Lane change Assistant
sirlongfellow-40
Sweden
C?ID=307800
Now I have an error code on the Lane Change Assistant
but I can't find anything on the code?
What should I change?
4191758 - Internal Control Module Memory Check Sum Error
B2000 00 [009] - -
[Control unit 1 for side assist - defect]
Mileage: 96504 km
Date: 2020.09.13
Time: 12:44:40
Tuesday,15,September,2020,17:03:09:55610
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WAUZZZ8T4CA035264   License Plate: TFF702
Chassis Type: 8T-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 20 22 36 3C 42 44 46 47 52 53
          56 5F 62 72 A9
VIN: WAUZZZ8T4CA035264   Mileage: 96630km-60043miles
Address 01: Engine (J623-CGWC)       Labels:. 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 D    HW: 4H0 907 551
   Component: 3.0l V6 TFSIH07 0004
   Revision: --H07---
   Coding: 1A250034052601020000
   Shop #: WSC 06324 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551D 001004
   ROD: EV_ECM30TFS0218K5907551D.rod
   VCID: 373ECFEE8E94BE3EE2-8062
   Part No SW: 8K1 927 156 R    HW: 0B5 927 156 F
   Component: 0B5 30TFSIRdW H10 0007
   Revision: --H10---    Serial number: 0000000638
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMDL501 A02196
   ROD: EV_TCMDL501.rod
   VCID: 44C4A822CF42E5A677-8010
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 295D4E
   Shop #: WSC 06342 000 00000
   VCID: 0444682287C225A637-8050
   Part No SW: 8K0 907 064 FF    HW: 8K0 907 064 FF
   Component: BCM2 2.0      H10 0602
   Coding: 05A40000000000000000
   VCID: 79BA09D6F000684E54-802C
   Serial number: 2312000004990008
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 N    HW: 8K1 820 043 N
   Component: KLIMA 3 ZONEN H04 0036
   Revision: C1000000    Serial number: 01020220120876
   Coding: 6620028080
   VCID: 3326FBFE92EC521EDE-8066
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 AH
   Component: BCM1 1.0      H14 0103
   Revision: 08014001    Serial number: 00000026028202
   Coding: 2600C0108074AFE0218140C300001D0D0F9CC30826090201000008000400030100000024000000
   Shop #: WSC 40995 222 97407
   VCID: 78BC0CD2CB0A71462B-802C
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 240112  H15 0070
   Serial number: SWF12010245784
   Coding: 00FD11
   Component: G397_RLFS  H06 0001
   Serial number: 20137882
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002001123042
   Component: AQ_Hum_Sensor  H02 0002
   Serial number: 43584D06000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD90PRF+
   Coding: 30513938363030303030554A304C38543053
   VCID: 48DCBC12F36AC1C69B-801C
   Serial number: 6334MSME6B05507BI
   Serial number: 6344MSME6A160F4BR
   Serial number: 6352QSME716A174ER
   Serial number: 6362QSME0B6B227EV
   Serial number: 63732SME5E662D72B
   Serial number: 63832SME12695050S
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120201000746
   Coding: 000036
   VCID: 51EA91760830000ECC-8004
   Component: E221 - MFL  H03 0003
   Part No SW: 8T0 920 930 F    HW: 8T0 920 930 F
   Component: KOMBIINSTR.   H23 0640
   Revision: 00100000    Serial number: M2R32NH1D
   Coding: 1327310083010008010000
   VCID: 393AC9D6B080A84E14-806C
   Part No SW: 8R0 907 468 D    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H10 0025
   Revision: 1Z070014    Serial number: 1441Z1211203D7
   Coding: 00CF07FF00
   VCID: 40CCA432D35AF98653-8014
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790491600
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 12028000922021200410
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02019864747464545425363E00
   VCID: 7CB410C2FF325D664F-8028
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 002001120001000
   VCID: 2F2EF78E76C476FEBA-807A
   Component: MEM-FS        H06 0076
   Revision: AA000000    Serial number: 00000022499394
   Coding: 01581B00000000000000
   VCID: 3B36D3DEBABC9A5E06-806E
   Part No SW: 8T0 907 566     HW: 8T0 907 566
   Component: SWA Master    H15 0030
   Serial number: 0160996575
   Coding: 010311
   VCID: 7DB21DC6EC28546E78-8028
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568     HW: 8T0 907 568
   Component: SWA Slave  H15 0030
   Serial number: 0159862776
   Coding: 010311
          B2000 00 [009] - -
                    Mileage: 96504 km
                    Date: 2020.09.13
                    Time: 12:44:40
   Part No SW: 8T0 959 793 G    HW: 8T0 959 793 G
   Component: TSG FA        H09 0302
   Coding: 011C12625E00450005
   VCID: 4DD28D06140824EEA8-8018
   Component: RCEPS         H36 0507
   Revision: 00001000    Serial number: 0009303180
   Coding: 100000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3424F8E29FE25526C7-8060
   Revision: 00002001    Serial number: 0167174556
   Coding: 013A0E2020B900818030043680000000
   Component: DSP Prem      H04 0030
   Revision: 00004001    Serial number: 94814001257801
   VCID: 2D12ED8674C804EE88-8078
   Part No SW: 8T0 959 792 G    HW: 8T0 959 792 G
   Component: TSG BF        H09 0302
   Coding: 011C12225E00450005
   VCID: 4CD48002EF122DE6BF-8018
   Part No SW: 8K0 907 801 J    HW: 8K0 907 801 J
   Component: EPB-4         H01 0001
   Revision: --------    Serial number: 30000000016575
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3620C2EA899E4736F9-8062
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227AW0C7531619
   Coding: 010003010000000001
   VCID: 260012AA513E37B649-8072
   Part No SW: 8R1 035 666 L    HW: 8R1 035 666
   Component: H-BN-EU       H43 1036
   Revision: --------    Serial number: 065AQ0C7517042
   Coding: 140100040206A1ED55808F5E00000403E40000020000000000
   VCID: 41CAA136D850F08E5C-8014
   Subsystem 1 - Part No: 8R0 060 884 GS
   Component: EUR 2020  3001
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130AB0BS086794
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001049125
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
03623 - Invalid Security/Release Code
                    Reset counter: 248
                    Mileage: 87565 km
                    Date: 2020.03.28
                    Time: 16:21:41
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 8T0 959 795 H    HW: 8T0 959 795 H
   Component: TSG HL        H07 0302
   Coding: 010C12224000450005
   VCID: 50EC9472033A0906C3-8004
   Component: TSG HR        H07 0302
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 111123201960
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 72A83EFAA5761B1615-8026
End----------(Elapsed Time: 01:54, VBatt start/end: 12.2V/12.2V)-----------
Jef
HQ
Thank you for including a full Auto-Scan! :thumbs:
Before you replace it (J769), load test the powers/grounds and verify they are good. Odds are... it is fine... but hate to find out about a crappy ground connection after you $$$ krkrkr for a replacement module.
edit - financial reasons
Jef
HQ
Looks to be on the right rear.
