Audi A4 2006, Key reprogramming
draugen
Norway
C?ID=400067
Saturday,12,September,2020,16:34:35:48853
VIN: WAUZZZ8E36Axxxxxx   License Plate:
Mileage: 146750km-91186mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E36Axxxxxx   Mileage: 146750km-91186miles
Address 01: Engine        Labels: 03G-906-016-BKE.clb
   Part No SW: 03G 906 016 FE    HW: 028 101 212 7
   Component: R4 1,9L EDC 0000SG  9820
   Revision: 12345678    Serial number: AUX6Z0E0142358
   Coding: 0000071
   Shop #: WSC 00030 218 81387
   VCID: 6B83C17E9F9E1D03971-5184
   Part No SW: 8E0 910 517 D    HW: 8E0 614 517 AK
   Component: ESP8 front      H05 0120
   Coding: 0004401
   Shop #: WSC 06325 000 00000
   VCID: 2809FE724EF8F61B3A3-807C
   Part No: 8E0 820 043 BK
   Component:   A4 Klimaautomat   2832
   Coding: 00000
   VCID: 6B83C17E9A9E1D03971-513C
00716 - Air recirculation Flap Positioning Motor (V113)
            41-10 - Blocked or No Voltage - Intermittent
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  NDL 0504
   Coding: 11012
   Shop #: WSC 65536
   VCID: 3B23313EAA7E4D83471-4B00
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H11 3530
   Revision: 91H1135    Serial number: 0036M007R5C$
   Coding: 0033622
   VCID: 3B23313EAF6E4D83471-806E
   Subsystem 1 - Serial number: 6332DRB40228CE14Q
   Subsystem 2 - Serial number: 6342DRB402314E0DL
   Subsystem 3 - Serial number: 6352ARB40061D5D7R
   Subsystem 4 - Serial number: 6362ARB4007CA41CT
   Subsystem 5 - Serial number: 63729RB400BAA9FD8
   Subsystem 6 - Serial number: 63829RB400BAAA92-
                    Reset counter: 39
   Part No: 8E0 953 549 S
   Component: Lenksáulenmodul     0611
   Coding: 01012
   Shop #: WSC 06325
   VCID: 43D349DED28E35430F1-4B00
   Part No SW: 8E0 920 901 B    HW: 8E0 920 901 B
   Component: KOMBI+WFS 3     H12 0110
   Revision: 0110        Serial number: AUX6Z0E0142358
   Coding: 0006141
   Shop #: WSC 80093 222 69422
   VCID: 2411EA4232C0127B16B-5184
   Coding: 0006141
   Part No: 8E0 959 433 BQ
   Component: Komfortgerát T01    3332
   Coding: 06992
   Shop #: WSC 00027
   VCID: 015F83D68812E7535DD-4B00
   Subsystem 1 - Part No: 8E1959801H
   Component: Tõrsteuer.FS BRM 0506
   Subsystem 2 - Part No: 8E1959802B
   Component: Tõrsteuer.BF BRM 0205
   Component: Tõrsteuer.HL BRM 0506
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 0506
   Part No: 8E0 035 186 D
   Component: concert II  GRO    0004
   Coding: 01001
   Shop #: WSC 06325
   VCID: 2809FE724BD8F61B3A3-4B1E
End----(Elapsed Time: 05:26, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
I've got 2 key remotes for my car, but only on one of these does the remote work on. Found this (link) on the wiki pages and thought i try it out, seems to be correct for my chassis-code. Is there any chance of fussing it up (so that I can't start the car?) Immobilizer issues? Both keys work in the manual keyhole and both can start the car.
Thanks for all feedback.
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
Immobilizer is separate function of remote control in that car so programing remote it will not mess with immobilizer. But if remote was working before and stop , that probablywill be bad remote .
draugen
Norway
C?ID=400067
Thanks for the reply. That's good to know.
The remote has not worked since I bought the car, but it looks brand new. Will try the procedure in the wiki and revert with result :)
draugen
Norway
C?ID=400067
Procedure worked as intended, but the "new" key I had did not registrer, the other "old" working key had no problem with being re-adapted.
So it probably is bricked from factory. Will order new.
