[Select]Where is the channel 16?
[01-Engine]
[Adaptation-10]
Put '16' (w/o the quotes] in the channel number box,
[Read]
After a few seconds, there should be an info balloon that explains more.
None... I have checked multiple timesAre any DTC's present now?
Uwe, I tried what you said and the Dpf light is still on.....[Select]
[01-Engine]
[Adaptation-10]
[Read]
Im sorry jack but im not entirely sure where you are talking about. I have looked in both "basic settings" and "Long Adaptation" and i do not see what your talking about. Sorry still a little new to the VCDS. Could you please help me a little more. Thank you so muchhttp://wiki.ross-tech.com/wiki/index.php/Diesel_Particle_Filter_Emergency_Regeneration
Not sure if your car supports but see if your car supports basic setting tests.
If it does.......... check each block for a test and do it. 0-255 to check.
Log them if you like....
There should be a whole bunch of calibration tests to do in adaption that can also be done if not in basics.
0x01-10- pull down menu and select documented tests.
Did you do what the info balloon suggested?Uwe, I tried what you said and the Dpf light is still on.....
I went to engine 01, the security access 16 (I entered the code 12233 so i can get into long adaptation) i tried to go to channel 10 and it says it doesnt exist. I looked through the drop down menu and i did not see any options for a test. How would we go about a remote sessionOkay
Please go into engine 01 and then security access 16 ........login if needed with login stated in caption window.
Then go to 10 adaption and pull down the needed menu for the tests of the PTF.
Hopefully that helps?
Please advise of new logs of DTC's and tests in 01 and OBD2 readiness values.
Wanna do a remote session?
VCDS Version: Release 14.10.1 (x64)
Data version: 20150130
Sunday,08,March,2015,11:53:47:13775
Chassis Type: AJ (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 44 47 56 77
VIN: 3VW3L7AJ2CM457587 Mileage: 104980km-65231miles
Part No SW: 03L 906 019 EH HW: 03L 907 309 AA
Component: R4 2,0L EDC G000SG 3523
Revision: 12H14--- Serial number:
Coding: 0050072
Shop #: WSC 00066 000 00000
VCID: F5A2ABE49CF47989CD6-80A0
001151 - Exhaust Pressure Control Valve
P047F - 000 - Stuck Open
Mileage: 104983 km
Date: 2015.03.08
Time: 23:22:41
RPM: 1610 /min
Speed: 96.0 km/h
Load: 44.3 %
Load: 43.9 %
Lambda: 100.2 %
Temperature: 186.0*C
Temperature: 89.1*C
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: B14B400C492700018D1002EC92200042A71000
VCID: FDB2B3C464C421C9856-80A8
Mileage: 104983 km
Date: 2015.03.08
Time: 00:00:57
Count: 2
Count: 12800
Count: 16390
Count: 49408
Address 08: Auto HVAC Labels: 5C0-820-047.clb
Part No SW: 5C0 820 047 AQ HW: 5C0 820 047 AQ
Component: J301 Klimaanlage 0203
Revision: 2001010S Serial number: 00000000917255
VCID: EFAE998CFEA8435907A-80BA
Address 09: Cent. Elect. (J519) Labels: 6R0-937-08x-09.clb
Part No SW: 5C0 937 087 E HW: 5C0 937 087 A
Component: BCM25 JLB H3 H66 0256
Revision: B2066001 Serial number: 04371110121185
Coding: 7B994B9A08AB0B0008382000240884C50082502E60000000300000000000
VCID: AF2E598CFE28035947A-80FA
Subsystem 1 - Part No SW: 6R0 959 801 AF HW: 6R0 959 801 AF Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 004 3464
Coding: 820000
Subsystem 2 - Part No SW: 6R0 959 802 AF HW: 6R0 959 802 AF Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 004 3464
Coding: 820000
Subsystem 3 - Part No SW: 5K0 959 591 HW: 5K0 959 591
Component: J245 PS41.022 H09 0007
Coding: 180000
Subsystem 4 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A
Component: E221__MFL-TAS H09 0013
Coding: 020000
Subsystem 5 - Part No SW: 6R0 959 811 H HW: 6R0 959 811 H
Component: J388__TSG_HL 004 3464
Coding: 800000
Subsystem 6 - Part No SW: 6R0 959 812 H HW: 6R0 959 812 H
Component: J389__TSG_HR 004 3464
Coding: 800000
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5C0 959 655 E HW: 5C0 959 655 E
Component: AirbagVW10G 014 0808
Serial number: 003GTM05H2HP
Coding: 00003936
ASAM Dataset: EV_AirbaVW10SMEVW360 A01023
ROD: EV_AirbaVW10SMEVW360_SK35.rod
VCID: B42456E01F0E20813A8-80E1
Subsystem 1 - Part No SW: 5C6 959 339 A HW: 5C6 959 339 A
Component: BF-Gewichtss. H10 0045
Serial number: 6940000Y120000DEJ30J
Coding: 303036
Serial number: 3572MSME5A24606AZZZ-
Serial number: 3582MSME5B41356CZZZ+
Serial number: 3516KSME705D2118ZZZQ
Subsystem 5 - Part No SW: 5K0 959 351 A HW: 5K0 959 351 A
Serial number: 3526KSME1B1C4B18ZZZ$
Subsystem 6 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3556LSME14266717ZZZS
Subsystem 7 - Part No SW: 5K0 959 659 A HW: 5K0 959 659 A
Serial number: 3566LSME1C195D17ZZZ1
Part No SW: 5C6 920 951 A HW: 5C6 920 951 A
Component: KOMBI H04 0604
Coding: 270A01
Shop #: WSC 00066 000 00118
VCID: A91AB794C8CC6D6999E-80FC
Address 19: CAN Gateway (J533) Labels: 6N0-909-901-6R.clb
Part No SW: 6N0 909 901 HW: 5C0 937 087 A
Component: GW-K-CAN TP20 H66 0256
Revision: B2066001
Coding: 102200
VCID: F0AC9AF023965CA11E0-80A5
Component: IMMO H04 0604
VCID: EA9888980D4AA671504-80BF
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7661922437
VCID: A91AB794C0CC6D6999E-80FC
Part No: 1K0 909 144 P
Component: EPS_ZFLS Kl. 70 3305
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: B73E61ECC678CB991FA-80E2
Part No SW: 5C6 035 456 HW: 5C6 035 456
Component: KonzernAmp10K H07 0468
Revision: -------- Serial number: EAA083A0015924
ROD: EV_AudioVerst10KanalSTT3.rod
VCID: E582FBA4E45489097D6-80B0
Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
Part No SW: 1K0 035 180 AE HW: 1K0 035 180 AE
Component: Radio Prem-8 H02 0016
Revision: -----16S Serial number: VWZ4Z7M3285691
Coding: 01020000010006
VCID: E386E5BCE260F739932-80B6
Reset counter: 0
Mileage: 104982 km
Date: 2015.03.08
Time: 11:05:20
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 E HW: 5K0 035 730 E
Component: TELEFON H09 2902
Revision: 1B001001 Serial number: 00007662015916
Coding: 0A10040000010110
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: EV_UHVNA.rod
VCID: A71EB1ACDED85B198FA-80F2
End-------------------------(Elapsed Time: 01:57)--------------------------
I think i have teamviewer. When would you have time to do that?Team viewer and please post a new auto-scan.........
http://www.teamviewer.com/en/index.aspx
I think your DPF light is on because it's in learn mode........
When i had the dpf out i worked the heck out of the exhaust flap to make sure it would work properly. Would that cause the Dpf light to be on?Well you will need to go investigate/unstick the EPCV in the exhaust and lube it up.
Make sure it is clean and lubed. Exercise it.
Then clear DTC and retest.
Sounds like contaminates made there way to the butterfly possibly.
Just a speed bump!
On a positive note.......of progress...
Before : Readiness: 1 1 0 0 1
After : Readiness: 0 0 0 0 0![]()
I'm fed up with this car... I doubt that flap will cause the dpf light to stay on
Might stick open when hot.When i had the dpf out i worked the heck out of the exhaust flap to make sure it would work properly.
Coding: 0050072
Mileage: 104983 km
Date: 2015.03.08
Time: 23:22:41
RPM: 1610 /min
Speed: 96.0 km/h
Load: 44.3 %
Load: 43.9 %
Lambda: 100.2 %
Temperature: 89.1*C
yes i can perform the output tests in VCDS. It was froze before i took it apart and im got it free and i could move it open and closed with my finger.In addition to basics...... this thing is known to be glitchy after flashing or something being uncle bad touched.
http://wiki.ross-tech.com/wiki/index.php/P047F/00115
Any blown fuses to J883........?
Can outputs be preformed in VCDS?
0x01-03 GO/Next/Do it
It does not throw an engine light, just the dpf light. When i try to clear the code it just sows back up right away. It flashes off the reappears (in VCDS)It will .............
The flap controls exhaust back PSI for EGR and PTF control.
Trust me.......... at least clear the DTC and run the basic settings/adp tests over and over to free it up.
I know this is all a PITA to do but it must be done.
You are so close man,........ don't give up.
Which fuse is it? Nothing in the owners manualIn addition to basics...... this thing is known to be glitchy after flashing or something being uncle bad touched.
