Dynamic Light Assist (DLA) Coding Issue
nibose
Perth, WA
C?ID=371170
Hi,
I tried to enable DLA but now getting the following error:
Tuesday,08,September,2020,19:29:28:34260
VCDS Version: Release 20.4.2 (x64) Running on Windows 8.1 x64
                Address 4B: Multifunc. Module       Labels: 3Q0-907-338-V2.clb
Control Module Part Number: 3Q0 907 338 C    HW: 3Q0 907 338 C
  Component and/or Version: FCM MQB Low   002 0345
           Software Coding: 000000060900034E03104F05020000040000000000000000000000000000
            Work Shop Code: WSC 05311 123 08193
              ASAM Dataset: EV_MultiModulContiVW48X 002006 (VW48)
                       ROD: EV_MultiModulContiVW48X_002_VW41.rod
                      VCID: 3537202735C92BE3B15-8060
5276145 - Power Output Module for Left Headlamp
          C1081 F1 [137] - Incorrectly Coded
                    Reset counter: 126
                    Mileage: 111 km
                    Date: 2020.09.08
                    Time: 19:27:10
5276401 - Power Output Module for Right Headlamp
          C1082 F1 [137] - Incorrectly Coded
                    Reset counter: 126
                    Mileage: 111 km
                    Date: 2020.09.08
                    Time: 19:27:10
I followed the following steps:
Module 09 - Central Electrics
1. Connect OBD Eleven to your car.
2. Turn the ignition on, not the engine! These changes won't apply if the engine is on. I've tried it.
3. Go to central electrics module 09.
4. Select adaptions from the list.
5. Find "Fernlicht_Assistent" and go into that menu.
6. Change "Erweiterte Fernlichtsteuerung" to AFS FLA Fernlicht (GLW:MDF).
7. Change "Menusteuerung Fernlichtassistent" to present.
8. Change "Menusteuerung Fernlichtassistent Worksteinstellung" to present.
Module A5 - Front Sensor
1. Got to module A5 - Front Sensor.
2. From the list select "long coding".
3. Find byte 19 - Bit 0-3 Value 00
4. Find byte 19 - Bit 4-7 Value 30
5. Find byte 21. Change it to hex value 40.
Module 4B - Multifunction Module
1. Go to module 4B.
2. In the list, select long coding.
3. Go to byte 9. Change the hex value to 10.
4. Go into byte 10. Tap the checkbox on bit 6 to enable it. Make sure bit 5 is unticked.
5. Go to byte 11. Tap the checkbox on bit 2 to enable it.
I can see only "Dynamic Light Assist" in the radio light settings; "Dynamic Cornering" no longer exists. Is this how its supposed to be?
Please help.
siLc
Tallinn, Estonia
C?ID=330192
Only a snippet of the FCM won't do - please post a full autoscan of the vehicle in question. Also admaps of the 09 BCM and probably 5F. Also add what you've already done (changed any hardware?).
TBAx
DE
C?ID=287144
What makes you assume, that you can simply code it? Does the necessary hardware exist?
nibose
Perth, WA
C?ID=371170
Hi,
Please find the autoscan as follows:
Tuesday,08,September,2020,19:38:40:34260
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 2B 36 3C 42 44 4B 52 5F 6C
          A5 BB BC CA CF D6 D7
VIN: WVWZZZ3CZKE054334
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CJSA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 264     HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 092500322464050B3000
   Shop #: WSC 05311 115 00311
   ASAM Dataset: EV_ECM18TFS0203G0906264 001007
   ROD: EV_ECM18TFS0203G0906264_VW48.rod
   VCID: 6597B067C5E99B63C15-8030
Readiness: 1110 0001
   Part No SW: 0CW 300 043 H    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501811136031
   Shop #: WSC 05311 115 00086
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 3C21350316E3FAAB4EB-8068
   Part No SW: 5Q0 614 517 DH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0754
   Revision: 00000000    Serial number: 63258000001330
   Coding: 0EEC928F34252370477A060360C74970492CC4E2600692753842F038C2A9420B00000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_037_VW37.rod
   VCID: 7AADF31B5C57049B1C7-802E
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0499916047
   Coding: 1F20000723
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 43D34EFF6B1D85530F1-8016
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 1112001420010000111510401210182A
   VCID: 78A9E913625B168B6A3-802C
   Geber f¸r K‰ltemitteldruck/K‰ltemitteltemperatur:
   Air quality sensor:
   Part No SW: 5Q0 937 086 BQ    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 036 0265
   Revision: --------    Serial number: 8658081118000S
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: EV_BCMBOSCH_019.rod
   VCID: 0A4DA3DB0CB7141B0C7-805E
   Subsystem 1 - Part No SW: 3G2 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    181104  043 0607
   Serial number:         181115102536
   Component: RLHS  052 0107
   Serial number: S7Y18M11D29H15M50S54
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 H    HW: 3G0 941 633 H
   Serial number: 25 09 2018  10000464
   Steering Column Switch:
   Subsystem 5 - Part No SW: 5Q1 953 521 AS    HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number: 0100241120180C301643
   Part No SW: 5QA 919 298 F    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0453
   Serial number: 000308417618311
   Coding: 0371167851
   ASAM Dataset: EV_EPHVA2CAU3700000 009037
   VCID: 53F37EBF9B7D15D3BF1-8006
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H05 0196
   Coding: 320467D359FFC428949C8045
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   Part No SW: 3Q0 959 655 BJ    HW: 3Q0 959 655 BJ
   Component: Airbag VW21   006 0712
   Revision: --------    Serial number: 003W5PN9QTH/
   Coding: 98FCC0C0000000005C540000008800000065
   Shop #: WSC 05311 000 08193
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 074B9AEF1FA56973139-8052
   Subsystem 1 - Part No SW: -----------    HW: 454 000 611 18
   Serial number: 35700000000162717231
   Subsystem 2 - Part No SW: -----------    HW: 454 000 611 18
   Serial number: 35800000000B5271723B
   Subsystem 3 - Part No SW: -----------    HW: 454 800 810 18
   Serial number: 35100F6C57A16000000S
   Subsystem 4 - Part No SW: -----------    HW: 454 801 211 18
   Serial number: 35200E660D916000000M
   Subsystem 5 - Part No SW: -----------    HW: 454 802 510 18
   Serial number: 35500E5619C16000000O
   Part No SW: 3G0 920 791 D    HW: 3G0 920 791 D
   Component: KOMBI         403 4191
   Coding: 27A501186F8C000801887B0B1001000080000000
   VCID: 2A0D035BEC77741B2C7-807E
   Serial number: 29111810804595
   Coding: 030300347F085900FB00025A1C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW37.rod
   VCID: 6E85CF4B101F583BB0F-803A
   Component: 0-00-03-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AE    HW: 5G0 959 442 AE  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0052
   Serial number: 29180002805690098475
   Coding: 2DFFFF
   Serial number: 75886002001811091A89
   Analog clock:
   Subsystem 4 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  111 1004
   Serial number: 1311201800010362
   Serial number: 18000349925013
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_VW37.rod
   VCID: 33331E3F3BBD35D39F1-8066
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 D    HW: 3Q0 959 760 D
   Component: Sitzmemory    H06 0024
   Serial number: Y0006RKR13119
   Coding: 001400020000050081C280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002022
   Part No SW: 3Q0 907 566 G    HW: 3Q0 907 566
   Component: MRR1Rear      H23 0530
   Revision: --------
   Coding: 44C002
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS001 0287
   Serial number: YE007RKG05581
   Coding: 003F1B20D201020000000000
   VCID: 44D14DE36E13826B36B-8010
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 93170000
   Shop #: WSC 00015 115 00311
   ROD: EV_SteerAssisMQB_015.rod
   Component: FCM MQB Low   002 0345
   Serial number: 23111810521586
   Shop #: WSC 05311 123 08193
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
                    Reset counter: 126
                    Mileage: 17811 km
                    Date: 2020.09.08
                    Time: 19:27:10
                    Reset counter: 126
                    Mileage: 17811 km
                    Date: 2020.09.08
                    Time: 19:27:10
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS001 0287
   Serial number: YE007RKG17817
   Coding: 003F1120DE01020000000000
   Part No SW: 5NA 035 045 C    HW: 5NA 035 045
   Component: MU-H-N-RW     H55 1161
   Serial number: A849K0JS036922
   Coding: 02840108FF00000051510001000808001F0106E601200402DF
   VCID: 3829291322DBD68BAA3-806C
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H52 9130
   Serial number: VWZ6ZJV3280358
   Subsystem 2 - Part No SW: V03 959 806 NC    HW: -----------
   Component: ROW 2020/2021  --- 0088
   Compact Disc Database:
   Component: Gracenote2  --- 4013
   Coding: 0184010162002017000040
   VCID: 392F2C1719D1CF8355D-806C
   Part No SW: 3Q0 980 654 H    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H09 0272
   Serial number: 20081815P12294
   Coding: 000408010000010100022346C150A90094000E300040
   Part No SW: 8W1 959 595 D    HW: 8W1 959 595 D
   Component: TSG HFS003 0187
   Serial number: YE007RKD22815
   Coding: 000E11200101020000000000
   VCID: 4EC56FCBB05F783B90F-801A
   Component: TSG HBFS003 0187
   Serial number: YE007RKD22811
   Part No SW: 4M0 907 594 K    HW: 4M0 907 594
   Component: SAD_STG_1     014 0005
   Coding: 508000748101
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3E253F0B00FFE8BB60F-806A
   Part No SW: 3Q0 907 590 G    HW: 3Q0 907 590
   Revision: --------
   Coding: 44C002
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C7AB480FC0FB98F-8042
   Component: LED1R         H09 0003
End----(Elapsed Time: 02:10, VBatt start/end: 11.5V/11.5V. VIgn 11.5V)-----
I've only done the coding as I'd mentioned above.
I've not done the basic settings which seems to be necessary though, as I'm not sure how to do this. Please let me know how to do this.
The other step I tried afterwards was to change a setting in module 4B:
4B, byte-9 and changed it back to 00 (Headlight type: Variant-1). With this setting, I can see "Dynamic light assist" and "Adaptive Front Lighting System" I guess I need to get "Dynamic Cornering System" instead of "AFS" for the full DLA to work. With this setting, the previous error does not exist, but a new one:
Address 4B: Multifunc. Module Labels: 3Q0-907-338-V2.CLB
Software Coding: 000000060900034E01004F0502000004000000000000000000 0000000000
VCID: 3537202734492BE3B15-8060
0032 - Headlight
C107E 54 [137] - Missing Calibration / Basic Setting
Reset counter: 126
Date: 2020.09.08
Time: 22:33:35
Pardon my ignorance but please assist me.
Hawkeye9723
C?ID=389466
AFAIK, the cars in the US do not have the hardware for DLA. The lights require the shutters to make it work. Without replacing the front lights, I don't think you're going to have any luck.
siLc
Tallinn, Estonia
C?ID=330192
Which PR code variant are your LED headlights: 8IT or 8IU? You can find the code on the vehicle data sticker in the spare wheel well and service book. If this is not 8IU, then you can't retrofit DLA with these lights as they don't have the necessary hardware.
Also this is a RoW market vehicle.
nibose
Perth, WA
C?ID=371170
Yay! It worked. The errors seemed to be due to a different issue. I was doing the coding last night and I ended up getting a battery low warning. I decided to go for a drive today evening and there was a warning in the cluster. I drove about 25 kms and suddenly noticed the warning disappeared! I then pulled the stalk and got the light assist icon in the cluster (headlight symbol with A superimposed in white colour). When driving in a dark or minimally illuminated roads, this turns blue. Both the low & high beams seems to move accordingly.
The MMI/settings /Vehicle/Lights shows Dynamic Light Assist and Adaptive Front Lighting System though.
One point to note: I had set module 4B, Byte 9, Bit 4-7 as 00 Head Light Type: Variant 1
The Adaptive front lighting System disappears from the mmi/lights menu if I set it to 10 Head Light Type: Variant 2
Not sure why.
