- Jul 9, 2020
- 52
- 14
- Canberra, Australia
- C?ID=410415
Bear with me while I set out the background to auto-scan below.
Have been running the direct TPMS fine until one of the values disappeared. I replaced the TPMS module which fixed it, until intermittent flat tyre warnings and then all four signals disappeared. Only fault code was C111A 31 [009] - No Signal and when I checked the measuring blocks three of the four sensors were sending implausible data (80 psi). Given I thought it unlikely that three of the four sensors had failed I ordered a new module, got the software flashed, parameters loaded and tested on another B6 that has the same retrofit. Plugged in the new module, warning light and fault codes were gone, until the car was driven. Now I have an additional fault code (internal system fault) and now two sensors (3 and 4) are sending crazy data - 370psi and 127 degrees celsius!
I can't got back to a direct TPMS as my CCM is 3AA so I need to figure out what's causing these issues given the module is not the issues.
Jono
Jono
Monday,07,September,2020,19:21:10:17021
VIN: WVWZZZ3CZAE030468 License Plate:
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 22 25 36 3C 42 44 46 47 52 53
55 62 65 6D 72
VIN: WVWZZZ3CZAE030468 Mileage: 133270km-82810miles
Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 FR HW: 03H 906 032 AB
Component: CC3.6-FSI-7MH G 4854
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 000 00000
VCID: 77ABEE3D33C96363639-8022
Readiness: 0010 0000
Part No SW: 02E 300 012 E HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1905
Revision: 04844002 Serial number: 00000906061395
VCID: 127DBFA9386BA64BF47-8046
Address 03: ABS Brakes Labels:. 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000795392275
Coding: 0001443
VCID: 629DAF69884B96CB247-8036
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 EB HW: 3C0 907 044 EB
Component: ClimatronicPQ46 133 1010
Revision: 00133026 Serial number: 00000000000000
VCID: 6597B4759965E1F3C15-8030
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-H.lbl
Part No SW: 3C8 937 049 E HW: 3C8 937 049 E
Revision: 00H54000 Serial number: 00000003221884
Coding: E68C8F0F40041A00470A00000F000000000B59435C400100000000000000
Shop #: WSC 05124 123 12345
VCID: 33331A2D67314F439F1-8066
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 110709 022 0601
Coding: 00046997
Shop #: WSC 05124
Component: RLS 040809 054 0402
Coding: 00471277
Shop #: WSC 05124
Address 10: Park/Steer Assist (J446) Labels:. 3C8-919-475.clb
Part No SW: 3C8 919 475 A HW: 3C8 919 475
Component: PARKHILFE 8K H07 0009
Revision: -------- Serial number: 08740920400943
Coding: 100102
Shop #: WSC 05314 000 00000
VCID: 323D1F29942B464B947-8066
Part No SW: 5N0 959 655 T HW: 5N0 959 655 T
Component: J234__007 VW10 HI 2118
Revision: 25018000 Serial number: 003LDP2K9X52
Coding: 0012343
Shop #: WSC 00280 959 94420
VCID: 4EC56BD9ECD302AB90F-801A
Subsystem 1 - Serial number: 6332MTS635521849
Subsystem 2 - Serial number: 6342MTS690121899
Subsystem 3 - Serial number: 6351HTS6ADF1V8KR
Subsystem 4 - Serial number: 6361HTS6J2QLV8KR
Address 16: Steering wheel Labels: 3C0-953-549-SW25.lbl
Part No SW: 3C0 953 549 AJ HW: 3C0 953 549 AJ
Component: J0527 0030
Revision: 00032000 Serial number: 3C9953507CN
Coding: 0001812
VCID: 74B1D93122BF087B46B-8020
Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H08 0010
Coding: 00000131
Part No SW: 3C8 920 881 HW: 3C8 920 881
Component: KOMBI H02 1109
Coding: 110F210000
Shop #: WSC 35942 002 104857
ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
VCID: 6A8DC7497CFBCE8BEC7-803E
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AJ
Component: J533 Gateway H51 1682
Revision: H51 Serial number: 15111300F12923
Coding: 462007
Shop #: WSC 19460 666 12345
VCID: 7BA3F20D03E14703071-802E
Mileage: 133233 km
Date: 2020.09.07
Time: 07:43:00
03175 - Invalid Data Set
Reset counter: 194
Mileage: 133233 km
Date: 2020.09.05
Time: 16:16:31
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
VCID: 44D149F1329FF8FB36B-8010
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: IMMO 052 0407
Revision: 00052000 Serial number: VWZCZ000000000
VCID: 38292D017E57AC1BAA3-806C
Component: ELV 027 0380
3C0905861G ELV 027 0380
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F3B165D8B196BA3FB9-807A
Address 3C: Lane Change Labels: None
Part No SW: 3AA 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH02 0010
Revision: 00H02000 Serial number: 6PZ 010 316-09
Coding: 0001173
VCID: 392F2805455DB51355D-806C
Subsystem 1 - Part No: 3AA 907 568 C
Component: J0770_SWA_Slave_H02 0010
Subsystem 2 - Serial number: 6PZ 010 316-29
Subsystem 3 - Serial number: 5F29.10.1300H02000AMS15346ÿ
Subsystem 4 - Serial number: S15346ÿ
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0007678305
Coding: 0017B7
Shop #: WSC 05311 115 12345
VCID: 3537243565C55173B15-8060
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389__TSG-HR 004 0307
Serial number: 00000001002999
Coding: 000090
Part No: 1K0 909 144 H
Component: EPS_ZFLS Kl. 143 2901
Revision: 00H17000
Shop #: WSC 02069 000 90108
Component: KSG PQ47 ELV 052 0645
Coding: 18900A00D1034E7F6C0295157008DFCE607801
Shop #: WSC 00046 123 12345
Component: Neigungssensor 004 0611
Part No SW: 5K0 035 456 HW: 5K0 035 456
Component: KonzernAmp 8K H06 0340
Revision: -------- Serial number: BP218198610877
ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
ROD: EV_AudioVerst8KanalBNO2.rod
VCID: 678BBE7D6FE9F3E3F39-8032
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0007707005
Coding: 0017B6
Shop #: WSC 05311 115 00000
VCID: 3635233978C35A6BB8F-8062
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388__TSG-HL 004 0307
Serial number: 00000000997232
Coding: 000090
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 C HW: 3C8 907 801 C
Component: J540 EPB3 VW-13618 0005
Revision: 010 Serial number: 00000000059064
Coding: 0000057
VCID: 2A0D0749B0FB0E8B2C7-807E
Address 55: Headlight Range Labels: 5M0-907-357-V2.lbl
Component: AFS-Steuergeraet 0142
Coding: 2344385
VCID: 34311931623F487B86B-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Coding: 00000035
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 30000000333907
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30_005.rod
VCID: 372B2E3D7FC9A363A39-8062
8398081 - Tire Pressure Sensor(s)
C111A 04 [009] - Internal System Fault
Reset counter: 196
Mileage: 133279 km
Date: 2020.09.07
Time: 19:19:39
Outside air temperature: 15.5 °C
Sensor identification number (sensor ID): 4029056619
CURRENT pressure: 5.4 bar
CURRENT temperature: 127 °C
8398082 - Tire Pressure Sensor(s)
Reset counter: 194
Mileage: 133238 km
Date: 2020.09.07
Time: 07:48:41
Vehicle speed: 72 km/h
Outside air temperature: 7.0 °C
Reception level antenna 1: 640 mV
Offset level antenna 1: 280 mV
Address 6D: Trunk Elect. Labels: 3C9-827-383.clb
Part No SW: 3C9 827 383 G HW: 3C9 827 383 G
Component: J605 HECKDECKEL 0730
Revision: 00H27001
VCID: 3537243569455173B15-8060
Subsystem 1 - Part No: 3C9 827 384 G
Component: J756 HECKDECKEL 0730
Subsystem 2 - Serial number: 0900H27001001C0075ÿ
End----(Elapsed Time: 01:44, VBatt start/end: 11.9V/11.8V. VIgn 11.8V)-----
