2011 Touareg TDI N82 valve test???
1975 Kombi
Acton, Ontario, Canada
C?ID=211204&TC=1
Is there a way to test the N82 valve via vagcom?? I have no heat in my Touareg so I'd like to check the valve. I believe it is either the electronic control head or the heater control valve (N82).
1975 Kombi
C?ID=211204&TC=1
There was no code thrown but the valve was not working. I have replaced the valve with a section of heater hose and now I have heat. Seems the valve works in both directions (open and closed) and is working on the bench but must have been stuck in the closed position is the car. I'm not sure if it will come back to life once installed again. I did a scan while the test heater hose was installed and it threw a HVAC code for the heater valve.
So I was wondering if there was a way to test the valve while installed? Via sending a signal to open and then to close. I'm hoping it is not the heater control unit in the console that has failed and not sending the signal to the valve.
In order to check if there's a test, we need to see exactly what HVAC module this vehicle has. Hence the request for an Auto-Scan.
1975 Kombi
C?ID=211204&TC=1
Chassis Type: BP-VW52 (7P6)
Scan: 01 02 03 05 08 09 15 16 17 19 36 42 46 52 53 56 5F 62 65 69
          6D 72
VIN: WVGFK9B   Mileage: 249149km-154814miles
Address 01: Engine (J623-CATA)       Labels:. 059-907-401-V2.clb
   Part No SW: 7P0 907 401 J    HW: 7P0 907 401 E
   Component: 3.0TDI FSA    H17 0008
   Revision: 56H17---
   Coding: 292A4012233600050000
   Shop #: WSC 93363 999 00000
   ASAM Dataset: EV_ECM30TDI0117P0907401J 002007
   ROD: EV_ECM30TDI0117P0907401J_002.rod
   VCID: 366328098965F636F9-8062
Readiness: 0 0 0 1 1
   Part No SW: 0C8 927 750 G    HW: 0C8 927 750 G
   Component: AL1000 AISIN  001 3407
   Coding: 00B368
   Shop #: WSC 57463 002 104857
   ROD: EV_TCMAL991031_002.rod
   VCID: 306F1E116B01D806A3-8064
Address 03: ABS Brakes (J104)       Labels:* 7P0-907-379.clb
   Part No SW: 7P0 907 379 K    HW: 7P0 907 379 A
   Component: MK25A         H36 0418
   Revision: --------    Serial number: 410510010EC010
   Coding: 5B7613C349242559DAFAC89492D9A4407700
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_MK25AXT 007001
   ROD: EV_ESPMK25A00700.rod
   VCID: 45815FC5C4836DAE60-8010
   Part No SW: 4H0 907 064 AK    HW: 4H0 907 064 AK
   Component: BCM2 2.0      H24 0217
   Coding: 0D860000000000000000
   VCID: 72EBD419AD8DAA1615-8026
   Subsystem 1 - Part No SW: 4H0 905 852 B    HW: 4H0 905 852 B
   Serial number: 3216000013415007
Address 08: Auto HVAC (J255)       Labels:| 7P6-907-040.clb
   Part No SW: 7P6 907 040 AG    HW: 7P6 907 040 AG
   Component: Klima 2 Zonen H18 0613
   Coding: B686000A80
   VCID: 79F9E335F8FBD94E54-802C
   Part No SW: 4H0 907 063 L    HW: 4H0 907 063 D
   Component: BCM1 2.0      H12 0092
   Revision: 15012002    Serial number: 00000001038483
   Coding: 69000012873C5D010004000380005F5F431C660882000261800000000000
   VCID: 31691B15680BD10EAC-8064
   Subsystem 1 - Part No SW: 7P0 955 119     HW: 7P0 955 119   Labels: 1KX-955-119.CLB
   Component: WWS    110410  31  0020
   Serial number: 90243400110414020710
   Coding: 004DBD
   Subsystem 2 - Part No SW: 7P0 955 559 D    HW: 7P0 955 559 D  Labels: 8K0-955-559.CLB
   Component: RLFS  H09 0011
   Serial number: 10156813
   Coding: 035223
   Subsystem 3 - Part No SW: 7P6 941 431 E    HW: 7P6 941 431 E
   Component: E1 - LDS  H04 0031
   Serial number: 00000000000604110089
   Subsystem 4 - Part No SW: 4H0 907 410 A    HW: 4H0 907 410 A
   Component: USHL4.2  H30 0020
   Serial number: 0000001805569R0CFB06
   Subsystem 5 - Part No SW: 4H0 907 705 J    HW: 4H0 907 705 C
   Component: EVLS-SG  H08 0280
   Serial number: WA102408000000239210
   Coding: 010300
Address 15: Airbags (J234)       Labels:| 7P0-959-655.clb
   Part No SW: 7P0 959 655 B    HW: 7P0 959 655 B
   Component: VW10Airbag025 H05 0023
   Revision: --------    Serial number: 003JX002AHA8
   Coding: 000000000000000000000000000000003235
   ROD: EV_AirbaVW10BPAVW526_001.rod
   VCID: 408F4ED1DBA1488653-8014
   Subsystem 1 - Part No SW: 7P6 959 339     HW: 7P6 959 339
   Component: BF-Gewichtss.  003 0005
   Serial number: 5850000R10B0902D28
   Serial number: 3575LRB40590G690EGJ5
   Serial number: 3585LRB40590G69071HP
   Serial number: 3515RRB405B0GQ8Q8P81
   Serial number: 3525RRB405B0GQ8QK8K9
   Serial number: 3555NRB405V0HBQUKP8+
   Serial number: 3565NRB405V0HBQUFOM7
   Part No SW: 4H0 953 568 B    HW: 7P6 953 507 A
   Component: Lenks.Modul   H08 0007
   Revision: --------    Serial number: 90815KDD0002D
   Coding: 000C15
   VCID: 326B14196D0DEA16D5-8066
   Subsystem 1 - Part No SW: 7P6 959 542     HW: 7P6 959 542
   Component: E221__MFL-TAS  H03 0027
   Serial number: 0073674
Address 17: Instruments (J285)       Labels:| 7P6-920-xxx-17.clb-SRI1
   Part No SW: 7P6 920 880 P    HW: 7P6 920 880 P
   Component: Kombi         H13 0239
   Revision: 11240062    Serial number: 658170411593006
   Coding: 0B37310023000008020004
   Shop #: WSC 93222 999 00000
   ASAM Dataset: EV_KombiUDSRBVW526 001013
   ROD: EV_KombiUDSRBVW526.rod
   VCID: 489F56F1F39170C69B-801C
   Part No SW: 7P6 907 530 C    HW: 7P6 907 530 A
   Component: GW-CAN-L-MOST H08 5202
   Revision: --------    Serial number: 00000000130987
   Coding: 0001037500
   ASAM Dataset: EV_GatewVW526UDS 001006
   ROD: EV_GatewUDS_VW52.rod
   VCID: 387F263183710046EB-806C
   Subsystem 1 - Part No SW: 7P0 915 181 A    HW: 7P0 915 181
   Component: Batt_Sensor  H07 0140
   Serial number: 00000000005650308704
   Part No SW: 4H0 959 760 D    HW: 4H0 959 760 D
   Component: MEM-FS        H08 0153
   Revision: AA000000    Serial number: 00000006072418
   Coding: 00581B0000004001000001010101202020202121202020
   VCID: 346712019719E426C7-8060
   Part No SW: 4H0 959 793 F    HW: 4H0 959 793 F
   Component: TSG FA        H07 0162
   Revision: --------    Serial number: 0000115321792
   Coding: 011D17205E00453005080000
   VCID: 3C773A21BF492C660F-8068
   Revision: 00002001    Serial number: 0147989591
   Coding: 01861E3A28B9509580A00620210000000000000000000000000000000000
   Subsystem 1 - Part No SW: 7P6 959 719     HW: 7P6 959 719
   Component: GTO BT  H19 0059
   Serial number: 285102155
   Subsystem 3 - Part No SW: 7P0 959 591     HW: 7P0 959 591
   Component: J245 PS30.050  H07 0006
   Serial number:     WOO11773474
   Coding: 191100
   Subsystem 4 - Part No SW: 7P0 959 591 A    HW: 4H0 959 591
   Component: J394 PS30.050  H07 0006
   Serial number:     WOO11781877
   Coding: 191100
   Part No SW: 4H0 959 792 F    HW: 4H0 959 792 F
   Component: TSG BF        H07 0162
   Revision: --------    Serial number: 0000115179356
   VCID: 3B75393DBA472B5E06-806E
Address 53: Parking Brake (J540-)       Labels:| 7P0-907-801.clb
   Part No SW: 7P0 907 801 E    HW: 7P0 907 801 E
   Component: EPB           H51 1100
   Revision: 00000000    Serial number: A11302000FF
   Coding: 01040000
   ROD: EV_ParkbA7.rod
   VCID: 35612F059463FD2EF0-8060
   Slave 3:
   Component: Radio U SIRIU H51 0133
   Revision: AB001007    Serial number: 471D+0B7573584
   Coding: 020007020100000001
   VCID: 2447E24127F974A657-8070
   Part No SW: 7P6 035 664 D    HW: 7P6 035 664
   Component: H-BN-NA       H43 0706
   Revision: --------    Serial number: 445DT0B7514036
   Coding: 010200050040E1EC41022B0C00000003F00001010000000000
   VCID: 39792335B07B194E14-806C
   Subsystem 1 - Part No: 7P6 060 884 J
   Component: NAR 2017/2018  1602
   Subsystem 2 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: DU8 SV Touch  H24 0045
   Serial number: VWZ8Z9L2900652
   Subsystem 3 - Part No SW: 7P6 919 603 C    HW: 7P6 919 603 C
   Component: CD-Database  1886
03175 - Invalid Data Set
                    Reset counter: 64
                    Mileage: 243591 km
                    Date: 2020.06.28
                    Time: 11:07:26
                    Voltage: 12.10 V
03623 - Invalid Security/Release Code
                    Reset counter: 64
                    Mileage: 243591 km
                    Date: 2020.06.28
                    Time: 11:07:27
                    Hex Value: 0x0004
                    Hex Value: 0x0009
                    Count: 7
   Part No SW: 4H0 959 795 B    HW: 4H0 959 795 B
   Component: TSG HL        H09 0162
   Revision: --------    Serial number: 0000115334906
   Coding: 011C17200000253005080000
   VCID: 3A7B3C39B57D12561D-806E
Address 65: Tire Pressure (J502)       Labels: 3Y0-907-273.clb
   Part No SW: 7P6 907 273 F    HW: 7P6 907 273 F
   Component: RDKBERU25     H09 0008
   Serial number: 10000000027751
   ASAM Dataset: EV_RDKBERU25 003006
   ROD: EV_RDKBERU25_VW52.rod
   VCID: 3F8D4D2DA65F377E2A-806A
Address 69: Trailer (J345)       Labels: Redir Fail!
   Part No SW: 7P0 907 383 F    HW: 7P0 907 383 B
   Component: Anhaenger     H09 0110
   Revision: 5A001001    Serial number: 00000146664417
   Coding: 020D000000000000
   Part No SW: 7P6 959 107     HW: 7P6 959 107
   Component: HDSG-Modul    H10 0611
   Revision: 22010001    Serial number: 101100597
   Coding: 0533314003
   ASAM Dataset: EV_HeckkTouar 202135
   ROD: EV_HeckkTouar.rod
   VCID: 7CF7FA21F7C9EC664F-8028
   Component: TSG HR        H09 0162
   Revision: --------    Serial number: 0000115333044
End-------------------------(Elapsed Time: 04:56)--------------------------
There's nothing explicitly for the N82 valve, I'd try this Output Test:
IDE01620-MAS01167 -- Maximum heat output
1975 Kombi
C?ID=211204&TC=1
Oddly I'm back sat this due to the cold temps in Ontario. lol. How do you go about testing? IDE01620-MAS01167 -- Maximum heat output
[Select]
[08-HVAC]
[Output Tests]
You should have a drop-box with a number of things that can be selected. One of them should be "Maximum heat output".
1975 Kombi
C?ID=211204&TC=1
Yep, tested full heat and nothing. Also, there is a test for coolant valve, and it didn't seem to produce heat. So could it be the hvac control panel not sending the info or it is the coolant valve for sure? lol. I just hate buying the wrong part.
I think it's have to trouble-shoot it with a wiring diagram and a meter to make a confident determination.
