DRL and windows
danbenhamo
Pirate
Israel
hi i was doing the US Parking Lights but its work when the lights position is on auto and at night time only. i want to make it work also at day time in auto position?
i was using this guide pic down
and also how can i program so when i lock the car the windows will close automatically without holding the bottom?
danbenhamo
Pirate
Israel
hi here is my auto-scan
Thursday,17,September,2020,17:04:26:00009
VCDS Version: 20.4.2.0
VIN: WVWZZZ3CZFE519549   License Plate:
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 2B 42 44 52 5F 6C
VIN: WVWZZZ3CZFE519549   Mileage: 102133km-63462miles
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0003
   Revision: --H13---
   Coding: 092500122424050B3000
   Shop #: WSC 05311 115 00300
   ASAM Dataset: EV_ECM18TFS0203G0906264 001006
   ROD: EV_ECM18TFS0203G0906264_VW48.rod
   VCID: 65C104936461CFAE80-8030
14916 - Catalyst System; Bank 1
          P0420 00 [096] - Efficiency Below Threshold
15187 - Park/Neutral Switch Input Circuit
          P0850 00 [096] - Open or Short to Plus
   Part No SW: 0CW 300 042 H    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005005    Serial number: CU501504055232
   Shop #: WSC 05311 115 00083
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 3B7582EBB265A95E06-806E
   Part No SW: 3Q0 907 379 Q    HW: 3Q0 907 379 F
   Component: ESC           H42 0610
   Revision: 00000000    Serial number: 61175000007522
   Coding: 0EEC6A8F34212B75077C060441CC4970562CD4E0608292F10042F078C209
   Shop #: WSC 00015 115 00001
   VCID: 489FED27F3B3F2C69B-801C
16401 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 53
                    Mileage: 101620 km
                    Date: 2020.08.27
                    Time: 16:11:35
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0709
   Revision: 00026000    Serial number: 0368085086
   Coding: 000F0F0703
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 397998E3B8599B4E14-806C
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 80
                    Mileage: 102089 km
                    Date: 2020.09.16
                    Time: 14:06:06
   Part No SW: 5G0 907 044 AG    HW: 5G0 907 044 AG
   Revision: 00001K10
   Coding: 11020004200100002015500012101802
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6CD771B7878BFEE6DF-8038
   Geber fr Kהltemitteldruck/Kהltemitteltemperatur:
   Air quality sensor:
328452 - Motor for Rear Temperature Flap
          B108E 71 [008] - Actuator stuck
                    Reset counter: 73
                    Mileage: 98831 km
                    Date: 2020.07.05
                    Time: 07:55:46
                    Voltage terminal 30: 14.2 V
                    Outside air temperature: 26.5 °C
                    Interior temperature: 27.4 °C
                    Rear temperature flap: actual value: 58
                    Rear temperature flap: actual value: 15.5 %
                    Rear temperature flap: specified value: 19
328455 - Position Sensor for Rear Temperature Flap Motor
          B1096 15 [008] - Open or Short to Plus
                    Reset counter: 53
                    Mileage: 101435 km
                    Date: 2020.08.19
                    Time: 14:45:14
                    Voltage terminal 30: 12.4 V
                    Outside air temperature: 35.5 °C
                    Interior temperature: 0.0 °C
                    Rear temperature flap: actual value: 24
                    Rear temperature flap: actual value: 0.0 %
329988 - Motor for Defroster Flap
          B1090 71 [008] - Actuator stuck
                    Reset counter: 77
                    Mileage: 102084 km
                    Date: 2020.09.14
                    Time: 20:55:31
                    Voltage terminal 30: 14.1 V
                    Outside air temperature: 32.0 °C
                    Interior temperature: 27.1 °C
                    Defroster flap: actual value: 0.0 %
                    Defroster flap: actual value: 233
                    Defroster flap: specified value: 19
          B10CD 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 80
                    Mileage: 102085 km
                    Date: 2020.09.15
                    Time: 23:21:35
                    Voltage terminal 30: 11.4 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 1
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 086 BB    HW: 5Q0 937 086 BB
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580104150266
   Coding: 00011842C24102FF43E04004000007081880000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7BF542EBF2E5695E46-802E
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    150324  042 0607
   Serial number:         150327213402
   Component: RLHS  037 0059
   Serial number: S4Y15M05D04H15M56S37
   Coding: 96A8DD
   Subsystem 3 - Part No SW: 3G0 941 633     HW: 3G0 941 633
   Serial number: 03 03 2015  00000703
9 Faults Found:
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [008] - Open or Short to Plus
                    Reset counter: 80
                    Mileage: 102045 km
                    Date: 2020.09.09
                    Time: 19:07:16
8458 - Bulb for Right DRL
          B121E 15 [008] - Open or Short to Plus
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [008] - Open or Short to Plus
                    Reset counter: 80
                    Mileage: 102089 km
                    Date: 2020.09.16
                    Time: 16:24:56
9994 - Bulb for Right Parking Lamp
          B12E9 15 [008] - Open or Short to Plus
                    Reset counter: 70
                    Mileage: 102045 km
                    Date: 2020.09.09
                    Time: 19:07:19
8714 - Bulb for Left Fog Lamp
          B121F 15 [008] - Open or Short to Plus
                    Fault Frequency: 15
                    Reset counter: 70
                    Mileage: 101134 km
                    Date: 2020.08.13
                    Time: 14:14:54
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [008] - Open or Short to Plus
                    Reset counter: 70
                    Mileage: 102045 km
                    Date: 2020.09.09
                    Time: 19:07:16
9738 - Bulb for Left Parking Lamp
          B12E8 15 [008] - Open or Short to Plus
                    Reset counter: 80
                    Mileage: 102045 km
                    Date: 2020.09.09
                    Time: 19:07:19
8970 - Bulb for Right Fog Lamp
          B1220 15 [008] - Open or Short to Plus
                    Fault Frequency: 187
                    Reset counter: 70
                    Mileage: 95105 km
                    Date: 2020.04.24
                    Time: 06:44:33
204290 - Remote key 1
          B1479 18 [008] - Current Too Low
                    Reset counter: 77
                    Mileage: 95102 km
                    Date: 2020.04.23
                    Time: 13:21:57
   Part No SW: 5Q0 919 294 H    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0053
   Revision: --------    Serial number: 39391511200597
   Coding: 0071251011
   VCID: 408FF507DB83CA8653-8014
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2P7WEZDT
   Coding: 88CCC000000000005C0000CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 020B3F0F950F189605-8056
   Subsystem 1 - Part No SW: -----------    HW: 454 001 804 15
   Serial number: 3576U000000612E44411
   Subsystem 2 - Part No SW: -----------    HW: 454 001 804 15
   Serial number: 3586U000000D31F4441B
   Subsystem 3 - Part No SW: -----------    HW: 454 802 004 15
   Serial number: 3516RCAA67606000000D
   Subsystem 4 - Part No SW: -----------    HW: 454 802 004 15
   Serial number: 3526RED6F7706000000P
   Subsystem 5 - Part No SW: -----------    HW: 454 802 504 15
   Serial number: 3556V05235A06000000
   Part No SW: 3Q0 953 521     HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20150412400393
   Coding: 0010
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 6DD17CB3BC91F7EEC8-8038
   Part No SW: 3G0 920 740     HW: 3G0 920 740
   Component: KOMBI         209 4311
   Coding: 03A501182380000800082A001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009043
   VCID: 60CF15877B43AA8673-8034
   Part No SW: 5Q0 907 530 AB    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2203
   Revision: --------    Serial number: 01051510802058
   Coding: 030300046F085900EF0002481C0F00010001070000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 71E960C3A0A9130EEC-8024
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29150000746970085155
   Coding: 29FFFF
   Serial number: 9217866403
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 15000078267006
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   Serial number: 140415BDD0017A
   Coding: 00350B20D000020000001000
   VCID: 428BFF0FD58FD89645-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 E    HW: 5Q4 959 812 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001322952
65608 - Lamp for Ambient Speaker Illumination
          B13C8 01 [008] - Electrical Failure
                    Reset counter: 61
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000223877
   Coding: 01000010005000
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   Serial number: 170415BD91615A
   Coding: 00350120DC00020000001000
   VCID: 4189F003D089C38E5C-8014
   Subsystem 1 - Part No SW: 5Q4 959 811 E    HW: 5Q4 959 811 E  Labels: 5QX-959-81X-V1.CLB
   Serial number: 00000000000001329235
   Coding: 090000
   Part No SW: 3Q0 035 824     HW: 3Q0 035 824
   Component: MU-S--ER      H10 0138
   Serial number: VWZAZ2R0105627
   Coding: 02840100FF00000011110001000938001F0100840120010000
   ASAM Dataset: EV_MUStd4CTSAT 001018
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 6ADB77AF8D7FE0D6AD-803E
   Subsystem 1 - Part No SW: 3G0 919 605 B    HW: 3G0 919 605 B
   Component: ABT_Std-2  H44 1017
   Serial number: VWZ8Z9RD70071P
   Part No SW: 5Q0 907 556     HW: 5Q0 907 556
   Component: Areaview 2    H11 0329
   Serial number: C854706JG001084
   Coding: 01840101E20F20000000400C
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 003013
   ROD: EV_CamSysRVAV2ARCE2MQBAB_003_VW37.rod
   VCID: 76E353DFC9C7343639-8022
End-------------------------(Elapsed Time: 05:06)--------------------------
siLc
Tallinn, Estonia
C?ID=330192
Admap of module 09 is also needed for the whole picture.
  • Agree
dan: Hi.
You don't say what type of turn signal lights are fitted to the car - but I would caution against this tweak if the vehicle has incandescent lamps. To explain why it's NOT a good idea to operate US Parking Lights on a RoW MQB vehicle with incandescent lamps, I must first apologize for launching into technical speak.
Think about how the turn signal light works; the blinker function has what design engineers call a "50% duty cycle" - which simply means that the lamp is in the OFF state for 50 % of the time as it flashes. While the flashing function is intended to be a visual emphasis, this OFF time has an important consequence for the design of the electrical equipment in the blinker circuit.
Because of the 50% OFF time, the "effective" electrical current (let's call this "I") in the blinker lamp is reduced to 50%. Now, the formula that defines how much heat is generated by the blinker lamp = (IxI) x R watts -where R=the resistance of the lamp. This heating is power that is dissipated by the blinker lamp and it mostly appears on the lamp holder at the base of the light (i.e. the metal bits).
I hope that you are following my tortured prose thus far! So - now think about what happens when you ask the blinker lamp to operate the US Parking Light function. Well..... what happens is that you force the lamp to operate @ 100% duty cycle - meaning that you effectively double the electrical current in the circuit. Because of the power dissipation formula above, this doubling of "I" means that the heating effect is quadrupled.
Hence, for the US Parking Light tweak - the lamp base must carry 4 x times the power of it's designed capacity - not a good idea for incandescent lamps!!!
PS: you can make the US Parking Light operate ALL THE TIME that the ignition is switched-on, but I don't believe that you can make " it work also at day time in [only] auto position".
how can i program so when i lock the car the windows will close automatically without holding the bottom [button?]?
It's normally done like this:
05 - Acc/Start Auth.
Coding - 07
Long Coding Helper
Go to Byte 2
Enable Bit 4 "Locking for door slamming active"
