Module 01, Value ENG109007-ENG99938, Spark Efficiency Deviation. Does this have a meaning or just a mistranlation? The % value (16) does not vary with load demand or rpm.
It would be easiest for me to check for a mistranslation from the original German if I knew exactly what ECU this is. Can you post (at least) the
ROD file name showing under 01-Engine in a scan?
Chassis Type: FF-AU37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 3C 42 44 52 55
5F 6C A5 A9 BB BC
VIN: WAUFFRFF8F1141715 Mileage: 54006km-33557miles
Address 01: Engine (J623-CYFB) Labels:. 06K-907-425-V1.clb
Part No SW: 8V0 906 259 H HW: 06K 907 425 E
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 0A1D00122466000E3004
Shop #: WSC 06385 790 00016
ASAM Dataset: EV_ECM20TFS0208V0906259H 001002
ROD: EV_ECM20TFS0208V0906259H.rod
VCID: 45D7575C852A61D3215-8010
More trivia. The spark pugs were replaced in kind but there is no change at all in the values, at idle/part load: 34/16%. The plugs that came out (54,200 km) were pristine. No deposits anywhere and center insulator a nice light tan.Hah! The German data has exactly the same wording -- in English!
"Spark_efficiency_deviation_at_part_load_maximum"
C:\Docs\S4\20160325\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 627: 621,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,34, %
Line 628: 622,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,39, %
C:\Docs\S4\20160418\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 626: 620,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,34, %
Line 627: 621,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,39, %
C:\Docs\S4\20160512\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 626: 620,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,35, %
C:\Docs\S4\20160615-Post-5kService\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 626: 620,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,36, %
C:\Docs\S4\20160615-Pre-5kService\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20160616-RevoStg1-07\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 626: 620,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,0, %
Line 627: 621,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,0, %
C:\Docs\S4\20160617\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 626: 620,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,20, %
C:\Docs\S4\20160620\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 626: 620,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,21, %
C:\Docs\S4\20160627\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 627: 621,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,7, %
C:\Docs\S4\20160630\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20160705\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20160719\blockmap-01-8K5-907-551-G.CSV (4 hits)
Line 1394: 620,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,35, %
Line 1395: 621,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,18, %
C:\Docs\S4\20160727\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 626: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,35, %
Line 627: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,18, %
C:\Docs\S4\20160804\blockmap-01-8k5-907-551-g.csv (2 hits)
C:\Docs\S4\20160907\blockmap-01-8K5-907-551-G-old.CSV (2 hits)
Line 626: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,41, %
Line 627: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,35, %
C:\Docs\S4\20160907\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20160913\blockmap-01-8K5-907-551-G-new.CSV (2 hits)
C:\Docs\S4\20160913\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20161005\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20161012\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20161017-PostSRI\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20161017-PreSRI\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20161026\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20161031\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20161122\blockmap-01-8K5-907-551-G.CSV (4 hits)
Line 1395: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,41, %
Line 1396: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,35, %
C:\Docs\S4\20161205\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 627: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,36, %
C:\Docs\S4\20161207\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20161208\blockmap-01-8K5-907-551-G.CSV (4 hits)
Line 1396: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,36, %
C:\Docs\S4\20161221\blockmap-01-8K5-907-551-G.CSV (4 hits)
C:\Docs\S4\20170105-LEDReverse\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170111-LEDtrunk-puddles\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170112\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170112-2\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170117\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170210\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170214\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170222\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170224\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170227\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170302\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170303\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 638: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,41, %
Line 639: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,36, %
C:\Docs\S4\20170322\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170327\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170402-PostDTCClear\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170402-PostSRI\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170402-PreSRI\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170403\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170410\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170414\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170425\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170506\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170518\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170530\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 628: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,41, %
Line 629: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,36, %
C:\Docs\S4\20170614\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170627\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170711\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170712\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170724\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170814\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170907\DS276\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170907\DS277\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 662: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,41, %
Line 663: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,36, %
C:\Docs\S4\20170913\DS276\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170913\DS278\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170919\S4Maps-DS276-20170919\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170919\S4Maps-DS278-20170919\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170926\S4Maps-20170926-DS276\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170926\S4Maps-20170926-DS279\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170929\DS276Maps\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170929\DS280Maps\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 714: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,41, %
Line 715: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,36, %
C:\Docs\S4\20170930-SRI\PostSRI\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20170930-SRI\PreSRI\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171002\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171009\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171011\DS276\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171011\DS282\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171012\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171019\DS276\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171019\DS283-2\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 718: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,41, %
Line 719: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,36, %
C:\Docs\S4\20171019\DS283-NewMUX\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171020-Idle\DS276\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171020-Idle\DS283-NewMux\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171103\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 716: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,41, %
Line 717: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,36, %
C:\Docs\S4\20171115\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171204\DS276\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 626: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,46, %
C:\Docs\S4\20171204\DS285\blockmap-01-8K5-907-551-G.CSV (2 hits)
Line 716: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,46, %
C:\Docs\S4\20171211\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20171214-MMIUpd942\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20180108\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20180115\17-12-1\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20180115\1781-Respin\blockmap-01-8K5-907-551-G.CSV (2 hits)
C:\Docs\S4\20180116\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180116\VINfixTest\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180121\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180202\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180202\DS287\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773 (2).CSV (2 hits)
Line 718: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,46, %
C:\Docs\S4\20180206-5pm\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180206-Idle\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180214\am\DS285\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180214\am\DS285\~blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180214\am\DS288\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180214\am\DS288\~blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180214\pm\DS285\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180214\pm\DS288-fix1\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180220\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773-EngOff.CSV (2 hits)
C:\Docs\S4\20180220\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773-idle.CSV (2 hits)
C:\Docs\S4\20180301-SRI\PostSRI\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180301-SRI\PreSRI\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180306\DS287\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180306\DS289\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180309\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180314\18.2\Logs\blockmap-01-8K5-907-551-G-WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180314\18.3\Logs\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180319\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180327\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180425\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180502\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180503\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180522\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180710\18.2\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773.CSV (2 hits)
C:\Docs\S4\20180710\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180710-1359.CSV (2 hits)
C:\Docs\S4\20180716\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180716-1039.CSV (2 hits)
C:\Docs\S4\20180723\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180723-0954.CSV (2 hits)
C:\Docs\S4\20180807\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180807-1000.CSV (2 hits)
C:\Docs\S4\20180807\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180807-1019.CSV (2 hits)
C:\Docs\S4\20180823\18.7.1-DS293\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180823-1329.CSV (2 hits)
C:\Docs\S4\20180823\18.7.2.1-DS295\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180823-1343.CSV (2 hits)
C:\Docs\S4\20180829\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180829-1505.CSV (2 hits)
C:\Docs\S4\20180904\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180904-1310.CSV (2 hits)
C:\Docs\S4\20180913\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180913-1401.CSV (2 hits)
C:\Docs\S4\20180920\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180920-1501.CSV (2 hits)
C:\Docs\S4\20180926\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20180926-1034.CSV (2 hits)
C:\Docs\S4\20181004\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181004-1401.CSV (2 hits)
C:\Docs\S4\20181005-Idle\430pm\blockmap-01-8K5-907-551-G-20181005-1640.CSV (2 hits)
C:\Docs\S4\20181005-Idle\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181005-1243.CSV (2 hits)
C:\Docs\S4\20181016-DTCClear\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181016-1044.CSV (2 hits)
C:\Docs\S4\20181016-DTCClear\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181016-1103.CSV (2 hits)
C:\Docs\S4\20181017\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181017-1732.CSV (2 hits)
C:\Docs\S4\20181030\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181030-1505.CSV (2 hits)
C:\Docs\S4\20181103-SRI\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181103-1432.CSV (2 hits)
C:\Docs\S4\20181103-SRI\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181103-1440.CSV (2 hits)
C:\Docs\S4\20181106-Idle\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181106-1504.CSV (2 hits)
C:\Docs\S4\20181113\DS296\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181113-1305.CSV (2 hits)
C:\Docs\S4\20181113\DS297\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181113-1300.CSV (2 hits)
C:\Docs\S4\20181113\DS297\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181113-1908.CSV (2 hits)
C:\Docs\S4\20181129\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181129-1131.CSV (2 hits)
C:\Docs\S4\20181213\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181213-1019.CSV (2 hits)
Line 717: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,38, %
C:\Docs\S4\20181213\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20181213-1316.CSV (2 hits)
C:\Docs\S4\20190103\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190103-0914.CSV (2 hits)
C:\Docs\S4\20190115\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190115-1256.CSV (2 hits)
C:\Docs\S4\20190122\DS296\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190122-0939.CSV (2 hits)
C:\Docs\S4\20190122\DS301\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190122-0934.CSV (2 hits)
Line 719: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,38, %
C:\Docs\S4\20190207\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190207-1353.CSV (2 hits)
C:\Docs\S4\20190209\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190209-1545.CSV (2 hits)
C:\Docs\S4\20190225\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190225-1412.CSV (2 hits)
C:\Docs\S4\20190313\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190313-1051.CSV (2 hits)
C:\Docs\S4\20190315-Summer Tires\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190315-1136.CSV (2 hits)
C:\Docs\S4\20190325\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190325-1057.CSV (2 hits)
C:\Docs\S4\20190331\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190331-1402.CSV (2 hits)
C:\Docs\S4\20190424\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190424-1029.CSV (2 hits)
C:\Docs\S4\20190427-SRI\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190427-1732.CSV (2 hits)
C:\Docs\S4\20190427-SRI\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190427-1741.CSV (2 hits)
C:\Docs\S4\20190510\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190510-1117.CSV (2 hits)
C:\Docs\S4\20190517\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190517-1054.CSV (2 hits)
C:\Docs\S4\20190529\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190529-1301.CSV (2 hits)
C:\Docs\S4\20190719\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190719-1254.CSV (2 hits)
C:\Docs\S4\20190719\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20190719-1311.CSV (2 hits)
C:\Docs\S4\20191015\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20191015-1328.CSV (2 hits)
C:\Docs\S4\20191021\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20191021-1456.CSV (2 hits)
C:\Docs\S4\20191104\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20191104-2109.CSV (2 hits)
C:\Docs\S4\20191108-HN0vsHN2-Beta1993\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20191108-2002.CSV (2 hits)
Line 717: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,41, %
C:\Docs\S4\20191127\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20191127-1046.CSV (2 hits)
C:\Docs\S4\20191204\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20191204-1633.CSV (2 hits)
C:\Docs\S4\20191204\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20191204-1642.CSV (2 hits)
Line 719: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,41, %
C:\Docs\S4\20191209\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20191209-1008.CSV (2 hits)
C:\Docs\S4\20191209\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20191209-1308.CSV (2 hits)
C:\Docs\S4\20200102\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200102-1024.CSV (2 hits)
C:\Docs\S4\20200110\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200110-1315.CSV (2 hits)
Line 714: ENG109006-ENG100882,Spark_efficiency_deviation_at_idle_maximum-EFF_IGA_CST_QUO_IS_MAX,46, %
Line 715: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,41, %
C:\Docs\S4\20200115\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200115-1355 ClutchEngaged.CSV (2 hits)
C:\Docs\S4\20200115\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200115-1356 ClutchDisengaged.CSV (2 hits)
C:\Docs\S4\20200115\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200115-1358. ClutchHalfway.CSV (2 hits)
C:\Docs\S4\20200212\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200212-0938.CSV (2 hits)
C:\Docs\S4\20200311\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200311-0930.CSV (2 hits)
Line 717: ENG109007-ENG99938,Spark_efficiency_deviation_at_part_load_maximum-EFF_IGA_CST_QUO_PL_MAX,44, %
C:\Docs\S4\20200330\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200330-1843.CSV (2 hits)
C:\Docs\S4\20200611\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200611-1525.CSV (2 hits)
C:\Docs\S4\20200701\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200701-1925.CSV (2 hits)
C:\Docs\S4\20200724\20-4-1\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200724-1052.CSV (2 hits)
C:\Docs\S4\20200724\20-7-0\blockmap-01-8K5-907-551-G_WAUDGAFL1GA000773-20200724-1019.CSV (2 hits)
There are many things that ECUs measure and make available to be read, which are not well documented or understood. This has been the case "forever". On pre-UDS modules, there were plenty of values in Measuring Blocks that simply weren't defined anywhere at all. Now with UDS, everything has a name of some sort (although some of those names can be quite cryptic). But that doesn't mean it's documented to the point where anyone outside of VAG (and the ECU vendor) really understands what it means or how it should be interpreted.So if a real parameter is being measured what can it be?
I suppose someone could buy and install a fresh set of coils to see if that changes it.Possibly secondary winding resistance?
Does that number change if you deliberately drive in a lower gear?Another trivia question. Module01, IDEIDE07019- # of ignitions reports numbers which directly vary with distance driven (S3 MQB motor). So something is actually being measured but why? If I divide the No of ignitions by the distance I get about 1600 ignitions per Km or 2600 per mile. That result seems like a plausible correlation with engine revolutions/mile.
I have not done that. The reported interval was about 1400 km. Many of my drives comprise of a number of very short segments one after the other but even then the total trip is seldom less than 25Km.Does that number change if you deliberately drive in a lower gear?
Trivia redux. A possibly useful application is for counting ignitions to facilitate DSG shifts. It is helpful and maybe necessary to reduce engine load on clutches during shifts like the throttle suppression with manual gear shifts. If some ignitions are suppressed they do not show up as misfires. Neat trick.Another trivia question. Module01, IDEIDE07019- # of ignitions reports numbers which directly vary with distance drivApoen (S3 MQB motor). So something is actually being measured but why? If I divide the No of ignitions by the distance I get about 1600 ignitions per Km or 2600 per mile. That result seems like a plausible correlation with engine revolutions/mile .
