2020 VW ID.3 (E11)
   #41
NEtech
Denmark
C?ID=56995
I just downloaded, most data, tpi etc.
You did not know this :D
After trying to ask many, vw will not tell what is the problem with my ordered car.
So today I have ordered another model, not the same color inside and outside as wanted, but it could take another month before that would be delivered.
  • Informative
Andy
Sector 7G
HC424490
Wow, that sucks, Niels. Is the new one equipped with a heat pump? I found this interesting graph/thread:
https://www.reddit.com/r/electricvehicles/comments/erl6ml
I know my A3 e-tron on EV really sucks down the electrons when it's cold and the human it's forced to carry insists on having the resistance heating on (no heatpump option for mine).
   #43
NEtech
Denmark
C?ID=56995
Yes all 1edition delivered to Denmark have, I don't remember if it is all 30.000 1edition.
   #44
strandgaard
Denmark
C?ID=50406
Yes please I have not seen UK car yet.
Just enter "2" in [Debug] and start an Autoscan.
Hello Niels,
I just tried that on my 1st Max (danish) and got "not supported by Gateway" when i start Autoscan with Autodetect. And ID.3 is not listed in the drop down menu.
Any ideas?
   #47
strandgaard
Denmark
C?ID=50406
@Uwe - I bought a HEX-V2 a while back and registered it on aug 12 2020.
I just can't find the spot to change the serial number in the forum.
OK. I found what is wrong and have fixed it, both in our internal records and here in the forum, where you are now Verified.
strandgaard
Denmark
C?ID=50406
Thanks ;-)
And the Beta will indeed communicate with my car.
   #51
Have an ID.4 on order - bookmarking this for now :-).
There will be a Release version that's compatible before you get your car. :cool:
NEtech
Denmark
C?ID=56995
And press the brake before you sit on the front seat (if you do that), else ignition is Off, when you move just a little.
Not necessary to delete DTC's, they just pop up right away :)
   #55
LeakyTurnip
C?ID=85240
Friday,04,December,2020,20:43:56:34079
VCDS Version: 20.12.0.1 (x64)  HEX-V2 CB: 0.4529.4
VIN: WVWZZZE1ZLP017665   License Plate: P29 CLW
Mileage: 725   Repair Order:
Chassis Type: E1-VWE3 (1EA)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 5F 6C 75
          8C A5 C0 C6 D6 D7 8105 8107 811E 811F 8120 8121 8123 8124 8125 8128 C002 C003
51-Electric Drive -- Status: Malfunction 0010
8105-DC/DC Converter 12V -- Status: Malfunction 0010
8107-Antenna -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Cannot be reached 0100
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
8128-Light line display -- Status: OK 0000
Address 01: Engine (J623-EBJC)       Labels: None
   Part No SW: 0EA 906 012 AA    HW: 0EA 907 425 C
   Component: E-Vehicle     H01 1101
   Coding: 010200000364140070080000001000402000060000000000
   ASAM Dataset: EV_VCU00XXX0200EA906012AA 001009
   ROD: EV_VCU00XXX0200EA906012AA.rod
   VCID: 6A8C34AE6CF7B8ABCD6-803E
8 Faults Found:
43522 - Unauthorized Software/Coding Detected
          P064F 00 [032] - -
                    Reset counter: 19
                    Mileage: 32 km
                    Engine RPM: 16383.75 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 255 km/h
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 12.675 V
                    Unlearning counter according OBD: 19
                    Driver intention torque: 0.0 Nm
                    PV: 0.00 %
                    LV_IGK: 00000000
                    TAA: 255.992 °C
                    Driving position: Initialization
                    Brake light switch status-actuated__activated: Not operated
                    Brake light switch status-Ident_32: 0
                    Hybrid batt charge cond act val standardized: 127.50 %
23076 - Implausible Data Received from Diagnostic Gateway Module
          U0447 00 [032] - -
                    Reset counter: 19
                    Mileage: 32 km
                    Date: 2020.10.06
                    Time: 09:39:33
                    Voltage terminal 30: 11.816 V
                    LF_MVB_PDU_INTC_DIAG_1: 32792
                    LF_MVB_PDU_INTC_DIAG_2: 3072
                    LF_MVB_PDU_INTC_DIAG_3: 0
                    LF_MVB_PDU_INTC_DIAG_4: 32768
                    LF_MVB_PDU_INTC_DIAG_5: 5
                    LF_MVB_PDU_INTC_DIAG_6: 0
                    LF_MVB_BUS_INTC_DIAG: 256
31949 - Front Camera for Driver Assist Systems
          U1229 00 [032] - Implausible Message
                    Mileage: 346 km
                    Date: 2020.11.21
                    Time: 12:18:24
                    Vehicle speed: 25 km/h
                    Voltage terminal 30: 15.078 V
                    LF_MVB_PDU_INTC_DIAG_2: 15360
                    LF_MVB_PDU_INTC_DIAG_5: 519
                    LF_MVB_PDU_INTC_DIAG_6: 3976
43559 - Release / Enable Active
          B184C 00 [040] - -
                    Reset counter: 19
                    Mileage: 25 km
                    Date: 2020.10.01
                    Time: 12:49:53
                    Voltage terminal 30: 13.906 V
                    PV: 0.00 %
                    LV_IGK: 00000001
                    TAA: 13.500 °C
                    Driving position: P
                    Hybrid batt charge cond act val standardized: 57.50 %
15364 - Unauthorized Software/Coding Detected
          P064F 00 [032] - -
          [Unauthorized Software/Calibration Detected]
                    Reset counter: 19
                    Mileage: 32 km
                    PV: 0.00 %
                    LV_IGK: 00000000
                    TAA: 255.992 °C
42945 - SAE - Invalid Data Received
          U0400 00 [032] - -
                    Fault Frequency: 11
                    Mileage: 32 km
                    Voltage terminal 30: 12.363 V
                    PV: 0.00 %
                    LV_IGK: 00000000
                    TAA: 255.992 °C
43489 - Unknown Error Code
          U3034 00 [032] - -
          [Communication Authentication Key/Certificate Missing/Invalid]
                    Fault Frequency: 11
                    Mileage: 32 km
                    PV: 0.00 %
                    LV_IGK: 00000000
                    TAA: 255.992 °C
38468 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
                    Reset counter: 30
                    Mileage: 48 km
                    Date: 2020.11.10
                    Time: 16:17:33
                    Voltage terminal 30: 13.750 V
   Part No SW: 1EA 614 517 N    HW: 1EA 614 517
   Component: ESC-ZF_EBC470 H14 0143
   Serial number: B000G76
   Coding: 09954A84153C903D5242A8E411DE11A648294916443111492888886512949268228C889214D6CBBCFC006BD33D3F00
   ASAM Dataset: EV_Brake1ZFESCEPBMEB 003042
   ROD: EV_Brake1ZFESCEPBMEB_003_VWE3.rod
   VCID: 3D26CFF24DF9FF13584-8068
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 5WA 959 436 G    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003_VW38.rod
   VCID: 58E87E66C29B3A3B6B2-800C
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 1EA 907 727 L    HW: 1EA 907 727 E
   Component: Climatronic   H01 0213
   Coding: 002122017010120000100010110001101000102100101001000000000000
   ASAM Dataset: EV_ACClimaBHBMEB31X 001045
   ROD: EV_ACClimaBHBMEB31X_001_VWE3.rod
   VCID: 43D2B90A2B1D89E32E0-8016
131076 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Reset counter: 27
                    Mileage: 32 km
                    Date: 2020.10.06
                    Time: 10:25:08
                    Voltage terminal 30: 0.00 V
                    Outside temperature: 12.50 °C
                    Engine RPM: 16383.8 /min
                    System run time-Terminal 15 on: 0 s
59051 - Refrigerant Expansion Valve 1
          P1C06 00 [040] - Implausible Signal
                    Reset counter: 34
                    Mileage: 739 km
                    Date: 2020.11.28
                    Time: 16:27:11
   Part No SW: 1EA 937 089 D    HW: 1EA 937 089 A
   Component: SAM_H         H22 0117
   Serial number: 06102018300686-
   ASAM Dataset: EV_SAMVW31x 003001
   ROD: EV_SAMVW31x.rod
   VCID: 3FDAB5FA47F5ED034A8-806A
539157 - Databus
          U1121 00 [044] - Missing Message
          [Klima Datenbus fehlende Botschaft]
                    Fault Frequency: 112
                    Reset counter: 35
                    Mileage: 32 km
                    Date: 2020.10.26
                    Time: 12:59:14
1074806 - Databus
          U1123 00 [108] - Received Error Message
          [ICAS1_Gateway Datenbus empfangener Fehlerwert]
                    Fault Frequency: 39
                    Reset counter: 37
                    Mileage: 48 km
                    Date: 2020.11.16
                    Time: 07:19:28
1059076 - Lamp 1 for Contour Lighting of Dashboard
          U117E 00 [036] - No Communications
953092 - Control Module for Roof Electronics
          U1165 00 [100] - No Communications
Address 10: Park/Steer Assist (-----)       Labels:* None
   Part No SW: 1EA 919 294 C    HW: 1EA 919 294
   Component: PDC08K------- H01 0087
   Serial number: 000026052094560
   Coding: 0040010001
   ASAM Dataset: EV_EPHBO18VW3100000 002016
   ROD: EV_EPHBO18VW3100000_VWE3.rod
   VCID: 3C20C2F656E3F61B6FA-8068
13959169 - Parking Sensor(s); Front
          B10FC F0 [036] - Function Limitation due to External Factors
          [Geber für Einparkhilfe - Schmutz bzw. Eisbildung vorn]
   Part No SW: 1EA 907 572 D    HW: 1EA 907 572
   Component: ARS510VW19 H02 0075
   Coding: 010310714071404512474000000040C5AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 003008
   ROD: EV_FRONTRADARCONTIVW310.rod
   VCID: 392EDBE259D1C33374C-806C
209054 - Databus
          U1123 00 [040] - Received Error Message
          [FAULT_BV_BLINDNESS_ERROR]
                    Reset counter: 32
                    Mileage: 1091 km
                    Date: 2020.12.03
                    Time: 21:07:44
0578 - Databus
          U1122 00 [032] - Implausible Message
          [FAULT_APS_BLINDNESS_DETECTED]
0527 - Activation Code Inconsistent
          B188C 00 [160] - -
          [FAULT_CONSISTENCY_NO_TSKACC]
          MIL ON - Intermittent - Not Confirmed - Tested Since Memory Clear
0110 - Transport Mode Active
          U1105 00 [128] - -
2063 - Databus
          U1122 00 [160] - Implausible Message
          [FAULT_MAINSWITCH_INIT]
Address 15: Airbags (J234)       Labels: None
   Part No SW: 1EA 959 655 CC    HW: 1EA 959 655 BN
   Component: VW40Airbag    009 0241
   Serial number: U185OkE1C45
   Coding: 88CC008000F0C000000000200000000051540000A1540000C000F68000AB0065
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X_001_VWE3.rod
   VCID: 04507A166E934EDB57A-8050
9444359 - Safety belt switch - driver side
          B101C 07 [040] - Mechanical Failure
                    Mileage: 48 km
                    Date: 2020.11.16
                    Time: 13:43:07
1078272 - Databus
          U1121 00 [032] - Missing Message
          [NWD: 0x16A954FD PAO_Status_01 Timeout]
Address 16: Steering wheel (J527)       Labels:* None
   Part No SW: 1EA 953 507 G    HW: 1EA 953 507 G
   Component: GSMMEB        006 0071
   Serial number: 000000060720260
   Coding: 0000
   ASAM Dataset: EV_SMLSKLOMEB 010001
   ROD: EV_SMLSKLOMEB_010.rod
   VCID: 3B22C1EA53EDF123660-806E
Address 17: Instruments (J1254)       Labels:* None
   Part No SW: 10A 920 320 B    HW: 10A 920 320
   Component: FAHRERDISPLAY 009 0465
   Serial number: 0E1X3800-612402
   Coding: E670
   ASAM Dataset: EV_DashBoardLGMEB 001026
   ROD: EV_DashBoardLGMEB.rod
   VCID: 14704A561EF3DE5BC7A-8040
   Part No SW: 1EA 937 012 G    HW: 1EA 937 012 A
   Component: ICAS1 Host-SG 064 0095
   Serial number: SJ8ICS150720117
   ASAM Dataset: EV_GatewICAS1MEB 005001
   ROD: EV_GatewICAS1MEB_VWE3.rod
   VCID: 3430EAD67EB33E5BA7A-8060
21 Faults Found:
1049259 - Ethernet Databus; Branch 11
          U14A8 00 [036] - No Communication
                    Reset counter: 22
                    Mileage: 48 km
                    Date: 2020.11.16
                    Time: 08:12:19
2502759 - Unknown Error Code
          U1642 00 [044] - -
          [Emergency-call_module_no_communication_vlan]
                    Fault Frequency: 19
                    Reset counter: 36
                    Date: 2020.10.06
                    Time: 09:51:17
2498675 - Unknown Error Code
          U1645 00 [044] - -
          [Information_electronics_control_module_1_no_communication_vlan]
                    Fault Frequency: 70
                    Date: 2020.10.02
                    Time: 00:25:34
2502842 - Unknown Error Code
          U1646 00 [046] - -
                    Fault Frequency: 161
                    Mileage: 25 km
                    Date: 2020.10.01
                    Time: 13:00:08
8397062 - Unknown Error Code
          P1A85 00 [044] - -
          [12_V_test_pulse_not_available_by_reason_of_EMHLR]
                    Reset counter: 37
                    Mileage: 48 km
                    Date: 2020.11.10
                    Time: 10:09:05
                    Reason for rejection: 1
                    Bad counter: 3
                    Test pulse counter not OK: 1
                    Counter increase not OK: 0
                    BZE_test_pulse_request: 2
                    BZE_test_pulse_result: 0
8397571 - LV Energy Management
          B1802 F1 [044] - Warning Triggered
                    Reset counter: 24
                    Mileage: 48 km
                    Date: 2020.11.10
                    Time: 10:15:37
                    23
8442113 - Unknown Error Code
          P1A85 00 [044] - -
          [12V_lead_battery_test_pulse_diagnosis_not_possible_high_voltage_energy_management]
                    Reset counter: 37
                    Date: 2020.10.12
                    Time: 07:31:30
                    Reason for rejection: 2
                    Bad counter: 1
                    Test pulse prompt: low-voltage EM to high-voltage EM: Requirement
                    Test pulse activation: high-voltage EM to low-voltage EM: No enabling
8540417 - Unknown Error Code
          U15FA 00 [044] - -
                    Fault Frequency: 46
                    Reset counter: 37
                    Mileage: 32 km
                    Date: 2020.10.06
                    Time: 08:53:37
8491266 - Unknown Error Code
          U14FE 00 [108] - -
          [SOK_signature_verification_failed]
                    Fault Frequency: 26
                    Reset counter: 39
                    Mileage: 32 km
                    Date: 2020.10.01
                    Time: 13:38:02
8511745 - Unknown Error Code
          U173E 00 [044] - -
                    Fault Frequency: 9
                    Reset counter: 22
                    Mileage: 48 km
                    Date: 2020.11.16
                    Time: 13:43:09
9371914 - predictive route data
          B1630 02 [109] - Signal Failure
                    Fault Frequency: 117
                    Mileage: 32 km
                    Date: 2020.10.01
                    Time: 13:41:21
2494543 - Unknown Error Code
          U1655 00 [044] - -
                    Reset counter: 22
                    Date: 2020.11.08
                    Time: 12:02:09
2494551 - Unknown Error Code
          U163C 00 [044] - -
                    Fault Frequency: 8
                    Reset counter: 39
                    Date: 2020.11.08
                    Time: 12:02:09
2494569 - Unknown Error Code
          U1643 00 [047] - -
          [Rearview_camera_system_control_module_no_communication_vlan]
                    Mileage: 25 km
                    Date: 2020.10.01
                    Time: 12:50:12
8515664 - Control Pilot
          P0CF4 00 [100] - Implausible Signal
          [HVLM_no_cp_communication_possible]
                    Reset counter: 24
                    Mileage: 125 km
                    Date: 2020.11.16
                    Time: 20:51:12
8516362 - Unknown Error Code
          U1633 00 [108] - -
          [HVLM_plc_link_lost]
                    Reset counter: 27
                    Mileage: 125 km
                    Date: 2020.11.16
                    Time: 20:50:43
          B184C 00 [044] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Reset counter: 21
                    Mileage: 25 km
                    Date: 2020.10.01
                    Time: 12:49:57
2240526 - Body Control Module (Central Electric)
          U0140 00 [040] - No Communications
          [Body_control_module_no_communication_data_bus_connect]
                    Reset counter: 36
                    Mileage: 32 km
                    Date: 2020.10.07
                    Time: 10:50:52
8515586 - Databus
          U1121 00 [109] - Missing Message
          [HVLM_occ_01_timeout]
                    Fault Frequency: 135
                    Mileage: 32 km
                    Date: 2020.10.01
                    Time: 13:41:21
8515587 - Databus
          [HVLM_occ_02_timeout]
                    Fault Frequency: 127
                    Mileage: 32 km
                    Date: 2020.10.01
                    Time: 13:41:22
8516406 - Unknown Error Code
          C1249 F6 [046] - Unknown Error Elaboration
                    Mileage: 32 km
                    Date: 2020.10.01
                    Time: 13:41:22
   Part No SW: 1EA 909 059 H    HW: 1EA 909 059
   Component: EBB-ZF-Gen1   H27 0241
   Serial number: ÿÿÿÿÿÿÿ
   Coding: 08951184003C103D884200E420DE2020202020202021212121000404040404040404848484840008001000
   ASAM Dataset: EV_BrakeBoostZFMEB 002035
   ROD: EV_BrakeBoostZFMEB_VWE3.rod
Address 2B: Steer. Col. Lock (J764)       Labels:* None
   Part No SW: 1EA 905 861     HW: 2Q0 905 861 B
   Component: ELV-MEB       H08 0040
   Serial number: 20000107031002
   Coding: 8800000000000000
   Shop #: WSC 00028 000 00000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 74B02AD63E337E5B67A-8020
   Part No SW: 1EA 959 593 A    HW: 1EA 959 593
   Component: TSG FS        003 0541
   Serial number: 0000403239677
   Coding: 003D1220D001848005001000
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
   ROD: EV_DCU3DriveSideMAXHCONT.rod
   VCID: 40D8B6063A0B92FB332-8014
          B1487 54 [008] - Missing Calibration / Basic Setting
                    Mileage: 25 km
                    Date: 2020.10.01
                    Time: 12:50:02
   Part No SW: 1EA 907 144 AD    HW: 1EA 907 144 G
   Component: BASGEN1MQB37  215 5023
   Serial number: 00142979
   Coding: 0000000000000201000002010100010000000100010102
   ROD: EV_SteerAssisBASGEN1MQB37_007_VW38.rod
   VCID: 75B617D235496753504-8020
   Part No SW: 1EA 907 121 C    HW: 1EA 907 121 C
   Component: MEB PSM       H08 6034
   Serial number: NRR_M6000058297
   ASAM Dataset: EV_DMCM15000F11EA907121C 001008
   ROD: EV_DMCM15000F11EA907121C.rod
   VCID: 2E04F8BE909F148BD1E-807A
41735 - Databus
                    Fault Frequency: 58
                    Reset counter: 19
                    Mileage: 1089 km
                    Date: 2020.12.03
                    Time: 21:04:56
                    Inverter_operating_state: FREEWHEEL_MODE
                    Actual_mechanical_torque_calculated: 3170790114 Nm
                    Actual_mechanical_torque_commanded_value: 0
                    Temperature_IGBT_phase_U: 1091679963 °C
                    Temperature_IGBT_phase_V: 1091679963 °C
                    Temperature_IGBT_phase_W: 1091492718 °C
                    CAN_operation_mode_HV_battery_module_control: Fahren_HV_aktiv
                    Voltage_Terminal_15: 15.125 V
                    DC_link_voltage: 1137463269 V
                    Freewheel_active: Fehler__EM_im_Freilauf
                    Actual_possible_maximum_torque: 3170790114 Nm
                    Actual_possible_minimum_torque: 3170790114 Nm
                    Absolut_value_RPM_e_machine: 1028391849 /min
                    Inverter_damping_control_gear_ratio: 11.531
                    Inverter_damping_control_tooth_number: 43
                    Expected_model_type: 0
41716 - Control Module Improper Shut Down
          U3001 00 [040] - -
                    Reset counter: 0
                    Mileage: 577 km
                    Date: 2000.11.26
                    Inverter_operating_state: NACHLAUF_MODE
                    Actual_mechanical_torque_calculated: 0 Nm
                    Temperature_IGBT_phase_U: 1104140248 °C
                    Temperature_IGBT_phase_V: 1104088847 °C
                    Temperature_IGBT_phase_W: 1103934645 °C
                    CAN_operation_mode_HV_battery_module_control: Init
                    Voltage_Terminal_15: 0.031 V
                    DC_link_voltage: 1062543234 V
                    Freewheel_active: Init
                    Actual_possible_maximum_torque: 0 Nm
                    Actual_possible_minimum_torque: 0 Nm
                    Absolut_value_RPM_e_machine: 0 /min
                    Inverter_damping_control_tooth_number: 0
   Part No SW: 1EA 959 592 A    HW: 1EA 959 592
   Component: TSG BFS       003 0541
   Serial number: 0000413713757
   Coding: 003D1020DC01048001801000
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
   ROD: EV_DCU3PasseSideMAXHCONT.rod
                    Reset counter: 46
                    Mileage: 25 km
                    Date: 2020.10.01
                    Time: 12:50:02
   Part No SW: 10A 035 820 D    HW: 10A 035 820 A
   Component: IC3-SF--EU    H20 0564
   Coding: 23106038000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 001001
   ROD: EV_MUICASSAFEPart_VWE3.rod
   VCID: 18683E66021BFA3BAB2-804C
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 1EA 980 556 C    HW: 5WA 980 556 A
   Component: RV eCompact   H18 0233
   Serial number: FCL-K2007.07.20
   Coding: 0203E204E43000
   ASAM Dataset: EV_CamSysRVCCompaFicosMEB 003010
   ROD: EV_CamSysRVCCompaFicosMEB.rod
   Part No SW: 10A 035 284 B    HW: 10A 035 284 A
   Component: OCUGen4       H15 0090
   Serial number: 0000000005VITD0
   Coding: 02310010106880008005460000000000
   ASAM Dataset: EV_OCUGen4 001035
   ROD: EV_OCUGen4_VWE3.rod
   VCID: 1A6C246EFC17E82B9D6-804E
0053 - Databus
          U1121 00 [108] - Missing Message
          [Button Module ECU : No communication]
                    Reset counter: 35
                    Mileage: 636 km
                    Date: 2020.11.26
                    Time: 20:57:18
                    Voltage terminal 30: 14.6 V
12866049 - Databus
          [Airbag: Error value received]
                    Reset counter: 35
                    Mileage: 636 km
                    Date: 2020.11.26
                    Time: 20:57:20
1375744 - Unknown Error Code
          U14FE 00 [040] - -
                    Mileage: 32 km
                    Date: 2020.10.09
                    Time: 23:37:15
   Part No SW: 0Z1 915 184 D    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 007 0840
   Serial number: 000000070720210
   ASAM Dataset: EV_BMCeVWBSMEB 001011
   ROD: EV_BMCeVWBSMEB.rod
   Part No SW: 1EA 980 654 D    HW: 1EA 980 654
   Component: MEB MFK 4.1   H02 5215
   Coding: 0009302C151108E0062420000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001017
   ROD: EV_MFK41ValeoMEB_VWE3.rod
1124497 - Databus
          U1123 00 [044] - Received Error Message
          [ACC_18_ACC_Status_ACC_irreversibel_ERROR]
                    Reset counter: 19
                    Mileage: 32 km
                    Date: 2020.10.14
                    Time: 11:24:30
1124755 - Databus
                    Reset counter: 28
                    Mileage: 32 km
                    Date: 2020.10.06
                    Time: 10:35:52
Address C0: Act. for Ext. Noise (J943)       Labels: None
   Part No SW: 10A 035 335 A    HW: 1EA 035 335
   Component: E_SOUND_SG    H05 0004
   Serial number: JTK072060720812
   ASAM Dataset: EV_ESoundMEBHarma 004010
   ROD: EV_ESoundMEBHarma.rod
   VCID: 1674305E080FCC4BB9E-8042
   Part No SW: 1EA 915 684 AF    HW: 1EA 915 684 AD
   Component: HV_CHARGER    H51 0012
   Serial number: 92832TDM000AX
   Coding: 1080
   ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002008
   ROD: EV_OCCXPhase1KLOMEB01B.rod
   VCID: 7F5AF5FA07752D030A8-802A
1061380 - Function Restriction due to
          C1249 F4 [040] - Too Many Wake-Up Requests in Charging Infrastructure
                    Reset counter: 19
                    Mileage: 1002 km
                    Date: 2020.12.03
                    Time: 10:12:15
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Frequency: 0 Hz
                    Control voltage: 0.0 mV
                    Duty cycle: 0.0 %
                    Activation charge cover lock charge socket A: not requested
                    Lock for high-voltage charging connector: not locked
                    Status connect. recognition: detected
                    Charge socket temperature sensor AC: 30.0 °C
                    Temperature sensor 1: resistance value: 1055 Ohm
                    DID 15E2: 29.0 °C
                    Sensor 1: 0.0 V
                    Sensor 2: 0.0 V
                    Sensor 3: 3.1 V
                    DID 0286: 12.0 V
                    DID 497C: not active
                    DID 537A: 14.3 V
                    DID 1525: 1945 mV
                    Status of voltage freedom: High voltage power off recognized
                    DID 5372: 26.0 °C
3276854 - Unknown Error Code
          U15BF 00 [096] - -
3280899 - Unknown Error Code
          B1AD0 F0 [109] - Unknown Error Elaboration
                    Fault Frequency: 13
                    Mileage: 32 km
                    Date: 2020.10.06
                    Time: 10:55:15
                    DID 1DA0: AC main charge
                    DID 1DAC: Charging
                    Frequency: 1000 Hz
                    Control voltage: 6022.0 mV
                    Duty cycle: 9.7 %
                    Lock for high-voltage charging connector: locked
                    Temperature sensor 1: resistance value: 1047 Ohm
                    DID 15E2: 13.0 °C
                    DID 081C: 0 W
                    DID 081D: 0 W
                    DID 081E: 1269 W
                    DID 0286: 13.9 V
                    DID 537A: 14.4 V
                    DID 1525: 1952 mV
                    Status of voltage freedom: High voltage power off not recognized
                    DID 5372: 13.0 °C
                    No. of lockings: 5
                    No. of connections: 0
                    Number of successful charging connector locks: 3
                    Wake-up counter: contact (proximity): 1
                    Wake-up counter: Control Pilot: 1
                    Charging standard abort: status: not active
                    Loading plan: status: Not available
                    Price/performance table: status: Not available
                    Transport Layer Security (TLS) status communication: not active
                    DID 103A: supported
                    number_evse_slac: 0
                    PLC_modem_status: active
                    number_slac_attemps: 1
                    DID 1033: SLAC_failed
                    DID 1038: no_description
                    DID 1039: supported
                    Target HV charge current: 3.2 A
5242881 - Unknown Error Code
          U14FE 00 [096] - -
13705218 - Databus
                    Fault Frequency: 100
                    Reset counter: 39
                    Mileage: 32 km
                    Date: 2020.10.06
                    Time: 09:12:05
                    DID 0286: 12.0 V
                    DID 1DA0: Internal malfunction
                    DID 1DAC: Standby
                    Status connect. recognition: not detected
                    DID 15E2: 12.0 °C
                    DID 537A: 14.3 V
                    DID 5372: 12.0 °C
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 992 941 572 AE    HW: 992 941 572 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 6694409E78EF9CCBE9E-8032
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H08 9202
Address 8105: DC/DC Converter 12V (A19)       Labels: None
   Part No SW: 1EA 907 190 B    HW: 1EA 907 190 B
   Component: DCDC Gen4H11 1136
   Revision: 00H11000
   ASAM Dataset: EV_DCDC10030111EA907190B 001019
   ROD: EV_DCDC10030111EA907190B.rod
   VCID: 3332E9CA7BBD3963BE0-8066
0372 - Implausible Data Received from Engine Control Module
          U0401 00 [040] - -
                    Reset counter: 35
                    Mileage: 48 km
                    Date: 2020.11.10
                    Time: 16:55:07
                    DC/DC Converter traction power supply: 4.06 V
                    DC/DC Converter controlled output current terminal 30: 12.119 V
                    DC/DC converter: voltage 1 active rectifier: 9.012 V
                    DC/DC converter: voltage 2 active rectifier: 9.059 V
                    DC/DC converter: transformer current 1: 0.000 A
                    DC/DC converter: transformer current 2: 0.000 A
                    DCDC temperature sensor 1: 15.75 °C
                    DCDC temperature sensor 2: 19.53 °C
                    DC/DC converter: operating mode output path 1: rbe_CmnGlb_DcdcMod_Stb_e
                    DC/DC converter: operating mode output path 1-Test_Program_Rbe Asw Dcdc Sym Enum rbe Cmn Glb St Dcdc Mod UBYTE: 1
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 1EA 035 741 C    HW: 1EA 035 741 C
   Component: TrxModulHigh  H07 0145
   Serial number: 0000000004VIPA7
   Coding: 02310611040200
   ASAM Dataset: EV_TrxMLGEMEB 006014
   ROD: EV_TrxMLGEMEB_006.rod
1375488 - Unknown Error Code
          U14FD 00 [096] - -
          [SOK_timeserver_not_available]
          U14FE 00 [109] - -
                    Mileage: 25 km
                    Date: 2020.10.01
                    Time: 12:49:59
                    Failed verification status: valid
                    Number of failed verifications: 2
                    Verification failed: 00 47
1281792 - Clock Syncronization Failure
          U138F 00 [032] - -
Address 811E: Burglary Protection FL (J518)       Labels: None
   Part No SW: 5WA 962 133 D    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: 49CEAB22093153B3E4C-801C
Address 811F: Burglary Protection FR (J518)       Labels: None
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: None
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: None
   ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: None
   Part No: V04 007 003 AR
   Component: ICAS1 Sys_Ada 0095
   ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
   ROD: EV_AppServe1Syste1ICAS1_VWE3.rod
   VCID: 77AA1DDA2F451543428-8022
Address 8124: App server 1 system 2 Java (SWC5)       Labels: None
   Part No: V04 007 003 AS
   Component: ICAS1 Sys_Jav 0095
   ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
   ROD: EV_AppServe1Syste2ICAS1_VWE3.rod
   VCID: 78A81EE6225B1A3B4B2-802C
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:* None
   Part No: V04 007 001 CK
   Component: IC3-IVI-D-EU  0564
   ASAM Dataset: EV_MUICASIVIPart 002007
   ROD: EV_MUICASIVIPart_002_VWE3.rod
   VCID: 70B826C64A2B427B832-8024
7191 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 39
                    Mileage: 48 km
                    Date: 2020.11.16
                    Time: 08:12:08
                    BAP: 00
                    Voltage terminal 30: 13.3 V
1872 - Unknown Error Code
          B1994 F4 [008] - Unknown Error Elaboration
          [a2b_bus_micro_defect]
                    Reset counter: 24
                    Mileage: 48 km
                    Date: 2020.11.16
                    Time: 07:55:30
                    Voltage terminal 30: 11.2 V
                    amount_of_nodes: 2
                    Node number: 1
                    Node name: Emergency call module and communication unit
                    Node status: OK
0021 - Functional Limitation due to Energy Management
          B10CD 00 [008] - -
          [Function restriction via shutoff stage Q2]
                    Fault Priority: 9
                    Fault Frequency: 9
                    Reset counter: 22
                    Voltage terminal 30: 11.5 V
Address 8128: Light line display
End----------(Elapsed Time: 01:51, VBatt start/end: 15.0V/15.0V)-----------
   #56
@LeakyTurnip: Thanks - fascinating auto-scan .
How is it possible for a car with so little kms to have so many DTC s - isn't this a new car?
   #57
Jacek
Poland
C?ID=360566
"Das Auto"
Jacek
Poland
C?ID=360566
Forced implementation of poorly developed technologies and mega savings on materials.
But this already applies to the global automotive industry.
   #59
Gizmo
S.E.Kent UK
C?ID=49193
They are 99% software issues only, the cars were rushed out as they have big fines to reduce and the most successful way to test any software is with as many end users (customers) as possible.
All EVs are the same to some extent.
