2012 TTRS questions
donnyoneil
I've been logging on my 8J TTRS after purchasing it from Denver. I live in Houston and I'm trying to get all I can out of it. My main question is, can I truly go by the narrowband or ecu lambda or should I purchase and run a wide and AFR for an accurate number. I'm currently seeing .80-.83 at WOT in 3rd to redline. The car is coded for 92 octane but I'm running an e16 blend. Sorry if this is the wrong section or way to much to answer. It's hard to find stuff on the 2012-2013 TTRS. TIA
We don't have a "tuning" or "alternate fuels" section, so there no section that's an obvious fit for this. However, it doesn't belong in Tweaks, so I'll move it to the catch-all New User section for now. Incidentally it seems we have a permissions problem with the new forum software. You're not Verified and shouldn't have been able to post in Tweaks to begin with. :eek:
Now on to your question: Why do you have so little faith in the ECU's lambda readings?
