Q5 2.0T CPMA, Misfires and rough at ~2000 RPM under Load. Throttle body won't adapt.
superjet
C?ID=194043
Hi,
2013 Q5 with the following symptoms. at ~2000 under load, runs rough like the mixture is off a little, occasionally throw a misfire (cylinder 4 and 2). Above 2500 rpm it's smooth. Occasionally will start rough like its running on 3 cylinders and will get check engine and EPC lights, if left alone it will smooth out in a couple minutes and generally left with a misfire cylinder 4 code. Have checked everything obvious (Coils plugs compression carbon intake turbo gas HPFP PCV).
Because it seems like the mixture is off for some reason, started to look at the throttle body, thinking it may be an adaptation issue.
So... went ahead and tried to do a throttle adaptation and here's what I get... Finished correctly | End of system test: system not OK.
Then tried the intake flap test and got the same message: Finished correctly | End of system test: system not OK.
I'm really at a loss here on when to turn next? Could it be the ECM? Anyway to test the ECM?
The car is drivable and 99% ok except for the roughness at ~2000RPM,
Any advice would be greatly appreciated
superjet
C?ID=194043
The implausible signal on Cam Adjustment Actuator B; Cylinder 2 is a connector that was replaced and evidently needs my attention again.... thanks
Saturday,12,September,2020,14:08:16:05469
VCDS Version: 20.4.2.0 (x64)
VIN: WA1CFBFPXDA032895   License Plate:
Mileage: 176300km-109547mi   Repair Order:
Chassis Type: FP-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 44 46 47 52 53 56 62 72
          77
VIN: WA1CFBFPXDA032895   Mileage: 176300km-109547miles
Address 01: Engine (DET-CPMA)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8R1 907 115 B    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0006
   Revision: ECH09---
   Coding: 6A2A0013242600062000
   Shop #: WSC 25817 003 1048576
   ASAM Dataset: EV_ECM20TFS0118R1907115B 001007
   ROD: EV_ECM20TFS0118R1907115B.rod
   VCID: 346699A99F2E3226C7-8060
7230 - Cam Adjustment Actuator B; Cylinder 2
          P11A8 00 [104] - Implausible Signal
                    Fault Frequency: 24
                    Mileage: 176092 km
                    Date: 2020.09.07
                    Time: 16:55:58
                    Engine speed: 739.50 /min
                    Normed load value: 14.5 %
                    Coolant temperature: 89 ∞C
                    Intake air temperature: 71 ∞C
                    Voltage terminal 30: 12.792 V
                    Heated oxygen sensor bank 1: sensor 1: resistance: 1251.72 Ohm
                    Heated oxygen sensor bank 1: sensor 1: activation: 2.454 %
                    Outside air temperature via CAN: 29.3 ∞C
                    Oxygen sensor 1 bank 1 ceramic temp: 625.58 ∞C
   Part No SW: 8R1 927 158 C    HW: 0BK 927 156 AL
   Component: 0BK 20TFSIUSA H16 1002
   Revision: --H16---
   Coding: 000002
   ASAM Dataset: EV_TCMAL551211 002020
   VCID: 3E72BB81A162E87621-806A
Address 03: ABS Brakes (J104)       Labels:. 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 AK    HW: 8R0 907 379 AK
   Component: ESP8 quattro  H09 0080
   Coding: 151D10
   Shop #: WSC 06335 000 00000
   VCID: 0918185DA02C1FCE44-805C
                    Fault Status: 00101101
                    Reset counter: 165
                    Mileage: 174859 km
                    Date: 2020.08.23
                    Time: 13:40:05
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x000B
                    Hex Value: 0x4690
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GL    HW: 8K0 907 064 FL
   Component: BCM2 2.0      H11 0621
   Coding: 09854000000000000000
   VCID: 000E057993165E8613-8054
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0512000070562019
   Serial number: 2312000225776007
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01261020120919
   Coding: 6481208000
   VCID: 3978A89DB04CCF4E14-806C
   Part No SW: 8K0 907 063 DB    HW: 8K0 907 063 DB
   Revision: 02016001    Serial number: 00000038614801
   Coding: 690000B1863CA7C00000080300007F7F0F1C460822080221000008004000030000000000000000
   VCID: 72EA5FB1ADBA7C1615-8026
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 121010  H11 0050
   Serial number: 90243014121001000703
   Coding: 01DD13
   Serial number: 20679900
   Coding: 02005C
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001110120725
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R3FHN02
   Serial number: F7D84056000000000001
Address 15: Airbags (J234)       Labels:* 8R0-959-655.clb
   Part No SW: 8R0 959 655 F    HW: 8R0 959 655 F
   Serial number: 003GPD90X2S0
   Coding: 303334313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 479CDE65FEB8A9BE92-8012
   Subsystem 1 - Part No SW: 8R0 959 339 A    HW: 8R0 959 339 A
   Serial number: 5810000R120000BSJA
   Serial number: 6334MSME71746B71H
   Serial number: 6344MSME7116003C4
   Serial number: 6352QSME5A231860C
   Serial number: 6362QSME4425454EK
   Serial number: 63732SME38252D4E7
   Serial number: 63832SME2C2228780
   Part No SW: 8K0 953 568 L    HW: 8K0 953 568 L
   Revision: --------    Serial number: 90372LJF000RM
   Coding: 000017
   VCID: 4384CA75C280859E4E-8016
Address 17: Instruments (J285)       Labels:. 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 950 G    HW: 8R0 920 950 G
   Component: KOMBIINSTR.   H07 0556
   Revision: 00200000    Serial number: UWB32KGAD
   Coding: 8B9722000301D705020000
   VCID: 3A7AB791B54AC4561D-806E
   Part No SW: 8R0 907 468 F    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0051
   Revision: 1V060024    Serial number: 2441V12A10801E
   Coding: 80C303FF00
   VCID: 428ACF71DD9A8C9645-8016
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790322371
Address 2E: Media Player 3 (R199)       Labels:. 8T0-035-785.clb
   Part No SW: 8T0 035 785 A    HW: 8T0 035 785
   Component: SG ext.Player H08 0290
   Revision: 00000000
   Coding: 020302
   Part No SW: 8K0 959 793 P    HW: 8K0 959 793 P
   Component: TSG FA        H02 0506
   Revision:             Serial number: 0000042288881
   Coding: 011D03204000440004
   VCID: 4D90EC4D14C443EEA8-8018
   Part No SW: 8R0 909 144 F    HW: 8R0 909 144 B
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0016971938
   Coding: 100000000000
   Shop #: WSC 06334 000 00000
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3B74B295B270FD5E06-806E
   Revision: 00002001    Serial number: 0185894540
   Coding: 0126063A20FA401484B0053200040000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000590168
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H03 0220
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE20SKB13  H03 0220
Address 47: Sound System (J525)       Labels:. 8T0-035-223-ASC.clb
   Part No SW: 8R0 035 223 G    HW: 8R0 035 223 E
   Component: DSP STD       H11 0460
   Revision: 00000000    Serial number: 00000000000001
   Coding: 0203010102
   VCID: 306E95B963360E06A3-8064
   Part No SW: 8K0 959 792 P    HW: 8K0 959 792 P
   Component: TSG BF        H02 0506
   Revision:             Serial number: 0000042264678
   VCID: 4C96E149EFDE4AE6BF-8018
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 20000000196066
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 387EAD998346D646EB-806C
464384 - Function Restriction due to Faults in Other Modules
          U1113 00 [008] - -
                    Reset counter: 165
                    Mileage: 174859 km
                    Date: 2020.08.23
                    Time: 13:40:05
                    Voltage terminal 30: 11.8 V
                    Internal Fault ID: 188
                    Function light in parking brake button: On
                    Red operating lamp: On
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: static
                    Status ParkingBrake left: Set
                    Status ParkingBrake right: Set
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 H    HW: 8R1 035 186 H
   Component: Con3 Sirius   H08 0461
   Revision: 00000001    Serial number: AUZ5Z6L1810480
   Coding: 04020002010585004359070800
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
                    Reset counter: 176
                    Mileage: 174851 km
                    Date: 2020.08.22
                    Time: 19:38:26
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000042207331
   Coding: 010C03204000240004
   VCID: 4682D361F1B2B0B669-8012
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000042207330
   Part No SW: 8T0 862 336 F    HW: 8T0 862 336 E
   Component: FSE_256x BT     H45 0660
   Revision: 00000000    Serial number: 00000005287974
   Coding: 0010370
   VCID: 3E72BB816962E87621-806A
End-------------------------(Elapsed Time: 04:16)--------------------------
TFSI
Maryland, USA
C?ID=66650
          77
   Revision: ECH09---
                    Fault Frequency: 24
                    Mileage: 176092 km
                    Date: 2020.09.07
                    Time: 16:55:58
   Revision: --H16---
   Coding: 000002
   Coding: 151D10
                    Reset counter: 165
                    Mileage: 174859 km
                    Date: 2020.08.23
                    Time: 13:40:05
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x000B
                    Hex Value: 0x4690
                    Hex Value: 0x0000
   Coding: 6481208000
   Coding: 01DD13
   Coding: 02005C
   Coding: 000017
   Coding: 80C303FF00
   Revision: 00000000
   Coding: 020302
   Coding: 0203010102
          U1113 00 [008] - -
                    Reset counter: 165
                    Mileage: 174859 km
                    Date: 2020.08.23
                    Time: 13:40:05
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Component: Display
                    Reset counter: 176
                    Mileage: 174851 km
                    Date: 2020.08.22
                    Time: 19:38:26
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
                    Bin. Bits: 10000000
                    Bin. Bits: 00000000
                    Bin. Bits: 00000000
   Coding: 0010370
Hello SuperJet,
A car with over 176000 miles, I wont be surprised carbon deposits is the culprit in this case..but it is best to determine which cylinder (s) exactly misfire under such conditions causing the rough run. I will Connect VCDS and take MVBs 15 and 16 on engine electronics at say between 1900-2200 RPM and post results.Also take and post the readings MVB 60 and 61 to see if throttle adaptation shows error. Remember for successful throttle body adaptation, battery voltage should be good plus make sure that the female socket pins are not over-widened or corroded.
Superjet has an ECU that uses the UDS protocol. It won't have traditional MVBs. He's going to have to use the search/filter function in the Advanced Measuring Value selections to look for "misfire".
NostraJackAss
Is this not under useful life warranty and a free repair at dealer for 10/120k and specified by the conformity application on file at EPA?
Did you check for metal shavings in adjuster yet?
Did you JPPSG all pages yet?
superjet
C?ID=194043
Hi All,
thanks for the help. Indeed its a UDS protocol, and I'll have to find similar measuring blocks to monitor. The car actually has ~109K miles on it. It's stock, but I have replaced the HPFP and cam follower ~ 70K and the PCV, and did a carbon cleaning (walnut shell method). I have found no evidence of metal shavings and have actually watch the throttle valve open and close with the gas pedal, however, when watching it during the adaptation, it simply fluttered at the 1-5 degrees open, never did the full range which I assume it would. I have tried this with and aftermarket Throttle valve and it did the same. Also timing chain is OK ~ for the miles, cam shaft adapt value at 4.08.
I'll try to get some measured values in the next couple of days.
Thanks again.
superjet
C?ID=194043
Oh yeah, forgot to mention, I stumbled across a post some where, there was a mention that for full UDS functionality, you need a better interface, I have the HEX + CAN, is that true? And possibly I'm missing some data?
-S
NostraJackAss
Did you know all that you aforementioned, even carbon cleaning, is under warranty and reimbursable even now?
Do you see carbon cleaning a routine maintenance item in RTFB?
Sure sounds like fuel injectors or pump leaking from failing useful life and maybe sump dilution with fuel as a result huh?
Don't worry the shavings and chain or head damge is right around corner and with no MIL confirmation yet is that right at 24 times lol?
superjet
C?ID=194043
Hi,
Sorry forgot to mention that the injectors and HPFP were replaced @ 70. I have the latest tensioner, but was going to do the chain soon. Oil seems fine and not diluted.
can you please expand on the comment "Don't worry the shavings and chain or head damge is right around corner and with no MIL confirmation yet is that right at 24 times lol?"
Also would you know the specific warranty I would quote if I went to the dealer?
thanks
Nah, on a 2013 car, you're fine with the HEX+CAN you have. I believe the worst case on that car is that you won't get some extended fault code data, which even the dealers' ODIS software doesn't provide.
NostraJackAss
ModelAudi Q5 qu. 2.0
Date of production10/31/2012
Model year2013
Sales type8RB/52A Emission standard ULEV 2
Engine CodeCPMA
Transmission CodeNTB
https://iaspub.epa.gov/otaqpub/publist1.jsp <<<<<<<<<<<<<< EPA PORTAL?
At link below do you see 120K checked on Page 57 & dont you see on page 64 do you see an EDR at EPA FOIA portal anywhere for that firmware level of 0006, you know like in your scan?
Component: 2.0l R4/4V TF H09 0006 <<<<<<<<<<<<<<<< OH MY WHAT DOES THIS ALL MEAN?
https://iaspub.epa.gov/otaqpub/display_file.jsp?docid=29696&flag=1 <<<<<<<<<<<<<<<<< THIS LINK?
superjet
C?ID=194043
Thanks for the reply Jack, and please excuse my naivety, I'm not sure, regarding the firmware version.. is it wrong? a mismatch, or something else.
I searched for 2.0l R4/4V TF H09 0006 and did and a previous post with someone playing around with the ECM on a 2013 Q5...
superjet
C?ID=194043
Hi, here are the two items,
and....
Could use a little help in deciphering what it all means. Appreciate any help I can get. thanks
