Hi guys, had an issue with the slip ring, buttons on steering wheel weren't working and air bag light on, so fitted new slip ring. Now can't set esp. I've coded (16) to orignal code. Any help appreciated
Monday,07,September,2020,09:40:21:24344
VCDS Version: 20.4.2.0 HEX-NET CB: 0.4513.4
VIN: WVWZZZ3CZCP002191 License Plate: EDDIE
Mileage: 157660km-97965mi Repair Order:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 37 42 44 46 4F 52 53 56 61
62 65 72
VIN: WVWZZZ3CZCP002191 Mileage: 157660km-97965miles
65-Tire Pressure -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAYC) Labels:. 03L-906-023-CAY.clb
Part No SW: 03L 906 023 FS HW: 03L 907 425 C
Component: 1,6l R4 CR td H43 9196
Revision: --H43--- Serial number: VWZCZ000000000
Coding: 00194036032501080000
Shop #: WSC 00028 028 00038
ASAM Dataset: EV_ECM16TDI02103L906023FS 003006
ROD: EV_ECM16TDI02103L906023FS_003.rod
VCID: FCB47A5277B4FF66CF-80A8
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AB HW: 3AA 614 109 AB
Component: J104 C2 450M V404 0022
Revision: --H07--- Serial number: 00000004315165
Coding: 0002983
Shop #: WSC 00028 028 00001
VCID: ED924716F4CE66EE48-80B8
Part No SW: 5K0 907 044 DT HW: 5K0 907 044 DT
Component: Climatronic H17 1010
Revision: 00001003
Coding: 0000000003
Shop #: WSC 00028 028 00021
VCID: 804C0EA21B5C9B8693-80D4
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 D HW: 3AA 937 087 D
Component: BCM PQ47 H 413 0455
Revision: BB413001
Coding: 000000000000000000180080140081E443516488406C81606480C7200041
VCID: BB36B94E3A3A385E86-80EE
Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 16051 26 0612
Coding: 00B795
Component: RLS 040611 05 54 0403
Coding: 0230ED
Fault Status: 00101010
Fault Frequency: 9
Reset counter: 37
Mileage: 156228 km
Date: 2015.01.05
Time: 19:05:47
Voltage: 14.45 V
Address 10: Park/Steer Assist (J446) Labels:| 3AE-919-475.clb
Part No SW: 3AE 919 475 HW: 7N0 919 475
Component: PARKHILFE 8K H04 0009
Revision: -------- Serial number: 77631115104731
Coding: 108001
ASAM Dataset: EV_EPHVA18VW47X0000 001003
ROD: EV_EPHVA18VW47X0000.rod
Part No SW: 5N0 959 655 R HW: 5N0 959 655 R
Component: J234__102 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PAQ48U/
Coding: 0012338
VCID: CCD4EA92AF948FE63F-8098
Subsystem 1 - Serial number: 6332MTS625111371
Subsystem 2 - Serial number: 6342MTS617171361
Subsystem 3 - Serial number: 6351HTS674VI5AKJ
Subsystem 4 - Serial number: 6361HTS6A1RI5AKJ
Fault Status: 11100001
Mileage: 153644 km
Date: 2014.08.05
Time: 16:40:47
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Component: LENKS.MODUL 014 0140
Revision: FF010040 Serial number: 20110529100339
Coding: 0182250000
VCID: F2A8546A25F0B91695-80A6
365080 - Controls in Steering Wheel
U108E 00 [009] - No Communications
Reset counter: 75
Mileage: 153644 km
Date: 2020.03.14
Time: 16:40:45
Part No SW: 3AA 920 970 E HW: 3AA 920 970 E
Component: KOMBI H03 0607
Coding: 460F00
VCID: B522AF76141EEE2E70-80E0
12658432 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
[Steuergerät für Reifendrucküberwachung: keine Kommunikation]
Fault Frequency: 9
Reset counter: 48
Mileage: 140746 km
Date: 2018.11.08
Time: 12:59:42
Part No SW: 7N0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H41 1620
Revision: H41 Serial number: 230511F1001862
Coding: 461007
VCID: B93AA34630060A4E94-80EC
Fault Frequency: 9
Reset counter: 48
Mileage: 140746 km
Date: 2013.03.31
Time: 12:59:42
02001 - Data-Bus Automatic Distance Regulation
Reset counter: 4
Mileage: 140725 km
Date: 2013.03.30
Time: 10:36:11
Part No SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0400
Revision: 00043000 Serial number: VWZCZ000000000
VCID: F6A0687A8198A536B9-80A2
Component: ELV 029 0380
3C0905861J ELV 029 0380
Part No SW: 5N0 035 342 E HW: 5N0 035 342 E
Revision: A1001003 Serial number: 7660103140
Coding: 020000
VCID: A91A7306C0A6BACEE4-80FC
Part No SW: 3C0 035 279 B HW: 3C0 035 279 B
Component: RNS315-EU H32 0263
Serial number: VWZAZ2L3357164
Coding: 040004010400100000019002
ASAM Dataset: EV_RNS315EUV2UDS A01004
ROD: EV_RNS315EUV2UDS.rod
VCID: A208642AB5906996A5-80F6
Component: EUR_W_0031 0031
1048598 - Front Right Treble Speaker
B1064 13 [009] - Open Circuit
[tweeter front right open load]
Reset counter: 211
Mileage: 139081 km
Date: 2018.08.04
Time: 11:23:53
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0002958579
Coding: 0212B7
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 704 HW: 3C0 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0408
Serial number: 00000002208139
Coding: 000290
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 195 3201
Revision: 00H20000
VCID: B4249272D764F72647-80E0
Component: KSG PQ47 ELV 043 0634
Coding: 01910A0002860E76300494157C085FCE105C01
Subsystem 1 - Component: Sounder No Answer
Component: Neigungssensor 004 0611
Reset counter: 86
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H41 1620
Coding: 00000008
VCID: EFAE5D1E3EC294FE7A-80BA
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0003
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0002955189
Coding: 0212B6
VCID: B620A87A0918E53679-80E2
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 703 HW: 3C0 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0408
Serial number: 00000002202932
Coding: 000290
66561 - Motor for mirror fold-in
B11F6 01 [009] - Electrical Failure
Reset counter: 215
Mileage: 139152 km
Date: 2018.08.09
Time: 11:37:35
Part No SW: 3AA 907 801 G HW: 3AA 907 801 G
Component: J540 EPB4 VW-64783 0009
Revision: H19 Serial number: 00000000031883
Coding: 0022167
VCID: B522AF76DC1EEE2E70-80E0
Part No SW: 7N0 907 534 HW: 1K0 907 951
Component: Batt.regelung H41 1620
Coding: 030B185A
VCID: F1AA5B6628F6820E6C-80A4
Component: J367-BDM H07 0180
Serial number: 00000000008900625782
Address 65: Tire Pressure
End----------(Elapsed Time: 02:19, VBatt start/end: 14.7V/14.7V)-----------
Monday,07,September,2020,14:38:54:24344
VIN: WVWZZZ3CZCP002191 License Plate: EDDIE 3
62 65 72
6632 - Check Coding of ECUs on Powertrain Data Bus
P1647 00 [100] - -
Mileage: 157540 km
Date: 2020.09.07
Time: 12:11:17
Engine speed: 815.00 /min
Normed load value: 30.6 %
Coolant temperature: 29 °C
Intake air temperature: 18 °C
Voltage terminal 30: 11.520 V
Coding in the engine control module-FRF_VARCOD: 1
Number of resets of main unit-CTR_RST_MC: 0
ACC target acceleration-AC_SP_CRU_EXT: -0.0000 m/s²
Acceleration-AC_VEH_CLC: -0.0000 m/s²
Status of ACC/CCS acceleration interface-STATE_CRU_AC: 3
Cruise Control System (CCS): status-Binary 8 Bit: 10000000
6116 - Function Restriction due to Faults in Other Modules
U1113 00 [047] - -
Fault Frequency: 9
Mileage: 157540 km
Date: 2020.09.07
Time: 12:11:16
Engine speed: 788.00 /min
Normed load value: 39.6 %
Accelerator position: normalized-Accelerator position: 0.00 %
Cruise Control System (CCS): switch position-STATE_CRU_SWI_POS: 00000010
Coding: 0002983
Fault Status: 01101000
Reset counter: 4
Mileage: 157665 km
Date: 2015.01.29
Time: 13:18:39
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 13.25 V
Bin. Bits: 00011110
Count: 248
Hex Value: 0x0002
Reset counter: 4
Mileage: 157665 km
Date: 2015.01.29
Time: 13:18:39
Hex Value: 0x0000
Voltage: 13.25 V
Bin. Bits: 00011110
Count: 248
Hex Value: 0x0002
Revision: 00001003
Coding: 0000000003
Revision: BB413001
Coding: 00B795
Coding: 0230ED
Fault Frequency: 9
Reset counter: 37
Mileage: 156228 km
Date: 2015.01.05
Time: 19:05:47
Voltage: 14.45 V
Coding: 108001
Coding: 0012338
Part No SW: 5K0 953 569 AS HW: 5K0 953 569 AS
Component: LENKS.MODUL 016 0180
Revision: --X01--- Serial number: 20200327200453
Coding: 0182250000
Shop #: WSC 01286 386 08256
VCID: 895A13862866DACEC4-80DC
Component: E221__MFL-TK6 H06 0022
Serial number: 70000000000000254329
Coding: E20000
229127 - Cruise Control Switch
B1154 11 [009] - Short to Ground
Reset counter: 4
Mileage: 157665 km
Date: 2020.09.07
Time: 13:05:18
1140738 - Steering angle sensor
Reset counter: 4
Mileage: 157665 km
Date: 2020.09.07
Time: 13:05:18
UBat: 13.10 V
MC1 interner Fehlercode: 0
MC2 interner Fehlercode: 0
Coding: 460F00
U1111 00 [009] - -
Reset counter: 4
Mileage: 157667 km
Date: 2020.09.07
Time: 13:34:16
Coding: 461007
Reset counter: 4
Mileage: 157667 km
Date: 2015.01.29
Time: 13:34:21
Reset counter: 4
Mileage: 157667 km
Date: 2015.01.29
Time: 13:34:17
Coding: 020000
B1064 13 [008] - Open Circuit
Reset counter: 44
Mileage: 139081 km
Date: 2018.08.04
Time: 11:23:53
Coding: 0212B7
Slave Driver:
Coding: 000290
Revision: 00H20000
Reset counter: 86
Coding: 00000008
Coding: 0212B6
Slave Passenger:
Coding: 000290
Reset counter: 215
Mileage: 139152 km
Date: 2018.08.09
Time: 11:37:35
Coding: 0022167
Coding: 030B185A
End----(Elapsed Time: 02:19, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
Hi guys, had an issue with the slip ring, buttons on steering wheel weren't working and air bag light on, so fitted new slip ring. Now can't set esp. I've coded (16) to orignal code. Any help appreciated 1st logged file was taken before i replaced slip ring 2nd after i replaced
Would you mind posting a fresh scan so people can see what the coding is now?Update on this. Because of the forward superseded part number the coding had to be changed via dealer.
