Golf Mk7 Steering Fault
LHSLTD
C?ID=271214
Have a 2018 Golf GTD in for a scan as the power steering is very heavy.
My scan is limited as my new Hex-Net isn't due to arrive until tomorrow or, more likely, Friday, so I scanned it with my existing Hex-Can and got the following:
Chassis Type  AU-VW37 (3Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 4B 52 5F A9
VIN: WVWZZZAUZJW124215   Mileage: 80776km-50191miles
44-Steering Assist -- Status: Cannot be reached 0100
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DGCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 HA HW: 04L 907 309 R
Component: R4 2.0l TDI H24 4010
Revision: B5H24---
Coding: 01190012034405082000
ASAM Dataset: EV_ECM20TDI01104L906026HA 004003
ROD: EV_ECM20TDI01104L906026HA_004.rod
   VCID: 70EFBEABABE43306E3-8024
17158 - Databus
U1123 00 [047] - Received Error Message
Mileage: 80776 km
                    Engine speed: 0.00 /min
Coolant temperature: 53 °C
Intake air temperature: 41 °C
Voltage terminal 30: 12.880 V
Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
26524 - No Communications with Power Steering Control Module
U0131 00 [047] - -
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:32
                    Engine speed: 790.00 /min
Normed load value: 35.7 %
Coolant temperature: 45 °C
Intake air temperature: 38 °C
Voltage terminal 30: 13.700 V
Cruise Control System (CCS): status-Bits 0-7: 7
                    selected gear-Bits 0-7: 0
5608 - No Communications with Steering Angle Sender (G85)
U0126 00 [047] - -
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:31
                    Engine speed: 794.00 /min
Normed load value: 35.3 %
Voltage terminal 30: 13.760 V
Part No SW: 5Q0 614 517 CQ HW: 5Q0 614 517 AC
Component: ESC H25 0423
Revision: 00000000 Serial number: 52787000000186
Coding: 01FA8AA1342209704779060140C82980512C90E26002947534605078C009430B00000012121212B835351919323200
ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 020BE4639548319605-8056
0166 - Steering angle sensor
B1168 31 [137] - No Signal
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:36
8238 - Databus
U1121 00 [137] - Missing Message
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:36
8242 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:36
16418 - Display for Tire Pressure Monitoring
C1146 02 [137] - Signal Failure
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:45
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0012010420211001100500000010102A
   VCID: 6DD1A7DFBCD6DEEEC8-8038
   Air quality sensor:
Part No SW: 5Q0 937 084 CP HW: 5Q0 937 084 CF
Component: BCM MQBAB M+ H36 0253
Serial number: 01001730701342
ROD: EV_BCMBOSCH_018.rod
   VCID: 081FF64BB3741BC65B-805C
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150618 042 0551
Serial number: 150724060126
Component: RLHS 047 0105
Serial number: S9Y17M10D30H21M23S07
   Coding: 00A8DD
   Serial number: 000000000ZY1728342FN
   Serial number: 00000000000071130542
555285 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:04:38
556053 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:04:39
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Serial number: 000308418617304
Coding: 0471051801
   VCID: 4B950947E28230DEB6-801E
13638913 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:05:01
13638914 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:05:01
13637426 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:05:01
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 2B00608159FFC728949C810560400600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
   VCID: 3E735093A130957621-806A
2101 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:45
                    Control Module temperature: 29 °C
Voltage terminal 15: 13.8 V
1031 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:45
2068 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:45
Part No SW: 5Q0 959 655 BJ HW: 5Q0 959 655 BJ
Component: AirbagVW21 005 0336
Serial number: 003VWR3GL0TX
Coding: 98CCC000000000005C0000CF008800000065
   VCID: 0919F34FA87E62CE44-805C
   Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169677E28101750098
   Coding: 333135
   Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169676E23101740256
   Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 002 810 17
Serial number: 357000000005C43CC82U
Subsystem 4 - Part No SW: ----------- HW: 480 003 010 17
Serial number: 35800000000CC729192R
Subsystem 5 - Part No SW: ----------- HW: 480 403 010 17
Serial number: 3510001C727FACA4E1AS
Subsystem 6 - Part No SW: ----------- HW: 480 400 311 17
Serial number: 3520001B927CABF4417I
Subsystem 7 - Part No SW: ----------- HW: 480 400 211 17
Serial number: 3550001AF27E04347262
1050112 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:50
Part No SW: 5Q0 953 507 FT HW: 5Q0 953 549 F
Revision: -------- Serial number: 02111708490014
Coding: 0400
   VCID: 0D11C75FDC167EEE68-8058
Part No SW: 5G1 920 791 A HW: 5G1 920 791 A
Component: KOMBI 407 3193
Coding: 27AD21002F80060001886B011401000000000000
   VCID: 2A5B6CC34DB809D66D-807E
16776978 - Databus
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:55
Part No SW: 3Q0 907 530 L HW: 3Q0 907 530 C
Component: GW MQB High 518 5323
Serial number: 20101710801928
Coding: 030100045F086800FB00027E080F00010001070000000000000000000000
ROD: EV_GatewNF_VW37.rod
   VCID: 387F468B8314AB46EB-806C
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H11 0040
Serial number: 29170002350430087423
   Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
   Serial number: 2674615704
131602 - Power Steering Control Module
U101D 00 [009] - No Communication
Reset counter: 168
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:58
                    Supply voltage: Terminal 30: 13.9 V
                    Terminal 15: On
Component: TSG FS 020 0041
Serial number: 211017EJL02494
Coding: 003F0220D001048000001000
   VCID: 43852167CAD2F89E4E-8016
Subsystem 1 - Part No SW: 5Q0 959 812 D HW: 5Q0 959 812 D
Component: FOND_FHSG_DRV 006 0007
Serial number: 00000000000017283003
   Coding: 0D0000
Address 44: Steering Assist
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Component: TSG BFS 020 0041
Serial number: 231017EJN01954
Coding: 003F0020DE01048000801000
   VCID: 428B2463D5C8F19645-8016
Subsystem 1 - Part No SW: 5Q0 959 811 D HW: 5Q0 959 811 D
Component: FOND_FHSG_PSG 006 0007
Serial number: 00000000000017127031
   Coding: 150000
Part No SW: 3Q0 035 874 C HW: 3Q0 035 874 C
Component: MU-S-ND-ER H41 0468
Serial number: VWZAZ2T1745398
Coding: 02731001FF00000051110101008808001F0502E601200000CF
ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 326B74A365684116D5-8066
Subsystem 1 - Part No SW: 5G6 919 605 B HW: 5G6 919 605 B
Component: ABT_Std-2_Nav H50 8130
   Serial number: VWZ6ZHT2990459
Subsystem 2 - Part No SW: 3G0 919 866 BC HW: -----------
Component: ECE1 2017/18 --- 0820
6696 - Instrument Cluster Control Module on Optical Bus
U10C0 00 [008] - No Communication
Reset counter: 208
Mileage: 80776 km
Date: 2020.09.14
                    Time: 00:07:09
                    Voltage terminal 30: 11.4 V
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 170908200388
   VCID: 6BD5A9C782C2D0DED6-803E
End-------------------------(Elapsed Time: 05:30)--------------------------
Guy was just driving along in the rain and the steering went heavy. I am assuming Power Steering Module failure or Can Bus issue, but will rescan when my Hex Net arrives. Just wondering if anyone could shine a light on where to start looking or checking in the meantime.
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
HEX-NET or HEX-V2 would be nice, but on a Golf 7 facelift GTD I think you're only missing 4B and the two or four headlight controllers behind it.
Rain + 44 missing == electric power steering rack is feeling very sad and quiet today.
Check fuses first. I don't have my docs handy but EPS draws from one of the very few xxxtra big-ass fuses (Murica!) in the under-bonnet fuse panel near the battery. If those check out good, check ground, power, and CAN bus at the rack, in that order. If it did blow the fuse, water plus blown fuse equals inspect everything anyway, that's a big fuse and it blew for a big reason. Look for missing fuse panel cover, chafed or gouged insulation on the power lead allowing it to ground out, etc.
Wanted to insert Jef's holy trinity pic here but couldn't immediately find it. Summon @Jef for meme support? :confused:
