CJKERRZO1
- Sep 15, 2020
- 8
- 1
- Dundee, UK
- HN1 (2nd hand)
I recon im not the only one who had this problem, i basically tried swapping dials on a 2009 golf gti import only saving scan data from immo and instruments..
when i swapped back to the old dials i had lost all my abs coding ( all 0s) ive tried using a coding calculator with no luck, anyone have a resolution to this?
here is a current autoscan
Tuesday,15,September,2020,10:15:02:17039
VCDS Version: 19.6.2.0 (x64) HEX-NET CB: 0.4526.4
VIN: WVWZZZ1KZAW039353 License Plate: CODING ERRR
Mileage: 121370km-75415mi Repair Order:
Chassis Type: 1K-VW36 (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72
VIN: WVWZZZ1KZAW039353 Mileage: 121370km-75415miles
04-Steering Angle -- Status: Cannot be reached 1100
Address 01: Engine (CCZ) Labels:. 06J-907-115-CCZ.clb
Part No SW: 5K0 907 115 HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0040
Revision: AAH03--- Serial number:
Coding: 0403000C1C070160
VCID: 679E6B1A562F5B7706-8032
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 000 -
Mileage: 121367 km
Date: 2015.02.06
Time: 00:18:44
RPM: 762 /min
Load: 21.2 %
Temperature: 77.0°C
Temperature: 25.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.589 V
Readiness: 0010 0001
Part No SW: 02E 300 051 R HW: 02E 927 770 AM
Component: GSG DSG AG6 511 1975
Revision: 05351113 Serial number: 00001107262282
Shop #: WSC 04940 001 00001
VCID: 22083A0EFD8D7E5F91-8076
18036 - Powertrain Data Bus
P1628 - 000 - Missing Message from Steering Angle Sensor
Fault Frequency: 255
Mileage: 121367 km
Date: 2015.02.06
Time: 00:18:44
Part No SW: 1K0 907 379 AM HW: 1K0 907 379 AM
Component: ESP MK60EC1 H45 0108
Revision: 00H45001
Coding: 000000000000000000000000000000000000
VCID: 7DB22972E4B3E1A7CC-8028
03306 - Coding Not Valid
Reset counter: 103
Mileage: 121376 km
Date: 2015.02.06
Time: 02:50:11
Count: 3
Count: 12
Count: 12800
Count: 4161
Count: 46848
Reset counter: 103
Mileage: 121376 km
Date: 2015.02.06
Time: 02:48:02
Count: 7
Count: 12
Count: 12800
Count: 195
Count: 46848
Count: 41728
01486 - System Function Test Activated
Reset counter: 103
Mileage: 121376 km
Date: 2015.02.06
Time: 02:48:02
Count: 7
Count: 12
Count: 12800
Count: 320
Count: 46848
Count: 41728
Fault Status: 01100101
Reset counter: 103
Mileage: 121376 km
Date: 2015.02.06
Time: 02:44:06
Count: 3
Count: 32780
Count: 29184
Count: 279
Count: 46592
Reset counter: 103
Mileage: 121376 km
Date: 2015.02.06
Time: 02:44:06
Count: 3
Count: 32780
Count: 29184
Count: 270
Count: 46592
Reset counter: 103
Mileage: 121376 km
Date: 2015.02.06
Time: 02:44:06
Count: 3
Count: 32780
Count: 29184
Count: 291
Count: 46592
Part No SW: 5K0 907 044 BC HW: 5K0 907 044 BC
Component: Climatronic H14 0608
Revision: 00003001
Coding: 0000000000
ASAM Dataset: EV_Climatronic A01001
VCID: 6D921932BCD371277C-8038
Part No SW: 1K0 937 087 F HW: 1K0 937 087 F
Component: BCM PQ35 H 103 0537
Revision: 00103 AC
Coding: 40180A3A98251AC0440800803400092443550088736D8960648000200000
Shop #: WSC 07130 981 60669
VCID: 3424CC569779E0EF73-8060
Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer 03060 21 0501
Coding: 009795
Component: RLS 220609 05 54 0402
Coding: 0B30AD
Reset counter: 103
Mileage: 121367 km
Date: 2015.02.06
Time: 00:18:44
Voltage: 14.05 V
Term 50 Off
Part No SW: 5K0 959 655 A HW: 5K0 959 655 A
Component: AirbagVW10G 033 0604
Serial number: 003C3D07DMUH
Coding: 00003233
ASAM Dataset: EV_AirbaVW10SMEVW360 A01009
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 383CF8668311048F5F-806C
Component: S.Sens.Fahr.V U01 ----
Serial number: 59607548ZZZZZZZZZZZZ
Component: S.Sens.Beif.V U01 ----
Serial number: 306A7548ZZZZZZZZZZZZ
Serial number: 2014303CZZZZZZZZZZZZ
Serial number: 1A273041ZZZZZZZZZZZZ
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0001632
VCID: 76A0365E0185B2FF8D-8022
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H05 0010
Coding: 00000131
Part No SW: 5K6 920 870 B HW: 5K6 920 870 B
Component: KOMBI H05 0206
Coding: 470F00
VCID: 3228CA4E656DEEDF61-8066
Part No SW: 1K0 907 530 AA HW: 1K0 907 951
Component: J533 Gateway H07 0081
Revision: H07 01 Serial number: 110609F2001200
Coding: ED817F06000202000003
VCID: 6680661E5125427F3D-8032
Reset counter: 103
Mileage: 121367 km
Date: 2015.02.06
Time: 00:18:44
Address 25: Immobilizer (J334) Labels:. 5K0-920-xxx-25.clb
Component: IMMO H05 0206
ROD: EV_Immo_UDS_VDD_RM09.rod
Part No SW: 5K0 959 701 E HW: 5K0 959 701 E
Component: Tuer-SG 009 2124
Coding: 0004790
VCID: 3424CC565779E0EF73-8060
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 74 2901
Revision: 00H15000
VCID: 2F2EC33ABE5FC3370E-807A
Fault Status: 11100101
Mileage: 121367 km
Date: 2015.02.06
Time: 00:20:08
Battery Volts: 14.2 V
DU
Temperature: 28.0°C
Count: 8
Steering Angle: 0.00°
SteerAng n.Init
Fault Status: 11100100
Reset counter: 103
Mileage: 121376 km
Date: 2015.02.06
Time: 23:43:36
Battery Volts: 12.6 V
DD
Temperature: 22.0°C
Count: 3
SteerAng n.Init
Part No SW: 5K0 959 702 C HW: 5K0 959 702 C
Component: Tuer-SG 009 2110
Coding: 0005046
VCID: 3326CF4A5277E7D76A-8066
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0142
Coding: 1443164
Subsystem 1 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000022
Subsystem 2 - Part No: 7L6 941 329 B Labels: 3D0-941-329.CLB
Coding: 00000022
Reset counter: 103
Mileage: 121367 km
Date: 2015.02.06
Time: 00:18:44
Voltage: 13.63 V
ABS 1
Part No SW: 5M0 035 186 L HW: 5M0 035 186 L
Component: Radio RCD310 004 0119
Revision: 01000001 Serial number: VWZ1Z2N1872077
Coding: 01000400020001
Shop #: WSC 00788 648 00255
VCID: 3522F1529C03F9E744-8060
02877 - Digital Radio Antenna (R183)
Reset counter: 102
Mileage: 121367 km
Date: 2015.02.06
Time: 00:14:39
Part No SW: 5K0 959 703 C HW: 5K0 959 703 C
Component: Tuer-SG 007 2101
Coding: 0000144
Shop #: WSC 01357 011 1012552
Part No SW: 5K0 959 704 C HW: 5K0 959 704 C
Coding: 0000144
VCID: 3522F1525C03F9E744-8060
End----------(Elapsed Time: 01:06, VBatt start/end: 12.2V/12.2V)-----------
Address 55: DTCs cleared
Address 44,1K0 909 144 H,channel 9,adapted from,1,to,0,
Address 44: DTCs cleared
Address 19: DTCs cleared
Address 09: DTCs cleared
Address 02: DTCs cleared
Address 01: DTCs cleared
Address 03: DTCs cleared
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B400C09250003680E02E9901C00A1010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B800C21250003680E01E9841C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B400C2103000968030205840300A1010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B200C09250003680E04E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B200C0A250003680E04E9501C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B200C11250003680E04E9881C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B200C49250003680E04E9921C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B200C19250003680E04E9981C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B200C21250003680E04E9841C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B200C89250003680E04E9911C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B400C09250003680E02E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B400C0A250003680E02E9501C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B400C11250003680E02E9881C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B400C49250003680E02E9921C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B400C19250003680E02E9981C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B400C21250003680E02E9841C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B400C89250003680E02E9911C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B600C09250003680E06E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B600C0A250003680E06E9501C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B600C11250003680E06E9881C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B600C49250003680E06E9921C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B600C19250003680E06E9981C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B600C21250003680E06E9841C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B600C89250003680E06E9911C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B800C09250003680E01E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B800C0A250003680E01E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B800C11250003680E01E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B800C49250003680E01E9501C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B800C19250003680E01E9501C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B800C21250003680E01E9501C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164B800C89250003680E01E9501C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164BC00C09250003680E03E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164BC00C0A250003680E03E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164BC00C11250003680E03E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164BC00C49250003680E03E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164BC00C19250003680E03E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164BC00C21250003680E03E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164BC00C89250003680E03E9901C0061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164BC00C09250103680E03E9901C8061010100,(01357/011/00200),
Address 03,1K0 907 379 AM,recoded (Long Coding),from,000000000000000000000000000000000000,to,164BC00C09250503680E03E9901CA061010100,(01357/011/00200),
