Today I began looking at a 2015 Crafter. I am not too familiar with these and it seems to have NOX faults. The coolant pump fault is the pump itself.
Both the NOX sensor and heating module have power and ground connections. If anyone has any suggestions they would be greatly appreciated and give me something to work off.
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
VIN: WV1ZZZ2EZF6039394
Address 01: Engine (J623-CSNA) Labels:. 03L-906-022-CAA.clb
Part No SW: 03L 906 021 C HW: 03L 906 021
Component: R4 2,0L EDC H20 7424
Revision: 89H20--- Serial number: VWXDZ0O1010918
Coding: 0119401020440C080000
Shop #: WSC 00000 555 00117
ASAM Dataset: EV_ECM20BTD01103L906021C 001008
ROD: EV_ECM20BTD01103L906021C.rod
VCID: 241015730E55B3AB16B-8070
9654 - Output Module 1 for Heating of Reductant
P148B 00 [039] - Malfunction
Mileage: 27144 km
Date: 2047.15.31
Time: 31:63:63
Engine speed: 0.00 /min
Coolant temperature: 71 °C
Intake air temperature: 34 °C
Voltage terminal 30: 12.220 V
Outside air temperature: 17.5 °C
Exh.gas temp.sen 4: 139.1 °C
Sensor for reducing agent tank temperature: temperature: 17.0 °C
Heat circuit 2 for reduc. agent meter. system: act. voltage: 171.0 mV
Heat circuit 1 for reduc. agent meter. system: act. voltage: 73.2 mV
Reducing agent fill level sensor: act. value: 233.3 mm
Reducing agent system and actuator: condition-Bits 0-7: 24
Reducing agent system and actuator: condition-Bits 0-7: 1
4875 - Coolant Pump 2
P261A 00 [167] - Open circuit
Mileage: 27156 km
Date: 2047.15.31
Time: 31:63:63
Coolant temperature: 19 °C
Intake air temperature: 21 °C
Voltage terminal 30: 11.740 V
Coolant temperature at radiator outlet: actual value: 19.9 °C
Bypass valve for EGR cooler: status-Bits 0-7: 0
exh.gas recirc.: shut-off conditions-Bits 0-7: 0
EGR cooling function: status-Bits 0-7: 4
exh.gas recirc. (EGR) cooler pump: specified value: 80.00 %
Temp sensor for EGR after cooler: raw value: 18.8 °C
Exh.gas temp.sen 1: 23.0 °C
9583 - NOx Sensor 1 Bank 1
P2200 00 [101] - Electrical Malfunction
Mileage: 27148 km
Date: 2047.15.31
Time: 31:63:63
Engine speed: 1892.50 /min
Normed load value: 67.1 %
Vehicle speed: 10 km/h
Coolant temperature: 82 °C
Intake air temperature: 25 °C
Voltage terminal 30: 14.180 V
Engine status: COENG_RUNNING
9879 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
P2209 00 [101] - Implausible Signal
Mileage: 27154 km
Date: 2047.15.31
Time: 31:63:63
Engine speed: 2123.50 /min
Normed load value: 56.5 %
Vehicle speed: 62 km/h
Coolant temperature: 85 °C
NOx sensor 2: NOx concentration: 9 ppm
NOx sensor 1: NOx concentration: -100 ppm
Target value of heating temperature of NOx sensor 2-Bits 0-7: 1
NOx sensor 2: feed voltage: 13600 mV
NOx sensor 1: feed voltage: 13760 mV
Mean injection quantity: 17.72 mg/stroke
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 843 C HW: 906 900 590 2
Component: IMMO 1231 1322
Revision: 00231000 Serial number: VWXDZ0O1010918
VCID: 270A027F73E358B3339-8072
01176 - Key
Address 94: LT3 Airbag
Part No HW: 9069005701
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55F678B7158F1A23515-8000
9003 - Supply voltage: Lower limit not reached
Test Complete - Stored
Address 96: LT3 Instruments
Part No SW: 9069026601 HW: 9069014901
ASAM Dataset: 32 1056
ROD: CRFT_KOMBI_32_1056.rod
VCID: 074A62FF9FA378B3139-8052
9128 - Voltage: Lower limit not reached
Address 99: LT3 Ign. Switch
Part No HW: 9069005902
ASAM Dataset: 67 259
ROD: CRFT_EZS_67_259.rod
9001 - Voltage: Lower limit not reached
Address 9A: LT3 Central Locks Labels: 2E0-905-865-9A.clb
Component: HF-FFB 1231 1322
Revision: 00231000 Serial number: 12345678901234
Address 9B: LT3 Driver Door
Part No HW: 9069000501
ASAM Dataset: 33 263
ROD: CRFT_FTUHR_33_263.rod
9021 - Voltage: Lower limit not reached
Address B4: LT3 Central Elec.
Part No SW: 9069024301 HW: 9069017501
ASAM Dataset: 33 852
ROD: CRFT_EZE_33_851.rod (*)
VCID: 025C73EBB4815D9B447-8056
9093 - Voltage: Lower limit not reached
90D5 - Center Instrument Panel Control Head (J819): No communication
905E - Right Swinging Door Rear Window Wiper Motor (V93) relay coil: Short to GND
Test Complete - Active/Stored
905B - Left Swinging Door Rear Window Wiper Motor (V92) relay coil: Short to GND
90C2 - Emergency light activated; for rotary light switch evaluation: voltage not correct
Address B6: LT3 Steering Wheel
Part No SW: 9065402645 HW: 9065402645
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 094E64C789B70EC305D-805C
End----(Elapsed Time: 01:23, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
