2013 NMS Passat TDI Highline (Canada) Adaptive Cruise Control Retrofit Help
nms_TDI_guy
Calgary, AB, Canada
C?ID=278050
Hi there I am currently working on retrofitting ACC Adaptive Cruise Control to my 2013 Passat TDI Highline. I have obtained the correct ABS Module 1K0 907 379 CC as well as the Adaptive Cruise Control Sensor 561 907 561 B. I believe I have most of the wiring figured out extended CAN High and Low (pins 7 and 17 If I recall Correctly), Ground, Pos to fuse box and fifth wire to Cruise control arm. My question is once I have the new sensor and abs module in will I need ODIS with GECKO access to enable Adaptive Cruise Control or can this be enabled using my VCDS Cable. I have attached my Auto Scan my CAN Gateway was upgraded to allow for 5F support and has support for Extended Gateway operation. If I am missing anything else let me know.
Tuesday,15,September,2020,15:32:23:45812
VCDS Version: 20.4.2.0 (x64)
VIN: 1VWCN7A34DC126203   License Plate: CCT0919
Mileage: 92940km-57750mi   Repair Order:
Chassis Type: A3-VW41 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 36 42 44 46 47 4F 52 5F
          62 72
VIN: 1VWCN7A34DC126203   Mileage: 92940km-57750miles
   Component: R4 2.0l TDI   H24 9982
   Revision: 71H24---    Serial number:
   Coding: 001D0012842400008000
   Shop #: WSC 99918 999 00000
   ROD: EV_ECM20TDI01103L997009H.rod
   VCID: 3B5BC822B2D7545E06-806E
8834 - Cylinder 1 Injection Timing
          P020A 00 [096] - -
8836 - Cylinder 3 Injection Timing
          P020C 00 [096] - -
8837 - Cylinder 4 Injection Timing
          P020D 00 [096] - -
8835 - Cylinder 2 Injection Timing
          P020B 00 [096] - -
8843 - Torque Difference Cylinder 2
          P1005 00 [096] - Limit Value Exceeded
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 9436
   Revision: 05651213    Serial number: 00001301121433
   Shop #: WSC 09003 957 00200
   VCID: 2469135EE7690BA657-8070
   Revision: 00H31001
   Coding: C54BC0F549240000A30D03E4921C0042271000
   VCID: 7DDF063AE4439A6E78-8028
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0196860023
   Coding: 130C0C
   Shop #: WSC 00062 444 00255
   VCID: 3449E31E9F899B26C7-8060
   Part No SW: 561 907 044 R    HW: 561 907 044 R
   Component: Climatronic   H03 0405
   Revision: 00001K01
   Coding: 0010001012
   VCID: 266D09565955F9B649-8072
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200EB8882B2AD4088802013600814800F1008645A005B064806000BC70
   Shop #: WSC 12345 123 61029
   VCID: 74C9231ED709DB2607-8020
   Component: RLS 240113 05  54  0403
   Coding: 22300A
   Serial number: 003MWM018S6-
   Coding: 00004D4A
   Shop #: WSC 02451 003 1048576
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 75CF1E1AD473C22E30-8020
   Serial number: 6940000Y130000SBS702
   Coding: 303047
   Serial number: 3572MSME21681378ZZZT
   Serial number: 3582MSME64701378ZZZU
   Serial number: 3516KSME6A605422ZZZO
   Serial number: 3526KSME6B544F22ZZZ$
   Serial number: 3556LSME22573B21ZZZR
   Serial number: 3566LSME0F433B21ZZZY
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20130131200337
   Coding: 001A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 7DDF063AEC439A6E78-8028
   Coding: E30000
   Part No SW: 561 920 870 C    HW: 561 920 870 C
   Component: KOMBI         H07 0705
   Coding: 331E01
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
   VCID: 191732AA182B464EF4-804C
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1663
   Revision:   H51       Serial number: 03101300F12781
   Coding: 461002
   Shop #: WSC 00132 132 00054
   VCID: 72C52506AD1DD51615-8026
   Component: IMMO          H07 0705
   Coding: 000007
   VCID: 6AF53D668DCD1DD6AD-803E
   Revision: 00000000    Serial number: 13000005151003
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X_VW01.rod
   VCID: 3041EF0E6B91A706A3-8064
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000052193037
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: 60E15F4E73F1578673-8034
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0006430394
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   VCID: 1C192BBE17193366EF-8048
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811 B    HW: 561 959 811 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  006 5470
   Serial number: 14102630130318085240
   Coding: 800000
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: 3753D41246FF703EE2-8062
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0037617
   ROD: EV_AudioVerst10KanalSTT3_VW41.rod
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
   Component: EZE_2         H51 1663
   Coding: 01030108
   VCID: 6FC32C72BE2FF8FEFA-803A
   Serial number: 53388786011230801531
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0006395584
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 1D1F26BA0C033A6E18-8048
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812 B    HW: 561 959 812 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  006 5470
   Serial number: 14202631130325212023
   Coding: 800000
   Part No SW: 5C0 035 684     HW: 5C0 035 684
   Component: MU-S-NS-US    H22 0245
   Serial number: VWZAZ2S0016993
   Coding: 02840102AA00000051220003001808001F0100D400200105C6
   ROD: EV_MUStd4CTSAT_VW37.rod
   VCID: 62E5554675FD459665-8036
   Subsystem 1 - Part No SW: 3G0 919 866 B    HW: -----------
   Component: NAR 2015/16  --- 0220
          B201A 00 [009] - -
                    Reset counter: 139
                    Mileage: 92942 km
                    Date: 2020.09.15
                    Time: 15:29:19
                    Voltage terminal 30: 11.9 V
                    Status_Software_Version_Management-module_name:
          U1101 00 [009] - Active
                    Reset counter: 139
                    Mileage: 92942 km
                    Date: 2020.09.15
                    Time: 15:29:19
                    Voltage terminal 30: 11.8 V
7194 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 139
                    Mileage: 92942 km
                    Date: 2020.09.15
                    Time: 15:29:21
                    BAP-BAP_Function_ID: 02
7223 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
                    Reset counter: 139
                    Mileage: 92942 km
                    Date: 2020.09.15
                    Time: 15:29:22
End-------------------------(Elapsed Time: 02:28)--------------------------
Hi. Please get verified so we can move this to Retrofits.
nms_TDI_guy
Calgary, AB, Canada
C?ID=278050
I just filled out the form 10 min ago to get verified. I has the receipts and papers in the trunk from when I bought it at concept 1 a year ago.
Got it. Moving to Retrofits.
Spacewalker
Poland
C?ID=159607
1st - you need to know if your ECU software supporting ACC, and is not just about coding, because coding is accepeted by 99.99% ECU, but ECU not understand ACC command , and it failed
2nd - that ACC module you provide is 2016 - and that generation use Component Protection , you can remove it onlinbe ONLY if your car VIN allow to do that , as I can see your cluster SW not supporting CP, so I can imageine whole car too , otherwise you will remove CP onlie to match your radio to your VIN, but you patched radio
3rd - the only one solution for you (if your ECU supporting ACC of course ) is to install 3AA sendor from Passat B7/CC
I seen in my life one Jetta without CP and with ACC, but I dont know what it was exactly , so hard to talk on one example
nms_TDI_guy
Calgary, AB, Canada
C?ID=278050
How do I go about determining if my ecu supports ACC and can you provide a hw model # for a b7/cc ACC module. Also is it possible to get my ecu codes to support ACC or replace it with one that supports ACC. 2nd option would be preferred to retain extended TDI warranty.
golfi_vend
Tartu, Estonia
C?ID=195131
2. It's possible to transfer CP codes from cluster to cluster. But this would mean You need to activate Radar in such car that has correct feature code.
There are 5 different FeC codes. You'd need to find such car with correct Feat.Code
10003100 - ACCLow Basic + FrontAssist inkl. CityANB
10003200 - ACCLow FTS + FrontAssist inkl. CityANB
10003400 - No ACC + FrontAssist inkl. CityANB
10003600 - ACCHigh Basic + FrontAssist inkl. CityANB
10003700 - ACCHigh FTS + FrontAssist inkl. CityANB
  • Informative
nms_TDI_guy
Calgary, AB, Canada
C?ID=278050
The radar I obtained is used so it should have been already activated in another car would that be sufficient? Still trying to determine how to verify my ecu's compatibility with ACC.
golfi_vend
Tartu, Estonia
C?ID=195131
No, because cluster must be read while radar is connected and activated.
