A6 4F C6 Air suspension problems
Degen Pleb
Belgium
C?ID=417611
Short story here, just the facts
A6 Estate/Avant 2.7 V6 TDI.2009
AAS trouble.
Left front went down overnights.
Errors on Airsuspension (dashboard)
Bought two new (remanufactured) struts
Wanted to replace them myself.
Ran into trouble with the pinch bolts for the upper control arms.
Went to a friends workshop and heated those to get them to loosen up. Worked. Rubbers burned. New control arms ordered and placed.
Right front strut was in jacking mode. Had to pull down everything to replace that one.
So. 2 new front struts. Left normal, right pumped fully. (I drove the vehicle for about 1.5 months with the leaking left front strut)
Thought I'd forced the level sensor on that axle.
Go to a small garage.
They replace left AND right sensors. +$550 in costs.
Car still limp. They promised me they didn't reprogram the AAS controller. (they did)
Options were:
in order they wanted to do it:
Replacing the solenoid valve block ($550 + work)
Replacing the Compressor (no problems with that unit, as it pumps the airstruts just fine) $1300 + work
Replace the controller unit $1900 + work.
Or sell the car to them for +/-$2K
Went to get my car back.
Bought a new solenoid valve block on ebay, $73
Replaced that.forgot to set the car up on blocks.
Ran aground when releasing the airlines.Compressor wouldn't turn on because too low.
Sigh.
Put it on blocks
Bought VCDS + Hex Can V2
Erased error codes. Pumped everything.
Used these commands to fill:
Then did this:
Left and right equal now.
Front way lower than back however.
I hope it's a calibration issue. Will try to do that again and keep you all posted.
(oh. Audi would have charged me $8K for what's being done by now. I'm only $1750 down at this moment and more has been replaced)
Now error codes are gone. It does however go to jacking mode by itself. Any advice?
Hi and welcome. It would be appreciated if you would post an Auto-Scan for context.
Degen Pleb
Belgium
C?ID=417611
Wanted to calibrate once, didn't work out.
Now it jusy keeps at "wait" whilst pumping it 0.5Cm up and down.
Doesn't change to "value".
Any idea's?
Can't I measure the height of the wheelcentre to fender and write it into avalue field to take a recalibration from there?
@Dr Sheldon maybe?
Also, here's the VCDS log. There are some more issues.
Saturday,19,September,2020,22:23:45:18439
VIN: WAUZZZ4F49N041XXX   License Plate:
Mileage: 181340km-112679mi   Repair Order:
Chassis Type: 4F-AU56 (4F0)
Scan: 01 03 05 08 09 0E 15 16 17 19 34 42 46 4F 52 53 55 56 5F 62
          69 6D 72 76
VIN: WAUZZZ4F49N041XXX   Mileage: 181340km-112679miles
Address 01: Engine (CAN)       Labels: Redir Fail!
   Part No SW: 4F7 910 401 K    HW: 4F0 907 401 E
   Component: 2.7TDI EDC17G004SG  0090
   Revision: 16H01---    Serial number:
   Coding: 010D002C18070928
   Shop #: WSC 45892 002 1048576
   VCID: 2B0303356F01B023D71-807E
8 Faults Found:
               U1017 - 007 -  - Intermittent
                    Fault Status: 00100111
                    Mileage: 181206 km
                    Date: 2020.09.14
                    Time: 15:22:08
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
000135 - Fuel Rail/System Pressure
               P0087 - 005 - Too Low - MIL ON
                    Fault Status: 11100101
                    Mileage: 181344 km
                    Date: 2020.09.19
                    Time: 22:18:22
                    RPM: 609 /min
                    Inj. Quantity: 40.0 mg/str
                    Temperature: 46.8°C
                    Pressure: 92.3 bar
                    (no units): 5.0
                    Bin. Bits: 00110100
               P0087 - 003 - Too Low - Intermittent
                    Fault Status: 00100011
                    Mileage: 181207 km
                    Date: 2020.09.14
                    Time: 19:16:23
                    RPM: 1029 /min
                    Speed: 2.2 km/h
                    Inj. Quantity: 19.0 mg/str
                    Temperature: 46.8°C
                    Pressure: 482.8 bar
                    (no units): 5.0
                    Bin. Bits: 00110111
001649 - Cylinder 1 Glow Plug Circuit (Q10)
               P0671 - 000 - Electrical Fault
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
001650 - Cylinder 2 Glow Plug Circuit (Q11)
               P0672 - 000 - Electrical Fault
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
001653 - Cylinder 5 Glow Plug Circuit (Q14)
               P0675 - 000 - Electrical Fault
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
001654 - Cylinder 6 Glow Plug Circuit (Q15)
               P0676 - 000 - Electrical Fault
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
001025 - EGR System
               P0401 - 000 - Insufficient Flow
                    Mileage: 181342 km
                    Date: 2020.09.19
                    Time: 20:20:03
                    RPM: 1890 /min
                    Speed: 70.6 km/h
                    (no units): -22.0
                    (no units): 200.0
                    Inj. Quantity: 15.0 mg/str
                    Absolute Pres.: 1295.4 mbar
                    Temperature: 38.7°C
Address 03: ABS Brakes        Labels:
   VCID: 55F785CD1C05D6D3515-FFFE
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 D
   Component: FBSAUDIC6 ELV   H05 0100
   Revision: 00H05000    Serial number: 10602601271585
   Coding: 0000129
   Shop #: WSC 00751 202 97796
   VCID: 2517F50D09E58653015-8070
   Subsystem 1 - Part No: 4F0 910 132 D
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0040
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043 B    HW: 4F1 820 043 AL
   Component: KLIMABETAETIGUNGH30 0070
   Revision: 00000073    Serial number: 00000000606585
   Coding: 0000278
   Shop #: WSC 02325 785 00200
   VCID: 1D67DDED21B54E93595-8048
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 185
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 12:55:59
                    Temperature: 32.0°C
01853 - Heated Seat; Left Front (Z45)
                    Reset counter: 193
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 12:55:59
                    Temperature: 25.0°C
   Part No SW: 4F0 910 279 N    HW: 4F0 907 279
   Component: ILM Fahrer      H22 0320
   Coding: 0003121
   Shop #: WSC 02335 785 00200
   VCID: 34311849B23FEFDB86B-8060
   Subsystem 1 - Part No: 4F1 910 113 D  Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H10 0040
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
Address 0E: Media Player 1 (R41)       Labels: 4E0-910-111.lbl
   Part No SW: 4E0 910 110 L    HW: 4E0 035 110 A
   Component: CDC-MP3-Pana  H47 0050
   Revision: 00000012
   VCID: 211FE11D11CD6A737DD-8074
Address 15: Airbags (J234)       Labels:* 4F0-910-655-10.clb
   Part No SW: 4F0 910 655 L    HW: 4F0 959 655 E
   Component: Airbag AU1042 H06 0090
   Revision: --------    Serial number: 003CH003G5S+
   Coding: 30314236303630303031554A304C34463053
   Shop #: WSC 02324 785 00200
   ROD: EV_Airba10AURB4.rod
   VCID: 303914594AA7D3FBE23-8064
   Serial number: 3574SRB400008A0CC98J
   Serial number: 3584SRB400008A109ACB
   Serial number: 35152RB401R838NMPJG
   Serial number: 35252RB401T838NMVSUR
   Serial number: 3554NRB400004910A01L
   Serial number: 3564NRB4000048F9D306
   Part No SW: 4F0 910 549 A    HW: 4F0 953 549 D
   Component: J0527               0530
   Revision: 00H05000    Serial number: 90055090230174
   Coding: 0002042
   VCID: 270BFF0573E99443339-8072
   Component: E0221           H02 0030
Address 17: Instruments (J285)       Labels:. 4F0-920-xxx-17.clb
   Part No SW: 4F0 920 933 L    HW: 4F0 920 933 L
   Component: KOMBIINSTR.   H06 0135
   Revision: 00100000    Serial number: AE7416329
   Coding: 0F74100502010008010100
   Shop #: WSC 02391 823 56573
   VCID: 303914594A27D3FBE23-8064
   Part No SW: 4F0 907 468 K    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0025
   Revision: 4LA80024    Serial number: 2400L0912082D2
   Coding: 000303
   VCID: 372B2F45AF4904C3A39-8062
   Subsystem 1 - Part No SW: 8K0 915 181 C    HW: 8K0 915 181 C
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140416978
Address 34: Level Control        Labels: 4F0-910-553.clb
   Part No SW: 4F0 910 553 C    HW: 4F0 907 553 A
   Component: J197 LUFTFEDER  H17 0030
   Serial number: 00871000523500
   Coding: 0000120
   VCID: 2411E80902DF7F5B16B-8070
01437 - Control Position not Learned
                    Reset counter: 193
                    Mileage: 181335 km
                    Date: 2020.09.18
                    Time: 19:09:56
01780 - Sensor for Vehicle Leveling
                    Reset counter: 233
                    Mileage: 181337 km
                    Date: 2020.09.19
                    Time: 10:50:02
   Part No SW: 4F0 959 793 R    HW: 8K0 959 793 D
   Revision:             Serial number: 0000100694282
   Coding: 011C06205040410001
   VCID: 46D55281D8A36D4B28F-8012
                    Fault Status: 01101000
                    Fault Frequency: 26
                    Reset counter: 193
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 13:59:08
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 K    HW: 4F0 907 289 K
   Component: Komfortgeraet   H27 0220
   Revision: 02200027    Serial number: 01170635240000
   Coding: 3277553
   VCID: 323D1E51482BE1EB947-8066
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
01502 - Bulb for Rear Fog; Left (L46)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 189
                    Mileage: 181207 km
                    Date: 2020.09.14
                    Time: 19:06:35
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H13 0100
   Revision:             Serial number: 00000000613555
   Coding: 0001103
   VCID: 5EE59AE16C33158B00F-800A
   Part No SW: 4F0 959 792 R    HW: 8K0 959 792 D
   Revision:             Serial number: 0000100691911
   VCID: 45D7558DE5A56653215-8010
Address 53: Parking Brake
   Part No: 8P0 907 357 H
   Coding: 0000004
   VCID: 3FDB47658B793C836B9-806A
   Part No SW: 4F0 035 056 K    HW: 4F0 035 056
   Component: Radio U STD   H45 0074
   Revision: AB001007    Serial number: 342BR097562705
   Coding: 010003020100000000
   VCID: 2809FC3972F79B3B3A3-807C
   Part No SW: 4E0 035 666 K    HW: 4E0 035 666
   Component: H-BN-EU       H64 0187
   Revision: --------    Serial number: 345B/097545858
   Coding: 01010001010293FD03002F15EF6300030001
   VCID: 2E050A215013C50BF0F-807A
   Subsystem 1 - Part No: 8R0 060 884 ED
   Component: EUR 2017  2402
   Component: DU7 High  H43 0306
   Serial number: 9356B-091058598
   Subsystem 3 - Part No SW: 4F0 910 609 E    HW: 4F1 919 611 S
   Component: Bedienteil MM  H01 0060
   Serial number: 00000001261611
                    Reset counter: 185
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 12:55:59
                    Voltage: 14.30 V
03175 - Invalid Data Set
                    Reset counter: 185
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 12:55:54
                    Voltage: 14.30 V
   Part No SW: 4F0 959 795 M    HW: 8K0 959 795 B
   Revision:             Serial number: 0000100718138
   Coding: 010804204040220001
   VCID: 43D34B95EB9158630F1-8016
Address 69: Trailer (J345)       Labels:. 4F0-907-383.clb
   Part No SW: 4F0 907 383 D    HW: 4F0 907 383 D
   Component: Anhaenger     H08 0080
   Revision: 2B002002    Serial number: 00000116967871
   Coding: 0103030000000000
   VCID: 2C010029660FB71BDEB-8078
   Part No SW: 4F9 910 591     HW: 4F9 827 851 G
   Component: ValeoHeckdeckel H29 0410
   Revision: --H29001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: 6C81C029AA8F771B9EB-8038
   Subsystem 1 - Part No: 4F9 910 592
   Subsystem 3 - Serial number: RD05.02.09--H29001001C0120ÿ
   Subsystem 4 - Serial number: 1C0120ÿ
   Revision:             Serial number: 0000100703822
   Part No SW: 4L0 910 283     HW: 4L0 919 283
   Component: Parkhilfe 4-Kan H02 0400
   Revision: 00H02000    Serial number: 13730902302294
   Coding: 0010016
   VCID: 678BBF05B3695443F39-8032
End----------(Elapsed Time: 01:56, VBatt start/end: 14.2V/14.1V)-----------
Adaptation Channel 001:
Stored value 0
Left Front Wheel/Height Calibration
  Wait
  Low Level
  Initiate
Stored value 0
  Wait
  Low Level
  Initiate
          69 6D 72 76
VIN: WAUZZZ4F49N041XXX   Mileage: 181360km-112691miles
34-Level Control -- Status: Malfunction 1010
8 Faults Found:
                    Mileage: 181206 km
                    Date: 2020.09.14
                    Time: 15:22:08
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
               P0087 - 005 - Too Low - Intermittent
                    Fault Status: 00100101
                    Mileage: 181344 km
                    Date: 2020.09.19
                    Time: 22:18:22
                    RPM: 609 /min
                    Temperature: 46.8°C
                    Pressure: 92.3 bar
                    (no units): 5.0
                    Bin. Bits: 00110100
                    Mileage: 181207 km
                    Date: 2020.09.14
                    Time: 19:16:23
                    RPM: 1029 /min
                    Speed: 2.2 km/h
                    Temperature: 46.8°C
                    Pressure: 482.8 bar
                    (no units): 5.0
                    Bin. Bits: 00110111
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
001025 - EGR System
               P0401 - 000 - Insufficient Flow - Intermittent
                    Mileage: 181342 km
                    Date: 2020.09.19
                    Time: 20:20:03
                    RPM: 1890 /min
                    Speed: 70.6 km/h
                    (no units): -22.0
                    (no units): 200.0
                    Temperature: 38.7°C
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 AK    HW: 4F0 614 517 AT
   Component: ESP8 front      H03 0060
   Coding: 0000395
   VCID: 6D87CD2D91957E13895-8038
01310 - Level Control System Control Module (J197)
                    Reset counter: 194
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:39:29
                    Hex Value: 0x0000
                    Hex Value: 0x40A6
                    Hex Value: 0x0013
                    Hex Value: 0x2AAF
                    Hex Value: 0x00FF
   Coding: 0000129
   Coding: 0000278
                    Reset counter: 194
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:32:42
                    Temperature: 25.0°C
                    Reset counter: 194
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:32:42
                    Temperature: 25.0°C
   Coding: 0003121
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Revision: 00000012
   Coding: 0002042
                    Reset counter: 234
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:39:29
   Coding: 000303
                    Reset counter: 234
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:39:29
                    Bin. Bits:    01111
                    Voltage: 13.70 V
                    Count: 7
                    Bin. Bits:     1011
                    Time: 0.00 s
   Coding: 0000120
                    Reset counter: 194
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:32:37
   Coding: 3277553
                    Reset counter: 189
                    Mileage: 181207 km
                    Date: 2020.09.14
                    Time: 19:06:35
   Coding: 0001103
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0000511
   Shop #: WSC 02145 785 00200
   VCID: 211FE11D1DCD6A737DD-8074
   Coding: 0000004
                    Reset counter: 234
                    Mileage: 181368 km
                    Date: 2020.09.20
                    Time: 18:39:28
   Coding: 0010016
End----------(Elapsed Time: 01:57, VBatt start/end: 14.2V/14.2V)-----------
Address 19: DTCs cleared
          69 6D 72 76
8 Faults Found:
                    Mileage: 181206 km
                    Date: 2020.09.14
                    Time: 15:22:08
                    Bin. Bits: 00101100
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Mileage: 181344 km
                    Date: 2020.09.19
                    Time: 22:18:22
                    RPM: 609 /min
                    Temperature: 46.8°C
                    Pressure: 92.3 bar
                    (no units): 5.0
                    Bin. Bits: 00110100
                    Mileage: 181207 km
                    Date: 2020.09.14
                    Time: 19:16:23
                    RPM: 1029 /min
                    Speed: 2.2 km/h
                    Temperature: 46.8°C
                    Pressure: 482.8 bar
                    (no units): 5.0
                    Bin. Bits: 00110111
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
                    Mileage: 181261 km
                    Date: 2020.09.15
                    Time: 11:19:43
                    RPM: 756 /min
                    Speed: 5.6 km/h
                    Voltage: 13.22 V
                    Temperature: 23.4°C
                    Lambda: 18.8 %
                    Temperature: 21.6°C
001025 - EGR System
                    Mileage: 181342 km
                    Date: 2020.09.19
                    Time: 20:20:03
                    RPM: 1890 /min
                    Speed: 70.6 km/h
                    (no units): -22.0
                    (no units): 200.0
                    Temperature: 38.7°C
   Coding: 0000395
   Coding: 0000129
   Coding: 0000278
                    Reset counter: 194
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:56:27
                    Temperature: 26.0°C
                    Reset counter: 194
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:56:27
                    Temperature: 25.0°C
   Coding: 0003121
   Coding: 00056595
   Shop #: WSC 02335
   Coding: 00146221
   Shop #: WSC 02335
   Revision: 00000012
   Coding: 0002042
   Coding: 000303
   Coding: 0000120
                    Reset counter: 194
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:56:22
   Coding: 3277553
                    Reset counter: 189
                    Mileage: 181207 km
                    Date: 2020.09.14
                    Time: 19:06:35
   Coding: 0001103
   Revision: --H05---
   Coding: 0000511
   Coding: 0000004
                    Reset counter: 194
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:56:27
                    Voltage: 14.20 V
                    Reset counter: 194
                    Mileage: 181361 km
                    Date: 2020.09.20
                    Time: 18:56:24
                    Voltage: 14.10 V
   Coding: 0010016
End----------(Elapsed Time: 01:48, VBatt start/end: 14.2V/14.2V)-----------
Under what circumstances does the "Sensor for Vehicle Leveling -- Mechanical Failure" fault come back if you clear it?
Have you looked through the measuring values in that module to see if one is obviously wrong? I would start with MVBs 004 and 005.
Degen Pleb
Belgium
C?ID=417611
How would I know which sensor this is?
Is this the one mounted on the strut itself, or would this be the the sensor mounted behind the wheel that is also used for the Xenon lights?
Also, I read out everything and clear all DTC's before trying to calibrate.
Could it be the small garage forgot to recode these new sensors, and would this give the same error?
And Thanks for all your answers!
Degen Pleb
Belgium
C?ID=417611
So I did these tests
004 returns "Reg. position not learned"
005 returns "Reg. position not learned"
But:
011 returns:
Left front height deviation: 127.0 mm
Right front height deviation: 5.0 mm
Left rear height deviation: 7.0 mm
Right rear height deviation: 5.0 mm
So there's definately a readout/sensor error, since the vehicle is pretty level.
But I don't know which sensors do these readouts; I'm guessing for the front these would be parts
4F0 941 285 B and 4F0 941 286 B
But I had those replaced....
I workplace manual would come in handy now to check if these are installed correctly and to see where the wiring goes to.
Tested some more, engine running, when turning the steering wheel, Left front height deviation flips from 128.0 mm to -128.0 mm.
So... Cabling or sensor?
Degen Pleb
Belgium
C?ID=417611
Went back to the garage. They didn't even want to look at it anymore. "THE SENSOR IS CORRECTLY INSTALLED AND WORKING" Is what I got back. SMFH.So I shall look the mounting instructions up. Thanks again.
Update:
I just remembered, since Audi didn't want to give me the partnrs for the struts I had to take off the wheel to identify the part. Of which I took pics.
Checking those pics, I luckily had one that included the old sensor. And indeed, the small expensive garage that mounted 2 sensors, whereas we agreed on mounting only one, mounted the sensor that I didn't want replaced wrong. And charged me bigtime for it.
Degen Pleb
Belgium
C?ID=417611
Found a great site, showing all systems in every Skoda/VW/Seat and Audi I'd like to share:
Translation is in order. Use it in Edge browser for automatic translation for instance.
Degen Pleb
Belgium
C?ID=417611
Update;
-after reinstalling the sensor correctly
-after bleeding the front axle to get it a bit more even (using http://wiki.ross-tech.com/wiki/index.php/Level_Control_Bleeding/Charging)
I drove to an underground parkinglot, which tends to be 100% flat, and started the calibration procedure, which succeeded!
Thank you all very much for the tips!
Onwards to solve the other misery that is stored in this car's DTC's!
Degen Pleb
Belgium
C?ID=417611
This error comes back after driving the car.
                    Reset counter: 233
                    Mileage: 181599 km
It then greys out the suspension options on the MMI
Stopping the car and starting it again gives me my suspension options in MMI back.
I would suspect the sensor being broken after being placed wrong.
Leaving it on the driveway, engine running for 5 minutes, doesn't trigger the error.
Any tips are welcome.
Degen Pleb
Belgium
C?ID=417611
Front sinks and blows up again overnight several times. Am I looking at 2 leaky struts or lines.
Also, despite callibration, left and right measure +/- 4cm difference. Can this difference be due to balancing the wheels?
