Crafter aux coolant pump
rsjon
West Kirby, UK
C?ID=374985
Hi, I'm Jon and I have a problem with a Crafter I could do with help with.
MIL came on with code P261A, aux coolant pump open circuit. I did some basic checks which seemed ok and then replaced the pump. Unfortunately the fault code persists and I am having trouble sorting it out. I have now checked the relay, relay supplies, pump supply and earth and continuity to everything except the ECU. I ran the VCDS output test to run the pump and it all works perfectly. I suspect there may be nothing wrong but the ECU is unhappy with the new pump (genuine part). My question is....is there anything on VCDS to reset the ECU when a new pump is installed or something similar? I have not found anything yet.
Many thanks,
Jon.
Bruce
Near Philadelphia, PA, USA
Hi Jon and welcome to the forum. It would help us immensely if you would post a complete autoscan. With that information, people will be able to look up information on your Crafter and suggest help.
How to post an Auto-Scan
rsjon
West Kirby, UK
C?ID=374985
Wednesday,09,September,2020,16:52:17:32475
VCDS Version: 19.6.2.0  HEX-V2 CB: 0.4508.4
VIN: WV1ZZZ2EZE6026492   License Plate:
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTC)       Labels:. 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 C    HW: 03L 906 012 A
   Component: R4 2.0l TDI   H26 9977
   Revision: 72H26---    Serial number: VWXDZ0N1003646
   Coding: 0119401020440C080000
   ASAM Dataset: EV_ECM20TDI01103L906012C 002018
   ROD: EV_ECM20TDI01103L906012A_002.rod
   VCID: 2411ECC1DE5C12978DF-8070
4875 - Coolant Pump 2
          P261A 00 [167] - Open circuit
                    Mileage: 40198 km
                    Date: 2047.15.31
                    Time: 31:63:63
                    Engine speed: 887.00 /min
                    Normed load value: 34.9 %
                    Coolant temperature: 32 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 14.460 V
                    Coolant temperature at radiator outlet: actual value: 22.2 °C
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 0
                    exh.gas recirc.: shut-off conditions-Bits 0-7: 37
                    EGR cooling function: status-Bits 0-7: 0
                    exh.gas recirc. (EGR) cooler pump: specified value: 95.00 %
                    EGR Vacuum Regulator Solen.val.: activation: 44.14 %
                    Exh.gas temp.sen 1: 106.9 °C
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 C    HW: 906 900 590 2
   Component: IMMO          1231  1322
   Revision: 00231000    Serial number: VWXDZ0N1003646
   Shop #: WSC 00527 210 86028
   VCID: 270BFBCDA3EAF98FA8D-8072
Address 94: LT3 Airbag
   Part No HW: 9069005701
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F78105C586BB1FCA1-8000
Address 96: LT3 Instruments
   Part No SW: 9069025601    HW: 9069010401
   ASAM Dataset: 32 1048
   ROD: CRFT_KOMBI_32_1048.rod
   VCID: 0655964948A0C087F3B-8052
Address 99: LT3 Ign. Switch
   Part No HW: 9069005902
   ASAM Dataset: 67 259
   ROD: CRFT_EZS_67_259.rod
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-93.clb
   Component: HF-FFB        1231  1322
   Revision: 00231000    Serial number: 12345678901234
Address 9B: LT3 Driver Door
   Part No HW: 9069000501
   ASAM Dataset: 33 263
   ROD: CRFT_FTUHR_33_263.rod
Address B4: LT3 Central Elec.
   Part No SW: 9069024301    HW: 9069014500
   ASAM Dataset: 33 852
   ROD: CRFT_EZE_33_851.rod (*)
   VCID: 025D8A596488FCA7DF3-8056
Address B6: LT3 Steering Wheel
   Part No SW: 9065402545    HW: 9065402545
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 0849987142B4D6F7817-805C
End----------(Elapsed Time: 01:19, VBatt start/end: 12.1V/12.1V)-----------
rsjon
West Kirby, UK
C?ID=374985
Thank you for your welcome.
I have posted the auto scan but the only fault code is the one I mentioned in my first post/
Jon.
I can't really imagine the ECU being unhappy with the new pump (you said it's genuine) unless the new pump is defective. Double check (including load-testing) all wiring and connections between the ECU and the pump, and any other wiring relevant to the pump.
rsjon
West Kirby, UK
C?ID=374985
Have double tested all wires and connections and all seems well.
As the pump works perfectly off VCDS I am wondering if there is something wrong with the monitoring of the pump.
Problem is I can't see how the ECU does that. I would guess that it monitors current draw from which it can work out a resistance, but I can't see anything on the circuit diagrams.
Jon.
Shade
South Africa
C?ID=291138
Hello Jon,
I'm sorry that I saw this late. I think I may know what is wrong with your vehicle, however could I please ask you the following
What happened before you got the code?
Do you get a light that looks like an orange radiator?
Did you touch any component in the cooling system?
rsjon
West Kirby, UK
C?ID=374985
This is a customer's car so do not have a full history.
No radiator symbol has illuminated and no work has been done to the cooling system.
The air intake temperature sensor was replaced not long before the problem started.
Jon.
Shade
South Africa
C?ID=291138
There are two pumps on the vehicle, a V51 pump, which is near the firewall, with two wires (brown and grey). Another pump, V400 is amounted next to the radiator and has three wires for the egr cooler. When you do the activation via VCDS, you will activate V400. I believe the code relates to V400, it will activate via the scan tool and later give you a code. The other pump you cannot activate via VCDS.
rsjon
West Kirby, UK
C?ID=374985
Thank you very much for this information. There are indeed two pumps and I think that V400 is the faulty one (or associated wiring etc).
However I am 100% sure that VCDS activates pump V50 (or at least mine does!).
Next step to check out V400 and associated parts. I will report back.
Jon.
rsjon
West Kirby, UK
C?ID=374985
V400 was the problem. Replaced it and problems all gone.
Many thanks for your help.
Jon.
