Issue with Caddy Steering with fault code 16351
golfi_vend
Tartu, Estonia
C?ID=195131
Issue in question is related to this fault code:
16351 - Control Module - Programming Error
            000 - - - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 0.0 V
                        PD
                    Temperature: 20.0°C
                    Hex Value: 0x0000
                    Hex Value: 0x0000
Car was in accident. Owner says that rear axle was replaced. Prior to axle replacement car drove fine.
I've tried flashing the firmware of the steering gear and then adapting Steering Profile. Nothing helps.
When I do G85 adaption from module 44, it does it successfully. Using ODIS it does it too, but claims that init. isn't completed and suggests trying calibrating steering ends. Doing this doesn't give any result as steering stays extremely hard and unassisted.
Thursday,03,September,2020,17:32:21:63851
VCDS Version: 20.4.2.0 (x64)  HEX-NET2 CB: 0.4528.4
Dealer/Shop Name: LeVWFreaks.eu
VIN: WV1ZZZ2KZKX   License Plate:
Mileage: 23540km-14627mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 10 15 16 17 18 19 22 25 42 44 46 52 5F 61
VIN: WV1ZZZ2KZK   Mileage: 23540km-14627miles
Address 01: Engine (J623-DFSE)       Labels: None
   Part No SW: 04L 906 016 NA    HW: 04L 907 309 K
   Component: R4 2.0l TDI   H20 4104
   Revision: 8AH20---
   Coding: 0119001A04260D090000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM20TDI01104L906016NA 001001
   ROD: EV_ECM20TDI01104L906016HD_004_VW36.rod
   VCID: 75BC8A9C454EA013715-8020
17158 - Implausible Data Received from ESP Control Module
          U0416 00 [047] - -
                    Mileage: 23477 km
                    Date: 2020.09.03
                    Time: 02:24:35
                    Engine speed: 855.00 /min
                    Normed load value: 17.6 %
                    Coolant temperature: 83 °C
                    Intake air temperature: 73 °C
                    Voltage terminal 30: 11.960 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 4
                    Drivetrain coordinator: brake function status-Bits 0-7: 32
                    Drivetrain coordinator: brake function status-Bits 0-7: 1
                    Acceleration: 0.000 m/s²
16936 - Control Circuit for Reductant Heating 2
          P20BD 00 [175] - Open Circuit
                    Mileage: 23474 km
                    Date: 2020.09.03
                    Time: 01:47:13
                    Engine speed: 830.50 /min
                    Normed load value: 33.7 %
                    Coolant temperature: 88 °C
                    Intake air temperature: 60 °C
                    Voltage terminal 30: 14.060 V
                    Extern.temp.sens.1 bank 1: raw value: 17.0 °C
                    Particle filter outlet temp.sens.1 bank 1: raw value: 164.3 °C
                    Sensor for reducing agent tank temperature: temperature: 20.9 °C
                    Heat circuit 2 for reduc. agent meter. system: act. voltage: 39.0 mV
                    Heat circuit 1 for reduc. agent meter. system: act. voltage: 0.0 mV
                    Reducing agent fill level sensor: act. value: 150.8 mm
                    Reducing agent system and actuator: condition-Bits 0-7: 0
                    Reducing agent system and actuator: condition-Bits 0-7: 32
16931 - Control Circuit for Reductant Heating 1
          P20B9 00 [175] - Open Circuit
                    Mileage: 23474 km
                    Date: 2020.09.03
                    Time: 01:47:11
                    Engine speed: 829.50 /min
                    Voltage terminal 30: 14.100 V
                    Particle filter outlet temp.sens.1 bank 1: raw value: 164.4 °C
Readiness: 1 2 0 0 0
Address 03: ABS Brakes (J104)       Labels:. User\7E0-907-37x-MK100ESC.lbl
   Revision: 00000000    Serial number: 60859000001030
   Coding: 1079809B9362A484087E017DC98525A3780050
   VCID: 3FD028B437F22A436B9-806A
0077 - Rear Left Wheel Speed Sensor
          C101C 07 [008] - Mechanical Failure
                    Reset counter: 199
                    Mileage: 23474 km
                    Date: 2020.09.03
                    Time: 01:48:06
0297 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 199
                    Mileage: 23474 km
                    Date: 2020.09.03
                    Time: 01:46:00
   Part No SW: 1K8 907 426 AQ    HW: 1K8 907 426 AQ
   Component: AC Manuell    H21 0909
   Revision: 00001003
   Coding: 0010004003
   VCID: 0256E140048087AB447-8056
   Part No SW: 5K0 937 085 AG    HW: 5K0 937 085 AG
   Component: BCM PQ35 B+   122 0193
   Revision: BB122001
   Coding: 411A583E8025E169088800829040006403010008424FAD60648087000045
   Shop #: WSC 35110 377 08192
   VCID: 78A283A852DCDD7B6A3-802C
   Subsystem 1 - Part No: 2K1 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 22031  61  0715
   Coding: 009795
   Subsystem 2 - Part No: 7N0 951 172
   Component: LIN BACKUP HO  H01 0009
   Part No SW: 1K8 919 465 A    HW: 5Q0 919 283
   Component: PARKHILFE 4K  H10 0480
   Revision: --------    Serial number: 39231908104750
   Coding: 0001050001
   ASAM Dataset: EV_EPHVA14VW364GP00 001007
   ROD: EV_EPHVA14VW364GP00_VW36.rod
   VCID: 372040941FC21203A39-8062
   Part No SW: 2K5 959 655 D    HW: 2K5 959 655 D
   Component: VW10Airbag00H 010 0018
   Revision: --------    Serial number: 003EL005ZVJ%
   Coding: 000000000000000000000000000000003048
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 3D2C52BC3DFE3853795-8068
   Serial number: 3497ARB404T5VK7Q6HKP
   Serial number: 3507ARB40515VK7QCGT4
   Part No SW: 5K0 953 521 GE    HW: 5K0 953 569 BF
   Revision: FF010042    Serial number: 20190326200761
   Coding: 1082460008
   ROD: EV_SMLSNGVOLWSR8C.rod
   Subsystem 1 - Part No SW: 2K0 959 442     HW: 2K0 959 442   Labels: 3C8-959-537.CLB
   Serial number: 0791920481402159BA2B
   Coding: 280000
   Part No SW: 2K5 920 876 K    HW: 2K5 920 876 K
   Component: KOMBI         H02 2030
   Coding: 110A001100
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05736
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 E
   Component: Standheizer     044 4941
   Revision: 00044000    Serial number: 09028239000000
   Coding: 0030032
   Shop #: WSC 00999 444 64523
   VCID: 3720409413421203A39-8062
02251 - Heater Unit Locked
                    Reset counter: 172
                    Mileage: 22846 km
                    Date: 2020.04.18
                    Time: 10:04:08
   Part No SW: 7N0 907 530 BN    HW: 7N0 907 530 AL
   Component: J533  Gateway H58 1691
   Revision:   H58       Serial number: 290319F1000641
   Coding: 357420
   VCID: 7DAC92BC7DFEF853395-8028
03981 - Pause recommendation not available
                    Fault Status: 01110000
                    Reset counter: 199
                    Mileage: 23489 km
                    Date: 2020.09.03
                    Time: 15:20:18
   Part No SW: 0AY 907 554 J    HW: 0CQ 525 130
   Component: Haldex4Motion H55 7540
   Serial number: HA1-00026.02.19
   Coding: 0501
   ROD: EV_AllWheelContrHA1VW37X_002.rod
   VCID: 52F611009460D72BB47-8006
   Component: IMMO          H02 2030
   Coding: 000002
   VCID: 6A86A9E01CF07FEBEC7-803E
   Part No SW: 2K5 959 701     HW: 2K5 959 701
   Component: Tuer-SG         009 2143
   Coding: 0131120
   VCID: 71B4BE8C3DA68C33ADD-8024
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 317    3501
   Revision: 00H22000
   VCID: 392446AC2556047355D-806C
            000 - - - MIL ON
                        PD
                    Temperature: 20.0°C
                    Hex Value: 0x0000
                    Hex Value: 0x0000
            000 - - - MIL ON
                    Battery Volts: 0.8 V
                        PD
                    Temperature: 48.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 2K5 959 702     HW: 2K5 959 702
   Coding: 0131120
   VCID: 72B6B18038A0B72B547-8026
   Part No SW: 1K8 035 150 H    HW: 1K8 035 150 H
   Component: MU-E--ER      070 7205
   Serial number: 29031900011776
   Coding: 063307002800000041110001010000001F0000C40000010001
   ROD: EV_MUEnt4CGen2LGE_VW32.rod
   VCID: 2A0669E0DC70BFEB2C7-807E
   Component: Batt.regelung H58 1691
   Coding: 030F1873
   VCID: 71B4BE8C31A68C33ADD-8024
   Subsystem 1 - Part No SW: 2K0 915 181     HW: 2K0 915 181
   Serial number: 758858030019040104E2
End----------(Elapsed Time: 01:17, VBatt start/end: 12.0V/12.0V)-----------
golfi_vend
Tartu, Estonia
C?ID=195131
Could this not be a problem?
Or some voltage missing, many (all) error codes (03803) show Bat. Voltage here.
Sorry, forgot to mention. Wheel bearing has been replaced due to bad magnet belt.
golfi_vend
Tartu, Estonia
C?ID=195131
Issue get's more complicated every day.
Now I get haldex module error - don't have exact fault code in this computer, but will post it later.
Issue lies here:
Car is only driven 20k KM or so.
Like in this thread:
golfi_vend
Tartu, Estonia
C?ID=195131
Weird things happening.
After I gave both haldex modules to owner, who decided to try repairing them at different place, I needed to go to garage and take some things.
While there, out of curiosity I read fault codes and 44, wasn't showing fault codes about "MODULE". I did steering angle init. and lights went out.... :O .
Seems like faulty haldex module was interfering with steering assist. ... Now to wait until I get working Haldex module back.
golfi_vend
Tartu, Estonia
C?ID=195131
Last scan. Has issue with SCR, but this I wont address.
Used Haldex module. Checked inside. Was good and no sign of water damage.
Thursday,24,September,2020,20:15:25:63851
VIN: WV1ZZZ2KZKX   License Plate: TAIMAR CADDY OK
VIN: WV1ZZZ2KZKX   Mileage: 23540km-14627miles
   Revision: 8AH20---
          P20BD 00 [039] - Open Circuit
                    Mileage: 23547 km
                    Date: 2020.09.24
                    Time: 00:31:46
                    Engine speed: 0.00 /min
                    Coolant temperature: 19 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 12.360 V
                    Extern.temp.sens.1 bank 1: raw value: 20.0 °C
                    Particle filter outlet temp.sens.1 bank 1: raw value: 14.2 °C
                    Sensor for reducing agent tank temperature: temperature: 19.0 °C
                    Reducing agent fill level sensor: act. value: 149.0 mm
                    Reducing agent system and actuator: condition-Bits 0-7: 56
          P20B9 00 [039] - Open Circuit
                    Mileage: 23547 km
                    Date: 2020.09.24
                    Time: 00:31:44
                    Reducing agent fill level sensor: act. value: 149.3 mm
   Revision: 00001003
   Coding: 0010004003
   Revision: BB122001
   Coding: 009795
   Subsystem 3 - Part No: 1K0 951 605 F
   Coding: 0001050001
   Coding: 1082460008
   Coding: 280000
   Coding: 110A001100
   Coding: 0030032
   Shop #: WSC 00046 000 00000
   Coding: 357420
   Component: Haldex4Motion H52 7540
   Serial number: HA1-00025.07.17
   Coding: 0001
   Shop #: WSC 00049 770 00150
   Coding: 000002
   Coding: 0131120
   Revision: 00H22000
   Coding: 0131120
   Coding: 030F1873
End----------(Elapsed Time: 01:10, VBatt start/end: 14.4V/14.3V)-----------
