Retrofit easy close on Passat b8 estate 2015
sam1754
France
C?ID=324989
Hello, I started a new retrofit but before going further, I'm asking which coding job I have to do. I already have electric lid and easy open feature.
I changed rear lid's button(E406) and plug (T8ct). I prepared wires and pins to plug it as per factory from lid's button to lid's control module (J605), through lid's coupling point (THK).
Pin T8ct/5 -> T10e/1-T10x/1 -> T32e/13
Pin T8ct/7 -> T10e/5-T10x/5 -> T32e/19
+ T8ct/6 to rear lid's earth coupling point 219
I'm asking myself if it's just a J605 coding issue or more???
I need an adamap-coding from a vehicule with this feature?
OEMplusCC
C?ID=160054
I was about to respond to you original question until I noticed that you already found my DYI :). Tiguan MQB and Passat B8 MQB are pretty much identical
Make sure you find a used module so you dont have to parameterize it. VCDS is not able parameterize new modules
Side Note:
Ross Tech team, I would gladly pay extra for VCDS if it was able to read/write modules entire eeproms . But I am sure there is some legal reason preventing you from doing that
