2013 C7 A6 3.0T AC stopped working plus other codes
Tareq
C?ID=369848
Hi All,
Sorry if i'm being a noob.
My AC went out a couple of days ago, so I did a scan and was surprised with the number of codes that came up. Could you please let me know what these codes mean and how bad is my situation? CEL was neveron, Thermostat and PSV Valve were replaced last year by an Audi dealer and the harmonic balancer was replaced a couple of months ago by a local mechanic.
Tuesday,15,September,2020,19:20:12:01949
VIN: WAUGGAFC3DN131124   License Plate: TAREQ
Mileage: 215371km-133825mi   Repair Order:
Chassis Type: FC-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 3C 42 44 46 47 52 53
          55 56 5F 62 6C 72 8F 90
VIN: WAUGGAFC3DN131124   Mileage: 215371km-133825miles
Address 01: Engine (J623-CTUA)       Labels: None
   Part No SW: 4G0 907 551 D    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0006
   Revision: --H07---
   Coding: 0A2A0032052601060000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30TFS0214G0907551D 001007
   ROD: EV_ECM30TFS0214G0907551D.rod
   VCID: 2A0D036AAC7F508B2C7-807E
20136 - PCV Valve Malfunction
          P052E 00 [109] - -
                    Fault Frequency: 28
                    Mileage: 210743 km
                    Date: 2020.06.23
                    Time: 15:12:49
                    Engine speed: 705.00 /min
                    Normed load value: 11.0 %
                    Coolant temperature: 94 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 14.218 V
                    Engine speed: actual: 704 /min
                    MAF_ENVD: 119.83529 mg/stroke
                    Coolant temperature (unfiltered): 72.75 °C
                    Engine: operating status: IS
                    Engine load: 10.937500 %
                    Vehicle speed: actual: 0 km/h
   Part No SW: 4G1 927 158 A    HW: 0BK 927 156 AM
   Component: 0BK 30TFSIUSA H16 1006
   Revision: --H16---
   Coding: 000002
   VCID: 2D0708769D9147B3C95-8078
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 44A78F0122E5F1805B00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 3635271A68C7046BB8F-8062
0605 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 77
                    Mileage: 214631 km
                    Date: 2020.09.05
                    Time: 12:54:28
                    VzRef: 55
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 29
                    Uz: B8
0630 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 77
                    Mileage: 214630 km
                    Date: 2020.09.05
                    Time: 12:52:46
                    VzRef: 5A
                    Bit Info 1: 00
                    Bit Info 2: 40
                    Bit Info 3: 26
                    Bit Info 4: 1F
                    F-Path: 01
                    F-Type: 2D
                    Uz: B8
   Part No SW: 4H0 907 064 CR    HW: 4H0 907 064 CR
   Component: BCM2 2.0      H33 0433
   Coding: 0DA82F46000000000000
   VCID: 7BA3F62E13E51903071-802E
   Serial number: 2313000028337002
Address 08: Auto HVAC (J255)       Labels:| 4G0-820-043-2Z.clb
   Part No SW: 4G0 820 043 AH    HW: 4G0 820 043 AH
   Component: KLIMA 2 ZONEN H11 0086
   Serial number: 15031300111094
   Coding: 6681201849
   ASAM Dataset: EV_AirCondiBasisUDS 002044
   ROD: EV_AirCondiBasisUDS_002.rod
   VCID: 6597B05685E1BFF3C15-8030
0387 - Function Restriction due to Faults in Other Modules
          U1113 00 [009] - -
          [Steuergerät für Bordnetz: Bitte Fehlerspeicher auslesen]
                    Reset counter: 37
                    Mileage: 214641 km
                    Date: 2020.09.07
                    Time: 15:29:27
                    Voltage terminal 30: 11.69 V
                    Outside air temperature: 30.0 °C
                    Engine speed: 1443 /min
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001527983
   Coding: 06002011063C8FE08F01088380003908CF9CD208A6090221000004406000
   VCID: 6FBBD27E579D75A3BB9-803A
   Component: WWS57X 130308  H36 0080
   Serial number:         130309104927
   Coding: 0045F7
   Serial number: 21089138
   Coding: 02006D
   Subsystem 3 - Part No SW: 4G0 941 531 D    HW: 4G0 941 531 D
   Component: E1 - LDS  H07 0044
   Serial number: 01 03 2013  00000574
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R57QB02
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 71F80B96000000000001
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 161
                    Mileage: 210698 km
                    Date: 2020.06.22
                    Time: 21:25:00
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 37
                    Mileage: 214641 km
                    Date: 2020.09.07
                    Time: 15:29:00
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061307101612
   Coding: A8C305
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD40641296353ADD-8024
   Part No SW: 4G0 959 655 A    HW: 4G0 959 655 A
   Component: Airbag10.43   H33 0033
   Revision: --------    Serial number: 003D8002VFWI
   Coding: 303234373131303030314A55304C34473053
   VCID: 33331E0E7BB511439F1-8066
   Component: BF-Gewichtss.  H11 0046
   Serial number: 6940000Y130000RZVG0.
   Serial number: 3575HRB40611SEBQ5P3R
   Serial number: 3585HRB404V1TEI481GY
   Serial number: 3515JRB401G50FSM79FL
   Serial number: 3525JRB401A50FFIOH6F
   Serial number: 3554VRB400K50F3CA9UM
   Serial number: 3564VRB401650DLMAP4Q
   Part No SW: 4H0 953 568 H    HW: 4H0 953 568 H
   Revision: --------    Serial number: 90372MCE001KH
   Coding: 000434
   VCID: 382929226253F21BAA3-806C
   Subsystem 1 - Part No SW: 4H0 951 528 E    HW: 4H0 951 528 E
   Serial number: 10 10 2012  11235115
   Part No SW: 4G8 920 983 E    HW: 4G8 920 983 E
   Component: TBenUsa       H79 0515
   Revision: 28460208    Serial number: 658110313596029
   Coding: 03EF09040B41D705020400
   ASAM Dataset: EV_RBD4K 004046
   ROD: EV_RBD4K_AU57.rod
   VCID: 372B2A1E6FCDFD63A39-8062
   Part No SW: 4G0 907 468 AC    HW: 4G0 907 468 AC
   Component: J533--Gateway H12 0037
   Revision: --------    Serial number: 00000000868061
   Coding: 00CD073000
   ASAM Dataset: EV_GatewPkoUDS 001018
   Serial number: 0719060203
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 130115000000000006E5
   Component: MEM-FS        H03 0154
   Revision: AA000000    Serial number: 00000053357474
   VCID: 77ABEA1E2FCD3D63639-8022
   Part No SW: 4G0 907 637 K    HW: 4G0 907 637 F
   Component: SARA 6D       H02 0056
   Revision: --------    Serial number: EJ1BPA8202ZSZI
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0050
   Revision: 00H03000    Serial number: 6PZ 010 287-03
   Coding: 0000001
   VCID: 3039110286232A5BE23-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H03 0050
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F19.03.1300H03000AMS15803ÿ
   Subsystem 4 - Serial number: S15803ÿ
   Component: TSG FA        H03 0507
   Coding: 011F17005E00628002000012
   VCID: 47CB5ADE1FAD8DE3D39-8012
   Component: RCEPS         H36 0010
   Revision: 00001000    Serial number: 0028305967
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   VCID: 323D1B0A84AF184B947-8066
   Revision: 00002001    Serial number: 0303502817
   Coding: 01060E3800FE408582B0080402050E070000000000000000000000000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000136058
   Subsystem 3 - Part No SW: 4G8 959 591     HW: 7P0 959 591 C
   Component: J245 PS40.039  H01 0008
   Serial number:     WOO20774161
   Coding: 101F00
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 161
                    Mileage: 210714 km
                    Date: 2020.06.22
                    Time: 21:44:48
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 161
                    Mileage: 210714 km
                    Date: 2020.06.22
                    Time: 21:45:46
02902 - Lamp for Brake / Blink / Parking 2; Right (M73)
                    Fault Status: 00101100
                    Reset counter: 99
                    Mileage: 210731 km
                    Date: 2020.06.23
                    Time: 14:49:51
02901 - Lamp for Brake / Blink / Parking 2; Left (M72)
                    Fault Frequency: 242
                    Reset counter: 97
                    Mileage: 210752 km
                    Date: 2020.06.23
                    Time: 15:45:41
   Revision: CJ007001    Serial number: 00000000039815
   VCID: 1D67D8B6EDB1B733595-8048
   Component: TSG BF        H03 0507
   Coding: 011F17005E00628002000002
   VCID: 46D557DA18A794EB28F-8012
   Part No SW: 4H0 907 801 F    HW: 4H0 907 801 A
   Component: EPB-4         H03 0013
   Revision: --------    Serial number: 00000000621009
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2B03066EA3854983D71-807E
   Part No SW: 4H0 907 357 B    HW: 4H0 907 357 B
   Component: ....LWR12.... H02 0010
   Serial number: 130316-0002-121
   Coding: 1221A6101002A500
   ROD: EV_HeadlRegulBasic.rod
   Part No SW: 4G0 035 082 E    HW: 4G0 035 082
   Component: Radio U SIRIU H60 0121
   Revision: AB001007    Serial number: 156CR0D7705013
   Coding: 020007010000000001
   VCID: 221DEB4AD4CF88CB647-8076
   Part No SW: 4G0 035 746 D    HW: 4G0 035 746 B
   Component: H-BNT-NA      H50 0622
   Revision: --------    Serial number: 194C$0D7526913
   Coding: 050200000003E2EF5712DF1E00000003100001000300000000
   VCID: 2809F962B2F3629B3A3-807C
   Subsystem 1 - Part No: 8R0 060 884 BA
   Component: NAR 2013  0703
   Subsystem 2 - Part No SW: 4G0 919 605 C    HW: 4G0 919 605 C
   Component: DU8 C7 SV  H43 0021
   Serial number: AUZ8ZDDD000VVTX
   Subsystem 3 - Part No SW: 4G1 919 610 C    HW: 4G1 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349MCE000JB
   Component: CD-Database  4949
                    Fault Frequency: 15
                    Reset counter: 58
                    Mileage: 215340 km
                    Date: 2020.09.15
                    Time: 18:27:07
                    Bin. Bits: 00000000 00001000
                    Bin. Bits: 00000000 00000000
                    Bin. Bits: 00000000 00010000
                    Fault Status: 00101011
                    Reset counter: 72
                    Mileage: 214121 km
                    Date: 2020.08.24
                    Time: 01:48:30
                    Voltage: 13.90 V
01524 - Antenna for Telephone
                    Fault Frequency: 44
                    Reset counter: 75
                    Mileage: 210698 km
                    Date: 2020.06.22
                    Time: 21:28:48
                    Voltage: 13.80 V
   Component: TSG HL        H03 0507
   Coding: 010F17004000628002000002
   VCID: 49CF5CE609B97B93C5D-801C
Address 6C: Back-up Cam.        Labels: 4H0-907-441.clb
   Part No SW: 4G0 907 441 B    HW: 4H0 907 441
   Component: SG Rueckfahrkamera  0061
   Revision: --H06---    Serial number: 525 PA8J32G3A0
   Coding: 1080004
   VCID: 2615F75AB4E774EB08F-8072
   Component: TSG HR        H03 0507
   Coding: 0006E008031F0300070308014244CA010000
   ASAM Dataset: EV_RGS_L 002004
   ROD: EV_RGS_L_VW51.rod
   VCID: 313F140681A92353EDD-8064
   ASAM Dataset: EV_RGS_R 002004
   ROD: EV_RGS_R_VW51.rod
End----(Elapsed Time: 02:25, VBatt start/end: 12.1V/12.1V. VIgn 12.0V)-----
   Revision: --H07---
          P052E 00 [039] - -
                    Mileage: 215371 km
                    Date: 2020.09.15
                    Time: 19:25:22
                    Engine speed: 702.00 /min
                    Coolant temperature: 93 °C
                    Intake air temperature: 63 °C
                    Voltage terminal 30: 13.609 V
                    Engine speed: actual: 672 /min
                    MAF_ENVD: 108.94117 mg/stroke
                    Coolant temperature (unfiltered): 93.00 °C
Readiness: 1110 1101
   Revision: --H16---
   Coding: 000002
   Coding: 6681201849
          U1113 00 [009] - -
                    Reset counter: 59
                    Mileage: 215371 km
                    Date: 2020.09.15
                    Time: 19:20:51
                    Voltage terminal 30: 12.12 V
                    Outside air temperature: 25.5 °C
                    Engine speed: 0 /min
   Coding: 0045F7
   Coding: 02006D
                    Reset counter: 59
                    Mileage: 215371 km
                    Date: 2020.09.15
                    Time: 19:20:00
            014 - Defective
                    Reset counter: 59
                    Mileage: 215371 km
                    Date: 2020.09.15
                    Time: 19:20:00
   Coding: A8C305
   Coding: 000434
   Coding: 00CD073000
   Voltage stabilizer:
   ROD: EV_SARA2.rod
   Coding: 0000001
   Coding: 101F00
                    Reset counter: 99
                    Mileage: 215371 km
                    Date: 2020.09.15
                    Time: 19:23:44
                    Reset counter: 59
                    Mileage: 215371 km
                    Date: 2020.09.15
                    Time: 19:20:54
   Coding: 1080004
End----------(Elapsed Time: 02:17, VBatt start/end: 14.0V/14.3V)-----------
Jef
HQ
Thank you for posting the full Auto-Scan! :thumbs:
So the HVAC module itself is fine, a "Function Restriction" code is basically saying "I can't do my job because some one else isn't doing their job", and we are given a clue:
Using my Google-Foo, this translates to Control unit for on-board power supply: Please read out fault memory. So we take a peak into the Central Electronics (J519) and we find this:
014 - Defective
Indeed, if that ain't good, AC is a no-go. As I recall, you will find this G395 sensor on the left side of the condenser. Unplug it and verify you have power on /1 and ground on /3. /2 will be a violet/white wire that is data. Locate the Garage Door module (J530) behind the Audi badge in the grill, unplug said module and T4r/2 is that same violet/white wire. Ohm test said wire from J530 to G395 and it should be a dead short, thus showing the data wire for the G395 is good.
If wiring checks out good for the G395, then replace sensor. It can be "hot swapped" without having to pull down the AC charge, there is a ball seat valve that seals off as you remove it. I would suggest to only purchase items with electrical connectors on them from the dealer.
siLc
Tallinn, Estonia
C?ID=330192
Indeed. Though beware, some refrigerant pressure will still be present behind the sensor - when unscrewing, it will make a whizzing sound and startle you, unless you expect it.
Tareq
C?ID=369848
014 - Defective
Thank you. you were right, it was the Sensor and it took me less than 5 minutes to replace
Tareq
C?ID=369848
Thanks, I would've thought that I broke something if I wasn't ready for that pop
