- Apr 2, 2014
- 122
- 135
Tuesday,22,September,2020,11:01:57:35467
VCDS Version: 20.9.0.0 (x64) HEX-V2 CB: 0.4529.4
Data version: 20200730 DS320.0
VIN: WVWZZZE1ZLP007472 License Plate:
Chassis Type: E1-VWE3 (1EA)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 5F 6C 75
8C A5 C0 C6 D6 D7 8105 8107 811E 811F 8120 8121 8123 8124 8125
51-Electric Drive -- Status: Malfunction 0010
C6-Batt. Chrg. -- Status: Malfunction 0010
8105-DC/DC Converter 12V -- Status: OK 0000
8107-Antenna -- Status: OK 0000
811E-Burglary Protection FL -- Status: OK 0000
811F-Burglary Protection FR -- Status: OK 0000
8120-Burglary Protection RL -- Status: OK 0000
8121-Burglary Protection RR -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Cannot be reached 0100
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
Address 01: Engine (J623-EBJC) Labels: None
Part No SW: 0EA 906 012 AA HW: 0EA 907 425 C
Component: E-Vehicle H01 1101
Coding: 010200000364140070080000001000402000060000000000
ASAM Dataset: EV_VCU00XXX0200EA906012AA 001009
ROD: EV_VCU00XXX0200EA906012AA.rod
VCID: 6A8C35E77CF741EBD97-803E
31949 - Front Camera for Driver Assist Systems
U1229 00 [032] - Implausible Message
Reset counter: 34
Mileage: 36 km
Date: 2020.09.18
Time: 08:54:06
Engine speed: 16383.75 /min
Normed load value: 100.0 %
Vehicle speed: 18 km/h
Coolant temperature: 215 °C
Intake air temperature: 215 °C
Ambient air pressure: 2550 mbar
Voltage terminal 30: 14.667 V
Unlearning counter according OBD: 34
LF_MVB_PDU_INTC_DIAG_1: 32792
LF_MVB_PDU_INTC_DIAG_2: 15360
LF_MVB_PDU_INTC_DIAG_3: 0
LF_MVB_PDU_INTC_DIAG_4: 32768
LF_MVB_PDU_INTC_DIAG_5: 517
LF_MVB_PDU_INTC_DIAG_6: 3976
LF_MVB_BUS_INTC_DIAG: 256
43559 - Release / Enable Active
B184C 00 [040] - -
Reset counter: 35
Mileage: 35 km
Date: 2020.09.18
Time: 07:47:11
Voltage terminal 30: 14.609 V
Unlearning counter according OBD: 35
Driver request torque: 0.0 Nm
PV: 0.00 %
LV_IGK: 00000001
TAA: 15.500 °C
Driving position: P
Brake light switch status-actuated__activated: not activated
Brake light switch status-Ident_32: 0
Hybrid batt charge cond act val standardized: 95.00 %
34298 - Databus
U1122 00 [032] - Implausible Message
Reset counter: 38
Mileage: 63 km
Date: 2020.09.18
Time: 19:19:26
Voltage terminal 30: 14.121 V
Unlearning counter according OBD: 38
CCS Switch: ACC operating unit
Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
ACC variants (coding): ACC with braking until at standstill/Stop & Go
Cruise control switch actuation-Main switch: not activated
Cruise control switch actuation-Setting: not activated
Cruise control switch actuation-Activation: not activated
Cruise control switch actuation-Status: OK
Cruise control switch actuation-Accelerate: not activated
Cruise control switch actuation-Decelerate: not activated
Cruise control switch actuation-Cancel: not activated
Cruise control switch actuation-Main switch hardware: not activated
Cruise control switch actuation-Coding: plausible
Cruise control switch actuation-Limit function: not selected
Cruise control switch actuation-Limit button: not activated
Cruise control switch actuation-Main switch CAN: not activated
Cruise control switch actuation-Large increment: not activated
Cruise control switch actuation-Control component verified: Yes
ACC variants: ACC with Stop & Go
ECU_STATE: ENG_STOP
38468 - Implausible Data Received from ESP Control Module
U0416 00 [032] - -
Reset counter: 37
Mileage: 39 km
Date: 2020.09.18
Time: 13:08:45
Voltage terminal 30: 13.085 V
Part No SW: 1EA 614 517 N HW: 1EA 614 517
Component: ESC-ZF_EBC470 H14 0143
Serial number: B00080Q
Coding: 09954A84153B903D5240A8E511DB11A648294916443111492888886512949268228C889214D6CBBCFC006BD33D3F00
ASAM Dataset: EV_Brake1ZFESCEPBMEB 003042
ROD: EV_Brake1ZFESCEPBMEB_003_VWE3.rod
VCID: 3D26CEBB5DF906534C5-8068
Address 05: Acc/Start Auth. (J518) Labels: None
Part No SW: 5WA 959 436 G HW: 5WA 959 436 C
Component: Kessy IOBOX 070 0706
Serial number: ---------------
ASAM Dataset: EV_Kessy37w 003022
ROD: EV_Kessy37w_003_VW38.rod
VCID: 58E87F2FD29BC37B7F3-800C
Address 08: Auto HVAC (J979) Labels:* None
Part No SW: 1EA 907 727 L HW: 1EA 907 727 C
Component: Climatronic H01 0213
Coding: 002122017010120000100010110001101000102100101001000000000000
ASAM Dataset: EV_ACClimaBHBMEB31X 001045
ROD: EV_ACClimaBHBMEB31X_VWE3.rod
VCID: 43D2B8433B1D70A33A1-8016
131076 - Function Restricted due to Insufficient Voltage
U1400 00 [040] - -
Reset counter: 34
Mileage: 39 km
Date: 2020.09.18
Time: 13:08:35
Voltage terminal 30: 0.00 V
Outside air temperature: 18.00 °C
Engine speed: 16383.8 /min
System run time-Terminal 15 on: 0 s
Part No SW: 1EA 937 089 D HW: 1EA 937 089 A
Component: SAM_H H22 0117
Serial number: 06102007100019ÿ
ASAM Dataset: EV_SAMVW31x 003001
ROD: EV_SAMVW31x.rod
VCID: 3FDAB4B357F514435E9-806A
539157 - Databus
U1121 00 [044] - Missing Message
[Klima Datenbus fehlende Botschaft]
Fault Frequency: 79
Reset counter: 39
Mileage: 35 km
Date: 2020.09.18
Time: 07:51:44
1074806 - Databus
U1123 00 [108] - Received Error Message
[ICAS1_Gateway Datenbus empfangener Fehlerwert]
Fault Frequency: 23
Reset counter: 39
Mileage: 35 km
Date: 2020.09.18
Time: 07:57:44
1059332 - Lamp 2 for Contour Lighting of Dashboard
U1180 00 [032] - No Communications
953092 - Control Module for Roof Electronics
U1165 00 [108] - No Communications
Reset counter: 23
Date: 2020.09.21
Time: 07:09:54
Address 10: Park/Steer Assist (-----) Labels:* None
Part No SW: 1EA 919 294 C HW: 1EA 919 294
Component: PDC08K------- H01 0087
Serial number: ````b``bb`idef`
Coding: 0040010001
ASAM Dataset: EV_EPHBO18VW3100000 002016
ROD: EV_EPHBO18VW3100000_VWE3.rod
VCID: 3C20C3BF46E30F5B7BB-8068
Address 13: Auto Dist. Reg (J428) Labels:* None
Part No SW: 1EA 907 572 D HW: 1EA 907 572
Component: ARS510VW19 H01 0075
Coding: 010310714071404512474000000040C5AE4020000000000000000000000000
ASAM Dataset: EV_FRONTRADARCONTIVW310 003008
ROD: EV_FRONTRADARCONTIVW310_003_VWE3.rod
VCID: 392EDAAB49D13A7360D-806C
Address 15: Airbags (J234) Labels: None
Part No SW: 1EA 959 655 CC HW: 1EA 959 655 H
Component: VW40Airbag 009 0241
Serial number: U069KnE02E4
Coding: 88CC008000F0C000000000200000000051540000A1540000C000F68000AB0065
ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
ROD: EV_AirbaVW40ALVVW38X_001_VWE3.rod
VCID: 04507B5F7E93B79B43B-8050
10487040 - invalid data record
B2005 00 [032] - -
[Invalid Dataset]
11469056 - Development code 1
B2F01 00 [032] - -
[Dataset inert calibration]
1078272 - Databus
U1121 00 [040] - Missing Message
[NWD: 0x16A954FD PAO_Status_01 Timeout]
Reset counter: 12
Mileage: 127 km
Date: 2020.09.21
Time: 07:10:43
Address 16: Steering wheel (J527) Labels:* None
Part No SW: 1EA 953 507 G HW: 1EA 953 507 G
Component: GSMMEB 006 0071
Serial number: 000000280620260
Coding: 0000
ASAM Dataset: EV_SMLSKLOMEB 010001
ROD: EV_SMLSKLOMEB_010.rod
VCID: 3B22C0A343ED0863721-806E
131380 - Databus
U1121 00 [032] - Missing Message
Reset counter: 36
Mileage: 39 km
Date: 2020.09.18
Time: 17:50:05
Address 17: Instruments (J1254) Labels:* None
Part No SW: 10A 920 320 B HW: 10A 920 320
Component: FAHRERDISPLAY 009 0465
Serial number: 9M1X3207-236579
Coding: E670
ASAM Dataset: EV_DashBoardLGMEB 001026
ROD: EV_DashBoardLGMEB.rod
VCID: 14704B1F0EF3271BD3B-8040
9582602 - Video Cable for Information Electronics 1
B13B9 01 [008] - Electrical Failure
Reset counter: 35
Mileage: 193 km
Date: 2020.09.22
Time: 07:11:01
Part No SW: 1EA 937 012 G HW: 1EA 937 012 A
Component: ICAS1 Host-SG 062 0095
Serial number: SJ8FST160520117
ASAM Dataset: EV_GatewICAS1MEB 005001
ROD: EV_GatewICAS1MEB_VWE3.rod
VCID: 3430EB9F6EB3C71BB3B-8060
15 Faults Found:
2502759 - Unknown Error Code
U1642 00 [044] - -
[Emergency-call_module_no_communication_vlan]
Reset counter: 35
Date: 2020.09.18
Time: 13:28:36
2498675 - Unknown Error Code
U1645 00 [044] - -
[Information_electronics_control_module_1_no_communication_vlan]
Fault Frequency: 12
Reset counter: 40
Date: 2020.09.18
Time: 13:28:12
2502842 - Unknown Error Code
U1646 00 [046] - -
Fault Frequency: 58
Reset counter: 40
Mileage: 35 km
Date: 2020.09.18
Time: 07:49:57
8397570 - Battery terminal recognition
U1411 00 [036] - Open circuit
Fault Frequency: 79
Reset counter: 40
Mileage: 193 km
Date: 2020.09.21
Time: 16:29:50
8397571 - LV Energy Management
B1802 F1 [044] - Warning Triggered
Fault Frequency: 81
Reset counter: 40
Date: 2020.09.18
Time: 17:50:00
8540417 - Unknown Error Code
U15FA 00 [044] - -
Fault Frequency: 10
Reset counter: 39
Mileage: 35 km
Date: 2020.09.18
Time: 07:55:08
8491266 - Unknown Error Code
U14FE 00 [108] - -
[SOK_signature_verification_failed]
Fault Frequency: 6
Reset counter: 36
Mileage: 39 km
Date: 2020.09.18
Time: 10:04:24
8511746 - Unknown Error Code
U173E 00 [036] - -
Reset counter: 37
Date: 2020.09.19
Time: 18:06:25
9371914 - predictive route data
B1630 02 [109] - Signal Failure
Fault Frequency: 57
Reset counter: 40
Mileage: 35 km
Date: 2020.09.18
Time: 07:51:38
8557314 - Databus
U1122 00 [036] - Implausible Message
[ZM_GNSS_Implausible]
Reset counter: 40
Mileage: 193 km
Date: 2020.09.21
Time: 18:32:59
2494569 - Unknown Error Code
U1643 00 [047] - -
[Rearview_camera_system_control_module_no_communication_vlan]
Reset counter: 40
Mileage: 35 km
Date: 2020.09.18
Time: 07:47:30
12400 - Release / Enable Active
B184C 00 [044] - -
[Unlock_protection_of_vehicle_diagnosis_active]
Reset counter: 35
Mileage: 35 km
Date: 2020.09.18
Time: 07:47:15
8515586 - Databus
U1121 00 [046] - Missing Message
[HVLM_occ_01_timeout]
Fault Frequency: 72
Reset counter: 40
Mileage: 35 km
Date: 2020.09.18
Time: 07:51:38
8515587 - Databus
U1121 00 [109] - Missing Message
[HVLM_occ_02_timeout]
Fault Frequency: 71
Reset counter: 40
Mileage: 35 km
Date: 2020.09.18
Time: 07:51:39
8516406 - Function Restriction due to
C1249 F5 [046] - Safety Functions of Charging Management
[FUSI_error_plug_locking_status_not_locked]
Fault Frequency: 144
Reset counter: 40
Mileage: 35 km
Date: 2020.09.18
Time: 07:51:38
Address 23: Brake Booster (J539) Labels: None
Part No SW: 1EA 909 059 H HW: 1EA 909 059
Component: EBB-ZF-Gen1 H27 0241
Serial number: ÿÿÿÿÿÿÿ
Coding: 08951184003B103D884000E520DB2020202020202021212121000404040404040404848484840008001000
ASAM Dataset: EV_BrakeBoostZFMEB 002035
ROD: EV_BrakeBoostZFMEB_VWE3.rod
Address 2B: Steer. Col. Lock (J764) Labels:* None
Part No SW: 1EA 905 861 HW: 2Q0 905 861 B
Component: ELV-MEB H08 0040
Serial number: 20000056851002
Coding: 8800000000000000
Shop #: WSC 00028 000 00000
ASAM Dataset: EV_ELVMarqMQBA0 002004
ROD: EV_ELVMarqMQBA0_VW27.rod
VCID: 74B02B9F2E33871B73B-8020
Address 42: Door Elect, Driver (J386) Labels:* None
Part No SW: 1EA 959 593 A HW: 1EA 959 593
Component: TSG FS 003 0541
Serial number: 0000407699267
Coding: 003D1220D001848005001000
ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
ROD: EV_DCU3DriveSideMAXHCONT.rod
VCID: 40D8B74F2A0B6BBB273-8014
Part No SW: 1EA 907 144 AD HW: 1EA 907 144 G
Component: BASGEN1MQB37 215 5023
Serial number: 00072404
Coding: 0000000000000201000002010100010000000100010102
ASAM Dataset: EV_SteerAssisBASGEN1MQB37 007046
ROD: EV_SteerAssisBASGEN1MQB37.rod
VCID: 75B6169B25499E13445-8020
Address 51: Electric Drive (J841) Labels: None
Part No SW: 1EA 907 121 C HW: 1EA 907 121 C
Component: MEB PSM H08 6034
Serial number: NRR_M2000046136
ASAM Dataset: EV_DMCM15000F11EA907121C 001008
ROD: EV_DMCM15000F11EA907121C.rod
VCID: 2E04F9F7809FEDCBC5F-807A
41735 - Databus
U1123 00 [040] - Received Error Message
Fault Frequency: 18
Reset counter: 4
Mileage: 198 km
Date: 2020.09.22
Time: 08:59:05
Inverter_operating_state: FREEWHEEL_MODE
Actual_mechanical_torque_calculated: 3155219944 Nm
Actual_mechanical_torque_commanded_value: 0
Temperature_IGBT_phase_U: 1102111630 °C
Temperature_IGBT_phase_V: 1102344647 °C
Temperature_IGBT_phase_W: 1102519410 °C
CAN_operation_mode_HV_battery_module_control: Fahren_HV_aktiv
Voltage_Terminal_15: 14.079 V
DC_link_voltage: 1138077144 V
Freewheel_active: Fehler__EM_im_Freilauf
Actual_possible_maximum_torque: 3155219944 Nm
Actual_possible_minimum_torque: 3155219944 Nm
Absolut_value_RPM_e_machine: 3164175499 /min
Inverter_damping_control_gear_ratio: 11.531
Inverter_damping_control_tooth_number: 43
Expected_model_type: 0
41716 - Control Module Improper Shut Down
U3001 00 [040] - -
Reset counter: 0
Mileage: 39 km
Date: 2000.09.18
Time: 00:00:00
Inverter_operating_state: NACHLAUF_MODE
Actual_mechanical_torque_calculated: 0 Nm
Temperature_IGBT_phase_U: 1103626240 °C
Temperature_IGBT_phase_V: 1103677641 °C
Temperature_IGBT_phase_W: 1103677641 °C
CAN_operation_mode_HV_battery_module_control: Init
Voltage_Terminal_15: 0.051 V
DC_link_voltage: 1061167631 V
Freewheel_active: Init
Actual_possible_maximum_torque: 0 Nm
Actual_possible_minimum_torque: 0 Nm
Absolut_value_RPM_e_machine: 0 /min
Inverter_damping_control_tooth_number: 0
Address 52: Door Elect, Pass. (J387) Labels:* None
Part No SW: 1EA 959 592 A HW: 1EA 959 592
Component: TSG BFS 003 0541
Serial number: 0000408976161
Coding: 003D1020DC01048001801000
ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
ROD: EV_DCU3PasseSideMAXHCONT.rod
Part No SW: 10A 035 820 D HW: 10A 035 820 A
Component: IC3-SF--EU H20 0564
Coding: 23106038000000000000000000000000000000000000000000
ASAM Dataset: EV_MUICASSAFEPart 001001
ROD: EV_MUICASSAFEPart_VWE3.rod
VCID: 18683F2F121B037BBF3-804C
16777133 - Unknown Error Code
C10DD F5 [044] - Unknown Error Elaboration
Reset counter: 0
Mileage: 117 km
Date: 2020.09.20
Time: 14:13:23
Address 6C: Back-up Cam. (J772) Labels:* None
Part No SW: 1EA 980 556 C HW: 5WA 980 556 A
Component: RV eCompact H18 0233
Serial number: FCL-K2024.02.20
Coding: 0203E204E43000
ASAM Dataset: EV_CamSysRVCCompaFicosMEB 003010
ROD: EV_CamSysRVCCompaFicosMEB.rod
13705529 - Databus
Address 75: Telematics (J949) Labels:* None
Part No SW: 10A 035 284 B HW: 10A 035 284 A
Component: OCUGen4 H15 0090
Serial number: 0000000003VICL8
Coding: 02310010106880008005460000000000
ASAM Dataset: EV_OCUGen4 001035
ROD: EV_OCUGen4_VWE3.rod
VCID: 1A6C2527EC17116B897-804E
0053 - Databus
U1121 00 [108] - Missing Message
[Button Module ECU : No communication]
Reset counter: 38
Mileage: 127 km
Date: 2020.09.21
Time: 07:10:43
Voltage terminal 30: 14.4 V
12866049 - Databus
[Airbag: Error value received]
Reset counter: 38
Mileage: 127 km
Date: 2020.09.21
Time: 07:10:44
Address 8C: Hybrid Battery (J840) Labels: None
Part No SW: 0Z1 915 184 D HW: 0Z1 915 184 D
Component: J840 K8C BMC 007 0840
Serial number: 000000250320100
ASAM Dataset: EV_BMCeVWBSMEB 001011
ROD: EV_BMCeVWBSMEB.rod
Address A5: Frt Sens. Drv. Assist (R242) Labels:* None
Part No SW: 1EA 980 654 D HW: 1EA 980 654
Component: MEB MFK 4.1 H02 5215
Coding: 0009302C151108E0062420000000000000000000000000000000000000000000
ASAM Dataset: EV_MFK41ValeoMEB 001017
ROD: EV_MFK41ValeoMEB_VWE3.rod
1124755 - Databus
Reset counter: 38
Mileage: 38 km
Date: 2020.09.18
Time: 09:48:14
Address C0: Act. for Ext. Noise (J943) Labels: None
Part No SW: 10A 035 335 A HW: 1EA 035 335
Component: E_SOUND_SG H05 0004
Serial number: JTK072050320812
ASAM Dataset: EV_ESoundMEBHarma 004010
ROD: EV_ESoundMEBHarma.rod
VCID: 16743117180F350BADF-8042
Address C6: Batt. Chrg. (J1050) Labels:* None
Part No SW: 1EA 915 684 AF HW: 1EA 915 684 AD
Component: HV_CHARGER H51 0012
Serial number: 92832TDK00078
Coding: 1080
ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002008
ROD: EV_OCCXPhase1KLOMEB01B_002_VWE3.rod
VCID: 7F5AF4B31775D4431E9-802A
1061380 - Function Restriction due to
C1249 F4 [040] - Too Many Wake-Up Requests in Charging Infrastructure
Reset counter: 32
Mileage: 193 km
Date: 2020.09.21
Time: 20:30:15
DID 1DA0: Standby
DID 1DAC: Standby
Frequency: 0 Hz
Control voltage: 0.0 mV
Duty cycle: 0.0 %
Activation charge cover lock charge socket A: not requested
Locking for H-V charge plug: not locked
Status connect. recognition: detected
Charge socket temperature sensor AC: 30.0 °C
Temperature sensor 1: resistance value: 1063 Ohm
DID 15E2: 34.0 °C
Sensor 1: 6.7 V
Sensor 2: 6.7 V
Sensor 3: 10.7 V
DID 0286: 13.1 V
DID 497C: not active
DID 537A: 14.3 V
DID 1525: 4683 mV
Status of voltage freedom: High voltage power off recognized
DID 5372: 36.0 °C
3280899 - Unknown Error Code
B1AD0 F0 [109] - Unknown Error Elaboration
Reset counter: 40
Mileage: 193 km
Date: 2020.09.21
Time: 16:21:12
DID 1DA0: AC main charge
DID 1DAC: charge
Frequency: 1000 Hz
Control voltage: 5678.0 mV
Duty cycle: 53.3 %
Locking for H-V charge plug: locked
Temperature sensor 1: resistance value: 1056 Ohm
DID 15E2: 28.0 °C
DID 081C: 3539 W
DID 081D: 0 W
DID 081E: 0 W
DID 0286: 13.1 V
DID 537A: 14.3 V
DID 1525: 1959 mV
Status of voltage freedom: High voltage power off not recognized
DID 5372: 28.0 °C
No. of lockings: 9
No. of connections: 0
Anzahl der erfolgreichen Ladesteckerverriegelungen: 3
Wakeupzähler: Kontakt (Proximity): 1
Wakeupzähler: Control Pilot: 2
Ladenormabbruch: Status: not active
Ladeplan: Status: Not available
Preis-/Leistungstabelle: Status: Not available
Transport Layer Security (TLS) Status Kommunikation: not active
DID 103A: supported
number_evse_slac: 0
PLC_modem_status: active
number_slac_attemps: 1
DID 1033: SLAC_failed
DID 1038: no_description
DID 1039: supported
HV charge current: spec. value: 8.8 A
5242881 - Unknown Error Code
U14FE 00 [096] - -
13705218 - Databus
Fault Frequency: 43
Reset counter: 35
Mileage: 35 km
Date: 2020.09.18
Time: 07:50:02
DID 0286: 12.8 V
DID 1DA0: Internal malfunction
DID 1DAC: Standby
Status connect. recognition: not recognized
Temperature sensor 1: resistance value: 1058 Ohm
DID 15E2: 17.0 °C
DID 537A: 14.3 V
DID 5372: 17.0 °C
Address D6: Light Ctrl Left 2 (A31) Labels: None
Part No SW: 992 941 572 AE HW: 992 941 572 A
Component: LED1L H08 9202
ASAM Dataset: EV_LLPGen3LKEBODPO68X 001003
ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
VCID: 669441D768EF658BFDF-8032
Address D7: Light Ctrl Right 2 (A27) Labels: None
Component: LED1R H08 9202
ASAM Dataset: EV_LLPGen3RKEBODPO68X 001003
Address 8105: DC/DC Converter 12V (A19) Labels: None
Part No SW: 1EA 907 190 B HW: 1EA 907 190 B
Component: DCDC Gen4H11 1136
Revision: 00H11000
ASAM Dataset: EV_DCDC10030111EA907190B 001019
ROD: EV_DCDC10030111EA907190B_VWE3.rod
VCID: 3332E8836BBDC023AA1-8066
Address 8107: Antenna (J666) Labels:* None
Part No SW: 1EA 035 741 C HW: 1EA 035 741 C
Component: TrxModulHigh H06 0145
Serial number: 0000000004VIXF4
Coding: 02310611040200
ASAM Dataset: EV_TrxMLGEMEB 006014
ROD: EV_TrxMLGEMEB_006.rod
1375744 - Unknown Error Code
U14FE 00 [047] - -
Mileage: 35 km
Date: 2020.09.18
Time: 07:47:17
Failed verification status: valid
Number of failed verifications: 12
Verification failed: 00 15
Address 811E: Burglary Protection FL (J518) Labels: None
Part No SW: 5WA 962 133 D HW: 5WA 962 133 B
Component: Kessy RSAD 070 0636
ASAM Dataset: EV_RSADVL37w 002013
ROD: EV_RSADVL37w_002_VW38.rod
VCID: 49CEAA6B1931AAF3F0D-801C
Address 811F: Burglary Protection FR (J518) Labels: None
ASAM Dataset: EV_RSADVR37w 002013
ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518) Labels: None
ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518) Labels: None
ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4) Labels: None
Part No: V04 007 003 AR
Component: ICAS1 Sys_Ada 0095
ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
ROD: EV_AppServe1Syste1ICAS1_VWE3.rod
VCID: 77AA1C933F45EC03569-8022
Address 8124: App server 1 system 2 Java (SWC5) Labels: None
Part No: V04 007 003 AS
Component: ICAS1 Sys_Jav 0095
ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
ROD: EV_AppServe1Syste2ICAS1.rod
VCID: 78A81FAF325BE37B5F3-802C
Address 8125: App server 3 system 1 infotaint. (SWC6) Labels:* None
Part No: V04 007 001 CK
Component: IC3-IVI-D-EU 0564
ASAM Dataset: EV_MUICASIVIPart 002007
ROD: EV_MUICASIVIPart_002_VWE3.rod
VCID: 70B8278F5A2BBB3B973-8024
1872 - Unknown Error Code
B1994 F4 [008] - Unknown Error Elaboration
[a2b_bus_micro_defect]
Reset counter: 37
Mileage: 39 km
Date: 2020.09.18
Time: 10:58:38
Voltage terminal 30: 12.2 V
amount_of_nodes: 2
Node number: 1
Node name: Telematics Communication Unit
Node status: OK
End----------(Elapsed Time: 01:39, VBatt start/end: 14.5V/14.5V)-----------
