Bleeding brakes with vcds
vw754
C?ID=52227
Hi, wanted to bleed brakes on a q5 and as i only own vw audi vehicles, i thought its good to know if its possible.
I did Google and found going in 03 abs, selecting basic settings and group 001 but that just gives me error... Is it possible or is it just older stuff that can be done, before i spend money and buy a pressure bleeding kit, if vcds does it, be good. I have the unlimited vins vcds
langers2k
C?ID=224085
VCDS can be used to help purge air/old fluid inside the ABS unit.
You'll still need to use traditional methods or a pressure bleeder to bleed the brake system though...
vw754
C?ID=52227
Thanks.
