Change Odo from Miles to KM
Souriau
Newry, NI, UK
C?ID=86928
How can I change the odometer from Miles to KM?
Tuesday,08,September,2020,15:12:47:46973
VCDS Version: 20.4.2.0  HEX-NET CB: 0.4513.4
Workshop Code: 000 18261 018261
VIN: WVWZZZ1KZAP090444   License Plate:
Chassis Type: 1K-VW36 (1K0)
VIN: WVWZZZ1KZAP090444   Mileage: 225450km-140088miles
   Part No SW: 03L 906 023 B    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 5863
   Revision: --------    Serial number: 00000000000000
   Coding: 00114014030500080000
   Shop #: WSC 00028 028 00025
   ASAM Dataset: EV_ECM16TDI02103L906023B 001005
   ROD: EV_ECM16TDI02103L906023A_001.rod
   VCID: A502B8C9A456FBAEC0-80F0
10116 - Fuel Rail/System Pressure
          P0087 00 [096] - Too Low
                    Fault Frequency: 8
                    Mileage: 225438 km
                    Date: 2020.09.08
                    Time: 19:08:00
                    Engine speed: 2195.50 /min
                    Normed load value: 88.2 %
                    Vehicle speed: 19 km/h
                    Coolant temperature: 82 °C
                    Intake air temperature: 29 °C
                    Voltage terminal 30: 14.231 V
                    Environmental conditions-PFU_ENVD: 6.3 MPa
                    Environmental conditions-LV_PCV_CTL: 00000000
                    Environmental conditions-FTL_CAN: 18 l
                    Environmental conditions-TFU_MES: 27 °C
                    Environmental conditions-VCV_ENVD: 45.882 %
                    Environmental conditions-PCV_ENVD: 35.686 %
                    Environmental conditions-PFU_SP_ENVD: 120.782 MPa
7478 - Fuel Metering Valve 1 Control Difference
          P228C 00 [096] - Pressure too Low
                    Mileage: 225438 km
                    Date: 2020.09.08
                    Time: 19:08:05
                    Engine speed: 1719.75 /min
                    Normed load value: 41.2 %
                    Vehicle speed: 13 km/h
                    Intake air temperature: 28 °C
                    Environmental conditions-PFU_ENVD: 96.5 MPa
                    Environmental conditions-TFU_MES: 34 °C
                    Environmental conditions-VCV_ENVD: 38.431 %
                    Environmental conditions-PCV_ENVD: 28.235 %
                    Environmental conditions-PFU_SP_ENVD: 100.391 MPa
Readiness: 1000 0000
   Part No SW: 1K0 907 379 AH    HW: 1K0 907 379 AH
   Component: ESP MK60EC1   H30 0107
   Revision: 00H30001
   Coding: 133B200D092B00FAC80F04E8901D0080300000
   Shop #: WSC 00028 028 00001
   VCID: F8BCA1BD4B64B646AB-80AC
                    Fault Frequency: 8
                    Reset counter: 123
                    Mileage: 225447 km
                    Date: 2015.01.30
                    Time: 19:14:54
                    Count: 7
                    Count: 12800
                    Count: 260
                    Count: 50746
                    Count: 198
                    Count: 65024
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 123
                    Mileage: 225428 km
                    Date: 2015.01.30
                    Time: 16:58:52
                    Count: 3
                    Count: 2
                    Count: 12800
                    Count: 288
                    Count: 44032
                    Count: 3840
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Revision: 00009001
   Coding: 0000000002
   ROD: EV_ClimaBasis_VW36.rod
   VCID: ED9280E93C2603EE48-80B8
9481748 - High Pressure Sensor
          B10AE 14 [009] - Open or Short to Ground
                    Reset counter: 122
                    Mileage: 225428 km
                    Date: 2020.09.08
                    Time: 16:57:34
   Part No SW: 1K0 937 084 B    HW: 1K0 937 084 B
   Component: BCM PQ35  B   103 0573
   Revision: 00103 AF
   Coding: 40180A3A9025180044000080100000E443010088524D8160648000200000
   VCID: AD1240E9F4A6C3EE08-80F8
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 21100  21  0512
   Coding: 009795
01495 - Bulb for High-Beams; Left (M30)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Fault Frequency: 14
                    Reset counter: 123
                    Mileage: 225428 km
                    Date: 2015.01.30
                    Time: 18:06:57
                    Voltage: 13.85 V
                        Term 50 Off
                    Fault Frequency: 12
                    Reset counter: 123
                    Mileage: 225428 km
                    Date: 2015.01.30
                    Time: 18:06:58
                    Voltage: 13.95 V
                        Term 50 Off
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKD033F3W
   Coding: 00003133
   Shop #: WSC 01383 790 00057
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: BB367EB132D25D5E86-80EE
   Serial number: 3572MSME0D57524AZZZ$
   Serial number: 3582MSME023A234DZZZV
   Serial number: 3512QSME2C184121ZZZM
   Serial number: 3522QSME2614423CZZZQ
   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
   Component: J0527           053 0111
   Coding: 0000004
   VCID: 8346C651C2A2E59E8E-80D6
   Part No SW: 5K0 920 960 N    HW: 5K0 920 960 N
   Component: KOMBI         H04 0308
   Coding: 470B00
   VCID: B83C61BD03E476466B-80EC
9453842 - Oil Level Thermal Sensor
          B1041 35 [009] - Signal high time > maximum
                    Reset counter: 122
                    Mileage: 225428 km
                    Date: 2020.09.08
                    Time: 16:57:47
   Part No SW: 1K0 907 530 AD    HW: 1K0 907 951
   Component: J533  Gateway   H07 0111
   Revision:   H07 01    Serial number: 091109F1001060
   Coding: E9801F06000202000001
   VCID: E99AF4F9C0CE1FCE24-80BC
   Component: IMMO          H04 0308
   VCID: EA988BF50DC814D62D-80BE
   Part No SW: 5K0 959 701 D    HW: 5K0 959 701 D
   Component: Tuer-SG         009 2138
   Coding: 0000564
   VCID: B3265691D282951E5E-80E6
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 69     3001
   Revision: 00H17000
   VCID: B12A5C99289EA70E2C-80E4
   Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
   Coding: 0000564
   VCID: B424558DD78C922647-80E0
   Part No SW: 1K0 035 156 B    HW: 1K0 035 156 B
   Component: Radio         510 0521
   Revision: R0510005    Serial number: VWZ5Z1I0214396
   Coding: 0000020002
   VCID: A208A3D5BD780C96A5-80F6
00856 - Radio Antenna
                    Reset counter: 122
                    Mileage: 225428 km
                    Date: 2015.01.30
                    Time: 16:58:10
End----------(Elapsed Time: 00:50, VBatt start/end: 12.4V/12.4V)-----------
;SW:5K0-920-960-N   HW:5K0-920-960-N ---  Instruments
;Component:KOMBI         H04 0308     Coding:070B00
;EV_Kombi_UDS_VDD_RM09    A04052    EV_Kombi_UDS_VDD_RM09_004_VW32.rod
;Tuesday    8    September    2020    15:30:32:46973
;VCDS Version: Release 20.4.2  Data version: 20200730 DS317.0
;VCID: B83C61BD03E476466B-80EC
Group    Description    Actual
IDE00019    Voltage terminal 30    12.1     V
IDE00021    Engine speed    0     /min
IDE00025    Coolant temperature    57.75     °C
IDE00029-MAS00210    Status of input signals 1-Parking Brake    operated
IDE00029-MAS00211    Status of input signals 1-Insufficient brake fluid    not activated
IDE00029-MAS00212    Status of input signals 1-Insufficient washer fluid    Not available
IDE00029-MAS00213    Status of input signals 1-Insufficient coolant    not activated
IDE00029-MAS00214    Status of input signals 1-Brake pad wear    not activated
IDE00029-MAS00216    Status of input signals 1-External button for daily distance driven    Not available
IDE00029-MAS01208    Status of input signals 1-Spare wheel button    Not available
IDE00029-MAS02002    Status of input signals 1-Pivoting trailer hitch    Stop
IDE00075    Vehicle speed    0     km/h
IDE00151    Oil fill level    OK
IDE00196    Engine oil temperature    -58     °C
IDE00301    Distance    225450     km
IDE00302    Oil pressure switch    dyn. oil press. warn. ON: oil press. < syst.-spec. sw. thresh.
IDE00303-MAS00215    Status of doors/lids 1-Tank flap    Not available
IDE00303-MAS00217    Status of doors/lids 1-Rear window    closed
IDE00303-MAS00218    Status of doors/lids 1-Driver door    Open
IDE00303-MAS00219    Status of doors/lids 1-Front Passenger Door    closed
IDE00303-MAS00220    Status of doors/lids 1-Left rear door    closed
IDE00303-MAS00221    Status of doors/lids 1-Right rear door    closed
IDE00303-MAS00222    Status of doors/lids 1-Rear lid    closed
IDE00303-MAS00223    Status of doors/lids 1-Hood    closed
IDE00304    Fuel level    18     l
IDE00305    Fuel Level Sensor    207     Ohm
IDE00306    Fuel Level Sensor 1    207     Ohm
IDE00310    Outside air temperature    21     °C
IDE00311-MAS00225    Status of seat/convertible top switch-Safety belt switch: driver side    not connected
IDE00311-MAS00226    Status of seat/convertible top switch-Rear backrest: left    Not available
IDE00311-MAS00227    Status of seat/convertible top switch-Rear backrest: right    Not available
IDE00311-MAS00228    Status of seat/convertible top switch-Memory Seat Buzzer    not activated
IDE00311-MAS00229    Status of seat/convertible top switch-Convertible top buzzer    Not available
IDE00311-MAS00230    Status of seat/convertible top switch-Safety belt switch: front passenger side    connected
IDE00311-MAS00231    Status of seat/convertible top switch-Seat occupant detection: front passenger side    Not available
IDE00316-IDE00500    Time-Hour    22     H
IDE00316-IDE00501    Time-Minute    35     min
IDE00323    Security Access: Number of invalid keys    0
IDE00325    Diagnostic mode    VW - diagnostic mode
IDE00329-MAS00232    Buttons for multi-function display-MFI button UP    not activated
IDE00329-MAS00233    Buttons for multi-function display-MFI button DOWN    not activated
IDE00329-MAS00234    Buttons for multi-function display-MFI button RESET / OK    not activated
IDE00329-MAS00235    Buttons for multi-function display-MFI-button "ESC"    Not available
IDE00329-MAS00236    Buttons for multi-function display-MFI buttons: number 3/4    Not available
IDE00333-ENG103024    Driver assistance systems button-Taster Fahrerassistenzsysteme    not activated
IDE00333-ENG100403    Driver assistance systems button-Taster Fahrerassistenzsysteme Fehler    not activated
IDE00334-IDE02444    General status 1-Steering side of vehicle    Not available
IDE00334-MAS00078    General status 1-S-contact    active
IDE00334-MAS00084    General status 1-Terminal 15 on    active
IDE00334-MAS00245    General status 1-Emergency operation    Not available
IDE00336-MAS00252    Status of input signals 2-Airbag indicator lamp    not active
IDE00336-MAS00253    Status of input signals 2-ABS indicator lamp    not active
IDE00336-MAS00254    Status of input signals 2-EBV indicator lamp    not active
IDE00336-MAS00255    Status of input signals 2-El. steering indicator lamp (red)    not active
IDE00336-MAS00256    Status of input signals 2-El. steering indicator lamp (yellow)    not active
IDE00336-MAS00257    Status of input signals 2-ESP warning lamp    active
IDE00336-MAS01207    Status of input signals 2-Differential lock indicator lamp    Not available
IDE00336-MAS01289    Status of input signals 2-Synchronize EBV indicator lamp    not active
IDE00337-MAS00258    Status of input signals 3-Glow plug system indicator lamp    not active
IDE00337-MAS00259    Status of input signals 3-EPC indicator lamp    Not available
IDE00337-MAS00260    Status of input signals 3-Coolant temperature indicator lamp analog    not active
IDE00337-MAS00261    Status of input signals 3-Exhaust Malfunction Indicator Lamp (MIL) (OBD)    active
IDE00337-MAS00262    Status of input signals 3-Kontrollleuchte für Partikelfilter    not active
IDE00337-MAS00263    Status of input signals 3-Tank flap indicator lamp    Not available
IDE00337-MAS00264    Status of input signals 3-Coolant temperature indicator lamp CAN    not active
IDE00337-MAS00265    Status of input signals 3-CCS indicator lamp    not active
IDE00338-MAS00523    Status of input signals 4-Driving light malfunction    active
IDE00338-MAS00524    Status of input signals 4-Turn signal indicator lamp    not active
IDE00338-MAS00525    Status of input signals 4-Trailer turn signal indicator lamp    Not available
IDE00338-MAS00526    Status of input signals 4-High beam indicator lamp    not active
IDE00338-MAS00527    Status of input signals 4-Rear backrest indicator lamp    Not available
IDE00338-MAS00528    Status of input signals 4-Indicator lamp for open doors    active
IDE00338-MAS00529    Status of input signals 4-Generator indicator lamp    active
IDE00338-MAS00530    Status of input signals 4-Rear fog light indicator lamp    not active
IDE00339-MAS00531    Status of input signals 5-Indicator lamp for open hood    not active
IDE00339-MAS00532    Status of input signals 5-Parking light/driving light indicator lamp    Not available
IDE00339-MAS00533    Status of input signals 5-Indicator lamp for open rear window    not active
IDE00339-MAS00534    Status of input signals 5-Rear window open signal (Altbit)    Current
IDE00339-MAS00535    Status of input signals 5-Indicator lamp for open rear lid    not active
IDE00339-MAS00536    Status of input signals 5-Indicator lamp for closing assist open    Not available
IDE00339-MAS00537    Status of input signals 5-Closing assist open signal (alt bit)    Not available
IDE00339-MAS03234    Status of input signals 5-ESP_off indicator lamp    not active
IDE00340-MAS00539    Status of input signals 6-Indicator lamp for tire pressure monitor    not active
IDE00340-MAS00541    Status of input signals 6-Indicator lamp for shift lock    not active
IDE00340-MAS00542    Status of input signals 6-Indicator lamp for safety belt warning    active
IDE00340-MAS00543    Status of input signals 6-Indicator lamp for el. parking brake (shift lock green)    not active
IDE00340-MAS00544    Status of input signals 6-Pulsing of tire pressure monitoring signal    Not available
IDE00340-MAS00545    Status of input signals 6-Tire pressure monitor signal: system status    Not available
IDE00340-MAS01206    Status of input signals 6-Hill descent control indicator lamp    Not available
IDE00340-MAS02617    Status of input signals 6-Motor indicator light (shift-lock green)    not active
IDE00341-MAS00556    Status of input signals 7-Electromechanical parking brake indicator lamp    Not available
IDE00341-MAS00557    Status of input signals 7-Red indicator lamp for electric steering column lock    Not available
IDE00341-MAS00558    Status of input signals 7-Yellow indicator lamp for electric steering column lock    Not available
IDE00341-MAS00559    Status of input signals 7-Pulsing of electric steering column lock signal    Not available
IDE00341-MAS00560    Status of input signals 7-Immobilizer (Kessy) indicator light    Not available
IDE00341-MAS00561    Status of input signals 7-Pulsing of immobilizer (Kessy) signal    Not available
IDE00341-MAS00562    Status of input signals 7-Indicator lamp for automatic driving light (AFS)    not active
IDE00341-MAS00563    Status of input signals 7-Pulsing of automatic driving light (AFS) signal    not active
IDE00483-MAS00564    Status of input signals 8-Indicator light for automatic distance control    Not available
IDE00483-MAS00565    Status of input signals 8-Indicator light for daytime running lights    Not available
IDE00483-MAS00566    Status of input signals 8-Indicator lamp for automatic convertible top operation    Not available
IDE00483-MAS00567    Status of input signals 8-Pulsing of automatic convertible top operation signal    Not available
IDE00483-MAS00568    Status of input signals 8-Automatic convertible top operation (alt bit)    Not available
IDE00483-MAS00569    Status of input signals 8-Indicator lamp for steering wheel heater    Not available
IDE00483-MAS02925    Status of input signals 8-Brake system indicator lamp    Not available
IDE00483-MAS04064    Status of input signals 8-El. steering column lock indicator lamp: shift lock green    Not available
IDE00485-MAS00583    Status of text/acoustics 2-Electric steering column lock: acoustics 1    Not available
IDE00485-MAS00584    Status of text/acoustics 2-Electric steering column lock: acoustics 2    Not available
IDE00485-MAS00585    Status of text/acoustics 2-Tire pressure monitor acoustics 1    Not available
IDE00485-MAS00586    Status of text/acoustics 2-Tire pressure monitor acoustics 2    Not available
IDE00485-MAS00587    Status of text/acoustics 2-Memory seat acoustics    Not available
IDE00485-MAS00588    Status of text/acoustics 2-Automatic distance control: acoustics 1    Not available
IDE00485-MAS00589    Status of text/acoustics 2-Automatic distance control: acoustics 2    Not available
IDE00485-MAS00590    Status of text/acoustics 2-Passenger memory seat acoustics    Not available
IDE00486-MAS00578    Status of text/acoustics 3-Electromechanical parking brake acoustics 1    Not available
IDE00486-MAS00579    Status of text/acoustics 3-Electromechanical parking brake acoustics 2    Not available
IDE00486-MAS00580    Status of text/acoustics 3-Electromechanical parking brake text 1    Not available
IDE00486-MAS00581    Status of text/acoustics 3-Electromechanical parking brake text 2    Not available
IDE00486-MAS00582    Status of text/acoustics 3-Automatic front-lighting system (AFS) text    Not available
IDE00486-ENG102723    Status of text/acoustics 3-Elektromechanische Feststellbremse Akustik    Not available
IDE00486-ENG102166    Status of text/acoustics 3-Noch zu belegen 2    Not available
IDE00487-MAS00591    Status of text/acoustics 4-Automatic convertible top operation acoustics 1    Not available
IDE00487-MAS00592    Status of text/acoustics 4-Automatic convertible top operation acoustics 2    Not available
IDE00487-MAS00593    Status of text/acoustics 4-Automatic convertible top operation acoustics 3    Not available
IDE00487-MAS00594    Status of text/acoustics 4-Special-purpose vehicle acoustics    not active
IDE00487-MAS00595    Status of text/acoustics 4-Depress clutch: text    not active
IDE00487-MAS00596    Status of text/acoustics 4-Depress clutch: acoustics    Not available
IDE00487-MAS01218    Status of text/acoustics 4-Daytime driving light change-over acoustics    Not available
IDE00510    ESI: distance driven from inspection    5300     km
IDE00511    ESI: time from inspection    97     d
IDE00515    ESI: oil quality    poor oil quality
IDE00517-ENG102544    ESI: soot entry-m-Aequivalent0..819100 in 100km    5100     km
IDE00518-ENG102544    ESI: thermal load-m-Aequivalent0..819100 in 100km    3500     km
IDE00519    Terminal 58d: input value    0     %
IDE00520    Phototransistor    26     %
IDE00521    Dimming channel large dial    53     %
IDE00522    Dimming channel small dial    53     %
IDE00523    Dimming channel long pointer    100     %
IDE00524    Dimming channel short pointer    100     %
IDE00525    Dimming channel LCD center    60.5     %
IDE00532    Dimming channel indicator lamps green    70.5     %
IDE00533    Dimming channel indicator lamps blue    70.5     %
IDE00534    Dimming channel indicator lamps yellow    70.5     %
IDE00609-MAS01155    Communication status of data bus 1-Control module    Engine Control Module 1
IDE00609-MAS01156    Communication status of data bus 1-Communication status    active
IDE00610-MAS01155    Time Out Recognition-Control module    Engine Control Module 1
IDE00610-MAS01166    Time Out Recognition-Number of timeouts    0
IDE00697    ESI: remaining distance    9700     km
IDE00698    ESI: remaining running time    275     d
IDE00699    ESI: minimum oil level in service interval    1620     ml
IDE00700    ESI: maximum oil level in service interval    1800     ml
IDE00701    ESI: long term mean value of oil level differences    1600     ml
IDE00705-IDE00660    Status of input signals 9-Drive readiness    No
IDE00705-IDE06339    Status of input signals 9-Hybrid readiness: status    not active
IDE00705-MAS00883    Status of input signals 9-Engine cold indicator lamp    Not available
IDE00705-MAS00884    Status of input signals 9-Low fuel indicator lamp    Not available
IDE00705-MAS00885    Status of input signals 9-Low fuel indicator lamp    not active
IDE00705-MAS01212    Status of input signals 9-Indicator lamp for air cleaner dirty display    Not available
IDE00705-MAS03950    Status of input signals 9-Combustion engine: status    not active
IDE00705-MAS05001    Status of input signals 9-Ethanol warning    not active
IDE00709-ENG102490    Refuel detection-Nachtankerkennung Benzin    No
IDE00709-ENG103312    Refuel detection-Refuel detection gas    Not available
IDE00728-ENG98601    Status of rear safety belt 2nd row-Driver side    Not supported
IDE00728-ENG98393    Status of rear safety belt 2nd row-Frt. pass. side    Not supported
IDE00728-ENG103282    Status of rear safety belt 2nd row-Middle    Not supported
IDE00729-ENG98601    Status of rear safety belt 3rd row-Driver side    Not supported
IDE00729-ENG98393    Status of rear safety belt 3rd row-Frt. pass. side    Not supported
IDE00729-ENG103282    Status of rear safety belt 3rd row-Middle    Not supported
IDE00730    Fuel level sensor 1 including soiling resistance    209     Ohm
IDE00732    Fuel level sensor 1 soiling resistance    2     Ohm
IDE00779-IDE02616    Status of brake texts/acoustics-Tire pressure warning    no warning
IDE00779-IDE04253    Status of brake texts/acoustics-Sys status of tire press monitoring display    Not installed due to specific system
IDE00779-IDE04451    Status of brake texts/acoustics-Tire press monitoring display indictor lamp    not active
IDE00779-IDE06612    Status of brake texts/acoustics-Tire pressure monitoring display (US) warning lamp    not active
IDE00779-IDE06613    Status of brake texts/acoustics-Tire pressure monitoring display (US) MI lamp    not active
IDE00779-MAS01202    Status of brake texts/acoustics-Brake text 2    1
IDE00779-MAS01203    Status of brake texts/acoustics-Brake acoustics 2    3
IDE00819    Day counter    3925     d
IDE00833    Operating range calculated    200     km
IDE00834    Operating range consumption    7.3     l/100km
IDE00835    Fuel gauge needle position    82.2     °
IDE00836    Operating range displayed    200     km
IDE00837    Instantaneous consumption    0     l/100km
IDE00838    Average consumption multi-function display 2    7.1     l/100km
IDE00839    Operating ranges of fuel supply    14.625     l
IDE00841    Operating range consumption damping    50     km
IDE00842    K-number    21960
IDE00843    Starting impulse recognized    No
IDE00845    Wheel circ.    1958     mm
IDE00846    Combi login attempts    0
IDE00847    remaining locking period    0     s
IDE00848-IDE00756    Gear change display-Current gear    9th gear
IDE00848-IDE00757    Gear change display-Specified gear    9th gear
IDE00848    Gear change display    Not available
IDE00848-IDE01994    Gear change display-Communication status at specified installations    No
IDE00885-ENG98391    General status 2-AFS configuration bit    CAN Bit = 0
IDE00885-ENG98358    General status 2-AFS functional status    CAN Bit = 0
IDE00885-ENG98380    General status 2-AUTO HOLD configuration bit    Not available
IDE00885-ENG98426    General status 2-AUTO HOLD functional status    Not available
IDE00885-ENG111997    General status 2-EasyEntry Funktionszustand    CAN Bit = 0
IDE00885-ENG111996    General status 2-EasyEntry Umschaltfunktion    CAN Bit = 0
IDE00885-ENG111995    General status 2-Segeln Funktionszustand    Not available
IDE00885-ENG111994    General status 2-Segeln Umschaltfunktion    Not available
IDE00885-ENG98992    General status 2-Travel mode (tourist light) configuration bit    CAN Bit = 0
IDE00885-ENG98991    General status 2-Travel mode (tourist light) functional status    CAN Bit = 0
IDE00926    ESI: Cum. total of fuel level differences Zdiff    0
IDE00927    ESI: Cum. total of fuel level values    0
IDE00928    ESI: Year's amount of driving    19880     km
IDE00929    ESI: Short-term average of fuel level differences    0     ml
IDE00930    ESI: Maximum upper limit of distance between mainten. intervals    30000     km
IDE00931    ESI: Maximum upper limit of time between mainten. intervals    744     d
IDE00932    ESI: Maximum lower limit of distance between mainten. intervals    15000     km
IDE00933    ESI: Maximum lower limit of time between mainten. intervals    744     d
IDE00934    ESI: Total fuel level differences Sdiff    0     l
IDE02227-MAS02005    Second oil pressure switch-Text request from engine    0
IDE02227-MAS02007    Second oil pressure switch-Enable oil pressure    No
IDE02227-MAS02008    Second oil pressure switch-Oil pressure warning from engine    not active
IDE02498-IDE03376    Status transmission 1-Transmission neutral position sensor status    not active
IDE02498-IDE03527    Status transmission 1-CAN signals    Transmission Control Module (TCM)
IDE02498-IDE06322    Status transmission 1-Current gear    0
IDE02498-MAS02868    Status transmission 1-Clutch alert    not active
IDE02498-MAS03172    Status transmission 1-Version    0
IDE02499-MAS02101    Status comfort 1-Child safety    not active
IDE02499-MAS02869    Status comfort 1-ID sensor battery warning    not active
IDE02642    Outside temp.: displayed value    20     °C
ENG108925-ENG103300    Service_Key_Data_Current_Page-Service_Data    DA C4 21 02 00 10 0E 7A 13 15 37 10 70 A9 00 03 30 3D 11 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 FF FF 00 00 00 00
ENG108926-ENG103300    Service_Key_Data_Previous_Page-Service_Data    9D 61 21 02 00 10 0E 7A 0E 15 00 3A 70 93 00 03 30 3D 11 13 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 FF FF 00 00 00 00
ENG108927-ENG99427    Service_Key_Master_Counter-Counter ID-Geber    0
ENG108927-ENG100006    Service_Key_Master_Counter-Counter Key-ID1    9416
ENG108927-ENG103077    Service_Key_Master_Counter-Counter Key-ID2    4132
ENG108927-ENG102096    Service_Key_Master_Counter-Counter Key-ID3    0
ENG108927-ENG100678    Service_Key_Master_Counter-Counter Key-ID4    0
ENG108927-ENG103705    Service_Key_Master_Counter-Counter Key-ID5    0
ENG108927-ENG102437    Service_Key_Master_Counter-Counter Key-ID6    0
ENG108927-ENG103366    Service_Key_Master_Counter-Counter Key-ID7    0
ENG108927-ENG99925    Service_Key_Master_Counter-Counter Key-ID8    0
ENG108927-ENG99901    Service_Key_Master_Counter-Counter Trigger    0
ENG108927-ENG102963    Service_Key_Master_Counter-Error Counter    2
ENG108927-ENG100636    Service_Key_Master_Counter-Immo Key    1
ENG108927-ENG98696    Service_Key_Master_Counter-Last key    1
ENG108927-ENG99298    Service_Key_Master_Counter-State    Engine_off
ENG108928-ENG100714    Service_Key_Mileage_Date-Day_Secure_Total_Distance    19
ENG108928-ENG103946    Service_Key_Mileage_Date-Day_Total_Distance_Um5    21
ENG108928-ENG104181    Service_Key_Mileage_Date-Hour_Secure_Total_Distance    18
ENG108928-ENG102814    Service_Key_Mileage_Date-Hour_Total_Distance_Um5    19
ENG108928-ENG101293    Service_Key_Mileage_Date-Minute_Secure_Total_Distance    37
ENG108928-ENG101144    Service_Key_Mileage_Date-Minute_Total_Distance_Um5    16
ENG108928-ENG101950    Service_Key_Mileage_Date-Month_Secure_Total_Distance    14
ENG108928-ENG100253    Service_Key_Mileage_Date-Month_Total_Distance_Um5    14
ENG108928-ENG99374    Service_Key_Mileage_Date-Second_Secure_Total_Distance    37
ENG108928-ENG100588    Service_Key_Mileage_Date-Second_Total_Distance_Um5    55
ENG108928-ENG101257    Service_Key_Mileage_Date-Secure_Total_Distance_Km    2137587717
ENG108928-ENG101154    Service_Key_Mileage_Date-Total_Distance_Km_Um5    1890123779
ENG108928-ENG103322    Service_Key_Mileage_Date-Year_Secure_Total_Distance    122
ENG108928-ENG102907    Service_Key_Mileage_Date-Year_Total_Distance_Um5    122
ENG108929-ENG99961    Service_Key_Pointer-Current_Bank    Bank 1
ENG108929-ENG104110    Service_Key_Pointer-Write_Pointer_Addr_127    9418
ENG108929-ENG99599    Service_Key_Pointer-Write_Pointer_Addr_159    9418
ENG108929-ENG100247    Service_Key_Pointer-Write_Pointer_Addr_95    9418
ENG109104-ENG28305    Status Start_Stop-1_reserved    0
ENG109104-ENG28376    Status Start_Stop-2_reserved    0
ENG109104-ENG103894    Status Start_Stop-Anzeige Start/Stopp_Automatikstart    0
ENG109104-ENG103361    Status Start_Stop-Netzwerkdiagnose-Freigabe    active
ENG109104-ENG101406    Status Start_Stop-Netzwerkdiagnose-Freigabe gueltig    active
ENG109104-ENG102072    Status Start_Stop-Start Stop Lampe    Not available
Elapsed Time: 00:24
There should be an Adaptation Channel in that cluster named:
IDE03346-IDE00301 -- Units adjusted - Distance
which you can flip between miles and kilometers.
Spacewalker
Poland
C?ID=159607
I think LowLine cluster not allow to change that because they use a linera LCD , not graphic ,
