Audi A4 K8 2.0 TDI CR. How to increase idle speed.
bednar
Poland
C?ID=327015
Hi. I would like to know how to increase idle speed in my car. I saw that in earlier version the option is available with out problems [Engine]->[Adaptation]. In my car I can only change maximum speed. Do you have any advice for me how to manage with this issue?
Engine screenshot
South Molton, UK
We'll need to see a full unedited VCDS Auto-Scan so we can see what versions of modules your A4 has.
If the ECU supports it at all, it may require some security access code that is not known.
bednar
Poland
C?ID=327015
Here you are.
Friday,11,September,2020,13:54:36:29305
VIN: WAUZZZ8K5EA155732   License Plate:
Mileage: 237240km-147414mi   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 20 42 44 46 52 53 56 5F 62 6D
          72
VIN: WAUZZZ8K5EA155732   Mileage: 237240km-147414miles
Address 01: Engine (J623-CGLC)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 JJ    HW: 03L 906 018 JL
   Component: R4 2.0l TDI   H25 9978
   Revision: 45H25---
   Coding: 12034012232401080000
   Shop #: WSC 02562 002 1048576
   ASAM Dataset: EV_ECM20TDI01103L906018JJ 003010
   ROD: EV_ECM20TDI01103L906018JJ.rod
   VCID: 7BA30A9F93624743071-802E
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K5 927 155 L    HW: 0AW 927 156 K
   Component: 0AW_20TDI_RdW H06 0004
   Revision: --H06---    Serial number: 0000000719
   Coding: 000002
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMVL381 A02433
   ROD: EV_TCMVL381.rod
   VCID: 41DFB877B10EED931DD-8014
Address 03: ABS Brakes (J104)       Labels:. 8K0-907-379-V2.clb
   Part No SW: 8K0 907 379 CN    HW: 8K0 907 379 CN
   Component: ESP8 front    H09 0020
   Coding: 171DCC01
   VCID: 074B666FDF2A13A3139-8052
   Part No SW: 8K0 907 064 JG    HW: 8K0 907 064 JG
   Component: BCM2 2.0      H14 0650
   Coding: 01A24000000000000000
   VCID: 7EA5038B80F0526B20F-802A
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0514000060503021
Address 08: Auto HVAC (J255)       Labels:. 8Kx-820-043-3Z.clb
   Part No SW: 8K1 820 043 BB    HW: 8K1 820 043 BB
   Revision: C1000000    Serial number: 01240420140109
   Coding: 342002E000
   VCID: 698F40D7E97EC5D3E5D-803C
   Part No SW: 8K0 907 063 DH    HW: 8K0 907 063 DH
   Revision: 08016001    Serial number: 00000804281001
   Coding: 260000108074AFC00081400300001D0D0F1C470826090201000008004401020100000020000000
   VCID: 78A91593A2D46C5B6A3-802C
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA170314  H18 0461
   Serial number: 1403130701306
   Coding: 004577
   Serial number: 22560412
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001304140240
   Serial number: 86F80427000000000001
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Component: AirbagVW-AU10 H48 0610
   Serial number: 003KFDC14DYT
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 11318 001 1048576
   VCID: 48C9A5539234DCDBDA3-801C
   Serial number: 6334MSME444B3650A
   Serial number: 6344MSME4419776BN
   Serial number: 6352QSME6D4A2262M
   Serial number: 6362QSME594A064CS
   Serial number: 63732SME33424B60W
   Serial number: 63832SME47402760U
   Part No SW: 8K0 953 568 Q    HW: 8K0 953 568 Q
   Component: Lenks.Modul   H03 0003
   Revision: C0062331    Serial number: 90862NDE001ET
   Coding: 000017
   VCID: 48C9A55392B4DCDBDA3-801C
   Part No SW: 8K0 920 932     HW: 8K0 920 932
   Component: KOMBIINSTR.   H35 0564
   Revision: 00100000    Serial number: ZAB53VW4F
   Coding: 13A6100003010008000000
   VCID: 6C8139C3E68CD0FB9EB-8038
   Part No SW: 8R0 907 468 P    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0060
   Revision: 1Z120030    Serial number: 3041Z1441603BB
   Coding: 80CF07FF00
   VCID: 4CC1994386CC30FBFEB-8018
   Serial number: 9439333203
   Serial number: 14115001409011200181
   Part No SW: 8T0 857 511 AD    HW: 8T0 857 511 AD
   Component: FLA           H04 0012
   Revision: AA001002
   Coding: 02019164747464545425363E00
   VCID: 7CA1098396EC407B0EB-8028
   Component: TSG FA        H02 0510
   Revision:             Serial number: 0000100220885
   Coding: 011C02205C00410001
   VCID: 4FFB8E4F77DA0BE39B9-801A
   Part No SW: 8K0 909 144 G    HW: 8K0 909 144 B
   Component: RCEPS         H40 0508
   Revision: 00001000    Serial number: 0012485746
   Coding: 100000000001
   Shop #: WSC 06334 000 00000
   ASAM Dataset: EV_RCEPSAU48X 008015
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 3537DCA7F5C65133B15-8060
   Revision: 00002001    Serial number: 0333286945
   Coding: 0100062820B930808320023680000047
   Component: TSG BF        H02 0510
   Revision:             Serial number: 0000099456374
   Coding: 011C02205E00410001
   VCID: 4EC5934B70D002EB90F-801A
   Component: EPB-4         H01 0005
   Revision: --------    Serial number: 30000000202425
   ROD: EV_ParkiBrake_AU48.rod
   VCID: 3A2DCF9BDCD8BE4B5C7-806E
   Part No SW: 4G1 035 053 J    HW: 4G1 035 053
   Component: Radio U Basic H41 0133
   Revision: AB001007    Serial number: 227D60E7999109
   Coding: 010003020100000001
   VCID: 26150BEB38E02AAB08F-8072
   Part No SW: 8R1 035 666 E    HW: 8R1 035 666 C
   Component: H-BN-EU       H47 0793
   Revision: --------    Serial number: 205D/0E7909239
   Coding: 0F0100010006A1ED01808B5E00000403E40100020000000000
   VCID: 3A2DCF9BDC58BE4B5C7-806E
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Component: DU7 High  H42 0104
   Serial number: A130DN0E3007663
   Subsystem 3 - Part No SW: 8T0 919 611 K    HW: 8T0 919 611 B
   Serial number: 00000001834498
   Component: CD-Database  5571
   Component: TSG HL        H01 0510
   Revision:             Serial number: 0000100341858
   Coding: 010C02204000210001
   VCID: 46D5AB6B98A0CAAB28F-8012
Address 6D: Trunk Elect. (J605)       Labels: 8K9-827-851.clb
   Part No SW: 8K9 827 851 C    HW: 8K9 827 851 C
   Component: J605  Master  H53 0330
   Revision: --------    Serial number: 8K9827851C
   VCID: 3E25C38BC070926B60F-806A
   Subsystem 1 - Part No SW: 8K9 827 852 C    HW: 8K9 827 852 C
   Component: J756  Slave  H53 0330
   Serial number: 8K9827852C
   Component: TSG HR        H01 0510
   Revision:             Serial number: 0000100346209
End----(Elapsed Time: 01:37, VBatt start/end: 12.0V/11.9V. VIgn 12.0V)-----
Log-WAUZZZ8K5EA155732-237240km-147414mi.txt
Displaying Log-WAUZZZ8K5EA155732-237240km-147414mi.txt.
That ECU does not appear to have a channel in which the idle speed can be altered.
