T5.1 Dsg locked in park
dioley
Cardiff, UK
H11-039770 (NRRT)
Hi can anyone tell me if the faults attached are contributing to my DSG being locked in park with the selection digits flashing red. Also my software cant communicate with my autobox or ECM?
cheers
Thursday,10,September,2020,11:39:14:61441
VIN: WV1ZZZ7HZFH072635   License Plate: KR64FZH
Chassis Type: 7H-VN75 (6N0)
Scan: 01 02 03 04 08 09 10 15 17 19 25 56 77
01-Engine -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes (-----)       Labels: 7E0-907-37x-MK25AXT.clb
   Part No SW: 7E0 907 379 L    HW: 7E0 907 379 L
   Component: ESP MK25A XT  H50 0113
   Revision: 00H50001
   Coding: 708724AD89AB0E9724A89174C96312
   Shop #: WSC 02737 790 49152
   VCID: 3B2333AE836AA0C3471-806E
                    Reset counter: 30
                    Mileage: 299687 km
                    Date: 2001.14.24
                    Time: 07:24:08
                    Count: 16448
                    Count: 1
                    Count: 8195
                    Count: 514
                    Reset counter: 2
                    Mileage: 299687 km
                    Date: 2001.14.24
                    Time: 07:24:08
                    Count: 16448
                    Count: 1
                    Count: 8194
                    Count: 514
   Serial number: 02111404651255
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EA5FABAD07875EB20F-802A
   Part No SW: 7E5 907 047 BN    HW: 7E5 907 047 BN
   Component: Climatic-T5   H20 0506
   Revision: 00001012
   Coding: 0000000002
   Shop #: WSC 02737 790 50316
   ROD: EV_ClimaT5Basis.rod
   VCID: 7CA1F0B2C66467FB0EB-8028
          U1111 00 [009] - -
          [Motorsteuergerät - kein Signal/Kommunikation]
                    Fault Frequency: 48
                    Reset counter: 2
                    Mileage: 298713 km
                    Date: 2065.14.15
                    Time: 10:18:38
9481746 - High Pressure Sensor
          B10AE 12 [009] - Short to Plus
                    Fault Frequency: 139
                    Reset counter: 2
                    Mileage: 300114 km
                    Date: 2065.14.25
                    Time: 13:39:09
9481748 - High Pressure Sensor
          B10AE 14 [008] - Open or Short to Ground
                    Reset counter: 42
                    Mileage: 300893 km
                    Date: 2065.14.29
                    Time: 00:09:28
9481769 - High Pressure Sensor
          B10AE 29 [008] - Signal Implausible
                    Fault Frequency: 17
                    Reset counter: 42
                    Mileage: 300893 km
                    Date: 2065.14.29
                    Time: 00:08:15
9480469 - Control Circuit for A/C Compressor
          B10A9 15 [009] - Open or Short to Plus
                    Reset counter: 2
                    Mileage: 300114 km
                    Date: 2065.14.25
                    Time: 13:38:29
   Part No SW: 7H0 937 087 P    HW: 7H0 937 087
   Component: BCM T5GP H+4  H34 0424
   Revision: BO034001    Serial number: 0673 301140576
   Coding: A0A4303A0A613433922848106C2B8C540080632F60840000320000000800
   Shop #: WSC 02739 790 00000
   VCID: 41DF4146E186CA131DD-8014
   Subsystem 1 - Part No SW: 7E0 959 801 K    HW: 7E0 959 801 K  Labels: 7E0-959-80X-V2.CLB
   Component: J386__TSG_FT  003 8653
   Serial number: KU0KU023101442961679
   Coding: 1000B0
   Subsystem 2 - Part No SW: 7E0 959 802 K    HW: 7E0 959 802 K  Labels: 7E0-959-80X-V2.CLB
   Component: J387__TSG_BT  003 8653
   Serial number: KU0KU030101443030106
   Coding: 0000A0
   Subsystem 3 - Part No: 7E1 951 172
   Subsystem 4 - Part No: 7E1 951 172
01758 - Bulbs for Brake Lamps
                    Fault Status: 00101011
                    Reset counter: 19
00901 - Back-Up Lamps
                    Reset counter: 19
                    Reset counter: 42
                    Mileage: 300893 km
                    Date: 2001.14.29
                    Time: 03:25:26
00538 - Reference Voltage
                    Fault Frequency: 81
                    Reset counter: 2
                    Mileage: 298713 km
                    Date: 2001.14.15
                    Time: 10:18:43
                    Fault Frequency: 87
                    Reset counter: 2
                    Mileage: 299687 km
                    Date: 2001.14.24
                    Time: 07:24:44
   Part No SW: 7E0 919 475 K    HW: 1Q0 919 475
   Component: PARKHILFE 4K  H03 0106
   Revision: --------    Serial number: 32901427900920
   Coding: 108101
   Shop #: WSC 02739 790 50316
   ASAM Dataset: EV_VW75XParkAssis4K 001004
   ROD: EV_VW75XParkAssis4K_001_VN75.rod
   VCID: 3A2D36AA8CD099CB5C7-806E
13635840 - Supply voltage
          [Versorgungsspannung - zu niedrig]
                    Reset counter: 42
                    Mileage: 300893 km
                    Date: 2065.14.29
                    Time: 03:24:01
          U1400 00 [008] - -
          [Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten]
                    Reset counter: 42
                    Mileage: 300893 km
                    Date: 2065.14.29
                    Time: 03:24:01
12648704 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Getriebesteuergerät - kein Signal/keine Kommunikation]
                    Reset counter: 2
                    Mileage: 300893 km
                    Date: 2065.14.29
                    Time: 07:28:13
   Component: VW10Airbag009 H07 0013
   Revision: --------    Serial number: 003HL00THJ7R
   Shop #: WSC 02734 790 50316
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 35372596A5CE76B3B15-8060
          B1000 1B [136] - Resistance Too High
                    Mileage: 298346 km
                    Date: 2065.14.13
                    Time: 17:45:22
9442836 - Front Passenger's Airbag Disabled Indicator Lamp
          B1016 14 [136] - Open or Short to Ground
                    Mileage: 298346 km
                    Date: 2065.14.13
                    Time: 18:20:18
Address 17: Instruments
   Part No SW: 6N0 909 901     HW: 7H0 937 087
   Component: GW-K-CAN TP20 H34 0424
   Revision: BO034001
   Coding: 042300
   VCID: 70B9D4829AAC139BA23-8024
                    Reset counter: 2
                    Mileage: 298713 km
                    Date: 2001.14.15
                    Time: 10:18:37
                    Reset counter: 2
                    Mileage: 298713 km
                    Date: 2001.14.15
                    Time: 10:18:37
01304 - Radio
                    Reset counter: 4
                    Mileage: 255552 km
                    Date: 2055.14.17
                    Time: 08:28:39
   Component: IMMO          H03 0805
   VCID: 6A8DC6EABCF0E94BEC7-803E
   Part No SW: 5M0 035 186 L    HW: 5M0 035 186 L
   Component: Radio RCD310  007 0119
   Revision: 01000001    Serial number: VWZ1Z2P0272234
   Coding: 05000200020014
   Shop #: WSC 02734 790 00000
   VCID: 35372596A54E76B3B15-8060
                    Reset counter: 42
                    Mileage: 300893 km
                    Date: 2001.14.29
                    Time: 03:25:09
                    Reset counter: 42
                    Mileage: 300893 km
                    Date: 2001.14.29
                    Time: 03:25:56
   Part No SW: 7P6 035 730 M    HW: 7P6 035 730 M
   Component: TELEFON       H16 4217
   Revision: 1B001001    Serial number: 00007666790822
   Coding: 0A01010000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3C2130B286E4A7FB4EB-8068
0022 - Radio
          U1066 00 [008] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                    Reset counter: 5
                    Mileage: 298346 km
                    Date: 2065.14.13
                    Time: 18:20:21
          U1400 00 [008] - -
                    Reset counter: 42
                    Mileage: 300893 km
                    Date: 2065.14.29
                    Time: 03:25:28
End-----(Elapsed Time: 01:46, VBatt start/end: 11.6V/9.3V. VIgn 9.2V)------
Neither the ECU or the TCU appear to be responding to VCDS or to the car's CAN gateway. Check for blown fuses or bad power supply relays.
Also: Your battery voltage dropped from 11.6V to 9.3V in the less than two minutes it took to scan the vehicle. Charge the battery and test the battery!
dioley
Cardiff, UK
H11-039770 (NRRT)
Thanks for reply , all fuses appear to be fine I'll check the relays, power dropped because my rad fan kicked in when turned key on? I've disconnected the fan recharged battery but still unable to connect to fully to VCDS.
