Can you disable the "press clutch to start" funtion, 2014 A4
Qwiksvo
C?ID=414097
Hi, while test driving my car after my last tweak, I thought of another tweak I would like to do. Can the "press clutch to start" function be turned off? It is hard on the crankshaft trust bearings to dry start with the full pressure of the clutch applied.
I know it is a safety feature, but I have been driving manual transmission cars for 36 years and I am use to starting a manual car in neutral without pressing the clutch. I have this defeated in all six of my other manual trans cars. It is one of the first things I do when I buy a car.
Thanks, Wade
Here is my current auto scan:
Monday,07,September,2020,23:15:10:14539
VIN: WAUDFAFL6EN038055   License Plate:
Chassis Type: FL-AU48 (8R0)
Scan: 01 03 05 08 09 15 16 17 19 42 44 46 52 53 56 5F 62 72
VIN: WAUDFAFL6EN038055   Mileage: 73910km-45925miles
Address 01: Engine (MY15-CAED)       Labels:. 06H-907-115-CDN.clb
   Part No SW: 8K5 907 115 M    HW: 8K2 907 115 L
   Component: 2.0l R4/4V TF H09 0005
   Revision: ECH09---
   Coding: 4A190013242600062000
   Shop #: WSC 15184 003 1048576
   ASAM Dataset: EV_ECM20TFS0118K5907115M 001006
   ROD: EV_ECM20TFS0118K5907115M.rod
   VCID: 3C2130CFA6E82B5B4EB-8068
Readiness: 1110 0101
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CP    HW: 8K0 907 379 CP
   Component: ESP8 quattro  H09 0020
   Coding: 071D1800
   Shop #: WSC 02391 785 00200
   VCID: 094F991BB93ACEF305D-805C
   Part No SW: 8K0 907 064 JL    HW: 8K0 907 064 JL
   Component: BCM2 2.0      H14 0650
   Coding: 0B814040000000000000
   VCID: 03538B339B1694A34F1-8056
   Subsystem 1 - Part No SW: 8K0 959 754 F    HW: 8K0 959 754 F
   Serial number: 0514000041919001
   Serial number: 0214000047704008
   Part No SW: 8K1 820 043 AM    HW: 8K1 820 043 AM
   Component: KLIMA 1 ZONE  H02 0122
   Revision: A0000000    Serial number: 01170320141860
   Coding: 6400208000
   VCID: 73B3DBF3CBB6A4235F1-8026
   Part No SW: 8K0 907 063 DF    HW: 8K0 907 063 DF
   Revision: 06016001    Serial number: 00000774004501
   Coding: 26000091863CAFC00000480000003D0D0F1C1308A2090221000004004000030100000000000000
   VCID: 76B5E2E7D8C4B10B78F-8022
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA050314  H18 0461
   Serial number: 1402270704681
   Coding: 004577
   Serial number: 22388710
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000000903145624
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555RANHP03
   Subsystem 5 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 80194B17000000000001
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KJDC02ZGY
   Coding: 303844354730303030304A55304C384B3053
   Shop #: WSC 29419 001 1048576
   VCID: 4ACD6617FC3C85EBCC7-801E
   Subsystem 1 - Part No SW: 8K0 959 339 C    HW: 8K0 959 339 C
   Serial number: 5810000R140000JD66
   Serial number: 6334MSME450960647
   Serial number: 6344MSME426D0C0BM
   Serial number: 6352QSME1B4042526
   Serial number: 6362QSME793D2C7A+
   Serial number: 63732SME4142317AV
   Serial number: 63832SME34432E50Z
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NCI0009D
   Coding: 000016
   VCID: 48C95C1FE2B077FBDA3-801C
   Part No SW: 8K0 920 983 F    HW: 8K0 920 983 F
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAA37UE3F
   Coding: 8BB409000301D705020000
   VCID: 38292CDF9250077BAA3-806C
   Part No SW: 8R0 907 468 N    HW: 8R0 907 468 C
   Component: GW-BEM 4CAN-M H11 0060
   Revision: 1Y080030    Serial number: 3041Y143100B79
   Coding: 80C303FF00
   VCID: 4ACD6617FCBC85EBCC7-801E
   Serial number: 5456222803
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0305
   Coding: 011C03204000410001
   VCID: 56F582673804D10B58F-8002
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0008375655
   Coding: 100000000001
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 353725EB85C2FA13B15-8060
   Revision: 00002001    Serial number: 0330208812
   Coding: 0106023A00FA404480B0013200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000815161
   Subsystem 3 - Part No SW: 8K0 959 591 B    HW: 8K0 959 591
   Component: J245 PS050  H08 0043
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0305
   VCID: 55F7856B2502DA13515-8000
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 30000000183694
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2D36D7ACDC156B5C7-806E
   Revision: AB001007    Serial number: 156C00E7983533
   Coding: 020007020100000001
   VCID: 2411E8AF3ED8739B16B-8070
02984 - Connection between Impedance Converter 2 and Window Antenna
                    Reset counter: 156
                    Mileage: 73913 km
                    Date: 2020.09.07
                    Time: 23:07:38
                    Voltage: 12.20 V
   Part No SW: 8R1 035 664 E    HW: 8R1 035 664 D
   Component: H-BN-NA       H41 0756
   Revision: --------    Serial number: 203CT0E7538107
   Coding: 0F0200000006A1EC01028B5C00000403F40000020000000000
   Subsystem 1 - Part No: 8R0 060 884 BL
   Component: NAR 2014  0902
   Component: DU7 High  H42 0104
   Serial number: A130CX0E2975139
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001793463
   Component: CD-Database  5571
   Part No SW: 8T0 959 795 Q    HW: 8T0 959 795 H
   Component: TSG HL        H07 0305
   Coding: 010C03204000210001
   VCID: 59EF895B491AFE7375D-800C
   Component: TSG HR        H07 0305
End----------(Elapsed Time: 01:41, VBatt start/end: 12.2V/12.2V)-----------
[CODE]
I am not sure that is possible. VW/Audi cars with manual transmissions have had that "feature" for just about as long as I can remember. In the old days, you could cheat by bypassing the clutch switch, but I would suppose doing that would have other consequences on your car (such as making the cruise control not work).
Qwiksvo
C?ID=414097
Yeah, I bypassed the switch on my other three Audis, but they are 2005 S4's and a 2002 A4. If I remember correctly, there are two different switchs on them (same with my mustangs) one kills the cruise and the other is the starter interupt. I'll have to look under the dash and see how this new model is set up. This car doesn't kill the cruise if I push the clutch pedal down to shift. It resumes automaticly when I down/up shift, so I figured there is something in the computer somewhere.
By the way, most manuals sold in the good old USA have had this saftey switch since sometime in the 70's, but I remember when I lived in Germany 2003-2006 the manuals cars I rented (Peugeot 206, VW beetle) didn't have this switch. I joked with my wife and said "the Germans must be smarter than us". She said "no, they probably don't have as many lawyers" LOL.
Yep. I suspect it's required by some sort of regulation in the US, but not in Europe. I don't know whether Germans are smarter, but they do (or at least used to) take their driving far more seriously. New driver training is quite rigorous, and ze rulez of ze road, zey must be followed, ja? ;)
MVB
C?ID=164610
Try a search for "push clutch to start bypass harness" on web & Ebay it works on VW and Audi models but I do not recall if it covers an A4 '14. CC & over rev functions are still intact.
NZDubNurd
New Zealand
C?ID=230482
Do you have to push the clutch to start MK5 platform cars in the USA?
Euro ones certainly don't... though I did think about trying to enable it in my Touran... Because my Wifes Touran is auto and when you're inside, it feels like the same car other than the transmission and 100 extra horse powders.
Yes. This goes all the way back to at least the Mk.3. I don't remember whether you had to on the Mk.1 or Mk.2, but it was definitely necessary on my Mk.3.
MVB
C?ID=164610
My NAR MK2 '87 GTI does not have a push to start clutch switch.
volkar
Estonia
C?ID=277260
Enable or disable "press clutch to start" message is stored in Instrument cluster EEPROM.
Depending on whether it is a manual transmission or an automatic transmission, the manufacturer has loaded different data into the EEPROM.
It is better to leave it untouched in case you ever sell a car
