Mag Ride Delete on 2014 Mk2 Audi TTS
PeteJ
C?ID=340777
I'm trying to do a mag ride delete on our 2014 TTS and made it all the way to the last step following these instructions and made it all the way to step 5 but can't find the correct coding. Anybody know the correct coding for a Mk2 TTS with DSG or know where to find potential options to try?
STEP1: remove the fuse 9 from the fuse BOX drivers side.
STEP 2: open vcds
Go to-19-CAN GATEWAY-
Then INSTALATION LIST- un-click mag ride. Block 14-Susp. Elect.
STEP3:VCDS-
Go to 17-INSTRUMENTS CLUSTER-
CODING 07-change the value according to the bubble and equipment.Character 4(Value 64 = Magnetic Ride chassis).remove 64 from the coding!..
Was 0369288 now 0369224
STEP 4:vcds
55-Headlight Range
First Enter Security Access Codes
02000>03000>04000>05000 in sequence
Then -change coding to 0000010 = Headlight range control automatic/dynamic + four-wheel drive + steel springs (PR number 8Q3 + 1X1 + 1BA/1BV)(0000009 for front Wheel Car)..
From 0000025 to 0000024
STEP 5:vcds-
03-ABS module.this is the one...no bubble for help in coding.
Change Coding
Was: 0618294 tried 0610102 also tried 06100678 and neither of them work
PeteJ
C?ID=340777
Tuesday,15,September,2020,18:39:09:24295
VIN: TRUB1AFKXE1003970   License Plate:
Mileage: 105560km-65591mi   Repair Order:
Chassis Type: FK (7N0)
Scan: 01 02 03 08 09 0F 14 15 16 17 19 22 25 42 44 46 47 4C 52 55
          61 77
VIN: TRUB1AFKXE1003970   Mileage: 105560km-65591miles
14-Susp. Elect. -- Status: Malfunction 1010
4C-Tire Pressure II -- Status: Malfunction 0010
Address 01: Engine (CDM)       Labels:. 06F-907-115-CDL.clb
   Part No SW: 8J0 907 115 BF    HW: 8P0 907 115 B
   Component: 2.0l R4/4V TFSI  02 0010
   Revision: 5BH21---    Serial number: AUX7Z0M6FNA00S
   Coding: 0113010A1C0F0160
   Shop #: WSC 01236 785 00200
   VCID: 71BF29125DACF4F3ADD-8024
Readiness: 0110 0101
   Part No SW: 02E 300 016 B    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4003
   Revision: 05652104    Serial number: 00001306160133
   VCID: 1373439A077066E3FF1-8046
Address 03: ABS Brakes        Labels: 8J0-614-517.clb
   Part No SW: 8J0 614 517 E    HW: 8J0 614 517 E
   Component: ESP MK60E1          0010
   Revision: 00H60001
   Coding: 0618294
   VCID: 2F3BEF6A8B18A203FB9-807A
00471 - Control Module for Elect. Regulated Dampers (J250)
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:33:03
                    Count: 8385
                    Count: 8229
                    Count: 44032
   Part No SW: 8J0 820 043 BH    HW: 8J0 820 043 BH
   Component: J255  Klima 1 Zone  0110
   Revision: 00H11009    Serial number: 00000001245958
   Coding: 1572900
   VCID: 6D87356241941013895-8038
   Part No SW: 8P0 907 063 AE    HW: 8P0 907 063 AE
   Component: BCM PQ35  H   113 0771
   Revision: AE113771
   Coding: 6E000B0FA81336242074C9E001100D4D50FE77AA3020D928DC000A440041
   Shop #: WSC 01236 758 00200
   VCID: 77AB170A3FC8AAC3639-8022
   Subsystem 1 - Part No SW: 8J1 955 119 A    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: Wischer AU354  H09 0080
   Coding: 00FD10
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 02492C
   Part No SW: 8E0 035 593 R    HW: 8E0 035 593 R
   Component: SDAR SIRIUS     H09 0170
   Revision: 00000000    Serial number: AUZ4Z7N0625568
   Coding: 0000100
   VCID: 3829D4367E5665BBAA3-806C
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:32:10
01304 - Radio
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:32:05
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 8J0 910 376 F    HW: 8J0 907 376 F
   Component: J250 Raddaempfung   0110
   Revision: --H22---    Serial number: 190DPH 3150036
   Coding: 0000232
   VCID: 323DE61E982A8FEB947-8066
00142 - Left Front Dampening Adjustment Valve (N336)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:29:08
                    Voltage: 12.48 V
                    Voltage: 4.95 V
                    Bin. Bits: 00010010
                    Bin. Bits: 00010000
                    Ohms: 0.0
                    Resistance: 390.15 ohms
00143 - Front Right Dampening Adjustment Valve (N337)
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:29:08
                    Voltage: 12.48 V
                    Voltage: 4.95 V
                    Bin. Bits: 00010010
                    Bin. Bits: 00010000
                    Ohms: 0.0
00144 - Rear Left Dampening Adjustment Valve (N338)
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:29:08
                    Voltage: 12.48 V
                    Voltage: 4.95 V
                    Bin. Bits: 00010010
                    Bin. Bits: 00010000
                    Ohms: 0.0
00145 - Rear Right Dampening Adjustment Valve (N339)
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:29:08
                    Voltage: 12.48 V
                    Voltage: 4.95 V
                    Bin. Bits: 00010010
                    Bin. Bits: 00010000
                    Ohms: 0.0
Address 15: Airbags        Labels: 8J0-959-655.lbl
   Part No SW: 8J0 959 655     HW: 8J0 959 655
   Component: 20 Airbag 9.43  H03 0020
   Revision: 93H03002    Serial number: 0036K006MYDI
   Coding: 0012848
   VCID: 79AF113205DCBCB315D-802C
   Subsystem 1 - Part No: 8J0 959 339 C
   Component: BF-Gewichtsens. H04 0040
   Subsystem 2 - Serial number: 024N4
   Subsystem 3 - Serial number: 0001.01.0000H0400000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332DRB40F241195Kÿ†63
   Subsystem 5 - Serial number: 41195Kÿ†6342DRB40F244919Sÿ†63
   Subsystem 6 - Serial number: 44919Sÿ†63747RB406F0F756.ÿ†63
   Subsystem 7 - Serial number: 0F756.ÿ†63847RB406EFCEA2Eÿ
   Subsystem 8 - Serial number: FCEA2Eÿ
   Part No SW: 8P0 953 549 K    HW: 8P0 953 549 K
   Component: J0527           H38 0070
   Coding: 0014141
   VCID: 46D5AACE04A2034B28F-8012
   Component: E0221           H06 0030
01304 - Radio
Address 17: Instruments        Labels: 8J0-920-xxx-17-MY8.clb
   Part No SW: 8J0 920 990 T    HW: 8J0 920 990 T
   Component: KOMBIINSTR. VDO H05 0793
   Revision: D0H05007    Serial number: 2246M007000921
   Coding: 0369288
   Shop #: WSC 04339 002 104857
   VCID: 43D3B3DA379036630F1-8016
   Part No SW: 7N0 907 530 AL    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1642
   Revision:   H58       Serial number: 050713F1000140
   Coding: 354100
   Shop #: WSC 12345 123 61029
   VCID: 7AAD0E3E0CDAB7AB1C7-802E
                    Reset counter: 88
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:33:02
   Part No SW: 0BR 907 554 C    HW: 0BR 907 554 C
   Component: Haldex 4Motion      3018
   Coding: 0000005
   VCID: 45D7ADC239A40853215-8010
   Revision: D0H05007    Serial number: AUX7Z0M6FNA00S
   Part No SW: 8J8 959 801 J    HW: 8J8 959 801 J
   Component: Tuer-SG         004 0102
   Coding: 0001149
   VCID: 44D1B0C6329E315B36B-8010
   Part No: 8J0 909 144 R
   Component: EPS_ZFLS Kl. 241    3501
   Revision: 00H22000
   VCID: 3FDBBF2A5B7852836B9-806A
Address 47: Sound System        Labels: 8J0-035-223.lbl
   Part No SW: 8J0 035 223 D    HW: 8J0 035 223 D
   Component: J525 Amp High   H04 0160
   Revision: PROD_01     Serial number: 00000000048557
   Coding: 0236116
   VCID: 25170D42D9E4E853015-8070
16349 - Control Module - Error in Output Stage
                    Fault Status: 00101110
                    Fault Frequency: 73
                    Mileage: 102915 km
                    Date: 2020.04.10
                    Time: 13:04:09
01304 - Radio
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:32:07
Address 4C: Tire Pressure II        Labels: 8J0-907-274.lbl
   Part No SW: 8J0 907 274 C    HW: 4F0 907 274
   Component: J793  RKA+      H04 0190
   Revision: 00000518    Serial number: 00005180083923
   Coding: 0614600
02214 - Tire Pressure Warning
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:31:59
                    Hex Value: 0x0080
                    Hex Value: 0x0000
                    Hex Value: 0x0001
                    Voltage: 11.90 V
                    Temperature: 24.0°C
                    (no units): 0.0
   Part No SW: 8J8 959 802 J    HW: 8J8 959 802 J
   Coding: 0001148
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000025
   VCID: 2B03FB7ABF00DE23D71-807E
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH05 0030
                    Fault Status: 11100101
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:31:59
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:33:02
   Component: Batt.regelung H58 1642
   Coding: F324115A
   VCID: 71BF291251ACF4F3ADD-8024
   Serial number: 5216710903
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005178910
   Coding: 0001277
   VCID: 3635DA0E744293CBB8F-8062
02503 - Output Wire to Radio
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:31:59
01304 - Radio
                    Reset counter: 48
                    Mileage: 105569 km
                    Date: 2020.09.15
                    Time: 18:31:59
End----------(Elapsed Time: 01:27, VBatt start/end: 12.1V/12.1V)-----------
PeteJ
C?ID=340777
AutoScan posted. The odd thing is that after running through the steps in the first post I now cannot clear the codes at all and have an Adaptive headlight failure and TPMS warning that won't go away...I had to reset the TPMS and relearn the headlight position so those warnings are gone but I still cannot code out the Mag Ride.
dieseltje
The Netherlands
C?ID=148044
Is this the scan after the steps you mentioned?
PeteJ
C?ID=340777
was after the steps I posted and then I had to revert back to the original settings because it didn't work.
dieseltje
The Netherlands
C?ID=148044
Did you pull both fuses. As i remember the computer for dcc has twi if them one for switchend 12v and one non switched.
PeteJ
C?ID=340777
I only removed fuse number 9. I do want to clarify, it is the last step in the process that I am struggling with, the one to properly set the ABS module.
dieseltje
The Netherlands
C?ID=148044
As long there is signal from your DCC module you will get errors
PeteJ
C?ID=340777
Understood on the DCC fuse.
My original question still stands, or are you saying that I do not have to recode the ABS to take into account that the vehicle no longer has Mag Ride? That is what I am trying to do.
For example on the older cars in the 03-ABS module coding 0026177 was for (quattro+mag ride+dsg+v6 engine+340mm brakes).
dieseltje
The Netherlands
C?ID=148044
For my Passat B6 I did not have to recode my ABS for DCC.
To my idea DCC doesn’t interfeer breakes.
United States
I believe you will need to change 03-ABS from Coding: 0618294 -to- 0610102
096F36 | 0618294
094F36 | 0610102
PeteJ
C?ID=340777
Per the original post I tried that code and it did not work.
"STEP 5:vcds-
Change Coding
Was: 0618294 tried 0610102 also tried 06100678 and neither of them work"
United States
OK. If you have a Auto-Scan in that condition please post it. Backups, even if they weren't manually saved, end up in C:\Ross-Tech\VCDS\Scans
dieseltje
The Netherlands
C?ID=148044
As long you don't pull both fuses, the DCC is communicating with ABS.
I suggest to pull both fuses, and than have a canbus rest period of a few minutes. There must be no sign of module 14 in the installation list.
In the scan you posted, the DCC module is still in your installation list. When it is not in your list, it will give code "not registered"
I expect that you will be able to code your ABS after complete deleted module 14 from instal list. You will not see anything then in the scan/log
