Awd Retro Fit
Rsdene
C?ID=330822
Hello there im pretty new to vcds and struggling coding a basic abs settings. Theres a few things that are stored faults which are not really issues, the car is a mk5 golf track car so has no air bags are heater controls etc.
I have installed a gen4 rear axle from a s3 with esp sensor and abs unit. If anyone could possibly point me in the right direction that would be great? also the tire pressure sensors need turning off too! many thanks
Dene
i have attached a full autoscan too, thanks
Monday,14,September,2020,09:05:49:51580
VIN: WAUZZZ8P39A065657   License Plate: D3NEC
Mileage: 123450km-76708mi   Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 03 09 16 17 19 22 25 42 44 46 52
VIN: WAUZZZ8P39A065657   Mileage: 123450km-76708miles
Address 01: Engine (CDL)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 8P0 907 115 AP    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: AUX7Z0H9FNN089
   Coding: 0103000C180F0060
   Shop #: WSC 66565 257 00032
   VCID: 00597DD3160F94CB523-8054
050211 - Implausible Data Received from Instrument Panel Control Module
               U0423 - 002 -
                    Fault Status: 01100010
                    Mileage: 121233 km
                    Time: 14:44:32
                    Temperature: 18.0°C
                    Temperature: 20.0°C
                    Absolute Pres.: 1010.0 mbar
                    Voltage: 12.065 V
049489 - No Communications with Airbag Control Module
               U0151 - 008 -
                    Fault Status: 01101000
                    Mileage: 121233 km
                    Time: 14:44:33
                    Temperature: 18.0°C
                    Temperature: 20.0°C
                    Voltage: 12.065 V
001152 - Coolant Fan Control Circuit 1
               P0480 - 004 - Electrical Malfunction
                    Mileage: 121233 km
                    Time: 14:44:33
                    RPM: 1215 /min
                    Load: 13.7 %
                    Temperature: 15.0°C
                    Temperature: 15.0°C
                    Voltage: 10.160 V
012425 - Signal Line for Fuel Pump Electronics
               P3089 - 004 - Electrical Malfunction - Intermittent
                    Mileage: 121280 km
                    RPM: 1014 /min
                    Load: 10.6 %
                    Temperature: 27.0°C
                    Temperature: 21.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 14.224 V
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -
                    Mileage: 123459 km
                    Time: 00:00:06
                    Temperature: 18.0°C
                    Temperature: 20.0°C
                    Voltage: 12.065 V
Readiness: 0110 0100
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-A.lbl
   Part No SW: 1K0 907 379 AB    HW: 1K0 907 379 AB
   Component: ESP 4MOTION MK60    0102
   Revision: 00H13001
   Coding: 0004744
   Shop #: WSC 06314 000 00000
   VCID: 72BD271B28A3B65B547-8026
7 Faults Found:
            003 - Mechanical Failure
01486 - System Function Test Activated
            014 - Defective
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001592116
   Coding: 008D0F0600041800001400001400000000087F075C
   VCID: 3A2DCF3B30530E1B5C7-806E
   Subsystem 1 - Part No: 1K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 12345
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksäulenmodul 521 0050
   Coding: 0000011
   Shop #: WSC 01279 785 00200
   VCID: 3537DC07194DE163B15-8060
   Part No: 1K6 920 960 D
   Component: KOMBIINSTRUMENT VDD 0812
   Coding: 0003403
   Shop #: WSC 00187 210 69756
   VCID: 3039ED13E62FC44BE23-8064
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 29001053190413
   Coding: AD0F0100070001
   Shop #: WSC 00020 210 01865
   VCID: 290F0077C5F5B58325D-807C
                    Reset counter: 158
                    Mileage: 123459 km
                    Time: 16:10:26
   Part No SW: 0BR 907 554 B    HW: 0BR 907 554 B
   Component: Haldex 4Motion      3017
   Coding: 0000005
   VCID: 44D1B1C3429748EB36B-8010
                    Reset counter: 138
                    Mileage: 123459 km
                    Time: 15:45:14
   Component: IMMO            VDD 0812
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1K0 959 701 E
   Component: Tuersteuergeraet 09 0170
   Coding: 0000052
   Shop #: WSC 01287 785 00200
   Part No: 8J0 909 144 P
   Component: EPS_ZFLS Kl. 236    3305
   Revision: 00H22000
   Shop #: WSC 01236 785 00200
   VCID: 3D27C427217D3923795-8068
   Part No: 1K0 959 433 AJ
   Coding: 01C802087F2D8505485AC69010CC
   VCID: 78A915334EDFDC0B6A3-802C
   Subsystem 2 - Component:       NGS No Answer
   Subsystem 3 - Component:      IRUE No Answer
00323 - Vehicle Inclination Sensor (G384)
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1K0 959 702 E
   Component: Tuersteuergeraet 09 0122
   Coding: 0000052
   VCID: 313FE817ED25CD43EDD-8064
End----------(Elapsed Time: 00:49, VBatt start/end: 12.2V/12.2V)-----------
NZDubNurd
New Zealand
C?ID=230482
Have you fitted a 4motion ABS module, but not rewired the loop in to plug to match the coding?
I can't recall the exact details, but there is a wiring loop I changed when I retrofitted 4motion to my Touran with MK60 ABS, and coded the module for the correct brake size. You may still have the wiring loop for the smaller 2WD brakes, but the ABS coded for the bigger disks?
Rsdene
C?ID=330822
Hi ya! I’ve fitted a awd abs unit and esp sensor, I haven’t not done the loop wiring, do you have any information on that please? Thanks for your reply most appreciated
NZDubNurd
New Zealand
C?ID=230482
You'll need a wiring diagram for the chassis your ABS came from - the loop varies based on the physical car options, and the coding options. A one hour ErWin subscription (and save all the PDF's you can) is probably the best place, if you don't have access to ElsaWin.
