074764
   Coding: 011C03204000410001
   VCID: C5C20B7D4C4083AEE0-8090
                    Reset counter: 44
                    Mileage: 147557 km
                    Date: 2020.09.02
                    Time: 19:33:09
   Revision: 00002001    Serial number: 0119910611
   Coding: 0126023A207A441400B0020000000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000151855
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS133  H06 0041
   Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J394 PS228  H06 0041
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Fault Frequency: 114
                    Reset counter: 4
                    Mileage: 118348 km
                    Date: 2018.07.27
                    Time: 06:45:26
02616 - Fuel Tank Cap; Unlock
                    Fault Frequency: 133
                    Reset counter: 8
                    Mileage: 118348 km
                    Date: 2018.07.27
                    Time: 08:38:28
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009071697
   VCID: C4C41679477ABAA6F7-8090
   Component: EPB Audi B8   H09 0090
   Revision: 00000003    Serial number: 10000000278940
   VCID: B42446B917DA0A2647-80E0
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: F7BEB1B5862C213EA2-80A2
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335GY097521359
   Coding: 020000020100000001
   VCID: 9D72831D8450AB6E98-80C8
02983 - Connection between Impedance Converter 1 and Window Antenna
                    Reset counter: 82
                    Mileage: 118345 km
                    Date: 2018.07.26
                    Time: 17:17:55
                    Voltage: 13.50 V
02788 - Internal Communications Error
                    Reset counter: 162
                    Mileage: 123994 km
                    Date: 2019.01.04
                    Time: 15:56:51
                    Bin. Bits: 00000001
   Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
   Component: H-BN-NA       H41 0042
   Revision: --------    Serial number: 490H/097513892
   Coding: 010200010006A1EF01000B0E000000030000
   Shop #: WSC 26097 444 11939
   VCID: B6207CB101A6183679-80E2
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Serial number: 9356GU091034908
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000323119
   Component: CD-Database  1293
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Revision:             Serial number: 0000101500020
   Coding: 010C03204000210001
   VCID: C2C810615D6EB496C5-8096
   Revision: --H03---    Serial number: 525PA8-J9690UI
   Coding: 1000007
   Shop #: WSC 06435 000 00000
   VCID: B83C7289CBB2EE466B-80EC
   Revision:             Serial number: 0000101499997
                    Fault Status: 01101000
                    Fault Frequency: 14
                    Reset counter: 73
                    Mileage: 135084 km
                    Date: 2019.11.09
                    Time: 16:19:42
End----(Elapsed Time: 01:55, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
iichel
Eindhoven, NB, NL
C?ID=284912
More often than not, the Clear All DTC command doesn't clear ABS errors either.
It can be, especially when the fault is flagged, "Intermittent - Not Confirmed" as this one is.
Try with Aggressive Mode un-checked and I expect it won't show up.
My interpretation: The ECU isn't confident enough that this fault is real to report that it has any faults to the the Gateway.
On many very recent cars, the ABS has become part of the OBD-II/EOBD system, and ABS faults will only clear with a generic OBD-II clear codes command. Unfortunately, this command requires functional rather than physical addressing, meaning that it will clear faults from the ECU and TCU as well.
Shzeps
C?ID=11561
Interesting, Thanks for the answers.
Shep
Shzeps
C?ID=11561
Is there any documentation on Aggressive Mode?
Shzeps
C?ID=11561
Yes, I have read thru the manual before (it's been a little while now) although it seemed as if a lot of the newer features were not described. Would you say all features and functions are up to date in the manual? So many great features, I would love to use all of them to the fullest including the toolbox.
Not 100%, no. Maybe 98%?
The Toolbox is not something we wrote. Our distributor in Denmark created it. :thanks:
