Saturday,12,September,2020,14:08:16:05469
VCDS Version: 20.4.2.0 (x64)
VIN: WA1CFBFPXDA032895 License Plate:
Mileage: 176300km-109547mi Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
77
VIN: WA1CFBFPXDA032895 Mileage: 176300km-109547miles
Address 01: Engine (DET-CPMA) Labels:. 06H-907-115-CDN.clb
Part No SW: 8R1 907 115 B HW: 8K2 907 115 L
Component: 2.0l R4/4V TF H09 0006
Revision: ECH09---
Coding: 6A2A0013242600062000
Shop #: WSC 25817 003 1048576
ASAM Dataset: EV_ECM20TFS0118R1907115B 001007
ROD: EV_ECM20TFS0118R1907115B.rod
VCID: 346699A99F2E3226C7-8060
7230 - Cam Adjustment Actuator B; Cylinder 2
P11A8 00 [104] - Implausible Signal
Fault Frequency: 24
Mileage: 176092 km
Date: 2020.09.07
Time: 16:55:58
Engine speed: 739.50 /min
Normed load value: 14.5 %
Coolant temperature: 89 ∞C
Intake air temperature: 71 ∞C
Voltage terminal 30: 12.792 V
Heated oxygen sensor bank 1: sensor 1: resistance: 1251.72 Ohm
Heated oxygen sensor bank 1: sensor 1: activation: 2.454 %
Outside air temperature via CAN: 29.3 ∞C
Oxygen sensor 1 bank 1 ceramic temp: 625.58 ∞C
Part No SW: 8R1 927 158 C HW: 0BK 927 156 AL
Component: 0BK 20TFSIUSA H16 1002
Revision: --H16---
Coding: 000002
ASAM Dataset: EV_TCMAL551211 002020
VCID: 3E72BB81A162E87621-806A
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 AK HW: 8R0 907 379 AK
Component: ESP8 quattro H09 0080
Coding: 151D10
Shop #: WSC 06335 000 00000
VCID: 0918185DA02C1FCE44-805C
Fault Status: 00101101
Reset counter: 165
Mileage: 174859 km
Date: 2020.08.23
Time: 13:40:05
Hex Value: 0x00C0
Hex Value: 0x07A2
Hex Value: 0x000B
Hex Value: 0x4690
Hex Value: 0x0000
Part No SW: 8K0 907 064 GL HW: 8K0 907 064 FL
Component: BCM2 2.0 H11 0621
Coding: 09854000000000000000
VCID: 000E057993165E8613-8054
Subsystem 1 - Part No SW: 8K0 959 754 F HW: 8K0 959 754 F
Serial number: 0512000070562019
Serial number: 2312000225776007
Address 08: Auto HVAC (J255) Labels:. 8Kx-820-043-3Z.clb
Part No SW: 8K1 820 043 T HW: 8K1 820 043 T
Revision: C1000000 Serial number: 01261020120919
Coding: 6481208000
VCID: 3978A89DB04CCF4E14-806C
Part No SW: 8K0 907 063 DB HW: 8K0 907 063 DB
Component: BCM1 1.0 H16 0103
Revision: 02016001 Serial number: 00000038614801
Coding: 690000B1863CA7C00000080300007F7F0F1C460822080221000008004000030000000000000000
VCID: 72EA5FB1ADBA7C1615-8026
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels: 1KX-955-119.CLB
Component: WWS416 121010 H11 0050
Serial number: 90243014121001000703
Coding: 01DD13
Component: G397_RLFS H06 0002
Serial number: 20679900
Coding: 02005C
Component: E1 - LDS H03 0031
Serial number: 00000000001110120725
Component: USHL4.2 H30 0030
Serial number: 0000002274555R3FHN02
Subsystem 5 - Part No SW: 4H0 907 658 HW: 4H0 907 658
Serial number: F7D84056000000000001
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Serial number: 003GPD90X2S0
Coding: 303334313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 479CDE65FEB8A9BE92-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R120000BSJA
Serial number: 6334MSME71746B71H
Serial number: 6344MSME7116003C4
Serial number: 6352QSME5A231860C
Serial number: 6362QSME4425454EK
Serial number: 63732SME38252D4E7
Serial number: 63832SME2C2228780
Part No SW: 8K0 953 568 L HW: 8K0 953 568 L
Revision: -------- Serial number: 90372LJF000RM
Coding: 000017
VCID: 4384CA75C280859E4E-8016
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 950 G HW: 8R0 920 950 G
Component: KOMBIINSTR. H07 0556
Revision: 00200000 Serial number: UWB32KGAD
Coding: 8B9722000301D705020000
VCID: 3A7AB791B54AC4561D-806E
Part No SW: 8R0 907 468 F HW: 8R0 907 468 A
Component: GW-BEM 5CAN H11 0051
Revision: 1V060024 Serial number: 2441V12A10801E
Coding: 80C303FF00
VCID: 428ACF71DD9A8C9645-8016
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790322371
Address 2E: Media Player 3 (R199) Labels:. 8T0-035-785.clb
Part No SW: 8T0 035 785 A HW: 8T0 035 785
Component: SG ext.Player H08 0290
Revision: 00000000
Coding: 020302
Part No SW: 8K0 959 793 P HW: 8K0 959 793 P
Component: TSG FA H02 0506
Revision: Serial number: 0000042288881
Coding: 011D03204000440004
VCID: 4D90EC4D14C443EEA8-8018
Part No SW: 8R0 909 144 F HW: 8R0 909 144 B
Component: RCEPS H37 0507
Revision: 00001000 Serial number: 0016971938
Coding: 100000000000
Shop #: WSC 06334 000 00000
ROD: EV_RCEPSAU48X_008.rod
VCID: 3B74B295B270FD5E06-806E
Revision: 00002001 Serial number: 0185894540
Coding: 0126063A20FA401484B0053200040000
Subsystem 1 - Part No SW: 8K0 959 719 B HW: 8K0 959 719
Component: GTO BF H01 0080
Serial number: 00000000000000590168
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H03 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H03 0220
Address 47: Sound System (J525) Labels:. 8T0-035-223-ASC.clb
Part No SW: 8R0 035 223 G HW: 8R0 035 223 E
Component: DSP STD H11 0460
Revision: 00000000 Serial number: 00000000000001
Coding: 0203010102
VCID: 306E95B963360E06A3-8064
Part No SW: 8K0 959 792 P HW: 8K0 959 792 P
Component: TSG BF H02 0506
Revision: Serial number: 0000042264678
VCID: 4C96E149EFDE4AE6BF-8018
Part No SW: 8K0 907 801 L HW: 8K0 907 801 J
Component: EPB-4 H01 0003
Revision: -------- Serial number: 20000000196066
ROD: EV_ParkiBrake_AU48.rod
VCID: 387EAD998346D646EB-806C
464384 - Function Restriction due to Faults in Other Modules
U1113 00 [008] - -
Reset counter: 165
Mileage: 174859 km
Date: 2020.08.23
Time: 13:40:05
Voltage terminal 30: 11.8 V
Internal Fault ID: 188
Network management state: normal
Function light in parking brake button: On
Red operating lamp: On
Red warning lamp: OFF
Green operating lamp: OFF
Yellow warning lamp: OFF
Terminal 15 status: On
RWU: not active
DSD: not active
HTR: not active
ECD: not active
ACC requested apply: not active
Auto Adjust: not active
General Inspection Function: not active
Internal Parking Brake state: static
Status of parking brake button: Not operated
Status ParkingBrake left: Set
Status ParkingBrake right: Set
Address 56: Radio (J503) Labels:. 8Tx-035-1xx-56.clb
Part No SW: 8R1 035 186 H HW: 8R1 035 186 H
Component: Con3 Sirius H08 0461
Revision: 00000001 Serial number: AUZ5Z6L1810480
Coding: 04020002010585004359070800
Subsystem 1 - Part No SW: 8T0 919 603 G HW: 8T0 919 603 G
Component: Display
Fault Frequency: 10
Reset counter: 176
Mileage: 174851 km
Date: 2020.08.22
Time: 19:38:26
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Bin. Bits: 10000000
Bin. Bits: 00000000
Bin. Bits: 00000000
Part No SW: 8K0 959 795 G HW: 8K0 959 795 D
Component: TSG HL H01 0506
Revision: Serial number: 0000042207331
Coding: 010C03204000240004
VCID: 4682D361F1B2B0B669-8012
Component: TSG HR H01 0506
Revision: Serial number: 0000042207330
Part No SW: 8T0 862 336 F HW: 8T0 862 336 E
Component: FSE_256x BT H45 0660
Revision: 00000000 Serial number: 00000005287974
Coding: 0010370
VCID: 3E72BB816962E87621-806A
End-------------------------(Elapsed Time: 04:16)--------------------------
