Hello this car have problem with a bearing in transfer case this bearing repair but now we have this fault code,all the fault code can clear except one fault code in abs unit that appear again
Friday,11,September,2020,15:59:07:57658
VCDS Version: 20.4.2.0 HEX-V2 CB: 0.4513.4
VIN: WV1ZZZ2HZB8013888 License Plate: NKH3540
Mileage: 235770km-146500mi Repair Order:
Chassis Type: 2H-VN81 (6N0)
Scan: 01 03 08 09 15 17 19 22 25 32 56
VIN: WV1ZZZ2HZB8013888 Mileage: 235770km-146500miles
Address 01: Engine (J623-CDCA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 019 FA HW: 03L 907 309 K
Component: R4 2.0l BTD H34 9978
Revision: 26H34--- Serial number: 00000000000000
Coding: 01194012232600080000
Shop #: WSC 40300 207 00000
ASAM Dataset: EV_ECM20BTD01103L906019FA 004006
ROD: EV_ECM20BTD01103L906019FA_004.rod
VCID: 6FB8D96477131FD3BB9-803A
4481 - Cruise Control Switch (E45)
P0568 00 [032] - Implausible Signal
Fault Frequency: 14
Mileage: 235772 km
Date: 2020.09.11
Time: 00:10:17
Engine speed: 857.50 /min
Normed load value: 29.4 %
Coolant temperature: 41 °C
Intake air temperature: 31 °C
Voltage terminal 30: 14.100 V
Cruise Control System (CCS): switch position-Bits 0-7: 129
Cruise Control System (CCS): status-Bits 0-7: 40
Cruise control switch-off: irreversible-Bits 0-7: 255
Cruise control switch-off: reversible-Bits 0-7: 15
Cruise Control System: specified speed: 105.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 0
4482 - Function Restriction due to Implausible Message(s)
U1112 00 [032] - -
Fault Frequency: 14
Mileage: 235772 km
Date: 2020.09.11
Time: 00:10:17
Engine speed: 859.50 /min
Voltage terminal 30: 14.120 V
Cruise Control System (CCS): switch position-Bits 0-7: 193
Cruise Control System (CCS): status-Bits 0-7: 232
Cruise control switch-off: irreversible-Bits 0-7: 0
Cruise Control System: specified speed: 0.00 km/h
Cruise control switch-off: irreversible w. brake intervention-Bits 0-7: 1
4708 - No Communications with HVAC Control Module (J301)
U0164 00 [032] - -
Fault Frequency: 18
Mileage: 235772 km
Date: 2020.09.11
Time: 00:10:21
Normed load value: 29.0 %
Voltage terminal 30: 14.140 V
selected gear-Bits 0-7: 0
Address 03: ABS Brakes (-----) Labels: 2H0-907-37x-ESP.clb
Part No SW: 2H0 907 379 F HW: 2H0 907 379 D
Component: ESP MK25A XT H43 0104
Revision: 00H43001
Coding: C07324B69295039824AA49AB6F5810
Shop #: WSC 00000 059 49152
VCID: 333015145B3B7B339F1-8066
02053 - Control Module for Transfer Case (J646)
Reset counter: 251
Mileage: 235773 km
Date: 2015.02.02
Time: 00:04:01
Count: 32896
Count: 4353
Count: 8269
Count: 514
03716 - Regulation Function Disabled; Blocking Electronics Active
Reset counter: 251
Mileage: 235773 km
Date: 2015.02.02
Time: 00:03:58
Count: 16384
Count: 4097
Count: 4175
Count: 514
Address 08: Auto HVAC (J301) Labels:| 7E5-907-047.clb
Part No SW: 2H0 907 047 E HW: 2H0 907 047 E
Component: Climatic-T5 H20 0505
Revision: 00001008
Coding: 0000000003
Shop #: WSC 02310 790 50316
ROD: EV_ClimaT5Basis.rod
VCID: 2A0E08708C713AFB2C7-807E
Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
Part No SW: 6R7 937 087 B HW: 6R7 937 087 B
Component: PQ25 BCM H10 0015
Revision: -1------ Serial number: 1002307800
Coding: 3C0002380C010000003000003C0A04C40080412E600200003000
Shop #: WSC 40300 207 66912
VCID: 43D045D40B9BCBB30F1-8016
Subsystem 1 - Part No SW: 6R0 959 801 M HW: 6R0 959 801 M Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 002 3321
Coding: 100000
Subsystem 2 - Part No SW: 6R0 959 802 P HW: 6R0 959 802 P Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 002 3321
Coding: 100000
Subsystem 3 - Part No SW: 6R0 959 811 D HW: 6R0 959 811 D
Component: J388__TSG_HL 002 3321
Coding: 100000
Subsystem 4 - Part No SW: 6R0 959 812 D HW: 6R0 959 812 D
Component: J389__TSG_HR 002 3321
Coding: 100000
03431 - Activation of Left Parking Light
03432 - Activation of Right Parking Light
Part No SW: 2H0 959 655 B HW: 2H0 959 655 B
Component: VW10Airbag00B H05 0013
Revision: -------- Serial number: 003HN00068BP
Coding: 000000000000000000000000000000003042
Shop #: WSC 07456 790 50316
ROD: EV_AirbaVW10BPAVN750.rod
VCID: 333015145BBB7B339F1-8066
Serial number: 3495RRB404R6NG4AKPKU
Serial number: 3505RRB404T6NG4AA88S
Serial number: 3555YRB40576N1H8DGM/
Serial number: 3565YRB404V6NG4ABH68
Part No SW: 2H0 920 863 HW: 2H0 920 863
Component: KOMBI H15 0206
Coding: 170A00
ROD: EV_Kombi_UDS_VDD_RM09_004_VW41.rod
VCID: 6696BC4058E9DE9BC8F-8032
Part No SW: 6N0 909 901 HW: 6R7 937 087 B
Component: GW-K-CAN TP20 0015
Revision: -1------
Coding: 742200
VCID: 70BADA186AAD002BA23-8024
Address 22: AWD Labels: None
Part No SW: 2H0 927 755 B HW: 2H0 927 755 B
Component: SG offroad VTG 0153
Revision: 00H06000 Serial number: T1IRB0950FQ76U
Coding: 0000013
VCID: 2F381964BB135FD3FB9-807A
Component: IMMO H15 0206
ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03006
VCID: 6A8EC8704CF1FAFBEC7-803E
Address 32: Differential Locks (J647) Labels:* 2H0-927-771.clb
Part No SW: 2H0 927 771 HW: 2H0 927 771
Component: Quersperre H04 0014
Revision: 11001001 Serial number: 4DG 19.05.10 00
ASAM Dataset: EV_QuersUDSAAMVN817 A01005
ROD: EV_QuersUDSAAMVN817.rod
VCID: 6B80CD74430BE3F3971-803E
Address 56: Radio
End----------(Elapsed Time: 00:56, VBatt start/end: 12.9V/12.8V)-----------
Address 09: DTCs cleared
Address 01: DTCs cleared
Address 03: DTCs cleared
Friday,11,September,2020,16:15:12:57658
Readiness: 1010 0000
Revision: 00H43001
Reset counter: 211
Mileage: 235775 km
Date: 2015.02.02
Time: 02:34:51
Count: 16768
Count: 4865
Count: 4175
Count: 515
Revision: 00001008
Coding: 0000000003
Coding: 100000
Coding: 100000
Coding: 100000
Coding: 100000
Coding: 170A00
Revision: -1------
Coding: 742200
Coding: 0000013
Address 56: Radio
End----------(Elapsed Time: 00:57, VBatt start/end: 14.0V/14.0V)-----------
Friday,11,September,2020,16:07:04:57658
VIN: WV1ZZZ2HZB8013888 License Plate: AMAROK
Address 03: ABS Brakes Labels: 2H0-907-37x-ESP.clb
Control Module Part Number: 2H0 907 379 F HW: 2H0 907 379 D
Component and/or Version: ESP MK25A XT H43 0104
Software Coding: C07324B69295039824AA49AB6F5810
Work Shop Code: WSC 00000 059 49152
Reset counter: 211
Mileage: 235774 km
Date: 2015.02.02
Time: 02:24:44
Count: 16448
Count: 4097
Count: 4175
Count: 766
