AUDI Q5 FY Coding required, after mounting hook ELECTRIC BOSAL
MAISNER
Iasi, Romania
C?ID=61532
Monday,14,September,2020,07:36:12:08687
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Workshop Code: 111 91742 011969
VIN: WAUZZZFYXJ2072499   License Plate:
Chassis Type: FY-AU49 (4M4)
Scan: 01 02 03 08 09 13 15 16 17 19 22 29 39 42 44 46 52 5F 69 6C
          6D 81 8B A5 AC BB BC
VIN: WAUZZZFYXJ2072499   Mileage: 38720km-24059miles
69-Trailer -- Status: Not registered 0011
Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 CE    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H35 3928
   Revision: B1H35---
   Coding: 2A654032256605083408
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM20TDI01104L906026CE 004004
   ROD: EV_ECM20TDI01104L906026CE_004.rod
   VCID: EFAE415C36BC63FE7A-80BA
17156 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 38720 km
                    Date: 2020.09.14
                    Time: 07:33:28
                    Engine speed: 0.00 /min
                    Coolant temperature: 47 °C
                    Intake air temperature: 47 °C
                    Voltage terminal 30: 11.820 V
                    Acceleration: 0.000 m/s˛
                    Cruise Control System (CCS): status-Bits 0-7: 2
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 0
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 128
                    Drivetrain coord: cause of shutdown in cruise cntr and ACC mode-Bits 0-7: 2
                    Drivetrain coordinator: brake fault status-Bits 0-7: 0
                    Accelerator pedal travel: raw value: 0.00 %
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
Address 02: Auto Trans (J217)       Labels:* None
   Part No SW: 80A 927 155 BA    HW: 0CJ 927 156
   Component: 0CJ 20TDI RdW H04 0001
   Revision: --H04---    Serial number: 0000000245
   ASAM Dataset: EV_TCMDL382021 002027
   ROD: EV_TCMDL382021_AU49.rod
   VCID: E99A2F4408588DCE24-80BC
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  0C4 0572
   Serial number: 75117081170209002243
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 80A 907 379 C    HW: 80A 907 379 A
   Component: ESP9 Premium  H13 0767
   Coding: 14AA48BE28A90A9891A2589A208652A2E4A5D228121450891A044A4527A54B
   ROD: EV_ESP9BOSCHCMP_002.rod
   VCID: AF2E815CF63C23FE3A-80FA
   Part No SW: 80A 820 043 K    HW: 80A 820 043 K
   Component: Klima Zone 3  H55 0210
   Coding: 641800295544400D02000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: A5026374A4C069AEC0-80F0
   Subsystem 1 - Part No SW: 4M1 820 021 A    HW: 4M1 820 021 A
   Component: J126 FLuftV  H08 0003
   Serial number: 00000000000001834206
   Component: AQ_Hum_Sensor  H01 0006
   Serial number: E9A0D3B880PAG0MUFU02
   Subsystem 3 - Part No SW: 80A 919 158     HW: 80A 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 CG    HW: 8W0 907 063 BG
   Component: BCM1 MLBevo   H13 0267
   Coding: C2501942C17900CD054500109C2E00F9110B3108000000000000000020001A010041002B025605
   VCID: 824818E8152E7E9685-80D6
   Subsystem 1 - Part No SW: 80B 955 119     HW: 80B 955 119
   Component: 426 LL 170821  040 0570
   Serial number: 00000001708182100121
   Coding: 5FC7F7
   Serial number: 20557193X81A955555A0
   Coding: 02006E
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 26 09 2017  72690700
   Serial number: GX1CE115091723810743
   Interior Light Module:
   Subsystem 5 - Part No SW: 80A 947 135 D    HW: 80A 947 135
   Component: Dachmodul Q5  H31 0310
   Serial number: Q00007506
   Coding: 010104
   Subsystem 6 - Part No SW: 8W0 925 301 BD    HW: 8W0 925 301 BD
   Component: SL-B9/Q5NF  H17 0010
   Serial number: 2617000191038004
   Part No SW: 80A 907 561     HW: 8W0 907 561
   Component: LRR4          H10 0220
   Coding: 3473FF6258FFEC0A949C80A4
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: E5822374E440A9AE00-80B0
1229 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.14
                    Time: 07:33:28
                    Control Module temperature: 29 °C
                    Voltage terminal 15: 11.7 V
                    Longitudinal_acceleration_vehicle_reference: 0.00 m/s˛
                    Status_ACC_System: ACC_Init
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.14
                    Time: 07:33:28
   Part No SW: 80A 959 655 N    HW: 80A 959 655 N
   Component: AirbagVW30    031 0513
   Serial number: 003WBM02GTPB
   Coding: AACCF0C00C800000985400FFF00C40000065
   ASAM Dataset: EV_AirbaVW31SMEAU65x 001006
   ROD: EV_AirbaVW31SMEAU65x_AU49.rod
   VCID: BE30AC182156DA76A1-80EA
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 80A857705G0209R00298
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 80A857706G0208R01023
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 480 001 807 17
   Serial number: 3570000000047C312528
   Subsystem 4 - Part No SW: -----------    HW: 480 001 807 17
   Serial number: 3580000000011374D529
   Subsystem 5 - Part No SW: -----------    HW: 480 030 501 17
   Serial number: 351000C1C8BAB5305FBR
   Subsystem 6 - Part No SW: -----------    HW: 480 032 001 17
   Serial number: 352000C1C8B0F610AC3F
   Subsystem 7 - Part No SW: -----------    HW: 480 031 108 17
   Serial number: 355000C244F2B5704867
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 480 031 108 17
   Serial number: 356000C244FAB2A0ED1Q
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 480 031 608 17
   Component: PedP_Sensor_C  002 0149
   Serial number: 230000C24E41F9705B7A
   Subsystem 10 - Part No SW: -----------    HW: 480 000 307 17
   Serial number: I0M0000000009775C2A6
   Subsystem 11 - Part No SW: -----------    HW: 480 000 307 17
   Serial number: I0N0000000012775C2A1
   Central Sensor XY:
   Subsystem 12 - Part No SW: -----------    HW: 480 022 807 17
   Component: CentrSensorXY  000 0108
   Serial number: I0O00019F2552CF2B293
1060617 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_CW]
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.14
                    Time: 07:33:28
1060614 - Databus
          [NWD: 0xTBD SDF_PSF_01 error value SDF_PSF_Time_To_Collision]
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.14
                    Time: 07:33:28
Address 16: Steering wheel (J527)       Labels: None
   Part No SW: 80A 907 129 AG    HW: 80A 907 129 AG
   Component: Lenks.Modul   H02 0003
   VCID: ED925B543CB091EE48-80B8
   Part No SW: 8W5 920 790 D    HW: 8W5 920 790 D
   Component: FBenRDW       H18 0371
   Coding: 05848EC4AC8000080A83E9601000400000000000
   VCID: C3C6DDEC4AB4B79ECE-8096
          U1014 00 [009] - -
          [ECU incorrectly coded]
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.14
                    Time: 07:33:26
   Part No SW: 4M4 907 468 E    HW: 4M4 907 468 E
   Component: Gateway       H22 0119
   Revision: 6Y060004    Serial number: 04G6Y019817908
   Coding: 030100010000064041070000005900325C3A0007100000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 003092
   VCID: BC34A610374AC8668F-80E8
   Subsystem 1 - Part No SW: 80A 951 523 D    HW: 80A 951 523 D
   Component: J453 MFL  H06 0002
   Serial number: 20170924093116 00165
   Serial number: 3269835300
66304 - Databus
          U1124 00 [009] - Additional Installations Detected
          [Data_Bus_Commponent_List_detected]
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.14
                    Time: 07:33:00
Address 22: AWD (J492)       Labels:* None
   Part No SW: 80A 927 755     HW: 0CJ 927 749
   Component: Q5_DL3_N_SD4  H18 0004
   Serial number: 1722632446
   Coding: 01070000
   ASAM Dataset: EV_AWDCQUOD31 001048
   ROD: EV_AWDCQUOD31.rod
   VCID: EC94565007AA98E65F-80B8
Address 29: Left Light (J1018)       Labels: None
   Part No SW: 80A 907 397 A    HW: 80A 907 397 A
   Component: LCM_MLBevo    H06 0017
   VCID: AD129B54FC3051EE08-80F8
Address 39: Right Light (J1023)       Labels: None
   Part No SW: 8W1 959 393     HW: 8W1 959 393
   Component: TSG FS001 0737
   Serial number: CLSM1QEF00EDG
   Coding: 00100B004000048000001080
   VCID: 864004F8390642B6A9-80D2
   Part No SW: 4M0 909 144 H    HW: 4M0 909 144 B
   Component: EPS_MLBEVO1BS H22 0005
   Serial number: 0000980063
   Coding: B0002101000101
   ASAM Dataset: EV_EPSVWBSAU736 009023
   ROD: EV_EPSVWBSAU736_009.rod
   VCID: B4248E301F1A002647-80E0
   Part No SW: 8W0 907 064 DM    HW: 8W0 907 064 DM
   Component: BCM2 MLBevo   019 0366
   Coding: 01340000002000E0630180000600980033020000804F00502F00000000040030001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 013013
   ROD: EV_BCM2HellaAU736_013_AU49.rod
   VCID: 8A5830C82D1E26D6CD-80DE
   Part No SW: 8W1 959 392     HW: 8W1 959 392
   Component: TSG BFS001 0737
   Serial number: CLSM1QGE000X8
   VCID: 854203F4040049AEA0-80D0
   Part No SW: 8W5 035 036 A    HW: 8W5 035 036
   Component: MU-P-LN-EU    034 1117
   Serial number: A795H0H9096781
   Coding: 01240601FF00000013110001000A00102F00156501700100DE
   ASAM Dataset: EV_MUHig4CGen2HBAS 001115
   VCID: B620B4380966123679-80E2
   Subsystem 1 - Part No SW: V03 959 802 TH    HW: -----------
   Component: ECE 2020  --- 0184
   Subsystem 2 - Part No SW: 80A 919 605     HW: 80A 919 605
   Component: AU426_DU_HIGH  H42 0008
   Serial number: AUZ8Z9HBL024D2
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 80A 919 615     HW: 80A 919 615
   Component: ControlUnit_P  H15 0209
   Serial number: 04081700000000000408
   Compact Disc Database:
   Component: Gracenote2  --- 1016
12 Faults Found:
1585 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for ASAM/ODX MUX]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
                    Voltage terminal 30: 11.9 V
1586 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for speed shutoff thresholds]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1587 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for language]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1588 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for visible MMI system languages]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1589 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for power management timer]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1590 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for sound audio parameters]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1592 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for DAB frequency tables]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1595 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for audio management HMI constants]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1655 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for sound announcement audio parameters (optional)]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1656 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for sound cabriolet audio parameters (optional)]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1657 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for sound configuration audio parameters (optional)]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
1603 - invalid data record
          B2005 00 [009] - -
          [Control module (data record download) - invalid data record for speech signal enhancement - telephone/voice recognition signal processing (SSE)]
                    Reset counter: 238
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:12:46
   Part No SW: 4M0 907 383 D    HW: 4M0 907 383 B
   Component: Anhaenger     H20 0214
   Revision: 9A001003    Serial number: 0412526000
   Coding: 0110000202000000
   Shop #: WSC 75035 187 00000
   VCID: B3268D2C1A14071E5E-80E6
136203 - Supply Voltage
          P1757 00 [008] - Open Circuit
                    Mileage: 38671 km
                    Date: 2020.09.11
                    Time: 18:06:07
   Component: RVC Compact   H12 0250
   Coding: 0224060102002005420040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   Part No SW: 8W8 959 107 B    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0161
   Revision: --------    Serial number: ˙˙˙˙˙˙˙˙˙˙˙˙˙˙
   Coding: 0710
   VCID: C8DCCAC0739294C61B-809C
   Part No SW: 80B 713 041 G    HW: 80B 713 041 G
   Component: GSM-LL        H09 0077
   Revision: 0L0D5012    Serial number: 20170910006095
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: A10A7764B0E8858EBC-80F4
Address 8B: Adaptive Cruise 2 (J850)       Labels: 4M0-907-541.clb
   Part No SW: 80A 907 541     HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: E3863D6CEA74D79EEE-80B6
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 80A 907 217 A    HW: 80A 907 217 A
   Component: BVS           H15 0050
   Coding: 0404020600000401022023A4A50000FEB0F0C010C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
   VCID: A4047E70AFFA90A6D7-80F0
0646 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Variant_coding_failure]
                    Mileage: 38720 km
                    Control Module temperature: 18 °C
                    Voltage terminal 15: 11.90 V
Address AC: Reductant Control (J880)       Labels: None
   Part No SW: 80A 907 355 E    HW: 80A 907 355 D
   Component: SCR-Stg-G4H07 0003
   ASAM Dataset: EV_RDCMHelbaAU426 003010
   ROD: EV_RDCMHelbaAU426_003.rod
   VCID: AB16954CC2245FDE16-80FE
   Part No SW: 8W1 959 395     HW: 8W1 959 395
   Component: TSG HFS001 0737
   Serial number: CLSM1QGS000V6
   Coding: 000009000000048000001080
   VCID: 885C0AC0331254C6DB-80DC
   Component: TSG HBFS001 0737
   Serial number: CLSM1QGS0003R
End----(Elapsed Time: 01:54, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)----
Can you help me do the coding? Thanks
South Molton, UK
First steps:
1) Add 69 into the Installation List of 19.
2) Investigate the open circuit Supply Voltage in 69.
MAISNER
Iasi, Romania
C?ID=61532
MULȚUMESC REZOLV ACEST PAS CU CODAREA, 69 19 PUTEȚI MĂ ROG SĂ MĂ AJUTAȚI MAI MULT
MAISNER
Iasi, Romania
C?ID=61532
I UNDERSTUD I WAS WRONG WRITTING HERE SO I PLEASE A SUPERVISOR IF POSIBILE TO MOVE TO RETROFIT ACTION, MY APPOLOGISE FOR THAT HOPE NO HAPPEN AGAIN
Moved to Retrofits.
MAISNER
Iasi, Romania
C?ID=61532
Tuesday,15,September,2020,06:49:58:08687
   Revision: B1H35---
   Coding: 2A654032257605083408
   Shop #: WSC 91742 111 11969
17156 - Databus
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:21
                    Coolant temperature: 27 °C
                    Intake air temperature: 28 °C
                    Voltage terminal 30: 11.300 V
                    Cruise Control System (CCS): status-Bits 0-7: 6
   Coding: 5FC7F7
   Coding: 02006E
   Coding: 010104
          U1014 00 [009] - -
          [FAULT_CODING_AAG]
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:20
                    Control Module temperature: 35 °C
                    Voltage terminal 15: 11.2 V
2153 - Databus
          [FAULT_HC_STA_FAIL]
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:20
   Coding: 88001B
   Coding: 88001B
   Central Sensor XY:
1060617 - Databus
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:20
1060614 - Databus
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:20
   Coding: 05848EC4AC8000080A83E9603000600000000000
16776995 - Databus
          [ARA_01 communication error can_error_timeout]
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:21
   Coding: 01070000
12 Faults Found:
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
                    Voltage terminal 30: 11.5 V
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
          B2005 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:23
   Coding: 0710
          U1014 00 [009] - -
                    Reset counter: 242
                    Mileage: 38720 km
                    Date: 2020.09.15
                    Time: 06:47:19
                    Voltage terminal 15: 11.20 V
Sfârșit ---- (Timp scurs: 01:52, VBatt start / sfârșit: 11,3V / 11,3V. VIgn 11,3V) -
Hi can you help me make the codes? does anyone have a scan that I could use to compare the coding required for the towing system?
NEtech
Denmark
C?ID=56995
You have installed an Electrical Swivel towbar/hook ?
Then please post data from [69-Towbar] > [Advanced ID - 1A]
MAISNER
Iasi, Romania
C?ID=61532
Tuesday,15,September,2020,09:35:02:08687
VCDS Version: Release 20.4.2 (x64)
Address 69: Trailer
Control Module Part Number: 4M0 907 383 D
Component and/or Version: Anhaenger H20 0214
Software Coding: 0110000202000000
Work Shop Code: WSC 75035
Advanced Identification/FAZIT
Identification: HLH-W42
Revision: 9A001003
Date: 02.08.16
Manufacturer number: P007
Test stand number: 0028
Flash Status
Programming Attempts(application): 1/0
Programming Attempts(data): 1/0/0
Successful Attempts(data): 1/0/0
Flash Date: 00.01.01
Flash Tool Code(data): 1048576 002 21490
Misc.
Hardware number: 4M0 907 383 B
Workshop System Name: J345
Equipment/PR Code: 000000000000000000000002
Dataset Number: 80B909527A
Dataset Version: 0008
ASAM Dataset Revision: 001008
VCDS Info:
Labels: 5Q0-907-383.clb
cârlig ele
Yes, I electrically installed the towbar
MAISNER
Iasi, Romania
C?ID=61532
DO I NEED TO POST ANOTHER SCAN?
MAISNER
Iasi, Romania
C?ID=61532
Hello. Give me an idea where I can find the coding
NEtech
Denmark
C?ID=56995
If the towbar controller supports swivel and other controllers don't need parametrization, these coding maybe work.
Copy this file to C:\Ross-Tech\VCDS\Labels\User
Connect powerful battery charger.
Disable start/stop button or what is available for that on this model, if available.
[19-CAN Gateway] > [Installation list] > Check-mark at [69] > [Save coding]
Use [Coding-07] "Soft reset" check-mark for all except [01-Engine].
Explanation: Copy the changed coding and insert as new coding:
[Controller No.] > ”New Coding”
- Ignition OFF 1 minute
- Ignition ON > [Applications] > [Erase All DTCs]
- Ignition OFF 10 sec.
- Ignition ON > [Applications] > [Gateway Installation List] > Click red lines > Erase DTC in each ECU
[03] > 1448280AD1582052A2E4A5D2281214508B1A044A4527A54B First [Security Access-16] > S11820
[09] > C2501942C17900CD054500109C3E00F9110B3108000000000000000020001A010041002B125605 First [Security Access-16]
[09] > or C2501942C17900CD054500109C3E00F9110B3108000000000000000020001A010041002B025605 First [Security Access-16]
[13] > 3473FF6A58FFEC0A949C80A4 First [Security Access-16] > 20103
[17] > 05848EC4AC8000080A83E9601000600000000000
[46] > 01340000002000E0630180000600D80033020000804F00502F00000000040030001F0001000000 First [Security Access-16]
[6C] > 0224060103002005420040
[6D] > 0790 First [Security Access-16]
[A5] > 0404020600000401022023A5A50000FEB0F0C010C020
[01] > 2A654032257605083408
Test Trailer lights
Drive a trip, straight on highway
MAISNER
Iasi, Romania
C?ID=61532
Sunday,20,September,2020,16:04:43:08687
VIN: WAUZZZFYXJ2072499   Mileage: 38790km-24102miles
   Revision: B1H35---
   Coding: C2501942C17900CD054500109C3E00F9110B3108000000000000000020001A010041002B125605
   Coding: 5FC7F7
   Coding: 02006E
   Coding: 010104
   Coding: 3473FF6A58FFEC0A949C80A4
   Coding: 88001B
   Coding: 88001B
   Central Sensor XY:
   Coding: 05848EC4AC8000080A83E9601000600000000000
   Coding: 01070000
   Coding: 01340000002000E0630180000600D80033020000804F00502F00000000040030001F0001000000
12 Faults Found:
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
                    Voltage terminal 30: 12.0 V
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
          B2005 00 [009] - -
                    Reset counter: 246
                    Mileage: 38790 km
                    Date: 2020.09.20
                    Time: 15:47:08
   Coding: 0224060103002005420040
   Coding: 0790
   Coding: 0404020600000401022023A5A50000FEB0F0C010C020
End----(Elapsed Time: 02:00, VBatt start/end: 11.9V/11.8V. VIgn 11.9V)-----
Hello. Thank you from the bottom of my heart, my colleague NEtech for your help. Now I'm going to the tests.
