2003 Audi TT 225 BEA VCDS label file, readiness script, and output tests
Sapper502
C?ID=415903
Hello everyone!
1st time noob post here. So I apologize in advance. The search box keeps omitting short search terms. Like "TT" "BEA".
Picked up a low mileage 2003 Audi TT Quattro that has the 225hp BEA engine.
I recently purchased the hex-v2 cable and have installed the latest version of VCDS. It seems to work pretty good. But it does t seem to have an associated engine label file, readiness scripts, or output tests for the car.
Was looking at the output tests to see if I could fire the drivers side radiator fan. From what I've read, that would be done with the out put tests.
Is this by design? Or am I missing something vital in the setup and detection process?
Oh and if anyone knows what part number the KO4 turbo is that would help. The over boost code is coming from the wastegate actuator ..it leaks pretty bad and isn't opening.
Thank you!
Posted the scan log below for the ecm controller info.
Friday,28,August,2020,11:04:27:20948
VIN: TRUUT28N531013402   License Plate:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
   Part No: 8N0 906 018 BB
   Component: 1.8L R4/5VT     G   0003
   Coding: 07710
   Shop #: WSC 01236
   VCID: 72BDDEBF1DBA3CDB547-513C
   TRUUT28N531013402     AUZ5Z0BD165029
17861 - Exhaust Gas Temp Sensor 1 (G235)
            P1453 - 35-00 - Open or Short to Plus
16618 - Boost Pressure Regulation
            P0234 - 35-00 - Limit Exceeded (Overboost Condition)
Readiness: 0000 1000
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 B
   Component: Airbag Front+Seite 6000
   Coding: 01103
   Shop #: WSC 01236
   VCID: 3FDB478B1E68A1B36B9-513C
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 980 A
   Component: KOMBI+WEGFAHRS. M73 D05
   Coding: 07244
   VCID: 343118A7272E72EB86B-4B00
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0010
   VCID: 2019E4F783D6FE4B723-4B00
Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
   Part No: 8N7 962 267 F
   Component: Central Lock/Alarm  D09
   Coding: 15900
   Shop #: WSC 01236
   VCID: 43D34B7B7280C5530F1-4EC8
01564 - Interior Lock Switch; Driver Side (E151); Unlock
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: 6597B5E3DC74DB63C15-5160
   Part No: 4B0 035 186 H
   Component: concert II  NP2    0050
   Coding: 00202
   VCID: 2517F5E39CF41B63015-4E20
End----------(Elapsed Time: 02:55, VBatt start/end: 12.7V/12.4V)-----------
Friday,28,August,2020,11:23:25:20948
   Coding: 07710
   Shop #: WSC 01236
No Faults Found
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-A.lbl
   Part No: 8N0 907 379 H
   Component: ESP ALLRAD MK60     0101
   Coding: 0022544
   Shop #: WSC 01236 785 00200
   VCID: 41DF41736D9CD7431DD-513C
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 2809FCD7EBE6060B3A3-2580
   Coding: 01103
   Shop #: WSC 01236
   Coding: 07244
   Coding: 15900
   Shop #: WSC 01236
   Coding: 00010
   Shop #: WSC 01236
   Coding: 00202
End----------(Elapsed Time: 02:34, VBatt start/end: 12.5V/12.5V)-----------
Hi and welcome.
Since that ECU uses the oldest of the VAG diagnostic protocols (KW1281), it only supports Sequential output tests. That means there's a sequence of tests programmed in the ECU and all VCDS (or any other scan tool) can do is to request the ECU to start that sequence, and once started, request the next test in the sequence. The ECU will send back a numeric code with each step in the sequence that VCDS will interpret to tell you what output is currently activated. There's no way to tell from a distance to know whether a particular output (such as the drivers side radiator fan) is part of that sequence. Note also that ECUs will often refuse to run the output test sequence more than once in a single key cycle.
As for label files and readiness scripts, I would imagine that an existing one can be adapted. I'll ask @Dana to take a look.
NEtech
Denmark
C?ID=56995
Please post Controller Channel Map from the engine.
[Applications]
[Controller Channel Map]
- Controller Address = 01
- Login or security code: Leave blank
- Function: Measuring values
- Output: CSV file
[Go]
File is placed in C:\Roos-Tech\VCDS\Logs
Sapper502
C?ID=415903
Hi and welcome.
Thanks for the info!
That explains why it would be showing error fields the second time I would access it!
Sapper502
C?ID=415903
[Applications]
- Output: CSV file
[Go]
Thanks NEtech.
I don't see a way to upload the file. So here is link to a Google drive. If it doesn't work I can copy and paste.
NEtech
Denmark
C?ID=56995
@Dana I guess 06A-906-032-BAM.lbl is close and could be used.
United States
@NEtech I agree. Either 06A-906-032-AWP (slightly lower 180 HP output) or 06A-906-032-BAM could be used. The AWP file may be better only because it has a Readiness script but the TT does have a few special groups and I often dig into the repair manual Readiness achievement PDFs when it comes to TT Readiness.
If the OP isn't opposed to tweaking this himself I would open C:\Ross-Tech\VCDS\Labels\8N-01.lbl using Notepad and edit this line from:
;8N0-906-018-BB  ; BEA (8N)
to:
REDIRECT,06A-906-032-AWP.LBL,8N0-906-018-BB  ; BEA (8N)
or to:
REDIRECT,06A-906-032-BAM.LBL,8N0-906-018-BB  ; BEA (8N)
Just make sure to note which file you are happy with so you can drop a copy of that redirect into C:\Ross-Tech\VCDS\Labels\User so it is preserved the next time you update VCDS. If you have any issues please send an email to Support with a link to this thread and I'll tweak the file for you.
In regard to the fans you might be better of unplugging and jumping each circuit of the fan switch on the rad to see if both high and low speeds work but Output tests in address 17 or 08 may activate the fans if that wasn't a sequential option under 01.
PL24 believes the current-day direct replacement turbo part number is 06A 145 704 QX based on VIN.
United States
@Sapper502,
If you can send Function: Meas. Blocks -and- Adaptation Control Module Maps using the Output: Pre-Label File selection to Support via e-mail at some point they would be helpful so we can create a more permanent solution in VCDS.
Thanks,
