I recently retrofitted a trailer module to my 2014 (UK) Touareg and I'm having an issue with the brake lights on my caravan.
All other lights work correctly, Indicators, reverse, fog, sidelights/marker lights just the brake lights.
When connected the brake lights remain illuminated on my caravan but work normally on the car.
The following fault code is logged on the Trailer module;
008 - Implausible Signal
Fault Status: 01101000
Reset counter: 152
Mileage: 78936 km
Date: 2020.09.13
Time: 18:44:11
If i keep the brake pedal depressed and clear the code it doesnt return until I release the brakes.
But no faults are logged on the ABS module.
Any help would be greatly appreciated as I'm now pulling my hair out!!
Reset counter: 152
Mileage: 78936 km
Date: 2020.09.13
Time: 18:44:11
Monday,14,September,2020,20:12:22:34416
VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4526.4
VIN: WVGZZZ7PZED051777 License Plate:
Mileage: 78936km-49048mi Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
69 6D 72
VIN: WVGZZZ7PZED051777 Mileage: 78936km-49048miles
Address 01: Engine (J623-CRCA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 H41 0007
Revision: 53H41---
Coding: 292A4012233601020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
ROD: EV_ECM30TDI_VW52.rod
VCID: 323D1ED864A7069B947-8066
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 BQ HW: 0C8 927 750 BQ
Component: AL1000 AISIN 002 2530
Coding: 003568
Shop #: WSC 54823 001 1048576
ASAM Dataset: EV_TCMAL991031 002115
ROD: EV_TCMAL991031_002.rod
VCID: 7CA1F0E0F66300EB0EB-8028
Address 03: ABS Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 P HW: 7P0 907 379 A
Component: MK25A H36 0446
Revision: -------- Serial number: 413040010EC818
Coding: 5B6B13C309292554DAFBC89A90D9A450F700
ROD: EV_ESPMK25A00800.rod
VCID: 4ACD6638EC376E5BCC7-801E
Part No SW: 4H0 907 064 FH HW: 4H0 907 064 EH
Component: BCM2 2.0 H36 0551
Coding: 05B60016000000000000
VCID: 74B1D8C0DEB348AB46B-8020
Subsystem 1 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Serial number: 0214000095983009
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 BR HW: 7P6 907 040 BR
Component: Klima 2 Zonen H21 1306
Coding: B6A6000890
VCID: 0557950485A94123615-8050
Part No SW: 4H0 907 063 CD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0130
Revision: 15012002 Serial number: 00000001759107
Coding: 26001010D1345D010021000300005D0C431D670807010241000000020000
VCID: 6C81C0A08683906B9EB-8038
Subsystem 1 - Part No SW: 7P0 955 120 HW: 7P0 955 120
Component: WWS 140523 033 0021
Serial number: 90243401140526224147
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 E HW: 7P0 955 559 E Labels: 8K0-955-559.CLB
Component: RLFS H10 0020
Serial number: 20330647
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 HW: 7P6 941 431
Component: E1 - LDS H04 0031
Serial number: 00000000000406140320
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 C HW: 7N0 919 475
Component: PARKHILFE 8K H05 0026
Revision: -------- Serial number: 28261415801352
Coding: 118501
ASAM Dataset: EV_VW526ParkiAssis2 001012
ROD: EV_VW526ParkiAssis2.rod
VCID: 43D34B1CCB1DBF130F1-8016
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 E HW: 7P0 959 655 E
Component: VW10Airbag00K H10 0043
Revision: -------- Serial number: 003NK0005F1O
Coding: 00000000000000000000000000000000304B
ASAM Dataset: EV_AirbaVW10BPAVW526 002001
ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
Serial number: 3575LRB40532KTAQ907M
Serial number: 3585LRB40512KTAQ9HH5
Serial number: 3517ARB404V2KSNMKGU6
Serial number: 3527ARB40512KSNMJGVL
Serial number: 3557BRB40572N22071D6
Serial number: 3567BRB40552N220NHS9
Part No SW: 4H0 953 568 H HW: 7P6 953 507 M
Revision: -------- Serial number: 01335NF7000L4
Coding: 000C35
VCID: 38292CF0825BECCBAA3-806C
Subsystem 1 - Part No SW: 7P6 959 542 A HW: 7P6 959 542 A
Component: E221__MFL-TAS H04 0028
Serial number: 0051478 TRW 20140512
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 982 S HW: 7P6 920 982 S
Component: Kombi H13 0419
Revision: 13240270 Serial number: 658050614592034
Coding: 332731002B00260001000C
ASAM Dataset: EV_KombiUDSRBVW526 001020
ROD: EV_KombiUDSRBVW526.rod
VCID: 4EC56A28105F427B90F-801A
Part No SW: 7P6 907 530 J HW: 7P6 907 530 F
Component: GW-CAN-L-MOST H13 6032
Revision: -------- Serial number: 00000001422112
Coding: 000D07AD00
ROD: EV_GatewUDS_VW52.rod
VCID: 3FDB47ECA7F5DBF36B9-806A
Subsystem 1 - Part No SW: 7P0 915 181 B HW: 7P0 915 181
Component: Batt_Sensor H07 0190
Serial number: 31155I58005701372736
Voltage stabilizer:
Subsystem 2 - Part No SW: 7PP 959 663 E HW: 7PP 959 663 E
Serial number: 14148003697021200181
16384 - Function Restriction due to Driver Fatigue Recognition
B130E 00 [008] - -
[Funktionseinschraenkung Pausenempfehlung]
Reset counter: 191
Mileage: 78912 km
Date: 2020.09.13
Time: 10:01:55
Voltage terminal 30: 14.5 V
Voltage terminal 15: 14.5 V
Control Module temperature: 39 °C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
Part No SW: 4H0 959 793 AC HW: 4H0 959 793 P
Component: TSG FA H02 0306
Revision: -------- Serial number: 0000105123973
Coding: 011D1620D001451005080002
VCID: 7AADF6F8FCD73EDB1C7-802E
Revision: 00002001 Serial number: 0337008685
Coding: 019B1E2228B9109583200624210000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Subsystem 3 - Part No SW: 7P0 959 591 B HW: 7P0 959 591 B
Component: J245 PS30.055 H01 0008
Serial number: WOO29690505
Coding: 191100
Subsystem 4 - Part No SW: 7P0 959 591 C HW: 7P0 959 591 C
Component: J394 PS30.055 H01 0008
Serial number: WOO2943858D
Coding: 191100
01134 - Alarm Horn (H12)
Fault Frequency: 37
Reset counter: 192
Mileage: 78820 km
Date: 2020.09.12
Time: 12:28:02
Part No SW: 4H0 959 792 S HW: 4H0 959 792 M
Component: TSG BF H02 0306
Revision: -------- Serial number: 0000104741493
Coding: 011D1620D001451005080000
VCID: 48C95C30F2BB9C4BDA3-801C
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: C1452400835
Coding: 01040100
ROD: EV_ParkbA7.rod
VCID: 363522C888CF1ABBB8F-8062
Slave 3:
Address 55: Headlight Range (J745) Labels:. 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 018E00000F000200
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0003
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0003
Coding: 130000
Part No SW: 4G0 035 061 N HW: 4G0 035 061
Component: Radio U DAB H60 0139
Revision: AB001007 Serial number: 109F%0E7933509
Coding: 010105020100000003
VCID: 2809FCB052FB7C4B3A3-807C
Reset counter: 190
Mileage: 78849 km
Date: 2020.09.12
Time: 21:36:45
Bin. Bits: 00000000 00101100
Part No SW: 7P6 035 670 G HW: 7P6 035 670 A
Component: H-BNT-EU H40 0822
Revision: -------- Serial number: 444F.0EB001791
Coding: 010101050040E1ED01000B0E00000003F00401030000000000
VCID: 392F29F4B951F5C355D-806C
Subsystem 1 - Part No: 8R0 060 884 BT
Component: EUR 2014 1903
Subsystem 2 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: DU8 SV Touch H27 0045
Serial number: VWZ8Z9PA2018CD
Subsystem 3 - Part No SW: 7P6 919 603 HW: 7P6 919 603
Component: CD-Database 5950
Fault Frequency: 11
Reset counter: 190
Mileage: 78849 km
Date: 2020.09.12
Time: 21:36:45
Bin. Bits: 10110111 10000010
Bin. Bits: 00000000 00001110
Bin. Bits: 00000000 00000000
Fault Frequency: 12
Reset counter: 190
Mileage: 78849 km
Date: 2020.09.12
Time: 21:37:05
Bin. Bits: 00011110 00011111
Bin. Bits: 00000000 00011010
Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
Part No SW: 4H0 959 795 P HW: 4H0 959 795 J
Component: TSG HL H03 0306
Revision: -------- Serial number: 0000105908883
Coding: 011814200001251005080000
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 K HW: 7P6 907 273 K
Component: RDKBERU25 H09 0009
Serial number: 10000000139915
ROD: EV_RDKBERU25_VW52.rod
VCID: 44D14800CE13B82B36B-8010
Address 69: Trailer (J345) Labels: Redir Fail!
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H12 0110
Revision: 5A001001 Serial number: 00000497130792
Coding: 0100000000000000
VCID: 3B2333FCB36DC7D3471-806E
Reset counter: 152
Mileage: 78936 km
Date: 2020.09.13
Time: 18:44:11
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 145400804
Coding: 0533314003
ROD: EV_HeckkTouar.rod
Component: TSG HR H03 0306
Revision: -------- Serial number: 0000105819320
End----------(Elapsed Time: 01:55, VBatt start/end: 12.6V/12.3V)-----------
