Hello there im pretty new to vcds and struggling coding a basic abs settings. Theres a few things that are stored faults which are not really issues, the car is a mk5 golf track car so has no air bags are heater controls etc.
I have installed a gen4 rear axle from a s3 with esp sensor and abs unit. If anyone could possibly point me in the right direction that would be great? also the tire pressure sensors need turning off too! many thanks
Dene
i have attached a full autoscan too, thanks
Dene
Untitled Post
Monday,14,September,2020,09:05:49:51580 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Versio...
txt.do
VIN: WAUZZZ8P39A065657 License Plate: D3NEC
Mileage: 123450km-76708mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 09 16 17 19 22 25 42 44 46 52
VIN: WAUZZZ8P39A065657 Mileage: 123450km-76708miles
Address 01: Engine (CDL) Labels:. 06F-907-115-CDL.clb
Part No SW: 8P0 907 115 AP HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0H9FNN089
Coding: 0103000C180F0060
Shop #: WSC 66565 257 00032
VCID: 00597DD3160F94CB523-8054
050211 - Implausible Data Received from Instrument Panel Control Module
U0423 - 002 -
Fault Status: 01100010
Mileage: 121233 km
Time: 14:44:32
Temperature: 18.0°C
Temperature: 20.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 12.065 V
049489 - No Communications with Airbag Control Module
U0151 - 008 -
Fault Status: 01101000
Mileage: 121233 km
Time: 14:44:33
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 12.065 V
001152 - Coolant Fan Control Circuit 1
P0480 - 004 - Electrical Malfunction
Mileage: 121233 km
Time: 14:44:33
RPM: 1215 /min
Load: 13.7 %
Temperature: 15.0°C
Temperature: 15.0°C
Voltage: 10.160 V
012425 - Signal Line for Fuel Pump Electronics
P3089 - 004 - Electrical Malfunction - Intermittent
Mileage: 121280 km
RPM: 1014 /min
Load: 10.6 %
Temperature: 27.0°C
Temperature: 21.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
Temperature: -40.0°C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 008 -
Mileage: 123459 km
Time: 00:00:06
Temperature: 18.0°C
Temperature: 20.0°C
Voltage: 12.065 V
Readiness: 0110 0100
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No SW: 1K0 907 379 AB HW: 1K0 907 379 AB
Component: ESP 4MOTION MK60 0102
Revision: 00H13001
Coding: 0004744
Shop #: WSC 06314 000 00000
VCID: 72BD271B28A3B65B547-8026
7 Faults Found:
003 - Mechanical Failure
01486 - System Function Test Activated
014 - Defective
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001592116
Coding: 008D0F0600041800001400001400000000087F075C
VCID: 3A2DCF3B30530E1B5C7-806E
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 12345
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 521 0050
Coding: 0000011
Shop #: WSC 01279 785 00200
VCID: 3537DC07194DE163B15-8060
Part No: 1K6 920 960 D
Component: KOMBIINSTRUMENT VDD 0812
Coding: 0003403
Shop #: WSC 00187 210 69756
VCID: 3039ED13E62FC44BE23-8064
Address 19: CAN Gateway Labels:. 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001053190413
Coding: AD0F0100070001
Shop #: WSC 00020 210 01865
VCID: 290F0077C5F5B58325D-807C
Reset counter: 158
Mileage: 123459 km
Time: 16:10:26
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BR 907 554 B HW: 0BR 907 554 B
Component: Haldex 4Motion 3017
Coding: 0000005
VCID: 44D1B1C3429748EB36B-8010
Reset counter: 138
Mileage: 123459 km
Time: 15:45:14
Component: IMMO VDD 0812
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0170
Coding: 0000052
Shop #: WSC 01287 785 00200
Part No: 8J0 909 144 P
Component: EPS_ZFLS Kl. 236 3305
Revision: 00H22000
Shop #: WSC 01236 785 00200
VCID: 3D27C427217D3923795-8068
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AJ
Component: KSG 0401
Coding: 01C802087F2D8505485AC69010CC
VCID: 78A915334EDFDC0B6A3-802C
Subsystem 1 - Component: Sounder No Answer
Subsystem 2 - Component: NGS No Answer
Subsystem 3 - Component: IRUE No Answer
00323 - Vehicle Inclination Sensor (G384)
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Component: Tuersteuergeraet 09 0122
Coding: 0000052
VCID: 313FE817ED25CD43EDD-8064
End----------(Elapsed Time: 00:49, VBatt start/end: 12.2V/12.2V)-----------
