Passat B8 Matrix problems
VAGParts
Denmark
C?ID=61241
I really need help with error codes on my Passat.
I have mounted the facelift 2020 Matrix headlights on my 2016 Passat.
I can not fix the last errors so I can preset my lights.
The problem is in 4B and A5
Friday,04,September,2020,10:46:38:52337
VCDS Version: 20.4.2.0 (x64)  HEX-NET CB: 0.4513.4
[URL="http://www.Ross-Tech.com"]www.Ross-Tech.com[/URL]
Workshop Code: 970 22339 012345
VIN: WVWZZZ3CZGExxxxxx   License Plate:
Mileage: 115442km-71732mi   Repair Order:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 18 19 2B 3C 42 44 4B 52 5F
          65 69 6C 6D A5 BB BC CF D6 D7
VIN: WVWZZZ3CZGE228682   Mileage: 115442km-71732miles
Address 01: Engine (J623-DFCA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 FN    HW: 04L 907 309 M
   Component: R4 2.0l TDI   X23 2011
   Revision: B4X23---
   Coding: 011D003A047405083000
   Shop #: WSC 92521 052 00000
   ASAM Dataset: EV_ECM20TDI01104L906026FN 004002
   ROD: EV_ECM20TDI01104L906026FM_004_VW48.rod
   VCID: 7BB621D8F229115E46-802E
   Part No SW: 0D9 300 041 J    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H53 4906
   Revision: 06253104    Serial number: TFK01602241041
   Shop #: WSC 05311 115 00061
   ROD: EV_TCMDQ250021.rod
   VCID: 1F0E35480671AD7E0A-804A
   Revision: 00000000    Serial number: 61046000000938
   Coding: 0FEC6A8F34220B74077D060841C549F0562CD0E0608292F11862F0084209
   Shop #: WSC 22339 970 00001
   VCID: 7AB824DCFD1328565D-802E
   Part No SW: 3Q0 959 435 B    HW: 3Q0 959 435 B
   Component: VWKESSYMQB    026 0710
   Revision: 00026000    Serial number: 0401603713
   Coding: 000F0F0F03
   Shop #: WSC 05311 115 00236
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 393AFBD0B895E34E14-806C
   Part No SW: 5G0 907 044 BH    HW: 5G0 907 044 BH
   Component: Climatronic   H04 1202
   Revision: 00001K10
   Coding: 12020104204101011115500000101802
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_ACClimaBHBVW37X 005137
   VCID: 6E90188CB15B74F6F1-803A
   Air quality sensor:
   Part No SW: 5Q0 937 086 CF    HW: 5Q0 937 086 BR
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: J53F18061900LA
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: EV_BCMBOSCH_020.rod
   VCID: 004C56349BCF728613-8054
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160326  042  0607
   Serial number:         160408192827
   Subsystem 2 - Part No SW: 8UD 955 559 B    HW: 8UD 955 559 B  Labels: 8U0-955-559.CLB
   Component: G397_RLFS  H06  0004
   Serial number: 90070925
   Coding: 00006E
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Component: E1 - LDS MQB  H01  0032
   Serial number: 20 01 2016  10000219
526359 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [Steuergerät falsch codiert->Keine Anzeige]
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:08:16
1049604 - Lamp 1 for Contour Lighting of Door; Front Left
          U1176 00 [009] - No Communications
          [Tür vorne links - Slave 1->kein Signal/Kommunikation]
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:08:20
1050628 - Lamp 1 for Contour Lighting of Door; Front Right
          U1178 00 [009] - No Communications
          [Tür vorne rechts - Slave 1->kein Signal/Kommunikation]
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:08:20
1051652 - Lamp 1 for Contour Lighting of Door; Rear Left
          U117A 00 [009] - No Communications
          [Tür hinten links - Slave 1->kein Signal/Kommunikation]
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:08:20
1052676 - Lamp 1 for Contour Lighting of Door; Rear Right
          U117C 00 [009] - No Communications
          [Tür hinten rechts - Slave 1->kein Signal/Kommunikation]
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:08:20
734997 - Control Module for Roof Electronics
          U1165 00 [009] - No Communications
          [Dachkonsole->kein Signal / Kommunikation]
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:08:20
   Part No SW: 5QA 919 298 C    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0045
   Serial number: 000308417618081
   Coding: 0A71267A51
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 50ECA6740B2F4206C3-8004
   Part No SW: 5Q0 907 572 R    HW: 3Q0 907 567 A
   Component: ACC BOSCH MQB H01 0771
   Coding: 321F1F7BDFFFFF6B979F82BC81508600000000000099400006
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_ACCBOSCHVW416 003014
   ROD: EV_ACCBOSCHVW416_003.rod
   VCID: 46C0802CF96B9CB669-8012
   Part No SW: 3Q0 959 655 BB    HW: 3Q0 959 655 BB
   Component: Airbag VW20   013 0195
   Revision: --------    Serial number: 003STP7HZFH4
   Coding: 88CCC000008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7F4ED5C8E6310D7E6A-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 204 16
   Serial number: 3576U000000426303A1.
   Subsystem 2 - Part No SW: -----------    HW: 454 000 204 16
   Serial number: 3586U000000A5B5D4A1P
   Subsystem 3 - Part No SW: -----------    HW: 454 802 503 16
   Serial number: 3516RE6FDFF090000000
   Subsystem 4 - Part No SW: -----------    HW: 454 802 503 16
   Serial number: 3526RB1E4FF09000000Q
   Subsystem 5 - Part No SW: -----------    HW: 454 802 803 16
   Serial number: 3556VB451470A0000006
   Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160303501287
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   Part No SW: 3G0 920 791 A    HW: 3G0 920 791 A
   Component: KOMBI         412 1460
   Coding: 07A509986E8C000C01887F0F3001000000000000
   VCID: 271E2DA85E2165BE72-8072
16777035 - Control module
          B2001 00 [009] - Incorrect software version
          [BAP_DoorLocking_0x0D falsche Softwareversion]
                    Reset counter: 211
                    Mileage: 114658 km
                    Date: 2020.08.28
                    Time: 22:27:59
Address 18: Aux. Heat (J364)       Labels:| 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 E    HW: 5Q0 963 272 E
   Component: STH-MQB       007 0072
   Coding: 9309
   Shop #: WSC 00015 115 00001
   VCID: 383CFED4839FFA46EB-806C
   Subsystem 1 - Part No SW: 5Q0 963 513 A    HW: 5Q0 963 513 A
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000001374380
   Part No SW: 3Q0 907 530 Q    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5344
   Serial number: 06051710520518
   Coding: 0B0300345F017300FB00025A1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 3D32EFC0ACBDDF6E38-8068
   Component: 1-01-03-01-04
   Subsystem 2 - Part No SW: 3G0 959 442 C    HW: 3G0 959 442 C
   Component: E221__MFL-PR6  X04 U100
   Serial number: PR6-0440036145180018
   Coding: 2F84FF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 0448649703
   Power Converter DC AC:
   Subsystem 4 - Part No SW: 5Q0 907 155 C    HW: 5Q0 907 155 C
   Component: WECHSELRICHTE  H55 0033
   Serial number: 0226931
   Analog clock:
   Subsystem 5 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
   Serial number: 16000073540012
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71AA03F0A0656B0EEC-8024
   Part No SW: 3Q0 907 566 E    HW: 3Q0 907 566
   Component: MRR1Rear      H16 0510
   Revision: --------
   Coding: 16C002
   Shop #: WSC 00046 000 00000
   VCID: 3A38E4DCBD93E8561D-806E
1188157 - Databus
          [databus unreasonable message - Perso_Status]
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:28:00
                    Control Module temperature: 37 °C
                    Voltage terminal 30: Measured value not available
                    Vehicle speed: 0.00 km/h
                    Terminal 15 status: Measured value not available
                    Voltage terminal 15: 11.90 V
   Serial number: 040416ED414997
   Coding: 001F0B20DC00020000001000
   VCID: 43C69938CA59A99E4E-8016
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000735503
   Coding: 01010011005000
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   Part No SW: 3Q0 907 338 F    HW: 3Q0 907 338 F
   Component: FCM MQB High  004 0370
   Serial number: 02101910802508
   Coding: 00000007090003CA01000F11000000000000000000000000000000000000
   ROD: EV_MultiModulContiVW48X_003_VW27.rod
13705479 - Databus
          [Kamera_FDD_Obj01 data bus missing message]
                    Reset counter: 17
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:27:27
13705999 - Databus
          [Kamera_FDD_Funktionsstatus_Fehler received error status]
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:25:41
5350720 - Left Matrix High Beam
          C1175 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:24:47
5350976 - Right Matrix High Beam
          C1176 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:24:47
0032 - Headlight
          C107E 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:24:47
   Serial number: 060416ED60262A
   Coding: 001F0120DC00020000001000
   VCID: 42C89C3CD543A09645-8016
   Part No SW: 5NA 035 022 D    HW: 5NA 035 022
   Component: MU-H-LND-EU   054 1367
   Serial number: A683D0GB030629
   Coding: 02840201FF00000051110001000808031F0106E441200000DF
   VCID: 3424CAE49FF71E26C7-8060
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT3280274
   Subsystem 2 - Part No SW: V03 959 806 N    HW: -----------
   Component: ECE 2020/2021  --- 0187
          B201A 00 [009] - -
                    Fault Frequency: 9
                    Reset counter: 232
                    Mileage: 114658 km
                    Date: 2020.08.28
                    Time: 22:28:08
                    Voltage terminal 30: 12.2 V
                    Status_Software_Version_Management-module_name: MDUV624/Main
   Serial number: 30000000199487
   ROD: EV_RDKBERU30_006_VW37.rod
   Part No SW: 5Q0 907 383 G    HW: 5Q0 907 383 D
   Component: Anhaenger     H21 0203
   Revision: 8A001003    Serial number: 0400569602
   Coding: 0100000202000000
   VCID: 3B36E1D8B2A9D15E06-806E
   Part No SW: 5Q0 907 556 C    HW: 5Q0 907 556
   Component: Areaview 2    H13 0608
   Serial number: C854707JG034284
   Coding: 01840201E30F20000000480C
   Shop #: WSC 00070 000 00000
   ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
   ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30613377500000
   Coding: 0280
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 3FCE95C8A6B1CD7E2A-806A
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| User\3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 04091815P12091
   Coding: 000408020000040100242347C046A90094000E300080
   VCID: 3C34E2C4B7A7D6660F-8068
1123203 - Databus
          [LWR_AFS_05_MXB_Status]
                    Reset counter: 232
                    Mileage: 115442 km
                    Date: 2020.09.04
                    Time: 10:37:07
                    Control Module temperature: 39 °C
                    Outside air temperature: 16.0 °C
                    System run time: 719.0 s
                    Voltage terminal 15: 11.7 V
                    mid: 02 E9
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 090316EC817976
   Coding: 000E01200100020000001000
   VCID: 45C28720C46D97AE60-8010
   Serial number: 090316EC817797
   Part No SW: 3Q0 907 590 E    HW: 3Q0 907 590
   Revision: --------
   Coding: 16C002
   VCID: 373EFDE88E81F53EE2-8062
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 992 941 572 CA    HW: 992 941 572 C
   Component: LED1L         H08 9002
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 64847AA46F97CEA697-8030
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H08 9002
End----(Elapsed Time: 02:34, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Mari
C?ID=150535
Next time, please use the </>-button (code) and place your autoscan in the popup-window... that will keep the forum readable ;)
Changing headlights maybe needs some coding... erase faultcodes and scan again, the ones that come back need attention!
golfi_vend
Tartu, Estonia
C?ID=195131
Wow...Cool project.
I wonder if the camera supports Matrix beam. It has this coding opion, but does it really support it...
downtime
Finland
C?ID=280813
Yes it does. There's a person on the other tool forum who did the same retrofit and used 3Q0 camera. No issues there.
downtime
Finland
C?ID=280813
Have you actually tried to calibrate the lights? The person who did the retrofit used a different 4B module :
   Part No SW: 3Q0 907 338 E    HW: 3Q0 907 338 E
   Component: FCM MQB Low   003 0367
