Rediness on 2008 Audi A4 Cabriolet VCDS
audi_mine
Charlotte, NC, USA
Hello, I am new here I need to get my car ready for inspection test in NC. I am trying to use the VCDS software to get my car ready. I am running some groups based on what I have found online on the Basic Settings section of the software. I do group 30, 37, 41, 43, 70, 71, but I am having issues on groups 34 and 46. I can never run the tests on these groups. On group 34 when I click the "ON/OFF/Next' button and press the break and try to throttle nothing happens. Something similar happens when I try to run test on group 46 but the difference is that I press the break pedal and throttle up to ~2000 rpm with the the pedal all the way down but nothing happens.
I would appreciate all the help I can get.
Thank you,
Please post an Auto-Scan for context, so people can see exactly what ECU and TCU this car has.
audi_mine
Charlotte, NC, USA
Uwe,
Thanks for the quick response here is the Auto-Scan I run this morning:
VCDS Version: Release 14.10.0 (x64)
Data version: 20141022
Thursday,10,September,2020,07:46:21:53046
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WAUDF48H68K014533   Mileage: 221840km-137844miles
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 8E1 910 115 G    HW: 8E0 907 115 D
   Revision: 5EH15---    Serial number:
   Coding: 011C010A190F0120
   Shop #: WSC 00672 785 00200
   VCID: 2645805F91283B11357-8073
005495 - Right Engine Mount Solenoid Valve (N145)
               P1577 - 004 - Open Circuit
                    Mileage: 221815 km
                    RPM: 810 /min
                    Load: 20.8 %
                    Temperature: 80.0°C
                    Temperature: 42.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.716 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -
                    Mileage: 221816 km
                    RPM: 856 /min
                    Load: 35.7 %
                    Speed: 6.0 km/h
                    Temperature: 77.0°C
                    Temperature: 35.0°C
                    Voltage: 13.716 V
008577 - Performance Malfunction in Cooling System
               P2181 - 008 -
                    Fault Status: 01101000
                    Mileage: 221830 km
                    RPM: 2512 /min
                    Load: 52.1 %
                    Speed: 116.0 km/h
                    Temperature: 72.0°C
                    Temperature: 26.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.970 V
Readiness: 0000 0001
   Part No SW: 8E1 910 156 K    HW: 09L 927 156 B
   Component: AG6 09L 2,0TFSI USA 0080
   Revision: --H01---    Serial number:        4433606
   Coding: 0000002
   VCID: 2F6B657BBED27A59C61-807A
   Part No SW: 8E0 910 517 J    HW: 8E0 614 517 BH
   Component: ESP8 quattro    H06 0140
   Coding: 0004528
   VCID: 2E55787FB9D87351CD7-807B
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   3233
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6DD7BF73275EC849B4D-5072
01272 - Positioning Motor for Central Flap (V70)
            41-00 - Blocked or No Voltage
00716 - Air recirculation Flap Positioning Motor (V113)
   Part No: 8E0 907 279 N
   Component: int. Lastmodul  USA 0907
   Coding: 21023
   VCID: 3D774F3337BE98C944D-4A9C
01498 - Bulb for Parking Lamps; Right (M3)
            30-00 - Open or Short to Plus
02397 - Parking Light Rear Right (M2)
Address 15: Airbags        Labels: 8H0-959-655-94.lbl
   Part No SW: 8H0 959 655 H    HW: 8H0 959 655 H
   Component:    Airbag 9.42  H01 1830
   Revision: 92H01183    Serial number: 003D00004YV%
   Coding: 0132105
   VCID: 3F8B353B6EB28AD9561-806A
   Subsystem 1 - Part No: 8H0 910 339 B
   Component: BF-Gewichtsens. H02 0020
   Subsystem 2 - Serial number: 027PY
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†6332BRB403847AAAXÿ†63
   Subsystem 5 - Serial number: 47AAAXÿ†6342BRB403847ACF+ÿ†63
   Subsystem 6 - Serial number: 47ACF+ÿ†63729RB403A5BC44Wÿ†63
   Subsystem 7 - Serial number: 5BC44Wÿ†63829RB403A5BC70Wÿ
   Subsystem 8 - Serial number: 5BC70Wÿ
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0801
   Coding: 03041
   Shop #: WSC 00672
   VCID: 418F33C34B46FC29205-4A3A
            49-00 - No Communications
   Part No SW: 8H0 920 982 B    HW: 8H0 920 982 B
   Component: KOMBI+WFS 4     H10 0200
   Revision: 0200        Serial number: 00000000000000
   Coding: 0007261
   Shop #: WSC 08316 444 12140
   VCID: 30696607A0EC65A1DFB-50E6
   Coding: 0007261
   VCID: 30696607A0EC65A1DFB-5000
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255 B
   Component:  VSG  B6 CABRIO     7195
   VCID: 356757135F8E40898CD-5000
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8H0 959 433 L
   Component: Komfortgerát T7B    5442
   Coding: 11820
   Shop #: WSC 00672
   VCID: 3D774F3337BE98C944D-4A3A
   Subsystem 1 - Part No: 8H1959801D
   Component: Tõrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8H1959802D
   Component: Tõrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0003
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0003
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 -  -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -  -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 -  -
00935 - Electric Window Motor; Rear Right (V27)
            62-10 - No or Incorrect Adjustment - Intermittent
   Part No SW: 4L0 910 357     HW: 4L0 907 357
   Component: AFS 1           H01 0040
   Coding: 0000019
   VCID: 69DFCB6340B6D469D85-803C
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH05 0030
End-------------------------(Elapsed Time: 07:27)--------------------------
So let's start with the fact that you've got fault codes. The 'Engine Mount Solenoid fault' might not affect your ability to set Readiness, but the 'too Lean at Idle' and 'Performance Malfunction in Cooling System' faults almost certainly will.
FWIW, that ECU should support the Automatic Test Sequence in Basic Settings Group 200, where it will run through all the tests one at a time without you having to find them individually.
audi_mine
Charlotte, NC, USA
Last year I got all the readiness test with the motor mount code and the cooling system malfunction code and a little bit of luck (Driving around). Any ideas of how I can run the tests on group 34 and 36? From info online some people say that test will start once I press break pedal, others say I should have my RPMs on 2400 for 55 secs, idle, 2400 RPMs for 45 seconds. Other forums say I should press break pedal and fully press on gas pedal to start test. I’m just confused how to start the tests in my vehicle.
