VW Windows/sunroof operation when opening door
Minikeum
Switzerland
C?ID=396805
Hi,
I own a euro VW Passat B7.
scenario that I’m sure happened to everyone: you arrive home, turn Off ignition, and realize you forgot to close the sunroof and/or the windows. No biggy, you close them, but before they finish closing, you open the door to get out. And at that very instant the Windows and sunroof stop closing.
the only way to let them finish the job, is turning the ignition back on, or if you have the confort access available you can use the key fob. A bit annoying.
my question: is there anyway to code the Windows and sunroof so that they don’t stop closing as soon as you open a door with ignition off? I couldn’t find info on that so I guess not, but I’d rather ask.
thanks!
Minikeum
Switzerland
C?ID=396805
here is the auto scan from tonight attached.
i had a look at module 46, and found the byte 6 bit 7 « power window/sunroof disabled after door opening », but it was already unselected (at zero).
Sunday,13,September,2020,22:24:30:21796
VIN: WVWZZZ3CZBE353067   License Plate:
Mileage: 164680km-102327mi   Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 13 14 15 16 17 19 22 25 2E 36 37 42 44 46
          47 4F 52 53 55 56 61 62 65 69 6C 6D 72 77
VIN: WVWZZZ3CZBE353067   Mileage: 164680km-102327miles
Address 01: Engine (0-32-BWS_)       Labels:. 03H-907-309-V1.clb
   Part No SW: 03H 906 023 L    HW: 03H 907 309 A
   Component: 3,6 FSI EU5   H03 1024
   Revision: MFH03---    Serial number: 00000000000000
   Coding: 001D0012246600000000
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ECM36FSI01103H906023L 002007
   ROD: EV_ECM36FSI01103H906023L.rod
   VCID: 2B02FD0003806213D71-807E
   Part No SW: 02E 300 013 A    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2606
   Revision: 05351112    Serial number: 00001012271003
   Shop #: WSC 44551 111 44551
   VCID: 0F7A49909B583E33DB9-805A
   Part No SW: 3AA 614 109 P    HW: 3AA 614 109 P
   Component: J104   C2 450M V5CE 0011
   Revision: --H07---    Serial number: 00000003379620
   Coding: 0115108
   Shop #: WSC 05311 000 08193
   VCID: 3A2CC844F05ACB9B5C7-806E
   Part No SW: 5K0 907 044 EA    HW: 5K0 907 044 EA
   Component: Climatronic   H17 1010
   Revision: 00003001
   Coding: 0000000002
   VCID: 6E843414F012573BB0F-803A
Address 09: Cent. Elect. (J519)       Labels:. 3AA-937-087.clb
   Part No SW: 3AA 937 087 B    HW: 3AA 937 087 B
   Component: BCM PQ47 H+   413 0452
   Revision: BC413001
   Coding: 0000000000000000001C0280740029F463D50088676D8D60E48046240041
   VCID: 392ED748F95CC08355D-806C
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 17011  10  0603
   Coding: 00B795
   Component: RLS 110211 05  54  0403
   Coding: 035028
Address 10: Park/Steer Assist (J791)       Labels:| 3AA-919-475.clb
   Part No SW: 3AA 919 475 D    HW: 3AA 919 475 A
   Component: PARKHILFE PLA H04 0007
   Revision: --------    Serial number: 20431101802353
   Coding: 318106
   ASAM Dataset: EV_EPHVA2C000000000 001006
   ROD: EV_EPHVA2C000000000_001_VW36.rod
   VCID: 3C20CE5CF6EEF5AB4EB-8068
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567     HW: 3AA 907 567
   Component: AC201  RDW A    031 0143
   Revision: 00031000    Serial number: 00000000086318
   Coding: 0010000
   VCID: 77AA117083C816F3639-8022
Address 14: Susp. Elect. (J250)       Labels:. 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0071
   Revision: 00000000    Serial number: 02021104130002
   Coding: 030180
   VCID: 270A01301FE84673339-8072
   Part No SW: 5N0 959 655 Q    HW: 5N0 959 655 Q
   Component: J234__10K VW10 HI   1918
   Revision: 22014000    Serial number: 003JZP1YET4Z
   Coding: 0012363
   Shop #: WSC 05311 000 00000
   VCID: 4BC29D80AFC04213F71-801E
   Subsystem 1 - Serial number: 6332MTS628970111
   Subsystem 2 - Serial number: 6342MTS621220111
   Subsystem 3 - Serial number: 6351HTS64EV6M9KR
   Subsystem 4 - Serial number: 6361HTS6Q6USM9KJ
Address 16: Steering wheel (J527)       Labels:| 3C0-953-569.clb
   Part No SW: 3C9 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110204301677
   Coding: 399AA50001
   VCID: 75B61B78954464E3715-8020
   Coding: E30000
   Part No SW: 3AA 920 880     HW: 3AA 920 880
   Component: KOMBI         H02 0206
   Coding: 161F01
   Shop #: WSC 05311 115 08193
   VCID: 70B82A6CEA2641CBA23-8024
   Part No SW: 7N0 907 530 G    HW: 1K0 907 951
   Component: J533  Gateway H41 1614
   Revision:   H41       Serial number: 100211F1001155
   Coding: 462006
   VCID: 3430E67CDE3E3DEB86B-8060
   Part No SW: 0BS 907 554 B    HW: 0BS 907 554 B
   Component: Haldex 4Motion      4015
   Coding: 0000005
   VCID: 45D6ABB889A4B463215-8010
   Part No SW: 3AA 959 799     HW: 3AA 959 799
   Component:    IMMO         083 0399
   Revision: 00083000    Serial number: VWZCZ000000000
   Shop #: WSC 36575 002 1048576
   VCID: 05566BB8C9247463615-8050
   Part No SW: 5N0 035 342 D    HW: 5N0 035 342 D
   Revision: A1001003    Serial number: 7669363451
   VCID: 2808020C12F6490B3A3-807C
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2301
   Revision: 00H05000
   Coding: 000039
   VCID: 3332E560DB303AD39F1-8066
   Part No SW: 1T0 035 680 C    HW: 1T0 035 680 C
   Component: RNS-MID       H50 2840
   Revision: AB001001    Serial number: VWZ6Z7L5044050
   Coding: 04050002010000A000
   VCID: 2E04F4143012173BF0F-807A
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0529
   Revision: 12110009    Serial number: 0002212593
   Coding: 0011FF
   VCID: 3536DB78D5C424E3B15-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000001885036
   Coding: 0000D8
   Part No SW: 5N1 909 144 L    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.318 0802
   Revision: 1AH03729    Serial number: 00110330152901
   Coding: 0000258
   VCID: 3B22CD40FF60F293471-806E
Address 46: Central Conv.        Labels:. 3C0-959-799-46.clb
   Component: 02 KESSY PQ47   083 0323
   Coding: 01900A00D2C30E76300494157200CFCE705801030424B8
   Subsystem 1 - Part No: 1K8 951 605 B
   Component: LIN BACKUP HORN H11 9005
   Component: Neigungssensor  004 0611
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No SW: 3AA 035 456     HW: 3AA 035 456
   Component: DSP 10 Kanal        0020
   Revision: 00H06001    Serial number: 75817000254206
   VCID: 6C803E1CCA8EA52B9EB-8038
   Component: EZE_2         H41 1614
   Coding: 050B0508
   VCID: 6FBA2910F7985E33BB9-803A
   Component: J245EE20SKB13  H02 0220
   Subsystem 3 - Part No SW: 3AA 919 204     HW: 3AA 919 204
   Component: Analoguhr  003 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0529
   Revision: 14110009    Serial number: 0002246456
   Coding: 0011FE
   VCID: 3634DC74C8C22FFBB8F-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000001891051
   Coding: 0000D8
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000171928
   Coding: 0022057
   VCID: 3332E560D7303AD39F1-8066
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0080
   Coding: 023A00000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002006
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   Subsystem 1 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0011
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 A    HW: 3D0 941 329 A  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0011
   Coding: 230000
   Component: Batt.regelung H41 1614
   Coding: 03221173
   VCID: 71BE2F68E1AC48C3ADD-8024
   Subsystem 1 - Part No SW: 3AA 915 181     HW: 3AA 915 181
   Component: J367-BDM  H07 0150
   Serial number: 00000000009370272717
   Part No SW: 3AA 907 273 B    HW: 3AA 907 273 B
   Component: RDKBERU30     H08 0008
   Serial number: 10000000018139
   ASAM Dataset: EV_RDKBERU30 003010
   ROD: EV_RDKBERU30_003.rod
   VCID: 3332E560DBB03AD39F1-8066
Address 69: Trailer (J345)       Labels:. 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00000142693020
   Coding: 4106040000000000
   VCID: 73B225609BB07AD35F1-8026
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Component: J772__Rearview      0020
   Revision: 00H09000    Serial number: 525PA8-J0Z0703
   Coding: 0030007
   VCID: 6888420CDE76890BFA3-803C
Address 6D: Trunk Elect.        Labels: 3C9-827-383.clb
   Part No SW: 3C9 827 383 J    HW: 3C9 827 383 J
   Component: J605  HECKDECKEL    0804
   Revision: 00H52001
   VCID: 3828D24CCE56D98BAA3-806C
   Subsystem 1 - Part No: 3C9 827 384 J
   Component: J756  HECKDECKEL    0804
   Subsystem 2 - Serial number: 1100H52001001C0031ÿ
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663071240
   Coding: 0210000000010101
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A2CC844FCDACB9B5C7-806E
End----------(Elapsed Time: 02:17, VBatt start/end: 12.1V/12.1V)-----------
on a side note, you confirm that rain closing won’t work with my hardware? From the info I found I believe it shouldn’t...
thanks!
Minikeum
Switzerland
C?ID=396805
I gave that bit (module 46, byte 6 bit 7) a try and activated it.
Now the windows and sunroof will keep closing (or opening) when I open the door. They will stop closing/opening when I shut the door. Maybe for anti-theft reason, I don’t really know.
Happy with the result
