2020 VW ID.3 (E11)
   #21
Stephan
Tuesday,22,September,2020,11:01:57:35467
VCDS Version: 20.9.0.0 (x64)  HEX-V2 CB: 0.4529.4
Data version: 20200730 DS320.0
VIN: WVWZZZE1ZLP007472   License Plate:
Chassis Type: E1-VWE3 (1EA)
Scan: 01 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 5F 6C 75
          8C A5 C0 C6 D6 D7 8105 8107 811E 811F 8120 8121 8123 8124 8125
51-Electric Drive -- Status: Malfunction 0010
8105-DC/DC Converter 12V -- Status: OK 0000
8107-Antenna -- Status: OK 0000
8123-App server 1 system 1 adaptive -- Status: Cannot be reached 0100
8124-App server 1 system 2 Java -- Status: Malfunction 0010
8125-App server 3 system 1 infotaint. -- Status: Malfunction 0010
Address 01: Engine (J623-EBJC)       Labels: None
   Part No SW: 0EA 906 012 AA    HW: 0EA 907 425 C
   Component: E-Vehicle     H01 1101
   Coding: 010200000364140070080000001000402000060000000000
   ASAM Dataset: EV_VCU00XXX0200EA906012AA 001009
   ROD: EV_VCU00XXX0200EA906012AA.rod
   VCID: 6A8C35E77CF741EBD97-803E
31949 - Front Camera for Driver Assist Systems
          U1229 00 [032] - Implausible Message
                    Reset counter: 34
                    Mileage: 36 km
                    Date: 2020.09.18
                    Time: 08:54:06
                    Engine speed: 16383.75 /min
                    Normed load value: 100.0 %
                    Vehicle speed: 18 km/h
                    Coolant temperature: 215 °C
                    Intake air temperature: 215 °C
                    Ambient air pressure: 2550 mbar
                    Voltage terminal 30: 14.667 V
                    Unlearning counter according OBD: 34
                    LF_MVB_PDU_INTC_DIAG_1: 32792
                    LF_MVB_PDU_INTC_DIAG_2: 15360
                    LF_MVB_PDU_INTC_DIAG_3: 0
                    LF_MVB_PDU_INTC_DIAG_4: 32768
                    LF_MVB_PDU_INTC_DIAG_5: 517
                    LF_MVB_PDU_INTC_DIAG_6: 3976
                    LF_MVB_BUS_INTC_DIAG: 256
43559 - Release / Enable Active
          B184C 00 [040] - -
                    Reset counter: 35
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:47:11
                    Voltage terminal 30: 14.609 V
                    Unlearning counter according OBD: 35
                    Driver request torque: 0.0 Nm
                    PV: 0.00 %
                    LV_IGK: 00000001
                    TAA: 15.500 °C
                    Driving position: P
                    Brake light switch status-actuated__activated: not activated
                    Brake light switch status-Ident_32: 0
                    Hybrid batt charge cond act val standardized: 95.00 %
34298 - Databus
          U1122 00 [032] - Implausible Message
                    Reset counter: 38
                    Mileage: 63 km
                    Date: 2020.09.18
                    Time: 19:19:26
                    Voltage terminal 30: 14.121 V
                    CCS Switch: ACC operating unit
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    ACC variants (coding): ACC with braking until at standstill/Stop & Go
                    Cruise control switch actuation-Main switch: not activated
                    Cruise control switch actuation-Setting: not activated
                    Cruise control switch actuation-Activation: not activated
                    Cruise control switch actuation-Accelerate: not activated
                    Cruise control switch actuation-Decelerate: not activated
                    Cruise control switch actuation-Cancel: not activated
                    Cruise control switch actuation-Main switch hardware: not activated
                    Cruise control switch actuation-Limit button: not activated
                    Cruise control switch actuation-Main switch CAN: not activated
                    Cruise control switch actuation-Large increment: not activated
                    ACC variants: ACC with Stop & Go
                    ECU_STATE: ENG_STOP
38468 - Implausible Data Received from ESP Control Module
          U0416 00 [032] - -
                    Reset counter: 37
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 13:08:45
                    Voltage terminal 30: 13.085 V
   Part No SW: 1EA 614 517 N    HW: 1EA 614 517
   Component: ESC-ZF_EBC470 H14 0143
   Serial number: B00080Q
   Coding: 09954A84153B903D5240A8E511DB11A648294916443111492888886512949268228C889214D6CBBCFC006BD33D3F00
   ASAM Dataset: EV_Brake1ZFESCEPBMEB 003042
   ROD: EV_Brake1ZFESCEPBMEB_003_VWE3.rod
   VCID: 3D26CEBB5DF906534C5-8068
Address 05: Acc/Start Auth. (J518)       Labels: None
   Part No SW: 5WA 959 436 G    HW: 5WA 959 436 C
   Component: Kessy IOBOX   070 0706
   Serial number: ---------------
   ASAM Dataset: EV_Kessy37w 003022
   ROD: EV_Kessy37w_003_VW38.rod
   VCID: 58E87F2FD29BC37B7F3-800C
Address 08: Auto HVAC (J979)       Labels:* None
   Part No SW: 1EA 907 727 L    HW: 1EA 907 727 C
   Component: Climatronic   H01 0213
   Coding: 002122017010120000100010110001101000102100101001000000000000
   ASAM Dataset: EV_ACClimaBHBMEB31X 001045
   ROD: EV_ACClimaBHBMEB31X_VWE3.rod
   VCID: 43D2B8433B1D70A33A1-8016
131076 - Function Restricted due to Insufficient Voltage
          U1400 00 [040] - -
                    Reset counter: 34
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 13:08:35
                    Voltage terminal 30: 0.00 V
                    Outside air temperature: 18.00 °C
                    Engine speed: 16383.8 /min
                    System run time-Terminal 15 on: 0 s
   Part No SW: 1EA 937 089 D    HW: 1EA 937 089 A
   Component: SAM_H         H22 0117
   Serial number: 06102007100019ÿ
   ASAM Dataset: EV_SAMVW31x 003001
   ROD: EV_SAMVW31x.rod
   VCID: 3FDAB4B357F514435E9-806A
539157 - Databus
          U1121 00 [044] - Missing Message
          [Klima Datenbus fehlende Botschaft]
                    Fault Frequency: 79
                    Reset counter: 39
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:44
1074806 - Databus
          U1123 00 [108] - Received Error Message
          [ICAS1_Gateway Datenbus empfangener Fehlerwert]
                    Fault Frequency: 23
                    Reset counter: 39
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:57:44
1059332 - Lamp 2 for Contour Lighting of Dashboard
          U1180 00 [032] - No Communications
953092 - Control Module for Roof Electronics
          U1165 00 [108] - No Communications
                    Reset counter: 23
                    Date: 2020.09.21
                    Time: 07:09:54
Address 10: Park/Steer Assist (-----)       Labels:* None
   Part No SW: 1EA 919 294 C    HW: 1EA 919 294
   Component: PDC08K------- H01 0087
   Serial number: ````b``bb`idef`
   Coding: 0040010001
   ASAM Dataset: EV_EPHBO18VW3100000 002016
   ROD: EV_EPHBO18VW3100000_VWE3.rod
   VCID: 3C20C3BF46E30F5B7BB-8068
   Part No SW: 1EA 907 572 D    HW: 1EA 907 572
   Component: ARS510VW19 H01 0075
   Coding: 010310714071404512474000000040C5AE4020000000000000000000000000
   ASAM Dataset: EV_FRONTRADARCONTIVW310 003008
   ROD: EV_FRONTRADARCONTIVW310_003_VWE3.rod
   VCID: 392EDAAB49D13A7360D-806C
Address 15: Airbags (J234)       Labels: None
   Part No SW: 1EA 959 655 CC    HW: 1EA 959 655 H
   Component: VW40Airbag    009 0241
   Serial number: U069KnE02E4
   Coding: 88CC008000F0C000000000200000000051540000A1540000C000F68000AB0065
   ASAM Dataset: EV_AirbaVW40ALVVW38X 001012
   ROD: EV_AirbaVW40ALVVW38X_001_VWE3.rod
   VCID: 04507B5F7E93B79B43B-8050
10487040 - invalid data record
          B2005 00 [032] - -
          [Invalid Dataset]
11469056 - Development code 1
          B2F01 00 [032] - -
          [Dataset inert calibration]
1078272 - Databus
          U1121 00 [040] - Missing Message
          [NWD: 0x16A954FD PAO_Status_01 Timeout]
                    Reset counter: 12
                    Mileage: 127 km
                    Date: 2020.09.21
                    Time: 07:10:43
Address 16: Steering wheel (J527)       Labels:* None
   Part No SW: 1EA 953 507 G    HW: 1EA 953 507 G
   Component: GSMMEB        006 0071
   Serial number: 000000280620260
   Coding: 0000
   ASAM Dataset: EV_SMLSKLOMEB 010001
   ROD: EV_SMLSKLOMEB_010.rod
   VCID: 3B22C0A343ED0863721-806E
131380 - Databus
          U1121 00 [032] - Missing Message
                    Reset counter: 36
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 17:50:05
Address 17: Instruments (J1254)       Labels:* None
   Part No SW: 10A 920 320 B    HW: 10A 920 320
   Component: FAHRERDISPLAY 009 0465
   Serial number: 9M1X3207-236579
   Coding: E670
   ASAM Dataset: EV_DashBoardLGMEB 001026
   ROD: EV_DashBoardLGMEB.rod
   VCID: 14704B1F0EF3271BD3B-8040
9582602 - Video Cable for Information Electronics 1
          B13B9 01 [008] - Electrical Failure
                    Reset counter: 35
                    Mileage: 193 km
                    Date: 2020.09.22
                    Time: 07:11:01
   Part No SW: 1EA 937 012 G    HW: 1EA 937 012 A
   Component: ICAS1 Host-SG 062 0095
   Serial number: SJ8FST160520117
   ASAM Dataset: EV_GatewICAS1MEB 005001
   ROD: EV_GatewICAS1MEB_VWE3.rod
   VCID: 3430EB9F6EB3C71BB3B-8060
15 Faults Found:
2502759 - Unknown Error Code
          U1642 00 [044] - -
          [Emergency-call_module_no_communication_vlan]
                    Reset counter: 35
                    Date: 2020.09.18
                    Time: 13:28:36
2498675 - Unknown Error Code
          U1645 00 [044] - -
          [Information_electronics_control_module_1_no_communication_vlan]
                    Fault Frequency: 12
                    Date: 2020.09.18
                    Time: 13:28:12
2502842 - Unknown Error Code
          U1646 00 [046] - -
                    Fault Frequency: 58
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:49:57
8397570 - Battery terminal recognition
          U1411 00 [036] - Open circuit
                    Fault Frequency: 79
                    Mileage: 193 km
                    Date: 2020.09.21
                    Time: 16:29:50
8397571 - LV Energy Management
          B1802 F1 [044] - Warning Triggered
                    Fault Frequency: 81
                    Date: 2020.09.18
                    Time: 17:50:00
8540417 - Unknown Error Code
          U15FA 00 [044] - -
                    Reset counter: 39
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:55:08
8491266 - Unknown Error Code
          U14FE 00 [108] - -
          [SOK_signature_verification_failed]
                    Reset counter: 36
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 10:04:24
8511746 - Unknown Error Code
          U173E 00 [036] - -
                    Reset counter: 37
                    Date: 2020.09.19
                    Time: 18:06:25
9371914 - predictive route data
          B1630 02 [109] - Signal Failure
                    Fault Frequency: 57
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:38
8557314 - Databus
          U1122 00 [036] - Implausible Message
          [ZM_GNSS_Implausible]
                    Mileage: 193 km
                    Date: 2020.09.21
                    Time: 18:32:59
2494569 - Unknown Error Code
          U1643 00 [047] - -
          [Rearview_camera_system_control_module_no_communication_vlan]
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:47:30
          B184C 00 [044] - -
          [Unlock_protection_of_vehicle_diagnosis_active]
                    Reset counter: 35
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:47:15
8515586 - Databus
          U1121 00 [046] - Missing Message
          [HVLM_occ_01_timeout]
                    Fault Frequency: 72
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:38
8515587 - Databus
          U1121 00 [109] - Missing Message
          [HVLM_occ_02_timeout]
                    Fault Frequency: 71
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:39
8516406 - Function Restriction due to
          C1249 F5 [046] - Safety Functions of Charging Management
          [FUSI_error_plug_locking_status_not_locked]
                    Fault Frequency: 144
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:38
   Part No SW: 1EA 909 059 H    HW: 1EA 909 059
   Component: EBB-ZF-Gen1   H27 0241
   Serial number: ÿÿÿÿÿÿÿ
   Coding: 08951184003B103D884000E520DB2020202020202021212121000404040404040404848484840008001000
   ASAM Dataset: EV_BrakeBoostZFMEB 002035
   ROD: EV_BrakeBoostZFMEB_VWE3.rod
Address 2B: Steer. Col. Lock (J764)       Labels:* None
   Part No SW: 1EA 905 861     HW: 2Q0 905 861 B
   Component: ELV-MEB       H08 0040
   Serial number: 20000056851002
   Coding: 8800000000000000
   Shop #: WSC 00028 000 00000
   ROD: EV_ELVMarqMQBA0_VW27.rod
   VCID: 74B02B9F2E33871B73B-8020
   Part No SW: 1EA 959 593 A    HW: 1EA 959 593
   Component: TSG FS        003 0541
   Serial number: 0000407699267
   Coding: 003D1220D001848005001000
   ASAM Dataset: EV_DCU3DriveSideMAXHCONT 001002
   ROD: EV_DCU3DriveSideMAXHCONT.rod
   VCID: 40D8B74F2A0B6BBB273-8014
   Part No SW: 1EA 907 144 AD    HW: 1EA 907 144 G
   Component: BASGEN1MQB37  215 5023
   Serial number: 00072404
   Coding: 0000000000000201000002010100010000000100010102
   ROD: EV_SteerAssisBASGEN1MQB37.rod
   VCID: 75B6169B25499E13445-8020
   Part No SW: 1EA 907 121 C    HW: 1EA 907 121 C
   Component: MEB PSM       H08 6034
   Serial number: NRR_M2000046136
   ASAM Dataset: EV_DMCM15000F11EA907121C 001008
   ROD: EV_DMCM15000F11EA907121C.rod
   VCID: 2E04F9F7809FEDCBC5F-807A
41735 - Databus
          U1123 00 [040] - Received Error Message
                    Fault Frequency: 18
                    Reset counter: 4
                    Mileage: 198 km
                    Date: 2020.09.22
                    Time: 08:59:05
                    Inverter_operating_state: FREEWHEEL_MODE
                    Actual_mechanical_torque_calculated: 3155219944 Nm
                    Actual_mechanical_torque_commanded_value: 0
                    Temperature_IGBT_phase_U: 1102111630 °C
                    Temperature_IGBT_phase_V: 1102344647 °C
                    Temperature_IGBT_phase_W: 1102519410 °C
                    CAN_operation_mode_HV_battery_module_control: Fahren_HV_aktiv
                    Voltage_Terminal_15: 14.079 V
                    DC_link_voltage: 1138077144 V
                    Freewheel_active: Fehler__EM_im_Freilauf
                    Actual_possible_maximum_torque: 3155219944 Nm
                    Actual_possible_minimum_torque: 3155219944 Nm
                    Absolut_value_RPM_e_machine: 3164175499 /min
                    Inverter_damping_control_gear_ratio: 11.531
                    Inverter_damping_control_tooth_number: 43
                    Expected_model_type: 0
41716 - Control Module Improper Shut Down
          U3001 00 [040] - -
                    Reset counter: 0
                    Mileage: 39 km
                    Date: 2000.09.18
                    Inverter_operating_state: NACHLAUF_MODE
                    Actual_mechanical_torque_calculated: 0 Nm
                    Temperature_IGBT_phase_U: 1103626240 °C
                    Temperature_IGBT_phase_V: 1103677641 °C
                    Temperature_IGBT_phase_W: 1103677641 °C
                    CAN_operation_mode_HV_battery_module_control: Init
                    Voltage_Terminal_15: 0.051 V
                    DC_link_voltage: 1061167631 V
                    Freewheel_active: Init
                    Actual_possible_maximum_torque: 0 Nm
                    Actual_possible_minimum_torque: 0 Nm
                    Absolut_value_RPM_e_machine: 0 /min
                    Inverter_damping_control_tooth_number: 0
   Part No SW: 1EA 959 592 A    HW: 1EA 959 592
   Component: TSG BFS       003 0541
   Serial number: 0000408976161
   Coding: 003D1020DC01048001801000
   ASAM Dataset: EV_DCU3PasseSideMAXHCONT 001002
   ROD: EV_DCU3PasseSideMAXHCONT.rod
   Part No SW: 10A 035 820 D    HW: 10A 035 820 A
   Component: IC3-SF--EU    H20 0564
   Coding: 23106038000000000000000000000000000000000000000000
   ASAM Dataset: EV_MUICASSAFEPart 001001
   ROD: EV_MUICASSAFEPart_VWE3.rod
   VCID: 18683F2F121B037BBF3-804C
16777133 - Unknown Error Code
          C10DD F5 [044] - Unknown Error Elaboration
                    Reset counter: 0
                    Mileage: 117 km
                    Date: 2020.09.20
                    Time: 14:13:23
Address 6C: Back-up Cam. (J772)       Labels:* None
   Part No SW: 1EA 980 556 C    HW: 5WA 980 556 A
   Component: RV eCompact   H18 0233
   Serial number: FCL-K2024.02.20
   Coding: 0203E204E43000
   ASAM Dataset: EV_CamSysRVCCompaFicosMEB 003010
   ROD: EV_CamSysRVCCompaFicosMEB.rod
13705529 - Databus
   Part No SW: 10A 035 284 B    HW: 10A 035 284 A
   Component: OCUGen4       H15 0090
   Serial number: 0000000003VICL8
   Coding: 02310010106880008005460000000000
   ASAM Dataset: EV_OCUGen4 001035
   ROD: EV_OCUGen4_VWE3.rod
   VCID: 1A6C2527EC17116B897-804E
0053 - Databus
          U1121 00 [108] - Missing Message
          [Button Module ECU : No communication]
                    Reset counter: 38
                    Mileage: 127 km
                    Date: 2020.09.21
                    Time: 07:10:43
                    Voltage terminal 30: 14.4 V
12866049 - Databus
          [Airbag: Error value received]
                    Reset counter: 38
                    Mileage: 127 km
                    Date: 2020.09.21
                    Time: 07:10:44
   Part No SW: 0Z1 915 184 D    HW: 0Z1 915 184 D
   Component: J840 K8C  BMC 007 0840
   Serial number: 000000250320100
   ASAM Dataset: EV_BMCeVWBSMEB 001011
   ROD: EV_BMCeVWBSMEB.rod
   Part No SW: 1EA 980 654 D    HW: 1EA 980 654
   Component: MEB MFK 4.1   H02 5215
   Coding: 0009302C151108E0062420000000000000000000000000000000000000000000
   ASAM Dataset: EV_MFK41ValeoMEB 001017
   ROD: EV_MFK41ValeoMEB_VWE3.rod
1124755 - Databus
                    Reset counter: 38
                    Mileage: 38 km
                    Date: 2020.09.18
                    Time: 09:48:14
Address C0: Act. for Ext. Noise (J943)       Labels: None
   Part No SW: 10A 035 335 A    HW: 1EA 035 335
   Component: E_SOUND_SG    H05 0004
   Serial number: JTK072050320812
   ASAM Dataset: EV_ESoundMEBHarma 004010
   ROD: EV_ESoundMEBHarma.rod
   VCID: 16743117180F350BADF-8042
   Part No SW: 1EA 915 684 AF    HW: 1EA 915 684 AD
   Component: HV_CHARGER    H51 0012
   Serial number: 92832TDK00078
   Coding: 1080
   ASAM Dataset: EV_OCCXPhase1KLOMEB01B 002008
   ROD: EV_OCCXPhase1KLOMEB01B_002_VWE3.rod
   VCID: 7F5AF4B31775D4431E9-802A
1061380 - Function Restriction due to
          C1249 F4 [040] - Too Many Wake-Up Requests in Charging Infrastructure
                    Reset counter: 32
                    Mileage: 193 km
                    Date: 2020.09.21
                    Time: 20:30:15
                    DID 1DA0: Standby
                    DID 1DAC: Standby
                    Frequency: 0 Hz
                    Control voltage: 0.0 mV
                    Duty cycle: 0.0 %
                    Activation charge cover lock charge socket A: not requested
                    Locking for H-V charge plug: not locked
                    Status connect. recognition: detected
                    Charge socket temperature sensor AC: 30.0 °C
                    Temperature sensor 1: resistance value: 1063 Ohm
                    DID 15E2: 34.0 °C
                    Sensor 1: 6.7 V
                    Sensor 2: 6.7 V
                    Sensor 3: 10.7 V
                    DID 0286: 13.1 V
                    DID 497C: not active
                    DID 537A: 14.3 V
                    DID 1525: 4683 mV
                    Status of voltage freedom: High voltage power off recognized
                    DID 5372: 36.0 °C
3280899 - Unknown Error Code
          B1AD0 F0 [109] - Unknown Error Elaboration
                    Mileage: 193 km
                    Date: 2020.09.21
                    Time: 16:21:12
                    DID 1DA0: AC main charge
                    DID 1DAC: charge
                    Frequency: 1000 Hz
                    Control voltage: 5678.0 mV
                    Duty cycle: 53.3 %
                    Locking for H-V charge plug: locked
                    Temperature sensor 1: resistance value: 1056 Ohm
                    DID 15E2: 28.0 °C
                    DID 081C: 3539 W
                    DID 081D: 0 W
                    DID 081E: 0 W
                    DID 0286: 13.1 V
                    DID 537A: 14.3 V
                    DID 1525: 1959 mV
                    Status of voltage freedom: High voltage power off not recognized
                    DID 5372: 28.0 °C
                    No. of lockings: 9
                    No. of connections: 0
                    Anzahl der erfolgreichen Ladesteckerverriegelungen: 3
                    Wakeupzähler: Kontakt (Proximity): 1
                    Wakeupzähler: Control Pilot: 2
                    Ladenormabbruch: Status: not active
                    Ladeplan: Status: Not available
                    Preis-/Leistungstabelle: Status: Not available
                    Transport Layer Security (TLS) Status Kommunikation: not active
                    DID 103A: supported
                    number_evse_slac: 0
                    PLC_modem_status: active
                    number_slac_attemps: 1
                    DID 1033: SLAC_failed
                    DID 1038: no_description
                    DID 1039: supported
                    HV charge current: spec. value: 8.8 A
5242881 - Unknown Error Code
          U14FE 00 [096] - -
13705218 - Databus
                    Fault Frequency: 43
                    Reset counter: 35
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:50:02
                    DID 0286: 12.8 V
                    DID 1DA0: Internal malfunction
                    DID 1DAC: Standby
                    Status connect. recognition: not recognized
                    Temperature sensor 1: resistance value: 1058 Ohm
                    DID 15E2: 17.0 °C
                    DID 537A: 14.3 V
                    DID 5372: 17.0 °C
Address D6: Light Ctrl Left 2 (A31)       Labels: None
   Part No SW: 992 941 572 AE    HW: 992 941 572 A
   Component: LED1L         H08 9202
   ROD: EV_LLPGen3LKEBODPO68X_VW27.rod
   VCID: 669441D768EF658BFDF-8032
Address D7: Light Ctrl Right 2 (A27)       Labels: None
   Component: LED1R         H08 9202
Address 8105: DC/DC Converter 12V (A19)       Labels: None
   Part No SW: 1EA 907 190 B    HW: 1EA 907 190 B
   Component: DCDC Gen4H11 1136
   Revision: 00H11000
   ASAM Dataset: EV_DCDC10030111EA907190B 001019
   ROD: EV_DCDC10030111EA907190B_VWE3.rod
   VCID: 3332E8836BBDC023AA1-8066
Address 8107: Antenna (J666)       Labels:* None
   Part No SW: 1EA 035 741 C    HW: 1EA 035 741 C
   Component: TrxModulHigh  H06 0145
   Serial number: 0000000004VIXF4
   Coding: 02310611040200
   ASAM Dataset: EV_TrxMLGEMEB 006014
   ROD: EV_TrxMLGEMEB_006.rod
1375744 - Unknown Error Code
          U14FE 00 [047] - -
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:47:17
                    Failed verification status: valid
                    Number of failed verifications: 12
                    Verification failed: 00 15
Address 811E: Burglary Protection FL (J518)       Labels: None
   Part No SW: 5WA 962 133 D    HW: 5WA 962 133 B
   Component: Kessy RSAD    070 0636
   ASAM Dataset: EV_RSADVL37w 002013
   ROD: EV_RSADVL37w_002_VW38.rod
   VCID: 49CEAA6B1931AAF3F0D-801C
Address 811F: Burglary Protection FR (J518)       Labels: None
   ASAM Dataset: EV_RSADVR37w 002013
   ROD: EV_RSADHL37w_002_VW38.rod
Address 8120: Burglary Protection RL (J518)       Labels: None
   ASAM Dataset: EV_RSADHL37w 002013
Address 8121: Burglary Protection RR (J518)       Labels: None
   ASAM Dataset: EV_RSADHR37w 002013
Address 8123: App server 1 system 1 adaptive (SWC4)       Labels: None
   Part No: V04 007 003 AR
   Component: ICAS1 Sys_Ada 0095
   ASAM Dataset: EV_AppServe1Syste1ICAS1 005001
   ROD: EV_AppServe1Syste1ICAS1_VWE3.rod
   VCID: 77AA1C933F45EC03569-8022
Address 8124: App server 1 system 2 Java (SWC5)       Labels: None
   Part No: V04 007 003 AS
   Component: ICAS1 Sys_Jav 0095
   ASAM Dataset: EV_AppServe1Syste2ICAS1 005001
   ROD: EV_AppServe1Syste2ICAS1.rod
   VCID: 78A81FAF325BE37B5F3-802C
Address 8125: App server 3 system 1 infotaint. (SWC6)       Labels:* None
   Part No: V04 007 001 CK
   Component: IC3-IVI-D-EU  0564
   ASAM Dataset: EV_MUICASIVIPart 002007
   ROD: EV_MUICASIVIPart_002_VWE3.rod
   VCID: 70B8278F5A2BBB3B973-8024
1872 - Unknown Error Code
          B1994 F4 [008] - Unknown Error Elaboration
          [a2b_bus_micro_defect]
                    Reset counter: 37
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 10:58:38
                    Voltage terminal 30: 12.2 V
                    amount_of_nodes: 2
                    Node number: 1
                    Node name: Telematics Communication Unit
                    Node status: OK
End----------(Elapsed Time: 01:39, VBatt start/end: 14.5V/14.5V)-----------
   #22
Stephan
one or two Fault codes on this one... - better not tell the wife :cool:
the good news is less than half the modules have issues :p
Stephan
of course.. i had to figure out how to reboot the center console on the first day ;-)
sorry.. i just had to...:
if this helps in any way...
and of course we all know it's supposed to have DoIP..
Stephan
new ID3 feature request for HEX-NET... configure Auto-Erase cycle time for devices constantly plugged into ID3...
   #26
Stephan
you want controller maps ? anything I need to configure for that? how do I go about that?
   #27
NEtech
Denmark
C?ID=56995
Yes please I have not seen UK car yet.
Just enter "2" in [Debug] and start an Autoscan.
   #28
And make sure you connect a battery charger, 'cause it will take a while.
Oh wait. Just plug the whole car in. :cool:
NEtech
Denmark
C?ID=56995
No need it has 58 kWh battery if it fully charged :)
I have not figured out how it exactly works, but it seems you must stay put in the front seat, else Ignition is removed.
   #30
NEtech
Denmark
C?ID=56995
From your manual picture: "Please regularly check yourself when your vehicle is next due for an inspection".
No need for that, service is every 2 year, no matter of mileage.
   #31
Stephan
yes, I've mentioned this to VW... it is highly frustrating.. as soon as you get out of the seat the console goes off... you'll see it here... :
So it was set to target 80%... got to car, and charging light is off at charge port (as expected).. open the door and charging light turns green again and console tells you that although you are at 81% it would still like to charge a further 5min minutes ;-)
  • Informative
Stephan
Then I have another issue that is more frustrating.. and that is that I put the car on charge (target 80%) and when I get there the next morning it stopped somewhere... last two were at 61% and anther time @ 75%... with an error... Now unfortunately the VW app is useless and has no comms with the car ito charging or SOC or errors etc.. so it relies on you going to check ont he car - so no peaceful sleep if you need to be driving anywhere the next day that might require a good sized SOC ;-)
and
and
Now I'm hop[ing any of you can tell me where the "Vehicle Wallet" is... - should I expect to find British Pounds or Cryptocurrency? :confused:
I've done another AutoScan and the C6 Batt. Chrg. modules still has the same 4 codes... I'm going to erase all codes later today and see whether I can find if any of them pertain to my vehicle wallet :)
Do you guys know what these are:
and
Monday,28,September,2020,11:38:19:35467
VIN: WVWZZZE1ZLP007472   License Plate: LF70OET
Mileage:    Repair Order: charge test
10-Park/Steer Assist -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
6C-Back-up Cam. -- Status: Cannot be reached 0100
A5-Frt Sens. Drv. Assist -- Status: Cannot be reached 0100
8105-DC/DC Converter 12V -- Status: Malfunction 0010
8107-Antenna -- Status: Cannot be reached 0100
                    Reset counter: 33
                    Mileage: 36 km
                    Date: 2020.09.18
                    Time: 08:54:06
                    Coolant temperature: 215 ∞C
                    Intake air temperature: 215 ∞C
                    Unlearning counter according OBD: 33
          B184C 00 [040] - -
                    Reset counter: 34
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:47:11
                    PV: 0.00 %
                    LV_IGK: 00000001
                    TAA: 15.500 ∞C
                    Driving position: P
34298 - Databus
          U1122 00 [096] - Implausible Message
                    Reset counter: 37
                    Mileage: 63 km
                    Date: 2020.09.18
                    Time: 19:19:26
                    Unlearning counter according OBD: 37
                    ECU_STATE: ENG_STOP
          U0416 00 [096] - -
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 13:08:45
                    Voltage terminal 30: 14.140 V
Readiness: N/A
          U1400 00 [040] - -
                    Reset counter: 39
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 13:08:35
                    Outside air temperature: 18.00 ∞C
   Serial number: 06102007100019ˇ
7 Faults Found:
539157 - Databus
                    Fault Frequency: 122
                    Reset counter: 39
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:44
1074806 - Databus
                    Fault Frequency: 44
                    Reset counter: 39
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:57:44
1059588 - Lamp 3 for Contour Lighting of Dashboard
          U1182 00 [044] - No Communications
                    Reset counter: 18
                    Mileage: 287 km
                    Date: 2020.09.25
                    Time: 14:22:39
1061380 - Lamp 1 for Ambient Lighting of Front Center-Console
          U1190 00 [044] - No Communications
                    Reset counter: 23
                    Mileage: 301 km
                    Date: 2020.09.26
                    Time: 21:53:00
15401216 - Unknown Error Code
          U14FE 00 [108] - -
          [Sichere on-board Kommunikation: Signatur¸berpr¸fung fehlgeschlagen]
                    Reset counter: 25
                    Date: 2020.09.27
                    Time: 06:44:33
                    Reset counter: 26
                    Date: 2020.09.27
                    Time: 06:45:38
          B2005 00 [032] - -
          [Invalid Dataset]
          B2F01 00 [032] - -
1078272 - Databus
          U1121 00 [096] - Missing Message
   Coding: 0000
131380 - Databus
                    Reset counter: 35
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 17:50:05
   Coding: E670
                    Reset counter: 26
                    Mileage: 193 km
                    Date: 2020.09.22
                    Time: 07:11:01
16 Faults Found:
          U1642 00 [044] - -
                    Reset counter: 39
                    Date: 2020.09.18
                    Time: 13:28:36
          U1645 00 [044] - -
                    Fault Frequency: 21
                    Date: 2020.09.18
                    Time: 13:28:12
          U1646 00 [047] - -
                    Fault Frequency: 95
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:49:57
                    Fault Frequency: 79
                    Reset counter: 39
                    Mileage: 193 km
                    Date: 2020.09.21
                    Time: 16:29:50
                    Fault Frequency: 82
                    Reset counter: 39
                    Date: 2020.09.18
                    Time: 17:50:00
          U15FA 00 [108] - -
                    Reset counter: 38
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:55:08
          U14FE 00 [108] - -
                    Fault Frequency: 8
                    Reset counter: 39
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 10:04:24
          U173E 00 [036] - -
                    Reset counter: 36
                    Date: 2020.09.19
                    Time: 18:06:25
                    Fault Frequency: 81
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:38
8557314 - Databus
                    Reset counter: 39
                    Mileage: 193 km
                    Date: 2020.09.21
                    Time: 18:32:59
          U1643 00 [109] - -
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:47:30
8515600 - Battery Charger Coupler
          P0E5F 00 [108] - Temperature too High
          [HVLM_ac_temperature_derating]
                    Mileage: 301 km
                    Date: 2020.09.26
                    Time: 14:28:54
          B184C 00 [044] - -
                    Reset counter: 34
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:47:15
8515586 - Databus
                    Fault Frequency: 98
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:38
8515587 - Databus
                    Fault Frequency: 95
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:39
                    Fault Frequency: 231
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:51:38
   Serial number: ˇˇˇˇˇˇˇ
41735 - Databus
          U1123 00 [044] - Received Error Message
                    Fault Frequency: 38
                    Reset counter: 5
                    Mileage: 303 km
                    Date: 2020.09.28
                    Time: 07:33:09
                    Actual_mechanical_torque_calculated: 3189950921 Nm
                    Temperature_IGBT_phase_U: 1099487124 ∞C
                    Temperature_IGBT_phase_V: 1099625095 ∞C
                    Temperature_IGBT_phase_W: 1099694080 ∞C
                    Voltage_Terminal_15: 14.448 V
                    DC_link_voltage: 1138093515 V
                    Actual_possible_maximum_torque: 3189950921 Nm
                    Actual_possible_minimum_torque: 3189950921 Nm
                    Absolut_value_RPM_e_machine: 1001738281 /min
          U3001 00 [040] - -
                    Reset counter: 0
                    Mileage: 39 km
                    Date: 2000.09.18
                    Temperature_IGBT_phase_U: 1103626240 ∞C
                    Temperature_IGBT_phase_V: 1103677641 ∞C
                    Temperature_IGBT_phase_W: 1103677641 ∞C
          C10DD F5 [108] - Unknown Error Elaboration
                    Reset counter: 0
                    Mileage: 117 km
                    Date: 2020.09.20
                    Time: 14:13:23
0053 - Databus
                    Reset counter: 37
                    Mileage: 127 km
                    Date: 2020.09.21
                    Time: 07:10:43
12866049 - Databus
          U1123 00 [104] - Received Error Message
                    Reset counter: 37
                    Mileage: 127 km
                    Date: 2020.09.21
                    Time: 07:10:44
   Coding: 1080
          C1249 F4 [032] - Too Many Wake-Up Requests in Charging Infrastructure
                    Mileage: 193 km
                    Date: 2020.09.21
                    Time: 16:21:12
                    DID 1DAC: charge
                    Frequency: 1000 Hz
                    Duty cycle: 53.3 %
                    Charge socket temperature sensor AC: 30.0 ∞C
                    DID 15E2: 28.0 ∞C
                    DID 081C: 3539 W
                    DID 081D: 0 W
                    DID 081E: 0 W
                    DID 0286: 13.1 V
                    DID 537A: 14.3 V
                    DID 1525: 1959 mV
                    DID 5372: 28.0 ∞C
                    No. of lockings: 9
                    Wakeupz‰hler: Kontakt (Proximity): 1
                    Wakeupz‰hler: Control Pilot: 2
                    DID 103A: supported
                    number_evse_slac: 0
                    DID 1039: supported
          U14FE 00 [096] - -
13705218 - Databus
                    Fault Frequency: 71
                    Reset counter: 36
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:50:02
                    DID 0286: 12.8 V
                    DID 1DAC: Standby
                    DID 15E2: 17.0 ∞C
                    DID 537A: 14.3 V
                    DID 5372: 17.0 ∞C
   Revision: 00H11000
0372 - Implausible Data Received from Engine Control Module
          U0401 00 [172] - -
                    Mileage: 306 km
                    Date: 2020.09.28
                    Time: 07:37:58
                    DC/DC converter: traction network voltage: 4.25 V
                    DC/DC converter: regulated output current term 30: 12.855 V
                    DC/DC converter: voltage 1 active rectifier: 9.080 V
                    DC/DC converter: voltage 2 active rectifier: 9.117 V
                    DC/DC converter: transformer current 1: 0.000 A
                    DC/DC converter: transformer current 2: 0.000 A
                    DCDC temperature sensor 1: 16.91 ∞C
                    DCDC temperature sensor 2: 19.36 ∞C
                    DC/DC converter: operating mode output path 1: rbe_CmnGlb_DcdcMod_Stb_e
                    DC/DC converter: operating mode output path 1-Test_Program_Rbe Asw Dcdc Sym Enum rbe Cmn Glb St Dcdc Mod UBYTE: 1
          U14FE 00 [109] - -
                    Mileage: 35 km
                    Date: 2020.09.18
                    Time: 07:47:17
                    Reset counter: 36
                    Mileage: 39 km
                    Date: 2020.09.18
                    Time: 10:58:38
                    amount_of_nodes: 2
                    Node number: 1
                    Node status: OK
End----(Elapsed Time: 01:28, VBatt start/end: 14.7V/14.7V. VIgn 0.0V)------
   #34
Stephan
"Vehicle Wallet" = Owners Manual in VAG speak :mad:
Ahhhh - WOW.... OK, so no crypto then... :p
Would be nice to search the PDF... but VW seems to have some issues there too.. when you try and download the User manual for this VIN... all you get is:
   #35
Andy
Sector 7G
HC424490
and
Not sure but:
B1AD0 Charging station: Detection faulty
U14FE Secure Onboard Communication: Signature inspection failed
IIRC, some guys on the A3 e-tron forum had weird problems with extension cords and ground loops and whatnot. Can you try charging from a different outlet?
Stephan
@Uwe @Eric, FYI pls see the difference in the two Autoscans... the latest one has "Cannot be reached" for 9 control modules that it did talk to in the first Autoscan
I'll list them for easy ref:
05
10
13
6C
A5
811E
811F
8120
8121
   #37
Stephan
Not sure but:
nope, this is my Type2 fixed with integrated cable... it is wired directly into the main DB...
  • Informative
NEtech
Denmark
C?ID=56995
You lifted your a.. I guess :)
If speed does not show 0, there is no ignition.
That is what I have done often, I am interested to see, if odis maybe does some keep alive stuff.
I was told, you should activate ignition before sitting in the driver seat. Have not tested that yet.
  • Informative
NEtech
Denmark
C?ID=56995
On all I have tested, there are 1 to the same 4 DTC's in [6C], standard software state currently :)
  • Informative
