VW Touareg 2014 retrofit trailer module issue
JonesyGT
C?ID=48476
I recently retrofitted a trailer module to my 2014 (UK) Touareg and I'm having an issue with the brake lights on my caravan.
All other lights work correctly, Indicators, reverse, fog, sidelights/marker lights just the brake lights.
When connected the brake lights remain illuminated on my caravan but work normally on the car.
The following fault code is logged on the Trailer module;
Fault Status: 01101000
Reset counter: 152
Mileage: 78936 km
Date: 2020.09.13
Time: 18:44:11
If i keep the brake pedal depressed and clear the code it doesnt return until I release the brakes.
But no faults are logged on the ABS module.
Any help would be greatly appreciated as I'm now pulling my hair out!!
Monday,14,September,2020,20:12:22:34416
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4526.4
VIN: WVGZZZ7PZED051777   License Plate:
Mileage: 78936km-49048mi   Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
          69 6D 72
VIN: WVGZZZ7PZED051777   Mileage: 78936km-49048miles
Address 01: Engine (J623-CRCA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 F    HW: 4G0 907 401
   Component: 3.0TDI EDC17  H41 0007
   Revision: 53H41---
   Coding: 292A4012233601020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0117P0907401F 001008
   ROD: EV_ECM30TDI_VW52.rod
   VCID: 323D1ED864A7069B947-8066
   Part No SW: 0C8 927 750 BQ    HW: 0C8 927 750 BQ
   Component: AL1000 AISIN  002 2530
   Coding: 003568
   Shop #: WSC 54823 001 1048576
   ASAM Dataset: EV_TCMAL991031 002115
   ROD: EV_TCMAL991031_002.rod
   VCID: 7CA1F0E0F66300EB0EB-8028
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 P    HW: 7P0 907 379 A
   Component: MK25A         H36 0446
   Revision: --------    Serial number: 413040010EC818
   Coding: 5B6B13C309292554DAFBC89A90D9A450F700
   ASAM Dataset: EV_MK25AXT 008001
   ROD: EV_ESPMK25A00800.rod
   VCID: 4ACD6638EC376E5BCC7-801E
   Part No SW: 4H0 907 064 FH    HW: 4H0 907 064 EH
   Component: BCM2 2.0      H36 0551
   Coding: 05B60016000000000000
   VCID: 74B1D8C0DEB348AB46B-8020
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 0214000095983009
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 BR    HW: 7P6 907 040 BR
   Component: Klima 2 Zonen H21 1306
   Coding: B6A6000890
   VCID: 0557950485A94123615-8050
   Part No SW: 4H0 907 063 CD    HW: 4H0 907 063 D
   Revision: 15012002    Serial number: 00000001759107
   Coding: 26001010D1345D010021000300005D0C431D670807010241000000020000
   VCID: 6C81C0A08683906B9EB-8038
   Subsystem 1 - Part No SW: 7P0 955 120     HW: 7P0 955 120
   Component: WWS    140523  033 0021
   Serial number: 90243401140526224147
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 E    HW: 7P0 955 559 E  Labels: 8K0-955-559.CLB
   Component: RLFS  H10 0020
   Serial number: 20330647
   Coding: 025223
   Subsystem 3 - Part No SW: 7P6 941 431     HW: 7P6 941 431
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000406140320
Address 10: Park/Steer Assist (J446)       Labels:| 7P6-919-475.clb
   Part No SW: 7P6 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H05 0026
   Revision: --------    Serial number: 28261415801352
   Coding: 118501
   ASAM Dataset: EV_VW526ParkiAssis2 001012
   ROD: EV_VW526ParkiAssis2.rod
   VCID: 43D34B1CCB1DBF130F1-8016
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 E    HW: 7P0 959 655 E
   Component: VW10Airbag00K H10 0043
   Revision: --------    Serial number: 003NK0005F1O
   Coding: 00000000000000000000000000000000304B
   ASAM Dataset: EV_AirbaVW10BPAVW526 002001
   ROD: EV_AirbaVW10BPAVW526_002_VW52.rod
   Serial number: 3575LRB40532KTAQ907M
   Serial number: 3585LRB40512KTAQ9HH5
   Serial number: 3517ARB404V2KSNMKGU6
   Serial number: 3527ARB40512KSNMJGVL
   Serial number: 3557BRB40572N22071D6
   Serial number: 3567BRB40552N220NHS9
   Part No SW: 4H0 953 568 H    HW: 7P6 953 507 M
   Revision: --------    Serial number: 01335NF7000L4
   Coding: 000C35
   VCID: 38292CF0825BECCBAA3-806C
   Subsystem 1 - Part No SW: 7P6 959 542 A    HW: 7P6 959 542 A
   Component: E221__MFL-TAS  H04 0028
   Serial number: 0051478 TRW 20140512
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 982 S    HW: 7P6 920 982 S
   Component: Kombi         H13 0419
   Revision: 13240270    Serial number: 658050614592034
   Coding: 332731002B00260001000C
   ASAM Dataset: EV_KombiUDSRBVW526 001020
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 4EC56A28105F427B90F-801A
   Part No SW: 7P6 907 530 J    HW: 7P6 907 530 F
   Component: GW-CAN-L-MOST H13 6032
   Revision: --------    Serial number: 00000001422112
   Coding: 000D07AD00
   ASAM Dataset: EV_GatewVW526UDS 001007
   ROD: EV_GatewUDS_VW52.rod
   VCID: 3FDB47ECA7F5DBF36B9-806A
   Subsystem 1 - Part No SW: 7P0 915 181 B    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0190
   Serial number: 31155I58005701372736
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 7PP 959 663 E    HW: 7PP 959 663 E
   Serial number: 14148003697021200181
16384 - Function Restriction due to Driver Fatigue Recognition
          B130E 00 [008] - -
          [Funktionseinschraenkung Pausenempfehlung]
                    Reset counter: 191
                    Mileage: 78912 km
                    Date: 2020.09.13
                    Time: 10:01:55
                    Voltage terminal 30: 14.5 V
                    Voltage terminal 15: 14.5 V
                    Control Module temperature: 39 °C
                    System status: Terminal 15 on
                    IN ESP_standstill flag: no standstill detected
                    Engine running: On
                    IN ZAS_Te_X: On
                    Terminal 15 status: On
                    Datenfeld: 0
   Part No SW: 4H0 959 793 AC    HW: 4H0 959 793 P
   Component: TSG FA        H02 0306
   Revision: --------    Serial number: 0000105123973
   Coding: 011D1620D001451005080002
   VCID: 7AADF6F8FCD73EDB1C7-802E
   Revision: 00002001    Serial number: 0337008685
   Coding: 019B1E2228B9109583200624210000000000000000000000000000000000
   Subsystem 1 - Part No: 7P6 951 171
   Component: DWA-Sensor  002 0204
   Subsystem 3 - Part No SW: 7P0 959 591 B    HW: 7P0 959 591 B
   Component: J245 PS30.055  H01 0008
   Serial number:     WOO29690505
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 C    HW: 7P0 959 591 C
   Component: J394 PS30.055  H01 0008
   Serial number:     WOO2943858D
   Coding: 191100
                    Fault Frequency: 37
                    Reset counter: 192
                    Mileage: 78820 km
                    Date: 2020.09.12
                    Time: 12:28:02
   Part No SW: 4H0 959 792 S    HW: 4H0 959 792 M
   Component: TSG BF        H02 0306
   Revision: --------    Serial number: 0000104741493
   Coding: 011D1620D001451005080000
   VCID: 48C95C30F2BB9C4BDA3-801C
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 F    HW: 7P0 907 801 F
   Component: EPB           H51 1201
   Revision: 00000000    Serial number: C1452400835
   Coding: 01040100
   ROD: EV_ParkbA7.rod
   VCID: 363522C888CF1ABBB8F-8062
   Slave 3:
Address 55: Headlight Range (J745)       Labels:. 7P6-907-357.clb
   Part No SW: 7P6 907 357     HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0110
   Coding: 018E00000F000200
   ASAM Dataset: EV_HeadlRegulVWAFS 005006
   ROD: EV_HeadlRegulVWAFS_VW52.rod
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0003
   Coding: 130000
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0003
   Coding: 130000
   Part No SW: 4G0 035 061 N    HW: 4G0 035 061
   Component: Radio U DAB   H60 0139
   Revision: AB001007    Serial number: 109F%0E7933509
   Coding: 010105020100000003
   VCID: 2809FCB052FB7C4B3A3-807C
                    Reset counter: 190
                    Mileage: 78849 km
                    Date: 2020.09.12
                    Time: 21:36:45
                    Bin. Bits: 00000000 00101100
   Part No SW: 7P6 035 670 G    HW: 7P6 035 670 A
   Component: H-BNT-EU      H40 0822
   Revision: --------    Serial number: 444F.0EB001791
   Coding: 010101050040E1ED01000B0E00000003F00401030000000000
   VCID: 392F29F4B951F5C355D-806C
   Subsystem 1 - Part No: 8R0 060 884 BT
   Component: EUR 2014  1903
   Subsystem 2 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: DU8 SV Touch  H27 0045
   Serial number: VWZ8Z9PA2018CD
   Subsystem 3 - Part No SW: 7P6 919 603     HW: 7P6 919 603
   Component: CD-Database  5950
                    Fault Frequency: 11
                    Reset counter: 190
                    Mileage: 78849 km
                    Date: 2020.09.12
                    Time: 21:36:45
                    Bin. Bits: 10110111 10000010
                    Bin. Bits: 00000000 00001110
                    Bin. Bits: 00000000 00000000
                    Fault Frequency: 12
                    Reset counter: 190
                    Mileage: 78849 km
                    Date: 2020.09.12
                    Time: 21:37:05
                    Bin. Bits: 00011110 00011111
                    Bin. Bits: 00000000 00011010
   Part No SW: 4H0 959 795 P    HW: 4H0 959 795 J
   Component: TSG HL        H03 0306
   Revision: --------    Serial number: 0000105908883
   Coding: 011814200001251005080000
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 K    HW: 7P6 907 273 K
   Component: RDKBERU25     H09 0009
   Serial number: 10000000139915
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 44D14800CE13B82B36B-8010
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H12 0110
   Revision: 5A001001    Serial number: 00000497130792
   Coding: 0100000000000000
   VCID: 3B2333FCB36DC7D3471-806E
                    Reset counter: 152
                    Mileage: 78936 km
                    Date: 2020.09.13
                    Time: 18:44:11
   Part No SW: 7P6 959 107 C    HW: 7P6 959 107
   Component: HDSG-Modul    H10 0043
   Revision: 22010001    Serial number: 145400804
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202142
   ROD: EV_HeckkTouar.rod
   Component: TSG HR        H03 0306
   Revision: --------    Serial number: 0000105819320
End----------(Elapsed Time: 01:55, VBatt start/end: 12.6V/12.3V)-----------
JonesyGT
C?ID=48476
Does anyone know what could cause an implausible signal?
NEtech
Denmark
C?ID=56995
Could be problems with correct Kl.15 (ignition) and Kl.30 (Battery) connection/ functioning .
JonesyGT
C?ID=48476
The power for the trailer loom is currently connected to the fused side of ‘F3’ in the battery fuse box. There is no terminal 15 connection unless it’s from fuse 42 in the fuse box in the end of the dash.
United States
That sounds like feedback from the trailer (caravan) into the vehicle. If they don't shut off with the ignition that may help narrow it down.
Have you checked the caravan brake light wiring and/or attempted to unplug any of them to make sure the brake light behavior doesn't change when one is unplugged? I suppose the difficulty level of doing so is going to depend on LED assemblies versus incandescent bulbs that you can pull one at a time.
JonesyGT
C?ID=48476
Hi Dana, I’ve done quite a bit of fault finding now, the fault code reappears instantly even when my caravan isn’t attached, same with the socket loom disconnected from the module.
United States
Ouch, I wasn't expecting that at all. It isn't the caravan in that case and the vehicle side harness from trailer module to trailer connector at the bumper should also be excluded at this point.
The wring to the trailer module must be responsible because the Coding appears to be OK. Your PR-Code is 1D0 Without trailer hitch. Am I correct in ASSuming that there wasn't any factory wiring ready to plug and play the trailer module into? If so, we might need to pop into a wiring diagram to try to figure out if there's an issue per Netech's suggestion.
JonesyGT
C?ID=48476
Hi Dana, that’s correct, the kit (westfalia) came with a wiring harness. It makes connections at the fuse box which is then powered by a connection at F3 (terminal 30?) at the battery and also fuse 42 (terminal 15?) which already had the power side to it. 3 connections were then made at the BCM2 control unit, orange/brown, orange/green (black connector) and black/red (grey connector).
The only other fault I have that’s reoccurring is the alarm horn also keeps throwing an implausible code. If there is a fault there could that be disrupting the signal? although I would of thought the ABS module would pick it up too??? I’m lost now!!
EDIT - just to add when I go to group 8 in measuring blocks on the trailer module I can see the first two boxes changing from no to yes as I press and release the brake pedal. One is marginally slower than the other depending upon pedal pressure but they both change.
United States
OK, I took a peek at the Wiring Diagram labeled Touareg Trailer coupling From April 2010 (Current Flow Diagram No. 19 / 1) and it shows up to 5 possible power sources depending on production splits and equipment. At the least I'd expect 4 fused powers to be necessary based on what I see there. If you don't already have diagrams I'd recommend obtaining them from erWin VW. We need to tread very lightly but I can offer you this (temp) link with the page #1 info:
There's also a Preparation for trailer coupling From April 2010 diagram which may be easier to follow.
Either way, I would make sure all of powers are OK and wired to the correct source (switched versus unswitched) before chasing the brake light connection. On that note however, brake light splice B335 is shown in the Engine diagram where it splices to BCM2/J393 (Address 46, the guy with the new alarm DTC), the brake switch and the engine controller. That direct connection, rather than lighting commands shared over a databus, may explain why all of the other functions are OK with the exception of brake lights.
JonesyGT
C?ID=48476
Hi Dana many thanks for the reply, i think I have now fixed it! I was talking to the technical line yesterday who was baffled, what he did tell me was that my car didn’t need the black/red wire as the module can sense the brake signal through the canbus. So I disconnected it last night and returned the factory pin back to its slot. I tested it today on a trailer at work and now they are working!! (the same trailer also had the issue of brake lights always on)
United States
Excellent! If you have issues with your caravan at home bump this back up.
In that case I could take a peek at my husband's 7P T'reg wiring at the factory installed module if needed. It would be interesting to see which wires are actually in-use and see if the NAR wiring diagrams are any different than the ones I checked for your vehicle.
